[petsc-dev] Jacobian lag persist with ROSW method
Jed Brown jed at jedbrown.org
Sun Mar 9 01:29:40 CST 2014
Mani Chandra <mc0710 at gmail.com> writes:
> It doesn't converge at all if I use a first order method. The time step
> required now is incredibly small. Is that an indication that something
> might be wrong?
Perhaps.  Limiters are very nonlinear, but they should still converge.
> In general should convergence be better with lower order?
Nonlinear solver convergence should be no worse, and is simpler to
understand.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140309/4ddf7b28/attachment.sig>
