[petsc-dev] error from Mira
Satish Balay
balay at mcs.anl.gov
Tue Mar 4 17:06:52 CST 2014
Defined "VERSION_GIT" to ""v3.4.3-2737-g9a5771d""
Defined "VERSION_DATE_GIT" to ""2013-11-21 21:45:16 -0600""
This is an old petsc-dev snapshot..
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
PETSc makefiles contain mistakes or files are missing on filesystem.
Makefile contains file not on filesystem: src/mat/order: ['<<<<<<<', 'HEAD']
Possible reasons:
1. Files were deleted locally, try "hg revert filename" or "git checkout filename".
2. Files were deleted from repository, but were not removed from makefile. Send mail to petsc-maint at mcs.anl.gov.
3. Someone forgot to "add" new files to the repository. Send mail to petsc-maint at mcs.anl.gov.
Perhaps you need 'git status' to make sure src/mat/order/makefile is not corrupted.
Satish
