[petsc-dev] error from Mira
    Mark Adams
    adams at alcf.anl.gov
    Tue Mar  4 16:58:03 CST 2014
                            Pushing language C
                            Popping language C
                            Pushing language CUDA
                            Popping language CUDA
                            Pushing language Cxx
                            Popping language Cxx
                            Pushing language FC
                            Popping language FC
Starting Configure Run at Tue Mar  4 22:12:25 2014
Configure Options: --configModules=PETSc.Configure --optionsModule=PETSc.compilerOptions --download-cmake=1 --download-hypre=1 --download-metis=1 --download-parmetis=1 --known-bits-per-byte=8 --known-level1-dcache-assoc=0 --known-level1-dcache-linesize=32 --known-level1-dcache-size=32768 --known-memcmp-ok=1 --known-mpi-c-double-complex=1 --known-mpi-long-double=1 --known-mpi-shared-libraries=0 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-sizeof-char=1 --known-sizeof-double=8 --known-sizeof-float=4 --known-sizeof-int=4 --known-sizeof-long-long=8 --known-sizeof-long=8 --known-sizeof-short=2 --known-sizeof-size_t=8 --known-sizeof-void-p=8 --with-64-bit-indices=1 --with-batch=1 --with-blas-lapack-lib="-L/soft/libraries/alcf/current/xl/LAPACK/lib -llapack -L/soft/libraries/alcf/current/xl/BLAS/lib -lblas" --with-cc=mpixlc_r --with-cxx=mpixlcxx_r --with-debugging=0 --with-fc="mpixlf90_r -qnosave" --with-fortran-kernels=1 --with-is-color-value-type=short --with-shared-libraries=0 --with-x=0 -COPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction" -CXXOPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction" -FOPTFLAGS=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction" PETSC_ARCH=arch-bgq-ibm-opt64
Working directory: /gpfs/mira-home/adams/petsc
Machine platform:
('Linux', 'miralac1', '2.6.32-358.6.2.el6.ppc64', '#1 SMP Tue May 14 15:52:06 EDT 2013', 'ppc64', 'ppc64')
Python version:
2.6.6 (r266:84292, Aug 28 2012, 10:58:57)
[GCC 4.4.6 20120305 (Red Hat 4.4.6-4)]
        Pushing language C
        Popping language C
        Pushing language FC
        Popping language FC
TEST configureExternalPackagesDir from config.framework(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/framework.py:823)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:823)
TEST configureDebuggers from PETSc.utilities.debuggers(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/debuggers.py:22)
TESTING: configureDebuggers from PETSc.utilities.debuggers(config/PETSc/utilities/debuggers.py:22)
  Find a default debugger and determine its arguments
Checking for program /usr/lib64/qt-3.3/bin/gdb...not found
Checking for program /home/adams/bin/gdb...not found
Checking for program /soft/environment/softenv-1.6.2/bin/gdb...not found
Checking for program /bin/gdb...not found
Checking for program /usr/bin/gdb...found
          Defined make macro "GDB" to "/usr/bin/gdb"
Checking for program /usr/lib64/qt-3.3/bin/dbx...not found
Checking for program /home/adams/bin/dbx...not found
Checking for program /soft/environment/softenv-1.6.2/bin/dbx...not found
Checking for program /bin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /usr/X11R6/bin/dbx...not found
Checking for program /sbin/dbx...not found
Checking for program /usr/sbin/dbx...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/dbx...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/dbx...not found
Checking for program /soft/debuggers/scripts/bin/dbx...not found
Checking for program /soft/cobalt/bin/dbx...not found
Checking for program /soft/accttools/bin/dbx...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/dbx...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/dbx...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/dbx...not found
Checking for program /soft/debuggers/ddt/bin/dbx...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/dbx...not found
Checking for program /soft/buildtools/cmake/current/bin/dbx...not found
Checking for program /soft/perftools/darshan/darshan/bin/dbx...not found
Checking for program /soft/compilers/wrappers/xl/dbx...not found
Checking for program /dbhome/db2cat/sqllib/bin/dbx...not found
Checking for program /dbhome/db2cat/sqllib/adm/dbx...not found
Checking for program /dbhome/db2cat/sqllib/misc/dbx...not found
Checking for program /usr/lpp/mmfs/bin/dbx...not found
Checking for program /opt/ibutils/bin/dbx...not found
Checking for program /home/adams/dbx...not found
Checking for program /usr/lib64/qt-3.3/bin/xdb...not found
Checking for program /home/adams/bin/xdb...not found
Checking for program /soft/environment/softenv-1.6.2/bin/xdb...not found
Checking for program /bin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /usr/X11R6/bin/xdb...not found
Checking for program /sbin/xdb...not found
Checking for program /usr/sbin/xdb...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/xdb...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/xdb...not found
Checking for program /soft/debuggers/scripts/bin/xdb...not found
Checking for program /soft/cobalt/bin/xdb...not found
Checking for program /soft/accttools/bin/xdb...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/xdb...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/xdb...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/xdb...not found
Checking for program /soft/debuggers/ddt/bin/xdb...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/xdb...not found
Checking for program /soft/buildtools/cmake/current/bin/xdb...not found
Checking for program /soft/perftools/darshan/darshan/bin/xdb...not found
Checking for program /soft/compilers/wrappers/xl/xdb...not found
Checking for program /dbhome/db2cat/sqllib/bin/xdb...not found
Checking for program /dbhome/db2cat/sqllib/adm/xdb...not found
Checking for program /dbhome/db2cat/sqllib/misc/xdb...not found
Checking for program /usr/lpp/mmfs/bin/xdb...not found
Checking for program /opt/ibutils/bin/xdb...not found
Checking for program /home/adams/xdb...not found
Checking for program /usr/lib64/qt-3.3/bin/dsymutil...not found
Checking for program /home/adams/bin/dsymutil...not found
Checking for program /soft/environment/softenv-1.6.2/bin/dsymutil...not found
Checking for program /bin/dsymutil...not found
Checking for program /usr/bin/dsymutil...not found
Checking for program /usr/local/bin/dsymutil...not found
Checking for program /usr/X11R6/bin/dsymutil...not found
Checking for program /sbin/dsymutil...not found
Checking for program /usr/sbin/dsymutil...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/dsymutil...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/dsymutil...not found
Checking for program /soft/debuggers/scripts/bin/dsymutil...not found
Checking for program /soft/cobalt/bin/dsymutil...not found
Checking for program /soft/accttools/bin/dsymutil...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/dsymutil...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/dsymutil...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/dsymutil...not found
Checking for program /soft/debuggers/ddt/bin/dsymutil...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/dsymutil...not found
Checking for program /soft/buildtools/cmake/current/bin/dsymutil...not found
Checking for program /soft/perftools/darshan/darshan/bin/dsymutil...not found
Checking for program /soft/compilers/wrappers/xl/dsymutil...not found
Checking for program /dbhome/db2cat/sqllib/bin/dsymutil...not found
Checking for program /dbhome/db2cat/sqllib/adm/dsymutil...not found
Checking for program /dbhome/db2cat/sqllib/misc/dsymutil...not found
Checking for program /usr/lpp/mmfs/bin/dsymutil...not found
Checking for program /opt/ibutils/bin/dsymutil...not found
Checking for program /home/adams/dsymutil...not found
        Defined make macro "DSYMUTIL" to "true"
        Defined "USE_GDB_DEBUGGER" to "1"
TEST configureGit from config.sourceControl(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
  Find the Git executable
Checking for program /usr/lib64/qt-3.3/bin/git...not found
Checking for program /home/adams/bin/git...not found
Checking for program /soft/environment/softenv-1.6.2/bin/git...not found
Checking for program /bin/git...not found
Checking for program /usr/bin/git...found
          Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 1.7.1
TEST configureMercurial from config.sourceControl(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/sourceControl.py:35)
TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
  Find the Mercurial executable
Checking for program /usr/lib64/qt-3.3/bin/hg...not found
Checking for program /home/adams/bin/hg...not found
Checking for program /soft/environment/softenv-1.6.2/bin/hg...not found
Checking for program /bin/hg...not found
Checking for program /usr/bin/hg...found
          Defined make macro "HG" to "hg"
Executing: hg version -q
stdout: Mercurial Distributed SCM (version 1.4)
TEST configureCVS from config.sourceControl(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/sourceControl.py:46)
TESTING: configureCVS from config.sourceControl(config/BuildSystem/config/sourceControl.py:46)
  Find the CVS executable
Checking for program /usr/lib64/qt-3.3/bin/cvs...not found
Checking for program /home/adams/bin/cvs...not found
Checking for program /soft/environment/softenv-1.6.2/bin/cvs...not found
Checking for program /bin/cvs...not found
Checking for program /usr/bin/cvs...found
          Defined make macro "CVS" to "cvs"
Executing: cvs --version
stdout:
Concurrent Versions System (CVS) 1.11.23 (client/server)
Copyright (C) 2006 Free Software Foundation, Inc.
Senior active maintainers include Larry Jones, Derek R. Price,
and Mark D. Baushke.  Please see the AUTHORS and README files from the CVS
distribution kit for a complete list of contributors and copyrights.
CVS may be copied only under the terms of the GNU General Public License,
a copy of which can be found with the CVS distribution kit.
Specify the --help option for further information about CVS
TEST configureSubversion from config.sourceControl(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/sourceControl.py:55)
TESTING: configureSubversion from config.sourceControl(config/BuildSystem/config/sourceControl.py:55)
  Find the Subversion executable
Checking for program /usr/lib64/qt-3.3/bin/svn...not found
Checking for program /home/adams/bin/svn...not found
Checking for program /soft/environment/softenv-1.6.2/bin/svn...not found
Checking for program /bin/svn...not found
Checking for program /usr/bin/svn...found
          Defined make macro "SVN" to "svn"
Executing: svn --version -q
stdout: 1.6.11
TEST configureMkdir from config.programs(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/programs.py:22)
TESTING: configureMkdir from config.programs(config/BuildSystem/config/programs.py:22)
  Make sure we can have mkdir automatically make intermediate directories
Checking for program /usr/lib64/qt-3.3/bin/mkdir...not found
Checking for program /home/adams/bin/mkdir...not found
Checking for program /soft/environment/softenv-1.6.2/bin/mkdir...not found
Checking for program /bin/mkdir...found
Executing: /bin/mkdir -p .conftest/tmp
      Adding -p flag to /bin/mkdir -p to automatically create directories
        Defined make macro "MKDIR" to "/bin/mkdir -p"
TEST configureAutoreconf from config.programs(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/programs.py:44)
TESTING: configureAutoreconf from config.programs(config/BuildSystem/config/programs.py:44)
  Check for autoreconf
Checking for program /usr/lib64/qt-3.3/bin/autoreconf...not found
Checking for program /home/adams/bin/autoreconf...not found
Checking for program /soft/environment/softenv-1.6.2/bin/autoreconf...not found
Checking for program /bin/autoreconf...not found
Checking for program /usr/bin/autoreconf...found
          All intermediate test results are stored in /tmp/petsc-ITHdGX
        All intermediate test results are stored in /tmp/petsc-ITHdGX/config.programs
Executing: cd /tmp/petsc-ITHdGX/config.programs/autoconfdir&&/usr/bin/autoreconf
TEST configurePrograms from config.programs(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/programs.py:65)
TESTING: configurePrograms from config.programs(config/BuildSystem/config/programs.py:65)
  Check for the programs needed to build and run PETSc
Checking for program /usr/lib64/qt-3.3/bin/sh...not found
Checking for program /home/adams/bin/sh...not found
Checking for program /soft/environment/softenv-1.6.2/bin/sh...not found
Checking for program /bin/sh...found
          Defined make macro "SHELL" to "/bin/sh"
Checking for program /usr/lib64/qt-3.3/bin/sed...not found
Checking for program /home/adams/bin/sed...not found
Checking for program /soft/environment/softenv-1.6.2/bin/sed...not found
Checking for program /bin/sed...found
          Defined make macro "SED" to "/bin/sed"
Executing: /bin/sed -i s/sed/sd/g "/tmp/petsc-ITHdGX/config.programs/sed1"
      Adding SEDINPLACE cmd: /bin/sed -i
        Defined make macro "SEDINPLACE" to "/bin/sed -i"
Checking for program /usr/lib64/qt-3.3/bin/mv...not found
Checking for program /home/adams/bin/mv...not found
Checking for program /soft/environment/softenv-1.6.2/bin/mv...not found
Checking for program /bin/mv...found
          Defined make macro "MV" to "/bin/mv"
Checking for program /usr/lib64/qt-3.3/bin/cp...not found
Checking for program /home/adams/bin/cp...not found
Checking for program /soft/environment/softenv-1.6.2/bin/cp...not found
Checking for program /bin/cp...found
          Defined make macro "CP" to "/bin/cp"
Checking for program /usr/lib64/qt-3.3/bin/grep...not found
Checking for program /home/adams/bin/grep...not found
Checking for program /soft/environment/softenv-1.6.2/bin/grep...not found
Checking for program /bin/grep...found
          Defined make macro "GREP" to "/bin/grep"
Checking for program /usr/lib64/qt-3.3/bin/rm...not found
Checking for program /home/adams/bin/rm...not found
Checking for program /soft/environment/softenv-1.6.2/bin/rm...not found
Checking for program /bin/rm...found
          Defined make macro "RM" to "/bin/rm -f"
Checking for program /usr/lib64/qt-3.3/bin/diff...not found
Checking for program /home/adams/bin/diff...not found
Checking for program /soft/environment/softenv-1.6.2/bin/diff...not found
Checking for program /bin/diff...not found
Checking for program /usr/bin/diff...found
Executing: "/usr/bin/diff" -w "/tmp/petsc-ITHdGX/config.programs/diff1" "/tmp/petsc-ITHdGX/config.programs/diff2"
        Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /home/adams/ps...not found
Checking for program /usr/lib64/qt-3.3/bin/gzip...not found
Checking for program /home/adams/bin/gzip...not found
Checking for program /soft/environment/softenv-1.6.2/bin/gzip...not found
Checking for program /bin/gzip...found
          Defined make macro "GZIP" to "/bin/gzip"
        Defined "HAVE_GZIP" to "1"
        Defined make macro "PYTHON" to "/usr/bin/python"
TEST configureCLanguage from PETSc.utilities.languages(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/languages.py:27)
TESTING: configureCLanguage from PETSc.utilities.languages(config/PETSc/utilities/languages.py:27)
  Choose whether to compile the PETSc library using a C or C++ compiler
      C language is C
        Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.utilities.petscdir(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/petscdir.py:23)
TESTING: configureDirectories from PETSc.utilities.petscdir(config/PETSc/utilities/petscdir.py:23)
  Checks PETSC_DIR and sets if not set
      Version Information:
      #define PETSC_VERSION_RELEASE    0
      #define PETSC_VERSION_MAJOR      3
      #define PETSC_VERSION_MINOR      4
      #define PETSC_VERSION_SUBMINOR   3
      #define PETSC_VERSION_PATCH      0
      #define PETSC_VERSION_DATE       "unknown"
      #define PETSC_VERSION_GIT        "unknown"
      #define PETSC_VERSION_DATE_GIT   "unknown"
      #define PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
      #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
      #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
      #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
      #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
        Defined make macro "DIR" to "/home/adams/petsc"
TEST configureInstallationMethod from PETSc.utilities.petscclone(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/petscclone.py:15)
TESTING: configureInstallationMethod from PETSc.utilities.petscclone(config/PETSc/utilities/petscclone.py:15)
      bin/maint exists. This appears to be a repository clone
        Defined "VERSION_GIT" to ""v3.4.3-2737-g9a5771d""
        Defined "VERSION_DATE_GIT" to ""2013-11-21 21:45:16 -0600""
TEST getDatafilespath from PETSc.utilities.dataFilesPath(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.utilities.dataFilesPath(config/PETSc/utilities/dataFilesPath.py:29)
  Checks what DATAFILESPATH should be
TEST configureETags from PETSc.utilities.Etags(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/Etags.py:27)
TESTING: configureETags from PETSc.utilities.Etags(config/PETSc/utilities/Etags.py:27)
  Determine if etags files exist and try to create otherwise
WARNING: ETags files have not been created
Checking for program /usr/lib64/qt-3.3/bin/etags...not found
Checking for program /home/adams/bin/etags...not found
Checking for program /soft/environment/softenv-1.6.2/bin/etags...not found
Checking for program /bin/etags...not found
Checking for program /usr/bin/etags...found
          Defined make macro "ETAGS" to "/usr/bin/etags"
           Running /usr/bin/etags to generate TAGS files
Executing: /home/adams/petsc/bin/maint/generateetags.py
*******Error generating etags files: Could not execute "/home/adams/petsc/bin/maint/generateetags.py":
Traceback (most recent call last):
  File "/home/adams/petsc/bin/maint/generateetags.py", line 154, in <module>
    main(ctags)
  File "/home/adams/petsc/bin/maint/generateetags.py", line 143, in main
    os.path.walk(os.getcwd(),processDir,[etagfile,ctagfile])
  File "/usr/lib64/python2.6/posixpath.py", line 236, in walk
    walk(name, func, arg)
  File "/usr/lib64/python2.6/posixpath.py", line 228, in walk
    func(arg, top, names)
  File "/home/adams/petsc/bin/maint/generateetags.py", line 94, in processDir
    if newls: createTags(etagfile,ctagfile,dirname,newls)
  File "/home/adams/petsc/bin/maint/generateetags.py", line 62, in createTags
    raise RuntimeError("Error running ctags "+output)
RuntimeError: Error running ctags sh: ctags: command not found
TEST configureArchitecture from PETSc.utilities.arch(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/arch.py:25)
TESTING: configureArchitecture from PETSc.utilities.arch(config/PETSc/utilities/arch.py:25)
  Checks PETSC_ARCH and sets if not set
              Warning: PETSC_ARCH from environment does not match command-line or name of script.
              Warning: Using from command-line or name of script: arch-bgq-ibm-opt64, ignoring environment: arch-bgq-ibm-dbg-64idx
        Defined "ARCH" to ""arch-bgq-ibm-opt64""
TEST setInstallDir from PETSc.utilities.installDir(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/installDir.py:27)
TESTING: setInstallDir from PETSc.utilities.installDir(config/PETSc/utilities/installDir.py:27)
   setup installDir to PETSC_DIR/PETSC_ARCH
TEST saveReconfigure from PETSc.utilities.installDir(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/installDir.py:53)
TESTING: saveReconfigure from PETSc.utilities.installDir(config/PETSc/utilities/installDir.py:53)
TEST cleanInstallDir from PETSc.utilities.installDir(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/installDir.py:46)
TESTING: cleanInstallDir from PETSc.utilities.installDir(config/PETSc/utilities/installDir.py:46)
TEST configureInstallDir from PETSc.utilities.installDir(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/installDir.py:31)
TESTING: configureInstallDir from PETSc.utilities.installDir(config/PETSc/utilities/installDir.py:31)
  Makes  installDir subdirectories if it does not exist
      Changed persistence directory to /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf
TEST restoreReconfigure from PETSc.utilities.installDir(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/installDir.py:66)
TESTING: restoreReconfigure from PETSc.utilities.installDir(config/PETSc/utilities/installDir.py:66)
TEST setExternalPackagesDir from PETSc.utilities.externalpackagesdir(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.utilities.externalpackagesdir(config/PETSc/utilities/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.utilities.externalpackagesdir(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.utilities.externalpackagesdir(config/PETSc/utilities/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1500)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1500)
      **** printenv ****
CH_TIMER_SAMPLE=60000
COMM_BASE=/bgsys/drivers/ppcfloor/comm
LESSOPEN=|/usr/bin/lesspipe.sh %s
CH_TIMER=FALSE
SSH_CLIENT=98.250.106.201 55728 22
CVS_RSH=ssh
LOGNAME=adams
USER=adams
PATH=/usr/lib64/qt-3.3/bin:/home/adams/bin:/soft/environment/softenv-1.6.2/bin:/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin:/sbin:/usr/sbin:/bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin:/bgsys/drivers/V1R2M0/ppc64/hlcs/bin:/soft/debuggers/scripts/bin:/soft/cobalt/bin:/soft/accttools/bin:/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin:/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin:/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin:/soft/debuggers/ddt/bin:/soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin:/soft/buildtools/cmake/current/bin:/soft/perftools/darshan/darshan/bin:/soft/compilers/wrappers/xl:/dbhome/db2cat/sqllib/bin:/dbhome/db2cat/sqllib/adm:/dbhome/db2cat/sqllib/misc:/usr/lpp/mmfs/bin:/opt/ibutils/bin:/home/adams/bin
QTDIR=/usr/lib64/qt-3.3
SOFTENV_ALIASES=/soft/environment/softenv-1.6.2/etc/softenv-aliases.sh
ARCH=linux-rhel_6-ppc64
LD_LIBRARY_PATH=/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64:/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64:/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64:/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64:/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64:/bgsys/drivers/ppcfloor/comm/xl/lib:/dbhome/db2cat/sqllib/lib64:/dbhome/db2cat/sqllib/lib32
LANG=en_US
DDT_HOST=miralac1.mira.i2b.alcf.anl.gov
TERM=xterm-color
SHELL=/bin/bash
CH_OUTPUT_INTERVAL=1000
TEXINPUTS=
IBM_CCMP_DIR=/soft/compilers/ibmcmp-may2013/vac/bg/12.1
DB2INSTANCE=db2cat
G_BROKEN_FILENAMES=1
PWD=/home/adams/petsc
HISTSIZE=1000
PLATFORM=linux-rhel_6-ppc64
HISTCONTROL=ignoredups
_=../arch-bgq-ibm-opt64.py
MANPATH=/home/adams/man:/soft/environment/softenv-1.6.2/man:/usr/share/man:/usr/local/man:/usr/X11R6/man:/bgsys/drivers/V1R2M0/ppc64/gnu-linux/man:/bgsys/drivers/V1R2M0/ppc64/hlcs/man:/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/man:/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/man:/soft/buildtools/cmake/current/man:/bgsys/drivers/ppcfloor/comm/xl/man
PETSC_DIR=/home/adams/petsc
JAVA_HOME=/usr/lib/jvm/jre-1.6.0-ibm.ppc64
HOME=/home/adams
IBM_MAIN_DIR=/soft/compilers/ibmcmp-may2013
IBMCMP_INCLUDE=/soft/compilers/ibmcmp-may2013/vac/bg/12.1/include:/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/include:/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/include:/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/include:/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/include
QTLIB=/usr/lib64/qt-3.3/lib
PYTHONPATH=
SHLVL=1
CLASSPATH=/dbhome/db2cat/sqllib/java/db2java.zip:/dbhome/db2cat/sqllib/java/db2jcc.jar:/dbhome/db2cat/sqllib/java/sqlj.zip:/dbhome/db2cat/sqllib/function:/dbhome/db2cat/sqllib/java/db2jcc_license_cu.jar:.
INCLUDE_PATH=/bgsys/drivers/ppcfloor/comm/xl/include
IBM_FCMP_DIR=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1
BGQDRV=V1R2M0
SOFTENV_LOAD=/soft/environment/softenv-1.6.2/etc/softenv-load.sh
XLF_USR_CONFIG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/etc/V1R2M0.xlf.cfg.rhel6.3.gcc446
WHATAMI=linux-rhel_6-ppc64
SSH_CONNECTION=98.250.106.201 55728 140.221.69.8 22
DISPLAY=localhost:49.0
XL_DEFMSG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/msg/en_US
NLSPATH=/soft/compilers/ibmcmp-may2013/msg/bg/%L/%N
SSH_TTY=/dev/pts/11
OLDPWD=/home/adams
HOSTNAME=miralac1
OBJECT_MODE=64
XLC_USR_CONFIG=/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/etc/V1R2M0.vac.cfg.rhel6.3.gcc446
QTINC=/usr/lib64/qt-3.3/include
PETSC_ARCH=arch-bgq-ibm-dbg-64idx
MAIL=/var/spool/mail/adams
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.tbz=01;31:*.tbz2=01;31:*.bz=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.axa=01;36:*.oga=01;36:*.spx=01;36:*.xspf=01;36:
COMM_SELECT=xl
IBM_CPPCMP_DIR=/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1
LM_LICENSE_FILE=
TEST resetEnvCompilers from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1507)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1507)
TEST checkMPICompilerOverride from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1472)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1472)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1491)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1491)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:400)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:400)
  Determine the compiler vendor
      Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:410)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:410)
  Initialize the compiler and linker flags
        Pushing language C
      Initialized CFLAGS to
      Initialized LDFLAGS to
        Popping language C
      Initialized CUDAFLAGS to
      Initialized CXXFLAGS to
      Initialized CXX_CXXFLAGS to
        Pushing language FC
      Initialized FFLAGS to
        Popping language FC
      Initialized CPPFLAGS to
      Initialized CUDAPPFLAGS to
      Initialized CXXCPPFLAGS to
      Initialized CC_LINKER_FLAGS to []
      Initialized CXX_LINKER_FLAGS to []
      Initialized FC_LINKER_FLAGS to []
      Initialized CUDAC_LINKER_FLAGS to []
      Initialized sharedLibraryFlags to []
      Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:526)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:526)
  Locate a functional C compiler
Checking for program /usr/lib64/qt-3.3/bin/mpixlc_r...not found
Checking for program /home/adams/bin/mpixlc_r...not found
Checking for program /soft/environment/softenv-1.6.2/bin/mpixlc_r...not found
Checking for program /bin/mpixlc_r...not found
Checking for program /usr/bin/mpixlc_r...not found
Checking for program /usr/local/bin/mpixlc_r...not found
Checking for program /usr/X11R6/bin/mpixlc_r...not found
Checking for program /sbin/mpixlc_r...not found
Checking for program /usr/sbin/mpixlc_r...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/mpixlc_r...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/mpixlc_r...not found
Checking for program /soft/debuggers/scripts/bin/mpixlc_r...not found
Checking for program /soft/cobalt/bin/mpixlc_r...not found
Checking for program /soft/accttools/bin/mpixlc_r...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/mpixlc_r...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/mpixlc_r...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/mpixlc_r...not found
Checking for program /soft/debuggers/ddt/bin/mpixlc_r...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/mpixlc_r...not found
Checking for program /soft/buildtools/cmake/current/bin/mpixlc_r...not found
Checking for program /soft/perftools/darshan/darshan/bin/mpixlc_r...not found
Checking for program /soft/compilers/wrappers/xl/mpixlc_r...found
          Defined make macro "CC" to "mpixlc_r"
          Pushing language C
                    All intermediate test results are stored in /tmp/petsc-ITHdGX/config.setCompilers
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers   /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                          Pushing language C
                                          Popping language C
                                          Pushing language FC
                                          Popping language FC
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    /tmp/petsc-ITHdGX/config.setCompilers/conftest.o
          Popping language C
TEST checkCPreprocessor from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:561)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:561)
  Locate a functional C preprocessor
          Defined make macro "CPP" to "mpixlc_r -E"
        Pushing language C
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers  /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
stdout:
#line 211 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include/stddef.h"
typedef unsigned long size_t;
#line 323
typedef int wchar_t;
#line 67 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/waitstatus.h"
union wait
    int w_status;
    struct
#line 79
	unsigned int:16;
	unsigned int __w_retcode:8;
	unsigned int __w_coredump:1;
	unsigned int __w_termsig:7;
      } __wait_terminated;
    struct
#line 93
	unsigned int:16;
	unsigned int __w_stopsig:8;
	unsigned int __w_stopval:8;
      } __wait_stopped;
#line 68 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
#line 98
typedef struct
    int quot;
    int rem;
  } div_t;
#line 106
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
#line 118
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
#line 140
extern size_t __ctype_get_mb_cur_max (void)  ;
#line 145
extern double atof (const char *__nptr)
      __attribute__ ((__pure__))  ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
#line 158
__extension__ extern long long int atoll (const char *__nptr)
#line 165
extern double strtod (const char *__restrict __nptr,
		      char **__restrict __endptr)
#line 173
extern float strtof (const char *__restrict __nptr,
		     char **__restrict __endptr)   ;
extern long double strtold (const char *__restrict __nptr,
#line 184
extern long int strtol (const char *__restrict __nptr,
			char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
#line 195
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
#line 209
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
#line 311
extern char *l64a (long int __n)  ;
#line 314
extern long int a64l (const char *__s)
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
#line 37
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
#line 53
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 134
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
#line 158
typedef int __clockid_t;
#line 161
typedef void * __timer_t;
#line 164
typedef long int __blksize_t;
#line 169
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
#line 173
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
#line 177
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
#line 184
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
#line 189
typedef long int __intptr_t;
#line 192
typedef unsigned int __socklen_t;
#line 34 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
#line 45
typedef __loff_t loff_t;
#line 49
typedef __ino_t ino_t;
#line 61
typedef __dev_t dev_t;
#line 66
typedef __gid_t gid_t;
#line 71
typedef __mode_t mode_t;
#line 76
typedef __nlink_t nlink_t;
#line 81
typedef __uid_t uid_t;
#line 87
typedef __off_t off_t;
#line 99
typedef __pid_t pid_t;
#line 105
typedef __id_t id_t;
#line 110
typedef __ssize_t ssize_t;
#line 116
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
#line 123
typedef __key_t key_t;
#line 60 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
typedef __clock_t clock_t;
#line 76
typedef __time_t time_t;
#line 92
typedef __clockid_t clockid_t;
#line 104
typedef __timer_t timer_t;
#line 151 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
#line 195
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
#line 201
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
#line 24 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigset.h"
typedef int __sig_atomic_t;
#line 29
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
#line 38 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
typedef __sigset_t sigset_t;
#line 120 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 75 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/time.h"
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
#line 49 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
typedef __suseconds_t suseconds_t;
#line 55
typedef long int __fd_mask;
#line 67
typedef struct
#line 75
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
#line 78
  } fd_set;
#line 85
typedef __fd_mask fd_mask;
#line 109
extern int select (int __nfds, fd_set *__restrict __readfds,
		   fd_set *__restrict __writefds,
		   fd_set *__restrict __exceptfds,
		   struct timeval *__restrict __timeout);
#line 121
extern int pselect (int __nfds, fd_set *__restrict __readfds,
		    const struct timespec *__restrict __timeout,
		    const __sigset_t *__restrict __sigmask);
#line 30 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/sysmacros.h"
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
					       unsigned int __minor)
#line 229 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __blksize_t blksize_t;
#line 236
typedef __blkcnt_t blkcnt_t;
#line 240
typedef __fsblkcnt_t fsblkcnt_t;
#line 244
typedef __fsfilcnt_t fsfilcnt_t;
#line 51 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
#line 54
typedef union
  char __size[56];
  long int __align__workaround;
} pthread_attr_t;
#line 62
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 77
typedef union
  struct __pthread_mutex_s
    volatile int __lock;
    volatile unsigned int __count;
    volatile int __owner;
    unsigned int __nusers;
#line 89
    int __kind;
    int __spins;
    __pthread_list_t __list;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
} pthread_mutexattr_t;
#line 116
typedef union
  struct
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align__workaround;
} pthread_cond_t;
typedef union
  char __size[4];
} pthread_condattr_t;
#line 141
typedef unsigned int pthread_key_t;
#line 145
typedef int pthread_once_t;
#line 151
typedef union
  struct
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
#line 168
    unsigned int __flags;
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
} pthread_rwlockattr_t;
#line 202
typedef volatile int pthread_spinlock_t;
#line 207
typedef union
  char __size[32];
} pthread_barrier_t;
typedef union
  char __size[4];
} pthread_barrierattr_t;
#line 327 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
extern long int random (void) ;
#line 330
extern void srandom (unsigned int __seed) ;
#line 336
extern char *initstate (unsigned int __seed, char *__statebuf,
			size_t __statelen)  ;
#line 341
extern char *setstate (char *__statebuf)  ;
#line 349
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
		     int32_t *__restrict __result)  ;
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
			size_t __statelen,
			struct random_data *__restrict __buf)
extern int setstate_r (char *__restrict __statebuf,
#line 380
extern int rand (void) ;
extern void srand (unsigned int __seed) ;
#line 387
extern int rand_r (unsigned int *__seed) ;
#line 395
extern double drand48 (void) ;
extern double erand48 (unsigned short int __xsubi[3])  ;
#line 399
extern long int lrand48 (void) ;
extern long int nrand48 (unsigned short int __xsubi[3])
#line 404
extern long int mrand48 (void) ;
extern long int jrand48 (unsigned short int __xsubi[3])
#line 409
extern void srand48 (long int __seedval) ;
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7])  ;
#line 418
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    unsigned long long int __a;
#line 428
extern int drand48_r (struct drand48_data *__restrict __buffer,
		      double *__restrict __result)  ;
extern int erand48_r (unsigned short int __xsubi[3],
#line 435
extern int lrand48_r (struct drand48_data *__restrict __buffer,
		      long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
#line 444
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
#line 453
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
		     struct drand48_data *__buffer)  ;
extern int lcong48_r (unsigned short int __param[7],
#line 471
extern void *malloc (size_t __size)  __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
#line 485
extern void *realloc (void *__ptr, size_t __size)
      __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) ;
#line 493
extern void cfree (void *__ptr) ;
#line 33 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/alloca.h"
extern void *alloca (size_t __size) ;
#line 503 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
extern void *valloc (size_t __size)  __attribute__ ((__malloc__)) ;
#line 508
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
#line 514
extern void abort (void)  __attribute__ ((__noreturn__));
#line 518
extern int atexit (void (*__func) (void))  ;
#line 536
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
#line 544
extern void exit (int __status)  __attribute__ ((__noreturn__));
#line 560
extern void _Exit (int __status)  __attribute__ ((__noreturn__));
#line 567
extern char *getenv (const char *__name)   ;
#line 572
extern char *__secure_getenv (const char *__name)
#line 579
extern int putenv (char *__string)  ;
#line 585
extern int setenv (const char *__name, const char *__value, int __replace)
#line 589
extern int unsetenv (const char *__name)  ;
#line 596
extern int clearenv (void) ;
#line 606
extern char *mktemp (char *__template)   ;
#line 620
extern int mkstemp (char *__template)  ;
#line 642
extern int mkstemps (char *__template, int __suffixlen)  ;
#line 663
extern char *mkdtemp (char *__template)   ;
#line 717
extern int system (const char *__command) ;
#line 734
extern char *realpath (const char *__restrict __name,
		       char *__restrict __resolved)  ;
#line 742
typedef int (*__compar_fn_t) (const void *, const void *);
#line 755
extern void *bsearch (const void *__key, const void *__base,
		      size_t __nmemb, size_t __size, __compar_fn_t __compar)
#line 761
extern void qsort (void *__base, size_t __nmemb, size_t __size,
		   __compar_fn_t __compar) ;
#line 771
extern int abs (int __x)  __attribute__ ((const)) ;
extern long int labs (long int __x)  __attribute__ ((const)) ;
#line 776
__extension__ extern long long int llabs (long long int __x)
#line 785
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
#line 793
__extension__ extern lldiv_t lldiv (long long int __numer,
				    long long int __denom)
#line 808
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
		   int *__restrict __sign)   ;
#line 814
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
#line 820
extern char *gcvt (double __value, int __ndigit, char *__buf)
#line 826
extern char *qecvt (long double __value, int __ndigit,
		    int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
#line 838
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
		   int *__restrict __sign, char *__restrict __buf,
		   size_t __len)  ;
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
		   size_t __len)  ;
extern int qecvt_r (long double __value, int __ndigit,
		    int *__restrict __decpt, int *__restrict __sign,
		    char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
#line 860
extern int mblen (const char *__s, size_t __n)  ;
#line 863
extern int mbtowc (wchar_t *__restrict __pwc,
		   const char *__restrict __s, size_t __n)  ;
#line 867
extern int wctomb (char *__s, wchar_t __wchar)  ;
#line 871
extern size_t mbstowcs (wchar_t *__restrict  __pwcs,
extern size_t wcstombs (char *__restrict __s,
			const wchar_t *__restrict __pwcs, size_t __n)
#line 885
extern int rpmatch (const char *__response)   ;
#line 896
extern int getsubopt (char **__restrict __optionp,
		      char *const *__restrict __tokens,
		      char **__restrict __valuep)
#line 948
extern int getloadavg (double __loadavg[], int __nelem)
        Popping language C
TEST checkCUDACompiler from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:595)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:595)
  Locate a functional CUDA compiler
Checking for program /usr/lib64/qt-3.3/bin/nvcc...not found
Checking for program /home/adams/bin/nvcc...not found
Checking for program /soft/environment/softenv-1.6.2/bin/nvcc...not found
Checking for program /bin/nvcc...not found
Checking for program /usr/bin/nvcc...not found
Checking for program /usr/local/bin/nvcc...not found
Checking for program /usr/X11R6/bin/nvcc...not found
Checking for program /sbin/nvcc...not found
Checking for program /usr/sbin/nvcc...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/nvcc...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/nvcc...not found
Checking for program /soft/debuggers/scripts/bin/nvcc...not found
Checking for program /soft/cobalt/bin/nvcc...not found
Checking for program /soft/accttools/bin/nvcc...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/nvcc...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/nvcc...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/nvcc...not found
Checking for program /soft/debuggers/ddt/bin/nvcc...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/nvcc...not found
Checking for program /soft/buildtools/cmake/current/bin/nvcc...not found
Checking for program /soft/perftools/darshan/darshan/bin/nvcc...not found
Checking for program /soft/compilers/wrappers/xl/nvcc...not found
Checking for program /dbhome/db2cat/sqllib/bin/nvcc...not found
Checking for program /dbhome/db2cat/sqllib/adm/nvcc...not found
Checking for program /dbhome/db2cat/sqllib/misc/nvcc...not found
Checking for program /usr/lpp/mmfs/bin/nvcc...not found
Checking for program /opt/ibutils/bin/nvcc...not found
Checking for program /home/adams/nvcc...not found
Checking for program /home/adams/petsc/bin/win32fe/nvcc...not found
TEST checkCUDAPreprocessor from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:633)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:633)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:736)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:736)
  Locate a functional Cxx compiler
Checking for program /usr/lib64/qt-3.3/bin/mpixlcxx_r...not found
Checking for program /home/adams/bin/mpixlcxx_r...not found
Checking for program /soft/environment/softenv-1.6.2/bin/mpixlcxx_r...not found
Checking for program /bin/mpixlcxx_r...not found
Checking for program /usr/bin/mpixlcxx_r...not found
Checking for program /usr/local/bin/mpixlcxx_r...not found
Checking for program /usr/X11R6/bin/mpixlcxx_r...not found
Checking for program /sbin/mpixlcxx_r...not found
Checking for program /usr/sbin/mpixlcxx_r...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/mpixlcxx_r...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/mpixlcxx_r...not found
Checking for program /soft/debuggers/scripts/bin/mpixlcxx_r...not found
Checking for program /soft/cobalt/bin/mpixlcxx_r...not found
Checking for program /soft/accttools/bin/mpixlcxx_r...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/mpixlcxx_r...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/mpixlcxx_r...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/mpixlcxx_r...not found
Checking for program /soft/debuggers/ddt/bin/mpixlcxx_r...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/mpixlcxx_r...not found
Checking for program /soft/buildtools/cmake/current/bin/mpixlcxx_r...not found
Checking for program /soft/perftools/darshan/darshan/bin/mpixlcxx_r...not found
Checking for program /soft/compilers/wrappers/xl/mpixlcxx_r...found
          Defined make macro "CXX" to "mpixlcxx_r"
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers     /tmp/petsc-ITHdGX/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                          Pushing language C
                                          Popping language C
                                          Pushing language FC
                                          Popping language FC
                  Pushing language CXX
                  Popping language CXX
Executing: mpixlcxx_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    /tmp/petsc-ITHdGX/config.setCompilers/conftest.o
TEST checkCxxPreprocessor from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:774)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:774)
  Locate a functional Cxx preprocessor
          Defined make macro "CXXCPP" to "mpixlcxx_r -E"
Executing: mpixlcxx_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers   /tmp/petsc-ITHdGX/config.setCompilers/conftest.cc
stdout:
#line 5 "/tmp/petsc-ITHdGX/config.setCompilers/conffix.h"
extern "C" {
#line 41 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/include/c++/4.4.6/cstdlib"
#pragma GCC system_header
#line 212 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/include/c++/4.4.6/powerpc64-bgq-linux/bits/c++config.h"
namespace std
  inline namespace __gnu_cxx_ldbl128 { }
#line 41 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/include/c++/4.4.6/cstddef"
#line 149 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include/stddef.h"
typedef long ptrdiff_t;
#line 211
#line 49 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/include/c++/4.4.6/cstddef"
namespace std __attribute__ ((__visibility__ ("default"))) {
  using ::ptrdiff_t;
  using ::size_t;
#line 28 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
extern "C" {
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 45
#line 49
#line 56
typedef __ino64_t ino64_t;
#line 61
#line 66
#line 71
#line 76
#line 81
#line 87
#line 94
typedef __off64_t off64_t;
#line 99
#line 105
#line 110
#line 116
#line 123
#line 76
#line 92
#line 104
#line 137 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __useconds_t useconds_t;
#line 141
#line 151
#line 195
#line 201
#line 29
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
#line 55 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
#line 67
typedef struct
#line 72
    __fd_mask fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
#line 78
  } fd_set;
#line 85
#line 99
extern "C" {
#line 109
#line 121
#line 128
__extension__
     throw ();
__extension__
     throw ();
__extension__
     throw ();
#line 236
#line 240
#line 244
#line 263
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
#line 274 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
#line 21 "/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/include/stdlib.h"
extern "C" {
  extern int abs(int) throw () __attribute__((__IBMBuiltin__));
  extern long labs(long) throw () __attribute__((__IBMBuiltin__));
#line 26
  extern long long llabs(long long) throw () __attribute__((__IBMBuiltin__));
#line 33
#line 35 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
extern "C" {
union wait
    int w_status;
    struct
#line 79
	unsigned int:16;
    struct
#line 93
	unsigned int:16;
      } __wait_stopped;
#line 98 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
typedef struct
    int quot;
    int rem;
  } div_t;
#line 106
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
#line 118
    long long int quot;
    long long int rem;
  } lldiv_t;
#line 140
extern size_t __ctype_get_mb_cur_max (void) throw () ;
#line 145
extern double atof (__const char *__nptr)
     throw () __attribute__ ((__pure__))  ;
extern int atoi (__const char *__nptr)
extern long int atol (__const char *__nptr)
#line 158
__extension__ extern long long int atoll (__const char *__nptr)
#line 165
extern double strtod (__const char *__restrict __nptr,
     throw ()  ;
#line 173
extern float strtof (__const char *__restrict __nptr,
		     char **__restrict __endptr) throw ()  ;
extern long double strtold (__const char *__restrict __nptr,
     throw ()  ;
#line 184
extern long int strtol (__const char *__restrict __nptr,
     throw ()  ;
extern unsigned long int strtoul (__const char *__restrict __nptr,
     throw ()  ;
#line 195
__extension__
extern long long int strtoq (__const char *__restrict __nptr,
     throw ()  ;
__extension__
extern unsigned long long int strtouq (__const char *__restrict __nptr,
     throw ()  ;
#line 209
__extension__
extern long long int strtoll (__const char *__restrict __nptr,
     throw ()  ;
__extension__
extern unsigned long long int strtoull (__const char *__restrict __nptr,
     throw ()  ;
#line 28 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/xlocale.h"
typedef struct __locale_struct
  struct __locale_data *__locales[13];
#line 34
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
#line 39
  const char *__names[13];
} *__locale_t;
#line 43
typedef __locale_t locale_t;
#line 240 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
extern long int strtol_l (__const char *__restrict __nptr,
			  char **__restrict __endptr, int __base,
			  __locale_t __loc) throw ()  ;
extern unsigned long int strtoul_l (__const char *__restrict __nptr,
				    int __base, __locale_t __loc)
     throw ()  ;
__extension__
extern long long int strtoll_l (__const char *__restrict __nptr,
				__locale_t __loc)
     throw ()  ;
__extension__
extern unsigned long long int strtoull_l (__const char *__restrict __nptr,
     throw ()  ;
extern double strtod_l (__const char *__restrict __nptr,
			char **__restrict __endptr, __locale_t __loc)
     throw ()  ;
extern float strtof_l (__const char *__restrict __nptr,
     throw ()  ;
extern long double strtold_l (__const char *__restrict __nptr,
			      __locale_t __loc)
     throw ()  ;
#line 311
extern char *l64a (long int __n) throw () ;
#line 314
extern long int a64l (__const char *__s)
#line 327
extern long int random (void) throw ();
#line 330
extern void srandom (unsigned int __seed) throw ();
#line 336
			size_t __statelen) throw () ;
#line 341
extern char *setstate (char *__statebuf) throw () ;
#line 349
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
		     int32_t *__restrict __result) throw () ;
     throw () ;
			size_t __statelen,
     throw () ;
     throw () ;
#line 380
extern int rand (void) throw ();
extern void srand (unsigned int __seed) throw ();
#line 387
extern int rand_r (unsigned int *__seed) throw ();
#line 395
extern double drand48 (void) throw ();
extern double erand48 (unsigned short int __xsubi[3]) throw () ;
#line 399
extern long int lrand48 (void) throw ();
     throw () ;
#line 404
extern long int mrand48 (void) throw ();
     throw () ;
#line 409
extern void srand48 (long int __seedval) throw ();
     throw () ;
extern void lcong48 (unsigned short int __param[7]) throw () ;
#line 418
struct drand48_data
#line 428
		      double *__restrict __result) throw () ;
#line 435
     throw () ;
     throw () ;
#line 444
     throw () ;
     throw () ;
#line 453
     throw () ;
		     struct drand48_data *__buffer) throw () ;
     throw () ;
#line 471
extern void *malloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
#line 485
     throw () __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) throw ();
#line 493
extern void cfree (void *__ptr) throw ();
#line 27 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/alloca.h"
extern "C" {
#line 33
extern void *alloca (size_t __size) throw ();
#line 39
extern void *valloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
#line 508
     throw ()  ;
#line 514
extern void abort (void) throw () __attribute__ ((__noreturn__));
#line 518
extern int atexit (void (*__func) (void)) throw () ;
#line 525
extern "C++" int at_quick_exit (void (*__func) (void))
     throw () __asm ("at_quick_exit") ;
#line 536
     throw () ;
#line 544
extern void exit (int __status) throw () __attribute__ ((__noreturn__));
#line 552
extern void quick_exit (int __status) throw () __attribute__ ((__noreturn__));
#line 560
extern void _Exit (int __status) throw () __attribute__ ((__noreturn__));
#line 567
extern char *getenv (__const char *__name) throw ()  ;
#line 572
extern char *__secure_getenv (__const char *__name)
     throw ()  ;
#line 579
extern int putenv (char *__string) throw () ;
#line 585
extern int setenv (__const char *__name, __const char *__value, int __replace)
     throw () ;
#line 589
extern int unsetenv (__const char *__name) throw () ;
#line 596
extern int clearenv (void) throw ();
#line 606
extern char *mktemp (char *__template) throw ()  ;
#line 620
#line 630
extern int mkstemp64 (char *__template)  ;
#line 642
#line 652
extern int mkstemps64 (char *__template, int __suffixlen)
#line 663
extern char *mkdtemp (char *__template) throw ()  ;
#line 674
extern int mkostemp (char *__template, int __flags)  ;
#line 684
extern int mkostemp64 (char *__template, int __flags)  ;
#line 694
extern int mkostemps (char *__template, int __suffixlen, int __flags)
#line 706
extern int mkostemps64 (char *__template, int __suffixlen, int __flags)
#line 717
extern int system (__const char *__command) ;
#line 724
extern char *canonicalize_file_name (__const char *__name)
     throw ()  ;
#line 734
extern char *realpath (__const char *__restrict __name,
		       char *__restrict __resolved) throw () ;
#line 742
typedef int (*__compar_fn_t) (__const void *, __const void *);
#line 745
typedef __compar_fn_t comparison_fn_t;
#line 749
typedef int (*__compar_d_fn_t) (__const void *, __const void *, void *);
#line 755
extern void *bsearch (__const void *__key, __const void *__base,
#line 761
extern void qsort_r (void *__base, size_t __nmemb, size_t __size,
		     __compar_d_fn_t __compar, void *__arg)
#line 771
extern int abs (int __x) throw () __attribute__ ((__const__)) ;
extern long int labs (long int __x) throw () __attribute__ ((__const__)) ;
#line 776
#line 785
#line 793
#line 808
		   int *__restrict __sign) throw ()  ;
#line 814
#line 820
     throw ()  ;
#line 826
     throw ()  ;
     throw ()  ;
     throw ()  ;
#line 838
		   size_t __len) throw () ;
     throw () ;
     throw () ;
#line 860
extern int mblen (__const char *__s, size_t __n) throw () ;
#line 863
		   __const char *__restrict __s, size_t __n) throw () ;
#line 867
extern int wctomb (char *__s, wchar_t __wchar) throw () ;
#line 871
			__const char *__restrict __s, size_t __n) throw ();
			__const wchar_t *__restrict __pwcs, size_t __n)
     throw ();
#line 885
extern int rpmatch (__const char *__response) throw ()  ;
#line 896
		      char *__const *__restrict __tokens,
     throw ()  ;
#line 905
extern void setkey (__const char *__key) throw () ;
#line 913
extern int posix_openpt (int __oflag) ;
#line 921
extern int grantpt (int __fd) throw ();
#line 925
extern int unlockpt (int __fd) throw ();
#line 930
extern char *ptsname (int __fd) throw () ;
#line 937
extern int ptsname_r (int __fd, char *__buf, size_t __buflen)
     throw () ;
#line 941
extern int getpt (void);
#line 948
     throw () ;
#line 964
#line 100 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/include/c++/4.4.6/cstdlib"
  using ::div_t;
  using ::ldiv_t;
  using ::abort;
  using ::abs;
  using ::atexit;
  using ::atof;
  using ::atoi;
  using ::atol;
  using ::bsearch;
  using ::calloc;
  using ::div;
  using ::exit;
  using ::free;
  using ::getenv;
  using ::labs;
  using ::ldiv;
  using ::malloc;
  using ::mblen;
  using ::mbstowcs;
  using ::mbtowc;
  using ::qsort;
  using ::rand;
  using ::realloc;
  using ::srand;
  using ::strtod;
  using ::strtol;
  using ::strtoul;
  using ::system;
  using ::wcstombs;
  using ::wctomb;
#line 138
  inline long
  abs(long __i) { return labs(__i); }
  inline ldiv_t
  div(long __i, long __j) { return ldiv(__i, __j); }
#line 157
namespace __gnu_cxx __attribute__ ((__visibility__ ("default"))) {
#line 160
  using ::lldiv_t;
#line 166
  using ::_Exit;
#line 169
  inline long long
  abs(long long __x) { return __x >= 0 ? __x : -__x; }
#line 173
  using ::llabs;
  inline lldiv_t
  div(long long __n, long long __d)
  { lldiv_t __q; __q.quot = __n / __d; __q.rem = __n % __d; return __q; }
  using ::lldiv;
#line 190
  using ::atoll;
  using ::strtoll;
  using ::strtoull;
  using ::strtof;
  using ::strtold;
#line 202
  using ::__gnu_cxx::lldiv_t;
  using ::__gnu_cxx::_Exit;
  using ::__gnu_cxx::abs;
  using ::__gnu_cxx::llabs;
  using ::__gnu_cxx::div;
  using ::__gnu_cxx::lldiv;
  using ::__gnu_cxx::atoll;
  using ::__gnu_cxx::strtof;
  using ::__gnu_cxx::strtoll;
  using ::__gnu_cxx::strtoull;
  using ::__gnu_cxx::strtold;
        Popping language Cxx
TEST checkFortranCompiler from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:883)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:883)
  Locate a functional Fortran compiler
Checking for program /usr/lib64/qt-3.3/bin/mpixlf90_r...not found
Checking for program /home/adams/bin/mpixlf90_r...not found
Checking for program /soft/environment/softenv-1.6.2/bin/mpixlf90_r...not found
Checking for program /bin/mpixlf90_r...not found
Checking for program /usr/bin/mpixlf90_r...not found
Checking for program /usr/local/bin/mpixlf90_r...not found
Checking for program /usr/X11R6/bin/mpixlf90_r...not found
Checking for program /sbin/mpixlf90_r...not found
Checking for program /usr/sbin/mpixlf90_r...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/mpixlf90_r...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/mpixlf90_r...not found
Checking for program /soft/debuggers/scripts/bin/mpixlf90_r...not found
Checking for program /soft/cobalt/bin/mpixlf90_r...not found
Checking for program /soft/accttools/bin/mpixlf90_r...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/mpixlf90_r...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/mpixlf90_r...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/mpixlf90_r...not found
Checking for program /soft/debuggers/ddt/bin/mpixlf90_r...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/mpixlf90_r...not found
Checking for program /soft/buildtools/cmake/current/bin/mpixlf90_r...not found
Checking for program /soft/perftools/darshan/darshan/bin/mpixlf90_r...not found
Checking for program /soft/compilers/wrappers/xl/mpixlf90_r...found
          Defined make macro "FC" to "mpixlf90_r -qnosave"
          Pushing language FC
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers   /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
Possible ERROR while running compiler:
stderr:
** main   === End of Compilation 1 ===
1501-510  Compilation successful for file conftest.F.
Source:
      program main
      end
stderr:
Source:
      program main
      end
                                          Pushing language C
                                          Popping language C
                                          Pushing language CUDA
                                          Popping language CUDA
                                          Pushing language Cxx
                                          Pushing language FC
                                          Popping language FC
                  Pushing language FC
                  Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    /tmp/petsc-ITHdGX/config.setCompilers/conftest.o
          Popping language FC
TEST checkFortranComments from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:902)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:902)
  Make sure fortran comment "!" works
        Pushing language FC
stderr:
Source:
! comment
      program main
      end
      Fortran comments can use ! in column 1
        Popping language FC
TEST checkPIC from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:965)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:965)
  Determine the PIC option for each compiler
       - There needs to be a test that checks that the functionality is actually working
      Skip checking PIC options on user request
TEST checkLargeFileIO from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:998)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:998)
TEST checkArchiver from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1097)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1097)
  Check that the archiver exists and can make a library usable by the compiler
        Pushing language C
Executing: ar -V
stdout:
GNU ar version 2.20.51.0.2-5.34.el6 20100205
Copyright 2009 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
            Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program /usr/lib64/qt-3.3/bin/ar...not found
Checking for program /home/adams/bin/ar...not found
Checking for program /soft/environment/softenv-1.6.2/bin/ar...not found
Checking for program /bin/ar...not found
Checking for program /usr/bin/ar...found
          Defined make macro "AR" to "/usr/bin/ar"
Checking for program /usr/lib64/qt-3.3/bin/ranlib...not found
Checking for program /home/adams/bin/ranlib...not found
Checking for program /soft/environment/softenv-1.6.2/bin/ranlib...not found
Checking for program /bin/ranlib...not found
Checking for program /usr/bin/ranlib...found
          Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /tmp/petsc-ITHdGX/config.setCompilers/libconf1.a /tmp/petsc-ITHdGX/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /tmp/petsc-ITHdGX/config.setCompilers/libconf1.a
Possible ERROR while running ranlib: exit code 256
stderr:
/usr/bin/ranlib: '-c': No such file
      Ranlib is not functional with your archiver.  Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
Successful compile:
Source:
int foo(int a) {
  return a+1;
          Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /tmp/petsc-ITHdGX/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
  int b = foo(1);  if (b);
  return 0;
                Pushing language C
                Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -L/tmp/petsc-ITHdGX/config.setCompilers -lconf1
        Defined make macro "AR_FLAGS" to "cr"
        Defined make macro "AR_LIB_SUFFIX" to "a"
        Popping language C
TEST checkSharedLinker from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1208)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1208)
  Check that the linker can produce shared libraries
                                  Pushing language C
                                  Popping language C
                                  Pushing language FC
                                  Popping language FC
      Checking shared linker /usr/bin/ar using flags []
          Defined make macro "LD_SHARED" to "/usr/bin/ar"
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("hello");
return 0;}
                  Pushing language C
                  Popping language C
Executing: /usr/bin/ar  cr /tmp/petsc-ITHdGX/config.setCompilers/libconftest.a  /tmp/petsc-ITHdGX/config.setCompilers/conftest.o ; /usr/bin/ranlib /tmp/petsc-ITHdGX/config.setCompilers/libconftest.a
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if(ret);;
  return 0;
                Pushing language C
                Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    /tmp/petsc-ITHdGX/config.setCompilers/conftest.o  -L/tmp/petsc-ITHdGX/config.setCompilers -lconftest
      Using shared linker /usr/bin/ar with flags [] and library extension a
Executing: uname -s
stdout: Linux
TEST checkSharedLinkerPaths from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1286)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1286)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
        Pushing language C
Executing: uname -s
stdout: Linux
Executing: mpixlc_r -V
stdout:
export XL_CONFIG=/soft/compilers/ibmcmp-may2013/vac/bg/12.1/etc/vac.cfg.rhel6.3.gcc446:bgxlc_r
export XLC_USR_CONFIG=/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/etc/V1R2M0.vac.cfg.rhel6.3.gcc446
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld --eh-frame-hdr -Qy -melf64ppc -static -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crt1.o /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crti.o /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtbeginT.o -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -R/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lpthread -lxlopt -lxl -ldl -lpthread -lgcc -lm --start-group -lc -lnss_files -lnss_dns -lresolv --end-group -lgcc -lgcc_eh /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtend.o /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crtn.o
rm /tmp/xlcW0rXTv0H
rm /tmp/xlcW1U4kaRf
rm /tmp/xlcW2dtVVHN
      Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
                Pushing language C
                Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest  -Wl,-rpath,/gpfs/mira-home/adams/petsc   /tmp/petsc-ITHdGX/config.setCompilers/conftest.o
        Valid C linker flag -Wl,-rpath,/gpfs/mira-home/adams/petsc
        Popping language C
Executing: uname -s
stdout: Linux
stdout:
rm /tmp/xlcW0uQC9yd
rm /tmp/xlcW1AHGfYg
rm /tmp/xlcW20M6blk
      Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
Executing: mpixlcxx_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest  -Wl,-rpath,/gpfs/mira-home/adams/petsc   /tmp/petsc-ITHdGX/config.setCompilers/conftest.o
        Valid Cxx linker flag -Wl,-rpath,/gpfs/mira-home/adams/petsc
        Pushing language FC
Executing: uname -s
stdout: Linux
stdout:
rm /tmp/xlcW0vps5ZW
rm /tmp/xlcW1mHh1NJ
rm /tmp/xlcW2B5V8Bw
      Trying FC linker flag -Wl,-rpath,
stderr:
Source:
      program main
      end
                Pushing language FC
                Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest  -Wl,-rpath,/gpfs/mira-home/adams/petsc   /tmp/petsc-ITHdGX/config.setCompilers/conftest.o
        Valid FC linker flag -Wl,-rpath,/gpfs/mira-home/adams/petsc
        Popping language FC
TEST checkLibC from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1321)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1321)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
TEST checkDynamicLinker from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1370)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1370)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
                    All intermediate test results are stored in /tmp/petsc-ITHdGX/config.headers
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.headers  /tmp/petsc-ITHdGX/config.headers/conftest.c
stdout:
#line 57 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/dlfcn.h"
extern void *dlopen (const char *__file, int __mode) ;
#line 61
extern int dlclose (void *__handle)  ;
#line 65
extern void *dlsym (void *__restrict __handle,
		    const char *__restrict __name)  ;
#line 72
extern int dladdrrange(void *handle, void **addrp, int *sizep);
#line 89
extern char *dlerror (void) ;
          Defined "HAVE_DLFCN_H" to "1"
          Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
            Pushing language C
                        All intermediate test results are stored in /tmp/petsc-ITHdGX/config.libraries
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.libraries   /tmp/petsc-ITHdGX/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    /tmp/petsc-ITHdGX/config.libraries/conftest.o  -ldl
Possible ERROR while running linker:
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
            Defined "HAVE_LIBDL" to "1"
            Popping language C
        Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
      Checking dynamic linker /usr/bin/ar using flags []
          Defined make macro "DYNAMICLINKER" to "/usr/bin/ar"
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers   /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
                                        Pushing language C
                                        Popping language C
                                        Pushing language FC
                                        Popping language FC
                Pushing language C
                Popping language C
Executing: /usr/bin/ar  -o /tmp/petsc-ITHdGX/config.setCompilers/libconftest.so   /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -ldl
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ar: no operation specified
      Checking dynamic linker mpixlc_r using flags ['-shared']
          Defined make macro "DYNAMICLINKER" to "mpixlc_r"
Successful compile:
Source:
int main() {
  return 0;
                Pushing language C
                Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest  -shared   /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -ldl
stderr:
nm: /tmp/tmp.pLk1yLOePt: no symbols
        Valid C linker flag -shared
Successful compile:
Source:
#include <stdio.h>
                Pushing language C
                Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.setCompilers/libconftest.so  -shared  /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -ldl
stderr:
/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crt1.o:(.rodata+0x8): undefined reference to `main'
        Unable to find working dynamic linker
TEST output from config.setCompilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/setCompilers.py:1416)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1416)
  Output module data as defines and substitutions
        Substituting "CC" with "mpixlc_r"
        Substituting "CFLAGS" with ""
        Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
        Substituting "CPP" with "mpixlc_r -E"
        Substituting "CPPFLAGS" with ""
        Substituting "CXX" with "mpixlcxx_r"
        Substituting "CXX_CXXFLAGS" with ""
        Substituting "CXXFLAGS" with ""
        Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
        Substituting "CXXCPP" with "mpixlcxx_r -E"
        Substituting "CXXCPPFLAGS" with ""
        Substituting "FC" with "mpixlf90_r -qnosave"
        Substituting "FFLAGS" with ""
        Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
        Substituting "LDFLAGS" with ""
        Substituting "LIBS" with "-ldl "
        Substituting "SHARED_LIBRARY_FLAG" with ""
Executing: uname -s
stdout: Linux
TEST checkSharedDynamicPicOptions from PETSc.utilities.sharedLibraries(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/sharedLibraries.py:37)
TESTING: checkSharedDynamicPicOptions from PETSc.utilities.sharedLibraries(config/PETSc/utilities/sharedLibraries.py:37)
TEST configureSharedLibraries from PETSc.utilities.sharedLibraries(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/sharedLibraries.py:53)
TESTING: configureSharedLibraries from PETSc.utilities.sharedLibraries(config/PETSc/utilities/sharedLibraries.py:53)
  Checks whether shared libraries should be used, for which you must
      - Specify --with-shared-libraries
      - Have found a working shared linker
    Defines PETSC_USE_SHARED_LIBRARIES if they are used
        Defined make rule "shared_arch" with dependencies "" and code []
        Defined make macro "BUILDSHAREDLIB" to "no"
        Defined "HAVE_SHARED_LIBRARIES" to "1"
      Shared libraries - disabled
TEST configureDynamicLibraries from PETSc.utilities.sharedLibraries(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/sharedLibraries.py:92)
TESTING: configureDynamicLibraries from PETSc.utilities.sharedLibraries(config/PETSc/utilities/sharedLibraries.py:92)
  Checks whether dynamic loading is available (with dlfcn.h and libdl)
TEST configureSerializedFunctions from PETSc.utilities.sharedLibraries(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/sharedLibraries.py:98)
TESTING: configureSerializedFunctions from PETSc.utilities.sharedLibraries(config/PETSc/utilities/sharedLibraries.py:98)
    Defines PETSC_SERIALIZE_FUNCTIONS if they are used
    Requires shared libraries
TEST configureCompilerFlags from config.compilerFlags(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilerFlags.py:65)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:65)
  Get the default compiler flags
        Pushing language C
Executing: mpixlc_r --version
stdout:
GNU ld (GNU Binutils) 2.21.1
Copyright 2011 Free Software Foundation, Inc.
the GNU General Public License version 3 or (at your option) a later version.
getCompilerVersion: mpixlc_r GNU ld (GNU Binutils) 2.21.1
Executing: mpixlc_r --help
stdout:
Usage: /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld [options] file...
Options:
  -a KEYWORD                  Shared library control for HP/UX compatibility
  -A ARCH, --architecture ARCH
                              Set architecture
  -b TARGET, --format TARGET  Specify target for following input files
  -c FILE, --mri-script FILE  Read MRI format linker script
  -d, -dc, -dp                Force common symbols to be defined
  -e ADDRESS, --entry ADDRESS Set start address
  -E, --export-dynamic        Export all dynamic symbols
  --no-export-dynamic         Undo the effect of --export-dynamic
  -EB                         Link big-endian objects
  -EL                         Link little-endian objects
  -f SHLIB, --auxiliary SHLIB Auxiliary filter for shared object symbol table
  -F SHLIB, --filter SHLIB    Filter for shared object symbol table
  -g                          Ignored
  -G SIZE, --gpsize SIZE      Small data size (if no size, same as --shared)
  -h FILENAME, -soname FILENAME
                              Set internal name of shared library
  -I PROGRAM, --dynamic-linker PROGRAM
                              Set PROGRAM as the dynamic linker to use
  -l LIBNAME, --library LIBNAME
                              Search for library LIBNAME
  -L DIRECTORY, --library-path DIRECTORY
                              Add DIRECTORY to library search path
  --sysroot=<DIRECTORY>       Override the default sysroot location
  -m EMULATION                Set emulation
  -M, --print-map             Print map file on standard output
  -n, --nmagic                Do not page align data
  -N, --omagic                Do not page align data, do not make text readonly
  --no-omagic                 Page align data, make text readonly
  -o FILE, --output FILE      Set output file name
  -O                          Optimize output file
  -plugin PLUGIN              Load named plugin
  -plugin-opt ARG             Send arg to last-loaded plugin
  -flto                       Ignored for GCC LTO option compatibility
  -flto-partition=            Ignored for GCC LTO option compatibility
  -Qy                         Ignored for SVR4 compatibility
  -q, --emit-relocs           Generate relocations in final output
  -r, -i, --relocatable       Generate relocatable output
  -R FILE, --just-symbols FILE
                              Just link symbols (if directory, same as --rpath)
  -s, --strip-all             Strip all symbols
  -S, --strip-debug           Strip debugging symbols
  --strip-discarded           Strip symbols in discarded sections
  --no-strip-discarded        Do not strip symbols in discarded sections
  -t, --trace                 Trace file opens
  -T FILE, --script FILE      Read linker script
  --default-script FILE, -dT  Read default linker script
  -u SYMBOL, --undefined SYMBOL
                              Start with undefined reference to SYMBOL
  --unique [=SECTION]         Don't merge input [SECTION | orphan] sections
  -Ur                         Build global constructor/destructor tables
  -v, --version               Print version information
  -V                          Print version and emulation information
  -x, --discard-all           Discard all local symbols
  -X, --discard-locals        Discard temporary local symbols (default)
  --discard-none              Don't discard any local symbols
  -y SYMBOL, --trace-symbol SYMBOL
                              Trace mentions of SYMBOL
  -Y PATH                     Default search path for Solaris compatibility
  -(, --start-group           Start a group
  -), --end-group             End a group
  --accept-unknown-input-arch Accept input files whose architecture cannot be determined
  --no-accept-unknown-input-arch
                              Reject input files whose architecture is unknown
  --as-needed                 Only set DT_NEEDED for following dynamic libs if used
  --no-as-needed              Always set DT_NEEDED for dynamic libraries mentioned on
                                the command line
  -assert KEYWORD             Ignored for SunOS compatibility
  -Bdynamic, -dy, -call_shared
                              Link against shared libraries
  -Bstatic, -dn, -non_shared, -static
                              Do not link against shared libraries
  -Bsymbolic                  Bind global references locally
  -Bsymbolic-functions        Bind global function references locally
  --check-sections            Check section addresses for overlaps (default)
  --no-check-sections         Do not check section addresses for overlaps
  --copy-dt-needed-entries    Copy DT_NEEDED links mentioned inside DSOs that follow
  --no-copy-dt-needed-entries Do not copy DT_NEEDED links mentioned inside DSOs that follow
  --cref                      Output cross reference table
  --defsym SYMBOL=EXPRESSION  Define a symbol
  --demangle [=STYLE]         Demangle symbol names [using STYLE]
  --embedded-relocs           Generate embedded relocs
  --fatal-warnings            Treat warnings as errors
  --no-fatal-warnings         Do not treat warnings as errors (default)
  -fini SYMBOL                Call SYMBOL at unload-time
  --force-exe-suffix          Force generation of file with .exe suffix
  --gc-sections               Remove unused sections (on some targets)
  --no-gc-sections            Don't remove unused sections (default)
  --print-gc-sections         List removed unused sections on stderr
  --no-print-gc-sections      Do not list removed unused sections
  --hash-size=<NUMBER>        Set default hash table size close to <NUMBER>
  --help                      Print option help
  -init SYMBOL                Call SYMBOL at load-time
  -Map FILE                   Write a map file
  --no-define-common          Do not define Common storage
  --no-demangle               Do not demangle symbol names
  --no-keep-memory            Use less memory and more disk I/O
  --no-undefined              Do not allow unresolved references in object files
  --allow-shlib-undefined     Allow unresolved references in shared libaries
  --no-allow-shlib-undefined  Do not allow unresolved references in shared libs
  --allow-multiple-definition Allow multiple definitions
  --no-undefined-version      Disallow undefined version
  --default-symver            Create default symbol version
  --default-imported-symver   Create default symbol version for imported symbols
  --no-warn-mismatch          Don't warn about mismatched input files
  --no-warn-search-mismatch   Don't warn on finding an incompatible library
  --no-whole-archive          Turn off --whole-archive
  --noinhibit-exec            Create an output file even if errors occur
  -nostdlib                   Only use library directories specified on
                                the command line
  --oformat TARGET            Specify target of output file
  -qmagic                     Ignored for Linux compatibility
  --reduce-memory-overheads   Reduce memory overheads, possibly taking much longer
  --relax                     Reduce code size by using target specific optimizations
  --no-relax                  Do not use relaxation techniques to reduce code size
  --retain-symbols-file FILE  Keep only symbols listed in FILE
  -rpath PATH                 Set runtime shared library search path
  -rpath-link PATH            Set link time shared library search path
  -shared, -Bshareable        Create a shared library
  -pie, --pic-executable      Create a position independent executable
  --sort-common [=ascending|descending]
                              Sort common symbols by alignment [in specified order]
  --sort-section name|alignment
                              Sort sections by name or maximum alignment
  --spare-dynamic-tags COUNT  How many tags to reserve in .dynamic section
  --split-by-file [=SIZE]     Split output sections every SIZE octets
  --split-by-reloc [=COUNT]   Split output sections every COUNT relocs
  --stats                     Print memory usage statistics
  --target-help               Display target specific options
  --task-link SYMBOL          Do task level linking
  --traditional-format        Use same format as native linker
  --section-start SECTION=ADDRESS
                              Set address of named section
  -Tbss ADDRESS               Set address of .bss section
  -Tdata ADDRESS              Set address of .data section
  -Ttext ADDRESS              Set address of .text section
  -Ttext-segment ADDRESS      Set address of text segment
  --unresolved-symbols=<method>
                              How to handle unresolved symbols.  <method> is:
                                ignore-all, report-all, ignore-in-object-files,
                                ignore-in-shared-libs
  --verbose [=NUMBER]         Output lots of information during link
  --version-script FILE       Read version information script
  --version-exports-section SYMBOL
                              Take export symbols list from .exports, using
                                SYMBOL as the version.
  --dynamic-list-data         Add data symbols to dynamic list
  --dynamic-list-cpp-new      Use C++ operator new/delete dynamic list
  --dynamic-list-cpp-typeinfo Use C++ typeinfo dynamic list
  --dynamic-list FILE         Read dynamic list
  --warn-common               Warn about duplicate common symbols
  --warn-constructors         Warn if global constructors/destructors are seen
  --warn-multiple-gp          Warn if the multiple GP values are used
  --warn-once                 Warn only once per undefined symbol
  --warn-section-align        Warn if start of section changes due to alignment
  --warn-shared-textrel       Warn if shared object has DT_TEXTREL
  --warn-alternate-em         Warn if an object has alternate ELF machine code
  --warn-unresolved-symbols   Report unresolved symbols as warnings
  --error-unresolved-symbols  Report unresolved symbols as errors
  --whole-archive             Include all objects from following archives
  --wrap SYMBOL               Use wrapper functions for SYMBOL
  @FILE                       Read options from FILE
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: supported targets: elf64-powerpc elf64-powerpcle elf32-powerpc elf32-powerpcle aixcoff-rs6000 aixcoff64-rs6000 aix5coff64-rs6000 elf64-little elf64-big elf32-little elf32-big srec symbolsrec verilog tekhex binary ihex
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: supported emulations: elf64ppc elf32ppclinux elf32ppc elf32ppcsim
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: emulation specific options:
elf64ppc:
  --build-id[=STYLE]          Generate build ID note
  --audit=AUDITLIB            Specify a library to use for auditing
  -P AUDITLIB, --depaudit=AUDITLIB
                              Specify a library to use for auditing dependencies
  -Bgroup                     Selects group name lookup rules for DSO
  --disable-new-dtags         Disable new dynamic tags
  --enable-new-dtags          Enable new dynamic tags
  --eh-frame-hdr              Create .eh_frame_hdr section
  --hash-style=STYLE          Set hash style to sysv, gnu or both
  -z combreloc                Merge dynamic relocs into one section and sort
  -z defs                     Report unresolved symbols in object files.
  -z execstack                Mark executable as requiring executable stack
  -z initfirst                Mark DSO to be initialized first at runtime
  -z interpose                Mark object to interpose all DSOs but executable
  -z lazy                     Mark object lazy runtime binding (default)
  -z loadfltr                 Mark object requiring immediate process
  -z muldefs                  Allow multiple definitions
  -z nocombreloc              Don't merge dynamic relocs into one section
  -z nocopyreloc              Don't create copy relocs
  -z nodefaultlib             Mark object not to use default search paths
  -z nodelete                 Mark DSO non-deletable at runtime
  -z nodlopen                 Mark DSO not available to dlopen
  -z nodump                   Mark DSO not available to dldump
  -z noexecstack              Mark executable as not requiring executable stack
  -z norelro                  Don't create RELRO program header
  -z now                      Mark object non-lazy runtime binding
  -z origin                   Mark object requiring immediate $ORIGIN
                                processing at runtime
  -z relro                    Create RELRO program header
  -z max-page-size=SIZE       Set maximum page size to SIZE
  -z common-page-size=SIZE    Set common page size to SIZE
  -z KEYWORD                  Ignored for Solaris compatibility
  --stub-group-size=N         Maximum size of a group of input sections that
                                can be handled by one stub section.  A negative
                                value locates all stubs before their branches
                                (with a group size of -N), while a positive
                                value allows two groups of input sections, one
                                before, and one after each stub section.
                                Values of +/-1 indicate the linker should
                                choose suitable defaults.
  --emit-stub-syms            Label linker stubs with a symbol.
  --no-emit-stub-syms         Don't label linker stubs with a symbol.
  --dotsyms                   For every version pattern "foo" in a version
                                script, add ".foo" so that function code
                                symbols are treated the same as function
                                descriptor symbols.  Defaults to on.
  --no-dotsyms                Don't do anything special in version scripts.
  --no-tls-optimize           Don't try to optimize TLS accesses.
  --no-tls-get-addr-optimize  Don't use a special __tls_get_addr call.
  --no-opd-optimize           Don't optimize the OPD section.
  --no-toc-optimize           Don't optimize the TOC section.
  --no-multi-toc              Disallow automatic multiple toc sections.
  --no-toc-sort               Don't sort TOC and GOT sections.
  --non-overlapping-opd       Canonicalize .opd, so that there are no
                                overlapping .opd entries.
elf32ppclinux:
  --secure-plt                Use new-style PLT if possible.
  --bss-plt                   Force old-style BSS PLT.
  --sdata-got                 Force GOT location just before .sdata.
elf32ppc:
elf32ppcsim:
Report bugs to <http://www.sourceware.org/bugzilla/>
stdout:
Options:
                              Set architecture
  -g                          Ignored
                                the command line
                                the command line
elf64ppc:
elf32ppclinux:
elf32ppc:
elf32ppcsim:
stdout:
Options:
                              Set architecture
  -g                          Ignored
                                the command line
                                the command line
elf64ppc:
elf32ppclinux:
elf32ppc:
elf32ppcsim:
      Trying C compiler flag -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Added C compiler flag -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction
        Popping language C
Executing: mpixlcxx_r --version
stdout:
getCompilerVersion: mpixlcxx_r GNU ld (GNU Binutils) 2.21.1
Executing: mpixlcxx_r --help
stdout:
Options:
                              Set architecture
  -g                          Ignored
                                the command line
                                the command line
elf64ppc:
elf32ppclinux:
elf32ppc:
elf32ppcsim:
stdout:
Options:
                              Set architecture
  -g                          Ignored
                                the command line
                                the command line
elf64ppc:
elf32ppclinux:
elf32ppc:
elf32ppcsim:
stdout:
Options:
                              Set architecture
  -g                          Ignored
                                the command line
                                the command line
elf64ppc:
elf32ppclinux:
elf32ppc:
elf32ppcsim:
      Trying Cxx compiler flag -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction     /tmp/petsc-ITHdGX/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction
        Pushing language FC
Executing: mpixlf90_r -qnosave --version
stdout:
getCompilerVersion: mpixlf90_r -qnosave GNU ld (GNU Binutils) 2.21.1
Executing: mpixlf90_r -qnosave --help
stdout:
Usage: ld [options] file...
Options:
                              Set architecture
  -g                          Ignored
                                the command line
                                the command line
elf64ppc:
elf32ppclinux:
elf32ppc:
elf32ppcsim:
stdout:
Options:
                              Set architecture
  -g                          Ignored
                                the command line
                                the command line
elf64ppc:
elf32ppclinux:
elf32ppc:
elf32ppcsim:
      Trying FC compiler flag -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
stderr:
Source:
      program main
      end
Added FC compiler flag -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction
        Popping language FC
TEST configureDebugging from PETSc.utilities.debugging(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/debugging.py:25)
TESTING: configureDebugging from PETSc.utilities.debugging(config/PETSc/utilities/debugging.py:25)
        Defined "USE_ERRORCHECKING" to "1"
                        WARNING! Compiling PETSc with no debugging, this should
                              only be done for timing and production runs. All development should
                              be done when configured using --with-debugging=1
TEST checkRestrict from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:136)
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:136)
  Check for the C/CXX restrict keyword
        Pushing language C
                  All intermediate test results are stored in /tmp/petsc-ITHdGX/config.compilers
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.compilers/conftest.c
Successful compile:
Source:
int main() {
float * restrict x;;
  return 0;
      compilers: Set C restrict keyword to restrict
        Defined "C_RESTRICT" to "restrict"
        Popping language C
TEST checkCFormatting from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:308)
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:308)
  Activate format string checking if using the GNU compilers
TEST checkCStaticInline from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:107)
TESTING: checkCStaticInline from config.compilers(config/BuildSystem/config/compilers.py:107)
  Check for C keyword: static inline
        Pushing language C
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
      compilers: Set C StaticInline keyword to static inline
        Popping language C
        Defined "C_STATIC_INLINE" to "static inline"
TEST checkDynamicLoadFlag from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:319)
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:319)
  Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
TEST checkCLibraries from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:163)
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:163)
  Determines the libraries needed to link with C
        Pushing language C
Successful compile:
Source:
int main() {
  return 0;
              Pushing language C
              Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.compilers/conftest  -v   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.compilers/conftest.o -ldl
stdout:
mpicc for MPICH2 version 1.5
exec: export(export,XL_CONFIG=/soft/compilers/ibmcmp-may2013/vac/bg/12.1/etc/vac.cfg.rhel6.3.gcc446:bgxlc_r,NULL)
exec: export(export,XLC_USR_CONFIG=/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/etc/V1R2M0.vac.cfg.rhel6.3.gcc446,NULL)
exec: /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld(/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld,--eh-frame-hdr,-Qy,-melf64ppc,-static,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crt1.o,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crti.o,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtbeginT.o,-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64,-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64,-L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64,-L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64,-R/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib,-o,/tmp/petsc-ITHdGX/config.compilers/conftest,/tmp/petsc-ITHdGX/config.compilers/conftest.o,-ldl,-lmpich,-lopa,-lmpl,-lpami,-lSPI,-lSPI_cnk,-lrt,-lpthread,-lstdc++,-lpthread,-lxlopt,-lxl,-ldl,-lpthread,-lgcc,-lm,--start-group,-lc,-lnss_files,-lnss_dns,-lresolv,--end-group,-lgcc,-lgcc_eh,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtend.o,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crtn.o,NULL)
unlink: /tmp/xlcW0CHiVgL
unlink: /tmp/xlcW1qMsJnm
unlink: /tmp/xlcW224uEuX
        Popping language C
      compilers: Checking arg mpicc
      compilers: Unknown arg mpicc
      compilers: Checking arg for
      compilers: Unknown arg for
      compilers: Checking arg MPICH2
      compilers: Unknown arg MPICH2
      compilers: Checking arg version
      compilers: Unknown arg version
      compilers: Checking arg 1.5
      compilers: Unknown arg 1.5
      compilers: Checking arg exec:
      compilers: Unknown arg exec:
      compilers: Checking arg export(export
      compilers: Unknown arg export(export
      compilers: Checking arg XL_CONFIG=/soft/compilers/ibmcmp-may2013/vac/bg/12.1/etc/vac.cfg.rhel6.3.gcc446:bgxlc_r
      compilers: Unknown arg XL_CONFIG=/soft/compilers/ibmcmp-may2013/vac/bg/12.1/etc/vac.cfg.rhel6.3.gcc446:bgxlc_r
      compilers: Checking arg NULL)
      compilers: Unknown arg NULL)
      compilers: Checking arg XLC_USR_CONFIG=/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/etc/V1R2M0.vac.cfg.rhel6.3.gcc446
      compilers: Unknown arg XLC_USR_CONFIG=/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/etc/V1R2M0.vac.cfg.rhel6.3.gcc446
      compilers: Checking arg /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld(/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld
      compilers: Unknown arg /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld(/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld
      compilers: Checking arg --eh-frame-hdr
      compilers: Unknown arg --eh-frame-hdr
      compilers: Checking arg -Qy
      compilers: Unknown arg -Qy
      compilers: Checking arg -melf64ppc
      compilers: Unknown arg -melf64ppc
      compilers: Checking arg -static
      compilers: Unknown arg -static
      compilers: Checking arg -L/bgsys/drivers/V1R2M0/ppc64/spi/lib
      compilers: Found library directory: -L/bgsys/drivers/V1R2M0/ppc64/spi/lib
      compilers: Checking arg -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib
      compilers: Found library directory: -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib
      compilers: Checking arg -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib
      compilers: Found library directory: -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib
      compilers: Checking arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crt1.o
      compilers: Unknown arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crt1.o
      compilers: Checking arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crti.o
      compilers: Unknown arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crti.o
      compilers: Checking arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtbeginT.o
      compilers: Unknown arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtbeginT.o
      compilers: Checking arg -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64
      compilers: Found library directory: -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64
      compilers: Checking arg -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64
      compilers: Found library directory: -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64
      compilers: Checking arg -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64
      compilers: Found library directory: -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64
      compilers: Checking arg -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64
      compilers: Found library directory: -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64
      compilers: Checking arg -R/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64
      compilers: Found -R library: /soft/compilers/ibmcmp-may2013/lib64/bg/bglib64
      compilers: Checking arg -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6
      compilers: Found library directory: -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6
      compilers: Checking arg -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib
      compilers: Found library directory: -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib
      compilers: Checking arg -o
      compilers: Unknown arg -o
      compilers: Checking arg /tmp/petsc-ITHdGX/config.compilers/conftest
      compilers: Unknown arg /tmp/petsc-ITHdGX/config.compilers/conftest
      compilers: Checking arg /tmp/petsc-ITHdGX/config.compilers/conftest.o
      compilers: Unknown arg /tmp/petsc-ITHdGX/config.compilers/conftest.o
      compilers: Checking arg -ldl
      compilers: Found library : -ldl
      compilers: Checking arg -lmpich
      compilers: Found library : -lmpich
      compilers: Checking arg -lopa
      compilers: Found library : -lopa
      compilers: Checking arg -lmpl
      compilers: Found library : -lmpl
      compilers: Checking arg -lpami
      compilers: Found library : -lpami
      compilers: Checking arg -lSPI
      compilers: Found library : -lSPI
      compilers: Checking arg -lSPI_cnk
      compilers: Found library : -lSPI_cnk
      compilers: Checking arg -lrt
      compilers: Found library : -lrt
      compilers: Checking arg -lpthread
      compilers: Found library : -lpthread
      compilers: Checking arg -lstdc++
      compilers: Found library : -lstdc++
      compilers: Checking arg -lxlopt
      compilers: Found library : -lxlopt
      compilers: Checking arg -lgcc
      compilers: Skipping system library: -lgcc
      compilers: Checking arg --start-group
      compilers: Unknown arg --start-group
      compilers: Checking arg -lc
      compilers: Skipping system library: -lc
      compilers: Checking arg -lnss_files
      compilers: Found library : -lnss_files
      compilers: Checking arg -lnss_dns
      compilers: Found library : -lnss_dns
      compilers: Checking arg -lresolv
      compilers: Found library : -lresolv
      compilers: Checking arg --end-group
      compilers: Unknown arg --end-group
      compilers: Checking arg -lgcc_eh
      compilers: Found library : -lgcc_eh
      compilers: Checking arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtend.o
      compilers: Unknown arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtend.o
      compilers: Checking arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crtn.o
      compilers: Unknown arg /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crtn.o
      compilers: Checking arg unlink:
      compilers: Unknown arg unlink:
      compilers: Checking arg /tmp/xlcW0CHiVgL
      compilers: Unknown arg /tmp/xlcW0CHiVgL
      compilers: Checking arg /tmp/xlcW1qMsJnm
      compilers: Unknown arg /tmp/xlcW1qMsJnm
      compilers: Checking arg /tmp/xlcW224uEuX
      compilers: Unknown arg /tmp/xlcW224uEuX
      compilers: Libraries needed to link C code with another linker: ['-L/bgsys/drivers/V1R2M0/ppc64/spi/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib', '-L/bgsys/drivers/V1R2M0/ppc64/spi/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib', '-L/bgsys/drivers/V1R2M0/ppc64/spi/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib', '-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64', '-L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64', '-Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib', '-ldl', '-lmpich', '-lopa', '-lmpl', '-lpami', '-lSPI', '-lSPI_cnk', '-lrt', '-lpthread', '-lstdc++', '-lxlopt', '-lxl', '-lnss_files', '-lnss_dns', '-lresolv', '-lgcc_eh']
      compilers: Check that C libraries can be used from Fortran
          Pushing language FC
stderr:
Source:
      program main
      end
stderr:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
          Popping language FC
TEST checkDependencyGenerationFlag from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:1320)
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1320)
  Check if -MMD works for dependency generation, and add it if it does
        Pushing language C
      Trying C compiler flag -MMD -MP
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -MMD -MP  /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 10240
stderr:
/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/.orig/bgxlc_r: 1501-208 (S) command option D is missing a subargument
Source:
int main() {
  return 0;
        Rejecting compiler flag -MMD -MP due to nonzero status from link
PETSc Error: No output file produced
      Rejected C compiler flag -MMD -MP
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -MMD  /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 63744
stderr:
/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/.orig/bgxlc_r: 1501-294 (S) No input file specified. Please use -qhelp for more information.
Source:
int main() {
  return 0;
        Rejecting compiler flag -MMD due to nonzero status from link
      Trying C compiler flag -xMMD
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -xMMD  /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
stderr:
/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/.orig/bgxlc_r: 1501-216 (W) command option -xMMD is not recognized - passed to ld
Source:
int main() {
  return 0;
        Rejecting compiler flag -xMMD due to
      Rejected C compiler flag -xMMD
      Trying C compiler flag -qmakedep=gcc
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -qmakedep=gcc  /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
        Defined make macro "C_DEPFLAGS" to "-qmakedep=gcc"
        Popping language C
      Trying Cxx compiler flag -MMD -MP
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  -MMD -MP   /tmp/petsc-ITHdGX/config.setCompilers/conftest.cc
stderr:
/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/.orig/bgxlC_r: 1501-208 (S) command option D is missing a subargument
Source:
int main() {
  return 0;
      Rejected Cxx compiler flag -MMD -MP
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  -MMD   /tmp/petsc-ITHdGX/config.setCompilers/conftest.cc
stderr:
/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/.orig/bgxlC_r: 1501-294 (S) No input file specified. Please use -qhelp for more information.
Source:
int main() {
  return 0;
      Trying Cxx compiler flag -xMMD
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  -xMMD   /tmp/petsc-ITHdGX/config.setCompilers/conftest.cc
stderr:
/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/.orig/bgxlC_r: 1501-216 (W) command option -xMMD is not recognized - passed to ld
Source:
int main() {
  return 0;
      Rejected Cxx compiler flag -xMMD
      Trying Cxx compiler flag -qmakedep=gcc
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  -qmakedep=gcc   /tmp/petsc-ITHdGX/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
        Defined make macro "CXX_DEPFLAGS" to "-qmakedep=gcc"
        Pushing language FC
      Trying FC compiler flag -MMD -MP
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -MMD -MP  /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
stderr:
/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/.orig/bgxlf90_r: 1501-214 (W) command option M reserved for future use - ignored
/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/.orig/bgxlf90_r: 1501-257 (W) Option P is not recognized.  Option will be ignored.
"/tmp/petsc-ITHdGX/config.setCompilers/conftest.F", 1520-031 (W) Option DLINES is ignored within Fortran 90 free form and IBM free form.
Source:
      program main
      end
      Rejected FC compiler flag -MMD -MP
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -MMD  /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
stderr:
Source:
      program main
      end
      Trying FC compiler flag -xMMD
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -xMMD  /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
stderr:
Source:
      program main
      end
      Rejected FC compiler flag -xMMD
      Trying FC compiler flag -qmakedep=gcc
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -qmakedep=gcc  /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
stderr:
COMMAND LINE  1520-003 (W) Option MAKEDEP is ignored.
Source:
      program main
      end
        Rejecting compiler flag -qmakedep=gcc due to
      Rejected FC compiler flag -qmakedep=gcc
      Trying FC compiler flag -MD
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -MD  /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
stderr:
Source:
      program main
      end
        Rejecting compiler flag -MD due to
      Rejected FC compiler flag -MD
        Popping language FC
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction    /tmp/petsc-ITHdGX/config.compilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
      compilers: Set Cxx restrict keyword to restrict
        Defined "CXX_RESTRICT" to "restrict"
TEST checkCxxNamespace from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:357)
TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:357)
  Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
  return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
  return 0;
      compilers: C++ has namespaces
        Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:332)
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:332)
  Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction      /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
"/tmp/petsc-ITHdGX/config.setCompilers/conftest.c", line 5.7: 1506-277 (S) Syntax error: possible missing ';' or ','?
Source:
int main() {
class somename { int i; };;
  return 0;
          Rejecting compiler flag   due to nonzero status from link
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+     /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -+
TEST checkCxxStaticInline from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:121)
TESTING: checkCxxStaticInline from config.compilers(config/BuildSystem/config/compilers.py:121)
  Check for C++ keyword: static inline
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+    /tmp/petsc-ITHdGX/config.compilers/conftest.cc
Successful compile:
Source:
int main() {
foo(1);;
  return 0;
      compilers: Set Cxx StaticInline keyword to static inline
        Defined "CXX_STATIC_INLINE" to "static inline"
TEST checkCxxLibraries from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:408)
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:408)
  Determines the libraries needed to link with C++
Successful compile:
Source:
int main() {
  return 0;
              Pushing language CXX
              Popping language CXX
Executing: mpixlcxx_r  -o /tmp/petsc-ITHdGX/config.compilers/conftest  -v   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+ /tmp/petsc-ITHdGX/config.compilers/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
stdout:
mpicxx for MPICH2 version 1.5
exec: export(export,XL_CONFIG=/soft/compilers/ibmcmp-may2013/vac/bg/12.1/etc/vac.cfg.rhel6.3.gcc446:bgxlC_r,NULL)
exec: /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld(/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld,--eh-frame-hdr,-Qy,-melf64ppc,-static,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib,-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64,-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64,-L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64,-L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crt1.o,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crti.o,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtbeginT.o,-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64,-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64,-L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64,-L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64,-R/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib,-o,/tmp/petsc-ITHdGX/config.compilers/conftest,/tmp/petsc-ITHdGX/config.compilers/conftest.o,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64,-ldl,-lmpich,-lopa,-lmpl,-lpami,-lSPI,-lSPI_cnk,-lrt,-lpthread,-lstdc++,-lxlopt,-lxl,-lnss_files,-lnss_dns,-lresolv,-lgcc_eh,-ldl,-lcxxmpich,-lmpich,-lopa,-lmpl,-lpami,-lSPI,-lSPI_cnk,-lrt,-lpthread,-lstdc++,-lpthread,-lxlopt,-lxl,-libmc++,-lxlopt,-lxl,-lstdc++,-lm,-ldl,-lpthread,-lgcc,-lm,--start-group,-lc,-lnss_files,-lnss_dns,-lresolv,--end-group,-lgcc,-lgcc_eh,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtend.o,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crtn.o,NULL)
unlink: /tmp/xlcW0FGMH3N
unlink: /tmp/xlcW1G1QAXr
unlink: /tmp/xlcW2vANAR5
        Popping language Cxx
      compilers: Checking arg mpicxx
      compilers: Unknown arg mpicxx
      compilers: Checking arg XL_CONFIG=/soft/compilers/ibmcmp-may2013/vac/bg/12.1/etc/vac.cfg.rhel6.3.gcc446:bgxlC_r
      compilers: Unknown arg XL_CONFIG=/soft/compilers/ibmcmp-may2013/vac/bg/12.1/etc/vac.cfg.rhel6.3.gcc446:bgxlC_r
      compilers: Checking arg -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib
      compilers: Checking arg -rpath
      compilers: Already in rpathflags, skipping:-rpath
      compilers: Found library: -ldl
      Library already in C list so skipping in C++
      compilers: Found library: -lmpich
      compilers: Found library: -lopa
      compilers: Found library: -lmpl
      compilers: Found library: -lpami
      compilers: Found library: -lSPI
      compilers: Found library: -lSPI_cnk
      compilers: Found library: -lrt
      compilers: Found library: -lpthread
      compilers: Found library: -lstdc++
      compilers: Found library: -lxlopt
      compilers: Found library: -lnss_files
      compilers: Found library: -lnss_dns
      compilers: Found library: -lresolv
      compilers: Found library: -lgcc_eh
      compilers: Checking arg -lcxxmpich
      compilers: Found library: -lcxxmpich
      compilers: Checking arg -libmc++
      compilers: Found library: -libmc++
      compilers: Checking arg /tmp/xlcW0FGMH3N
      compilers: Unknown arg /tmp/xlcW0FGMH3N
      compilers: Checking arg /tmp/xlcW1G1QAXr
      compilers: Unknown arg /tmp/xlcW1G1QAXr
      compilers: Checking arg /tmp/xlcW2vANAR5
      compilers: Unknown arg /tmp/xlcW2vANAR5
      compilers: Libraries needed to link Cxx code with another linker: ['-L/bgsys/drivers/V1R2M0/ppc64/spi/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib', '-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64', '-L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib', '-Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64', '-lcxxmpich', '-libmc++']
      compilers: Check that Cxx libraries can be used from C
          Pushing language C
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -lcxxmpich -libmc++ -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
          Popping language C
      compilers: Check that Cxx libraries can be used from Fortran
          Pushing language FC
stderr:
** main   === End of Compilation 1 ===
1501-510  Compilation successful for file conftest.F.
Source:
      program main
      end
stderr:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -lcxxmpich -libmc++ -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
          Popping language FC
TEST checkCxx11 from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:372)
TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:372)
  Determine the option needed to support the C++11 dialect
    We auto-detect C++11 if the compiler supports it without options,
    otherwise we require with-cxx-dialect=C++11 to try adding flags to
    support it.
        Pushing language Cxx
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+     /tmp/petsc-ITHdGX/config.setCompilers/conftest.cc
stderr:
"/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/include/c++/4.4.6/c++0x_warning.h", line 31.2: 1540-0859 (S) #error directive: This file requires compiler and library support for the upcoming
ISO C++ standard, C++0x. This support is currently experimental, and must be
enabled with the -std=c++0x or -std=gnu++0x compiler options..
Source:
#include <random>
int main() {
          std::random_device rd;
          std::mt19937 mt(rd());
          std::normal_distribution<double> dist(0,1);
          const double x = dist(mt);
  return 0;
TEST checkFortranTypeSizes from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:566)
TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:566)
  Check whether real*8 is supported and suggest flags which will allow support
        Pushing language FC
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.compilers/conftest.F
stderr:
Source:
      program main
      real*8 variable
      end
        Popping language FC
TEST checkFortranNameMangling from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:625)
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:625)
  Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
          Pushing language C
Successful compile:
Source:
          Popping language C
          Pushing language FC
stderr:
Source:
      program main
       call d1chk()
      end
                  Pushing language FC
                  Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.compilers/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.compilers/conftest.o /tmp/petsc-ITHdGX/config.compilers/confc.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
stderr:
/tmp/petsc-ITHdGX/config.compilers/conftest.o:(.text+0xc): undefined reference to `d1chk'
          Popping language FC
Testing Fortran mangling type unchanged with code void d1chk(void){return;}
          Pushing language C
Successful compile:
Source:
          Popping language C
          Pushing language FC
stderr:
Source:
      program main
       call d1chk()
      end
                  Pushing language FC
                  Popping language FC
          Popping language FC
      compilers: Fortran name mangling is unchanged
        Defined "HAVE_FORTRAN_NOUNDERSCORE" to "1"
TEST checkFortranNameManglingDouble from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:662)
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:662)
  Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
          Pushing language C
Successful compile:
Source:
void d1_chk__(void){return;}
          Popping language C
          Pushing language FC
stderr:
Source:
      program main
       call d1_chk()
      end
                  Pushing language FC
                  Popping language FC
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-ITHdGX/config.compilers/conftest.o:(.text+0xc): undefined reference to `d1_chk'
          Popping language FC
TEST checkFortranPreprocessor from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:672)
TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:672)
  Determine if Fortran handles preprocessing properly
        Pushing language FC
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction    /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
stderr:
Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
        Popping language FC
      compilers: Fortran uses CPP preprocessor
TEST checkFortranDefineCompilerOption from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:693)
TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:693)
  Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
        Pushing language FC
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  -DTesting  /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
stderr:
"/tmp/petsc-ITHdGX/config.setCompilers/conftest.F", line 5.12: 1515-019 (S) Syntax is incorrect.
1501-511  Compilation failed for file conftest.F.
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
        Rejecting compiler flag -DTesting due to nonzero status from link
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  -WF,-DTesting  /tmp/petsc-ITHdGX/config.setCompilers/conftest.F
stderr:
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
        Popping language FC
      compilers: Fortran uses -WF,-D for defining macro
TEST checkFortranLibraries from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:709)
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:709)
  Substitutes for FLIBS the libraries needed to link with Fortran
    This macro is intended to be used in those situations when it is
    necessary to mix, e.g. C++ and Fortran 77, source code into a single
    program or shared library.
    For example, if object files from a C++ and Fortran 77 compiler must
    be linked together, then the C++ compiler/linker must be used for
    linking (since special C++-ish things need to happen at link time
    like calling global constructors, instantiating templates, enabling
    exception support, etc.).
    However, the Fortran 77 intrinsic and run-time libraries must be
    linked in as well, but the C++ compiler/linker does not know how to
    add these Fortran 77 libraries.
    This code was translated from the autoconf macro which was packaged in
    its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
    However, nearly all of this macro came from the OCTAVE_FLIBS macro in
    octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
    for writing this extremely useful macro.
        Pushing language FC
Executing: mpixlf90_r -qnosave -V
stdout:
export XL_CONFIG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/etc/xlf.cfg.rhel6.3.gcc446:bgxlf90_r
export XLF_USR_CONFIG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/etc/V1R2M0.xlf.cfg.rhel6.3.gcc446
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld --eh-frame-hdr -Qy -melf64ppc -static -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crt1.o /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crti.o /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtbeginT.o -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64 -R/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lpthread -lmpichf90 -lxlf90_r -lxlopt -lxlomp_ser -lxl -lxlfmath -ldl -lpthread -lm -lc -lgcc -lgcc_eh -ldl -lm --start-group -lc -lnss_files -lnss_dns -lresolv --end-group -lgcc -lgcc_eh -lgcc -ldl /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtend.o /bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crtn.o  |
/bin/awk 'BEGIN{a=0;b=0;s=""};{if(($0!~/.*-224.*@TP.*/)&&($0!~/.*-34[45].*loadmap.*/||b==1||a==0)){b=1;print $0;}else{a=1;if((s=="")&& $0 ~ /.*-34[45].*loadmap.*/){s=$0}}};END{if(b==1 && s!=""){print s}}'
rm /tmp/optf.25068EPtsZV
rm /tmp/version.25068SUi4MH
stderr:
Source:
      program main
      end
              Pushing language FC
              Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.compilers/conftest  -v   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.compilers/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
stdout:
mpif77 for MPICH2 version 1.5
exec: export(export,XL_CONFIG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/etc/xlf.cfg.rhel6.3.gcc446:bgxlf90_r,NULL)
exec: export(export,XLF_USR_CONFIG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/etc/V1R2M0.xlf.cfg.rhel6.3.gcc446,NULL)
exec: /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld(ld,--eh-frame-hdr,-Qy,-melf64ppc,-static,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib,-L/bgsys/drivers/V1R2M0/ppc64/spi/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib,-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64,-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64,-L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64,-L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib,-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crt1.o,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crti.o,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtbeginT.o,-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64,-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64,-L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64,-R/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc,-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib,-o,/tmp/petsc-ITHdGX/config.compilers/conftest,/tmp/petsc-ITHdGX/config.compilers/conftest.o,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64,-ldl,-lmpich,-lopa,-lmpl,-lpami,-lSPI,-lSPI_cnk,-lrt,-lpthread,-lstdc++,-lxlopt,-lxl,-lnss_files,-lnss_dns,-lresolv,-lgcc_eh,-ldl,-lmpich,-lopa,-lmpl,-lpami,-lSPI,-lSPI_cnk,-lrt,-lpthread,-lstdc++,-lpthread,-lmpichf90,-lxlf90_r,-lxlopt,-lxlomp_ser,-lxl,-lxlfmath,-ldl,-lpthread,-lm,-lc,-lgcc,-lgcc_eh,-ldl,-lm,--start-group,-lc,-lnss_files,-lnss_dns,-lresolv,--end-group,-lgcc,-lgcc_eh,-lgcc,-ldl,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/crtend.o,/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/lib/crtn.o,NULL)  |
exec: /bin/awk(/bin/awk,BEGIN{a=0;b=0;s=""};{if(($0!~/.*-224.*@TP.*/)&&($0!~/.*-34[45].*loadmap.*/||b==1||a==0)){b=1;print $0;}else{a=1;if((s=="")&& $0 ~ /.*-34[45].*loadmap.*/){s=$0}}};END{if(b==1 && s!=""){print s}},NULL)
unlink: /tmp/optf.25365f7Fnms
        Popping language FC
      compilers: Checking arg mpif77
      compilers: Unknown arg mpif77
      compilers: Checking arg XL_CONFIG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/etc/xlf.cfg.rhel6.3.gcc446:bgxlf90_r
      compilers: Unknown arg XL_CONFIG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/etc/xlf.cfg.rhel6.3.gcc446:bgxlf90_r
      compilers: Checking arg XLF_USR_CONFIG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/etc/V1R2M0.xlf.cfg.rhel6.3.gcc446
      compilers: Unknown arg XLF_USR_CONFIG=/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/etc/V1R2M0.xlf.cfg.rhel6.3.gcc446
      compilers: Checking arg /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld(ld
      compilers: Unknown arg /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld(ld
      compilers: Already in lflags so skipping: -L/bgsys/drivers/V1R2M0/ppc64/spi/lib
      compilers: Already in lflags so skipping: -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib
      compilers: Already in lflags so skipping: -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6
      compilers: Already in lflags so skipping: -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib
      compilers: Already in lflags so skipping: -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib
      compilers: Already in lflags so skipping: -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64
      compilers: Already in lflags so skipping: -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64
      compilers: Checking arg -L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64
      compilers: Found library directory: -L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64
      compilers: Already in rpathflags so skipping: -rpath
      Library already in C list so skipping in Fortran
      compilers: Already in lflags: -ldl
      compilers: Already in lflags: -lmpich
      compilers: Already in lflags: -lopa
      compilers: Already in lflags: -lmpl
      compilers: Already in lflags: -lpami
      compilers: Already in lflags: -lSPI
      compilers: Already in lflags: -lSPI_cnk
      compilers: Already in lflags: -lrt
      compilers: Already in lflags: -lpthread
      compilers: Already in lflags: -lstdc++
      compilers: Checking arg -lmpichf90
      compilers: Found library: -lmpichf90
      compilers: Checking arg -lxlf90_r
      compilers: Found library: -lxlf90_r
      compilers: Already in lflags: -lxlopt
      compilers: Checking arg -lxlomp_ser
      compilers: Found library: -lxlomp_ser
      compilers: Checking arg -lxlfmath
      compilers: Found library: -lxlfmath
      compilers: Found system library therefor skipping: -lc
      compilers: Found system library therefor skipping: -lgcc
      compilers: Already in lflags: -lgcc_eh
      compilers: Already in lflags: -lnss_files
      compilers: Already in lflags: -lnss_dns
      compilers: Already in lflags: -lresolv
      compilers: Checking arg |
      compilers: Unknown arg |
      compilers: Checking arg /bin/awk(/bin/awk
      compilers: Unknown arg /bin/awk(/bin/awk
      compilers: Checking arg BEGIN{a=0;b=0;s=""};{if(($0!~/.*-224.*@TP.*/)&&($0!~/.*-34[45].*loadmap.*/||b==1||a==0)){b=1;print
      compilers: Unknown arg BEGIN{a=0;b=0;s=""};{if(($0!~/.*-224.*@TP.*/)&&($0!~/.*-34[45].*loadmap.*/||b==1||a==0)){b=1;print
      compilers: Checking arg $0;}else{a=1;if((s=="")&&
      compilers: Unknown arg $0;}else{a=1;if((s=="")&&
      compilers: Checking arg ~
      compilers: Unknown arg ~
      compilers: Checking arg /.*-34[45].*loadmap.*/){s=$0}}};END{if(b==1
      compilers: Unknown arg /.*-34[45].*loadmap.*/){s=$0}}};END{if(b==1
      compilers: Checking arg &&
      compilers: Unknown arg &&
      compilers: Checking arg s!=""){print
      compilers: Unknown arg s!=""){print
      compilers: Checking arg s}}
      compilers: Unknown arg s}}
      compilers: Checking arg /tmp/optf.25365f7Fnms
      compilers: Unknown arg /tmp/optf.25365f7Fnms
      compilers: Libraries needed to link Fortran code with the C linker: ['-L/bgsys/drivers/V1R2M0/ppc64/spi/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib', '-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64', '-L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib', '-L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64', '-Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64', '-lmpichf90', '-lxlf90_r', '-lxlomp_ser', '-lxlfmath', '-lm', '-lm']
      compilers: Libraries needed to link Fortran main with the C linker: []
      compilers: Check that Fortran libraries can be used from C
          Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -lmpichf90 -lxlf90_r -lxlomp_ser -lxlfmath -lm -lm -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
          Popping language C
      compilers: Check that Fortran libraries can be used from C++
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: mpixlcxx_r  -o /tmp/petsc-ITHdGX/config.setCompilers/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+ /tmp/petsc-ITHdGX/config.setCompilers/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -lmpichf90 -lxlf90_r -lxlomp_ser -lxlfmath -lm -lm -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
      compilers: Fortran libraries can be used from C++
TEST checkFortranLinkingCxx from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:1054)
TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1054)
  Check that Fortran can be linked against C++
Successful compile:
Source:
extern "C" void d1chk(void);
void foo(void){d1chk();}
Successful compile:
Source:
          Pushing language FC
stderr:
Source:
      program main
       call d1chk()
      end
                  Pushing language FC
                  Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.compilers/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.compilers/conftest.o /tmp/petsc-ITHdGX/config.compilers/cxxobj.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh /tmp/petsc-ITHdGX/config.compilers/confc.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
          Popping language FC
      compilers: Fortran can link C++ functions
TEST checkFortran90 from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:1089)
TESTING: checkFortran90 from config.compilers(config/BuildSystem/config/compilers.py:1089)
  Determine whether the Fortran compiler handles F90
        Pushing language FC
stderr:
Source:
      program main
      INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
      INTEGER (KIND=int) :: ierr
      ierr = 1
      end
                Pushing language FC
                Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.compilers/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.compilers/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
        Defined "USING_F90" to "1"
      Fortran compiler supports F90
        Popping language FC
TEST checkFortran2003 from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:1102)
TESTING: checkFortran2003 from config.compilers(config/BuildSystem/config/compilers.py:1102)
  Determine whether the Fortran compiler handles F2003
        Pushing language FC
stderr:
"/tmp/petsc-ITHdGX/config.compilers/conftest.F", line 9.25: 1516-169 (S) A variable that is specified as an argument to the intrinsic procedure C_LOC must either have type and type parameters that are interoperable with a C type, or be a nonpolymorphic, scalar variable with no length type parameters.
Source:
      program main
      use,intrinsic :: iso_c_binding
      Type(C_Ptr),Dimension(:),Pointer :: CArray
      character(kind=c_char),pointer   :: nullc => null()
      character(kind=c_char,len=5),dimension(:),pointer::list1
      allocate(list1(5))
      CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
      end
          Compile failed inside link
      Fortran compiler does not support F2003
        Popping language FC
TEST checkFortran90Array from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:1122)
TESTING: checkFortran90Array from config.compilers(config/BuildSystem/config/compilers.py:1122)
  Check for F90 array interfaces
stdout:
rm /tmp/optf.27356pkOzHs
rm /tmp/version.27356GBPxfL
      compilers: Using --with-batch, so guess that F90 uses a single argument for array pointers
TEST checkFortranModuleInclude from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:1209)
TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1209)
  Figures out what flag is used to specify the include path for Fortran modules
        Pushing language FC
stderr:
** configtest   === End of Compilation 1 ===
Source:
      module configtest
      integer testint
      parameter (testint = 42)
      end module configtest
        Pushing language FC
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.compilers/confdir  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.compilers/conftest.F
stderr:
Source:
      program main
      use configtest
      write(*,*) testint
      end
                Pushing language FC
                Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.compilers/conftest   -I/tmp/petsc-ITHdGX/config.compilers/confdir  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.compilers/conftest.o /tmp/petsc-ITHdGX/config.compilers/configtest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
      compilers: Fortran module include flag -I found
        Popping language FC
TEST checkFortranModuleOutput from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:1275)
TESTING: checkFortranModuleOutput from config.compilers(config/BuildSystem/config/compilers.py:1275)
        Pushing language FC
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -module /tmp/petsc-ITHdGX/config.compilers/confdir  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.compilers/conftest.F
stderr:
/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/.orig/bgxlf90_r: 1501-216 (W) command option -module is not recognized - passed to ld
Source:
      module configtest
      integer testint
      compilers: Fortran module output flag -module  failed
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -module:/tmp/petsc-ITHdGX/config.compilers/confdir  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.compilers/conftest.F
stderr:
/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/.orig/bgxlf90_r: 1501-216 (W) command option -module:/tmp/petsc-ITHdGX/config.compilers/confdir is not recognized - passed to ld
Source:
      module configtest
      integer testint
      compilers: Fortran module output flag -module: failed
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -fmod=/tmp/petsc-ITHdGX/config.compilers/confdir  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.compilers/conftest.F
stderr:
Source:
      module configtest
      integer testint
      compilers: Fortran module output flag -fmod= failed
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -J/tmp/petsc-ITHdGX/config.compilers/confdir  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.compilers/conftest.F
stderr:
/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/.orig/bgxlf90_r: 1501-216 (W) command option -J/tmp/petsc-ITHdGX/config.compilers/confdir is not recognized - passed to ld
Source:
      module configtest
      integer testint
      compilers: Fortran module output flag -J failed
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -M/tmp/petsc-ITHdGX/config.compilers/confdir  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.compilers/conftest.F
stderr:
/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/.orig/bgxlf90_r: 1501-216 (W) command option -/tmp/petsc-ITHdGX/config.compilers/confdir is not recognized - passed to ld
Source:
      module configtest
      integer testint
      compilers: Fortran module output flag -M failed
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -p/tmp/petsc-ITHdGX/config.compilers/confdir  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.compilers/conftest.F
stderr:
Source:
      module configtest
      integer testint
      compilers: Fortran module output flag -p failed
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.compilers/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -qmoddir=/tmp/petsc-ITHdGX/config.compilers/confdir  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.compilers/conftest.F
stderr:
Source:
      module configtest
      integer testint
      compilers: Fortran module output flag -qmoddir= found
        Popping language FC
TEST setupFrameworkCompilers from config.compilers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/compilers.py:1406)
TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1406)
TEST configureFortranCPP from PETSc.utilities.fortranCPP(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/fortranCPP.py:27)
TESTING: configureFortranCPP from PETSc.utilities.fortranCPP(config/PETSc/utilities/fortranCPP.py:27)
  Handle case where Fortran cannot preprocess properly
        Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} -o $@ $<']
        Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
        Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} ${FCPPFLAGS} -o $@ $<']
        Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
TEST checkStdC from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.headers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.headers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.headers/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
  return 0;
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.headers  /tmp/petsc-ITHdGX/config.headers/conftest.c
stdout:
#line 211 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include/stddef.h"
typedef unsigned long size_t;
#line 44 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/string.h"
extern void *memcpy (void *__restrict __dest,
		     const void *__restrict __src, size_t __n)
#line 49
extern void *memmove (void *__dest, const void *__src, size_t __n)
#line 57
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
		      int __c, size_t __n)
#line 65
extern void *memset (void *__s, int __c, size_t __n)  ;
#line 68
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
      __attribute__ ((__pure__)) ;
#line 95
extern void *memchr (const void *__s, int __c, size_t __n)
#line 128
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
		      const char *__restrict __src, size_t __n)
#line 136
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
		      size_t __n)  ;
#line 143
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
#line 150
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
#line 28 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/xlocale.h"
typedef struct __locale_struct
  struct __locale_data *__locales[13];
#line 34
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
#line 39
  const char *__names[13];
} *__locale_t;
#line 43
typedef __locale_t locale_t;
#line 165 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/string.h"
extern int strcoll_l (const char *__s1, const char *__s2, __locale_t __l)
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
			 __locale_t __l)  ;
#line 175
extern char *strdup (const char *__s)
      __attribute__ ((__malloc__)) ;
#line 183
extern char *strndup (const char *__string, size_t __n)
#line 235
extern char *strchr (const char *__s, int __c)
#line 262
extern char *strrchr (const char *__s, int __c)
#line 284
extern size_t strcspn (const char *__s, const char *__reject)
#line 288
extern size_t strspn (const char *__s, const char *__accept)
#line 314
extern char *strpbrk (const char *__s, const char *__accept)
#line 342
extern char *strstr (const char *__haystack, const char *__needle)
#line 348
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
#line 354
extern char *__strtok_r (char *__restrict __s,
			 const char *__restrict __delim,
			 char **__restrict __save_ptr)
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
#line 399
extern size_t strlen (const char *__s)
#line 406
extern size_t strnlen (const char *__string, size_t __maxlen)
#line 413
extern char *strerror (int __errnum) ;
#line 427
extern int
strerror_r (int __errnum, char *__buf, size_t __buflen)   _Pragma("map(strerror_r, \"__xpg_strerror_r\")") ;
#line 445
extern char *strerror_l (int __errnum, __locale_t __l) ;
#line 451
extern void __bzero (void *__s, size_t __n)  ;
#line 455
extern void bcopy (const void *__src, void *__dest, size_t __n)
#line 459
extern void bzero (void *__s, size_t __n)  ;
#line 462
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
#line 489
extern char *index (const char *__s, int __c)
#line 517
extern char *rindex (const char *__s, int __c)
#line 523
extern int ffs (int __i)  __attribute__ ((const));
#line 536
extern int strcasecmp (const char *__s1, const char *__s2)
#line 540
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
#line 559
extern char *strsep (char **__restrict __stringp,
#line 566
extern char *strsignal (int __sig) ;
#line 569
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
#line 576
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
stdout:
#line 323
typedef int wchar_t;
#line 67 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/waitstatus.h"
union wait
    int w_status;
    struct
#line 79
	unsigned int:16;
	unsigned int __w_retcode:8;
	unsigned int __w_coredump:1;
	unsigned int __w_termsig:7;
      } __wait_terminated;
    struct
#line 93
	unsigned int:16;
	unsigned int __w_stopsig:8;
	unsigned int __w_stopval:8;
      } __wait_stopped;
#line 68 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
#line 98
typedef struct
    int quot;
    int rem;
  } div_t;
#line 106
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
#line 118
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
#line 140
extern size_t __ctype_get_mb_cur_max (void)  ;
#line 145
extern double atof (const char *__nptr)
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
#line 158
__extension__ extern long long int atoll (const char *__nptr)
#line 165
extern double strtod (const char *__restrict __nptr,
		      char **__restrict __endptr)
#line 173
extern float strtof (const char *__restrict __nptr,
		     char **__restrict __endptr)   ;
extern long double strtold (const char *__restrict __nptr,
#line 184
extern long int strtol (const char *__restrict __nptr,
			char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
#line 195
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
#line 209
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
#line 311
extern char *l64a (long int __n)  ;
#line 314
extern long int a64l (const char *__s)
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
#line 37
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
#line 53
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 134
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
#line 158
typedef int __clockid_t;
#line 161
typedef void * __timer_t;
#line 164
typedef long int __blksize_t;
#line 169
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
#line 173
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
#line 177
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
#line 184
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
#line 189
typedef long int __intptr_t;
#line 192
typedef unsigned int __socklen_t;
#line 34 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
#line 45
typedef __loff_t loff_t;
#line 49
typedef __ino_t ino_t;
#line 61
typedef __dev_t dev_t;
#line 66
typedef __gid_t gid_t;
#line 71
typedef __mode_t mode_t;
#line 76
typedef __nlink_t nlink_t;
#line 81
typedef __uid_t uid_t;
#line 87
typedef __off_t off_t;
#line 99
typedef __pid_t pid_t;
#line 105
typedef __id_t id_t;
#line 110
typedef __ssize_t ssize_t;
#line 116
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
#line 123
typedef __key_t key_t;
#line 60 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
typedef __clock_t clock_t;
#line 76
typedef __time_t time_t;
#line 92
typedef __clockid_t clockid_t;
#line 104
typedef __timer_t timer_t;
#line 151 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
#line 195
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
#line 201
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
#line 24 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigset.h"
typedef int __sig_atomic_t;
#line 29
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
#line 38 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
typedef __sigset_t sigset_t;
#line 120 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 75 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/time.h"
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
#line 49 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
typedef __suseconds_t suseconds_t;
#line 55
typedef long int __fd_mask;
#line 67
typedef struct
#line 75
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
#line 78
  } fd_set;
#line 85
typedef __fd_mask fd_mask;
#line 109
extern int select (int __nfds, fd_set *__restrict __readfds,
		   fd_set *__restrict __writefds,
		   fd_set *__restrict __exceptfds,
		   struct timeval *__restrict __timeout);
#line 121
extern int pselect (int __nfds, fd_set *__restrict __readfds,
		    const struct timespec *__restrict __timeout,
		    const __sigset_t *__restrict __sigmask);
#line 30 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/sysmacros.h"
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
					       unsigned int __minor)
#line 229 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __blksize_t blksize_t;
#line 236
typedef __blkcnt_t blkcnt_t;
#line 240
typedef __fsblkcnt_t fsblkcnt_t;
#line 244
typedef __fsfilcnt_t fsfilcnt_t;
#line 51 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
#line 54
typedef union
  char __size[56];
  long int __align__workaround;
} pthread_attr_t;
#line 62
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 77
typedef union
  struct __pthread_mutex_s
    volatile int __lock;
    volatile unsigned int __count;
    volatile int __owner;
    unsigned int __nusers;
#line 89
    int __kind;
    int __spins;
    __pthread_list_t __list;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
} pthread_mutexattr_t;
#line 116
typedef union
  struct
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align__workaround;
} pthread_cond_t;
typedef union
  char __size[4];
} pthread_condattr_t;
#line 141
typedef unsigned int pthread_key_t;
#line 145
typedef int pthread_once_t;
#line 151
typedef union
  struct
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
#line 168
    unsigned int __flags;
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
} pthread_rwlockattr_t;
#line 202
typedef volatile int pthread_spinlock_t;
#line 207
typedef union
  char __size[32];
} pthread_barrier_t;
typedef union
  char __size[4];
} pthread_barrierattr_t;
#line 327 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
extern long int random (void) ;
#line 330
extern void srandom (unsigned int __seed) ;
#line 336
extern char *initstate (unsigned int __seed, char *__statebuf,
			size_t __statelen)  ;
#line 341
extern char *setstate (char *__statebuf)  ;
#line 349
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
		     int32_t *__restrict __result)  ;
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
			size_t __statelen,
			struct random_data *__restrict __buf)
extern int setstate_r (char *__restrict __statebuf,
#line 380
extern int rand (void) ;
extern void srand (unsigned int __seed) ;
#line 387
extern int rand_r (unsigned int *__seed) ;
#line 395
extern double drand48 (void) ;
extern double erand48 (unsigned short int __xsubi[3])  ;
#line 399
extern long int lrand48 (void) ;
extern long int nrand48 (unsigned short int __xsubi[3])
#line 404
extern long int mrand48 (void) ;
extern long int jrand48 (unsigned short int __xsubi[3])
#line 409
extern void srand48 (long int __seedval) ;
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7])  ;
#line 418
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    unsigned long long int __a;
#line 428
extern int drand48_r (struct drand48_data *__restrict __buffer,
		      double *__restrict __result)  ;
extern int erand48_r (unsigned short int __xsubi[3],
#line 435
extern int lrand48_r (struct drand48_data *__restrict __buffer,
		      long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
#line 444
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
#line 453
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
		     struct drand48_data *__buffer)  ;
extern int lcong48_r (unsigned short int __param[7],
#line 471
extern void *malloc (size_t __size)  __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
#line 485
extern void *realloc (void *__ptr, size_t __size)
      __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) ;
#line 493
extern void cfree (void *__ptr) ;
#line 33 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/alloca.h"
extern void *alloca (size_t __size) ;
#line 503 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
extern void *valloc (size_t __size)  __attribute__ ((__malloc__)) ;
#line 508
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
#line 514
extern void abort (void)  __attribute__ ((__noreturn__));
#line 518
extern int atexit (void (*__func) (void))  ;
#line 536
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
#line 544
extern void exit (int __status)  __attribute__ ((__noreturn__));
#line 560
extern void _Exit (int __status)  __attribute__ ((__noreturn__));
#line 567
extern char *getenv (const char *__name)   ;
#line 572
extern char *__secure_getenv (const char *__name)
#line 579
extern int putenv (char *__string)  ;
#line 585
extern int setenv (const char *__name, const char *__value, int __replace)
#line 589
extern int unsetenv (const char *__name)  ;
#line 596
extern int clearenv (void) ;
#line 606
extern char *mktemp (char *__template)   ;
#line 620
extern int mkstemp (char *__template)  ;
#line 642
extern int mkstemps (char *__template, int __suffixlen)  ;
#line 663
extern char *mkdtemp (char *__template)   ;
#line 717
extern int system (const char *__command) ;
#line 734
extern char *realpath (const char *__restrict __name,
		       char *__restrict __resolved)  ;
#line 742
typedef int (*__compar_fn_t) (const void *, const void *);
#line 755
extern void *bsearch (const void *__key, const void *__base,
		      size_t __nmemb, size_t __size, __compar_fn_t __compar)
#line 761
extern void qsort (void *__base, size_t __nmemb, size_t __size,
		   __compar_fn_t __compar) ;
#line 771
extern int abs (int __x)  __attribute__ ((const)) ;
extern long int labs (long int __x)  __attribute__ ((const)) ;
#line 776
__extension__ extern long long int llabs (long long int __x)
#line 785
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
#line 793
__extension__ extern lldiv_t lldiv (long long int __numer,
				    long long int __denom)
#line 808
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
		   int *__restrict __sign)   ;
#line 814
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
#line 820
extern char *gcvt (double __value, int __ndigit, char *__buf)
#line 826
extern char *qecvt (long double __value, int __ndigit,
		    int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
#line 838
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
		   int *__restrict __sign, char *__restrict __buf,
		   size_t __len)  ;
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
		   size_t __len)  ;
extern int qecvt_r (long double __value, int __ndigit,
		    int *__restrict __decpt, int *__restrict __sign,
		    char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
#line 860
extern int mblen (const char *__s, size_t __n)  ;
#line 863
extern int mbtowc (wchar_t *__restrict __pwc,
		   const char *__restrict __s, size_t __n)  ;
#line 867
extern int wctomb (char *__s, wchar_t __wchar)  ;
#line 871
extern size_t mbstowcs (wchar_t *__restrict  __pwcs,
extern size_t wcstombs (char *__restrict __s,
			const wchar_t *__restrict __pwcs, size_t __n)
#line 885
extern int rpmatch (const char *__response)   ;
#line 896
extern int getsubopt (char **__restrict __optionp,
		      char *const *__restrict __tokens,
		      char **__restrict __valuep)
#line 948
extern int getloadavg (double __loadavg[], int __nelem)
        Defined "STDC_HEADERS" to "1"
TEST checkStat from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
  Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 45
#line 49
#line 61
#line 66
#line 71
#line 76
#line 81
#line 87
#line 99
#line 105
#line 110
#line 116
#line 123
#line 76
#line 92
#line 104
#line 195
#line 201
#line 29
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
#line 55
#line 67
typedef struct
#line 75
#line 78
  } fd_set;
#line 85
#line 109
#line 121
__extension__
__extension__
__extension__
#line 236
#line 240
#line 244
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
#line 143 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/stat.h"
struct stat
    __dev_t st_dev;
    __ino_t st_ino;
#line 151
    __nlink_t st_nlink;
    __mode_t st_mode;
    __uid_t st_uid;
    __gid_t st_gid;
    int __pad2;
    __dev_t st_rdev;
    __off_t st_size;
#line 162
    __blksize_t st_blksize;
#line 165
    __blkcnt_t st_blocks;
#line 176
    struct timespec st_atim;
    struct timespec st_mtim;
    struct timespec st_ctim;
#line 190
    unsigned long int __unused4;
    unsigned long int __unused5;
    unsigned long int __unused6;
#line 211 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/stat.h"
extern int stat (const char *__restrict __file,
		 struct stat *__restrict __buf)  ;
#line 216
extern int fstat (int __fd, struct stat *__buf)  ;
#line 240
extern int fstatat (int __fd, const char *__restrict __file,
		    struct stat *__restrict __buf, int __flag)
#line 265
extern int lstat (const char *__restrict __file,
#line 286
extern int chmod (const char *__file, __mode_t __mode)
#line 293
extern int lchmod (const char *__file, __mode_t __mode)
#line 299
extern int fchmod (int __fd, __mode_t __mode) ;
#line 305
extern int fchmodat (int __fd, const char *__file, __mode_t __mode,
		     int __flag)
#line 314
extern __mode_t umask (__mode_t __mask) ;
#line 323
extern int mkdir (const char *__path, __mode_t __mode)
#line 330
extern int mkdirat (int __fd, const char *__path, __mode_t __mode)
#line 338
extern int mknod (const char *__path, __mode_t __mode, __dev_t __dev)
#line 345
extern int mknodat (int __fd, const char *__path, __mode_t __mode,
		    __dev_t __dev)  ;
#line 352
extern int mkfifo (const char *__path, __mode_t __mode)
#line 359
extern int mkfifoat (int __fd, const char *__path, __mode_t __mode)
#line 366
extern int utimensat (int __fd, const char *__path,
		      const struct timespec __times[2],
		      int __flags)
#line 374
extern int futimens (int __fd, const struct timespec __times[2]) ;
#line 401
extern int __fxstat (int __ver, int __fildes, struct stat *__stat_buf)
extern int __xstat (int __ver, const char *__filename,
		    struct stat *__stat_buf)  ;
extern int __lxstat (int __ver, const char *__filename,
extern int __fxstatat (int __ver, int __fildes, const char *__filename,
		       struct stat *__stat_buf, int __flag)
#line 444
extern int __xmknod (int __ver, const char *__path, __mode_t __mode,
		     __dev_t *__dev)  ;
extern int __xmknodat (int __ver, int __fd, const char *__path,
		       __mode_t __mode, __dev_t *__dev)
TEST checkSysWait from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
  Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
Successful compile:
Source:
#include <sys/types.h>
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
    int s;
    wait (&s);
    s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
  return 0;
        Defined "HAVE_SYS_WAIT_H" to "1"
TEST checkTime from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
  Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 76
#line 92
#line 104
#line 120
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 133
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
#line 146
  long int tm_gmtoff;
  const char *tm_zone;
#line 152
#line 161
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
#line 168
struct sigevent;
#line 174
#line 183
extern clock_t clock (void) ;
#line 186
extern time_t time (time_t *__timer) ;
#line 189
extern double difftime (time_t __time1, time_t __time0)
#line 193
extern time_t mktime (struct tm *__tp) ;
#line 199
extern size_t strftime (char *__restrict __s, size_t __maxsize,
			const char *__restrict __format,
			const struct tm *__restrict __tp) ;
#line 34
#line 39
} *__locale_t;
#line 43
#line 217 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
			  const struct tm *__restrict __tp,
			  __locale_t __loc) ;
#line 233
extern struct tm *gmtime (const time_t *__timer) ;
#line 237
extern struct tm *localtime (const time_t *__timer) ;
#line 243
extern struct tm *gmtime_r (const time_t *__restrict __timer,
#line 248
extern struct tm *localtime_r (const time_t *__restrict __timer,
#line 255
extern char *asctime (const struct tm *__tp) ;
#line 258
extern char *ctime (const time_t *__timer) ;
#line 266
extern char *asctime_r (const struct tm *__restrict __tp,
			char *__restrict __buf) ;
#line 270
extern char *ctime_r (const time_t *__restrict __timer,
#line 276
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
#line 283
extern char *tzname[2];
#line 287
extern void tzset (void) ;
#line 291
extern int daylight;
extern long int timezone;
#line 298
extern int stime (const time_t *__when) ;
#line 313
extern time_t timegm (struct tm *__tp) ;
#line 316
extern time_t timelocal (struct tm *__tp) ;
#line 319
extern int dysize (int __year)   __attribute__ ((const));
#line 328
extern int nanosleep (const struct timespec *__requested_time,
		      struct timespec *__remaining);
#line 333
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) ;
#line 336
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) ;
#line 339
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
#line 347
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
			    const struct timespec *__req,
			    struct timespec *__rem);
#line 352
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) ;
#line 357
extern int timer_create (clockid_t __clock_id,
			 struct sigevent *__restrict __evp,
			 timer_t *__restrict __timerid) ;
#line 362
extern int timer_delete (timer_t __timerid) ;
#line 365
extern int timer_settime (timer_t __timerid, int __flags,
			  const struct itimerspec *__restrict __value,
			  struct itimerspec *__restrict __ovalue) ;
#line 370
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
#line 374
extern int timer_getoverrun (timer_t __timerid) ;
          Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 76 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
struct timeval
    __time_t tv_sec;
#line 29
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 55
#line 67
typedef struct
#line 75
#line 78
  } fd_set;
#line 85
#line 109
#line 121
#line 57 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/time.h"
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
#line 73
extern int gettimeofday (struct timeval *__restrict __tv,
			 __timezone_ptr_t __tz)  ;
#line 79
extern int settimeofday (const struct timeval *__tv,
			 const struct timezone *__tz)
#line 87
extern int adjtime (const struct timeval *__delta,
		    struct timeval *__olddelta) ;
#line 93
enum __itimer_which
    ITIMER_REAL = 0,
#line 99
    ITIMER_VIRTUAL = 1,
#line 103
    ITIMER_PROF = 2
#line 109
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
#line 122
typedef int __itimer_which_t;
#line 127
extern int getitimer (__itimer_which_t __which,
		      struct itimerval *__value) ;
#line 133
extern int setitimer (__itimer_which_t __which,
		      const struct itimerval *__restrict __new,
		      struct itimerval *__restrict __old) ;
#line 140
extern int utimes (const char *__file, const struct timeval __tvp[2])
#line 145
extern int lutimes (const char *__file, const struct timeval __tvp[2])
#line 149
extern int futimes (int __fd, const struct timeval __tvp[2]) ;
          Defined "HAVE_SYS_TIME_H" to "1"
Successful compile:
Source:
#include <sys/time.h>
#include <time.h>
int main() {
struct tm *tp = 0;
if (tp);
  return 0;
        Defined "TIME_WITH_SYS_TIME" to "1"
TEST checkMath from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:203)
TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:203)
  Checks for the math headers and defines
Checking for header: math.h
stdout:
#line 55 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include-fixed/bits/mathdef.h"
typedef double float_t;
typedef double double_t;
#line 55 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/mathcalls.h"
extern double acos (double __x)  ; extern double __acos (double __x)  ;
extern double asin (double __x)  ; extern double __asin (double __x)  ;
extern double atan (double __x)  ; extern double __atan (double __x)  ;
extern double atan2 (double __y, double __x)  ; extern double __atan2 (double __y, double __x)  ;
#line 64
extern double cos (double __x)  ; extern double __cos (double __x)  ;
extern double sin (double __x)  ; extern double __sin (double __x)  ;
extern double tan (double __x)  ; extern double __tan (double __x)  ;
#line 73
extern double cosh (double __x)  ; extern double __cosh (double __x)  ;
extern double sinh (double __x)  ; extern double __sinh (double __x)  ;
extern double tanh (double __x)  ; extern double __tanh (double __x)  ;
#line 89
extern double acosh (double __x)  ; extern double __acosh (double __x)  ;
extern double asinh (double __x)  ; extern double __asinh (double __x)  ;
extern double atanh (double __x)  ; extern double __atanh (double __x)  ;
#line 101
extern double exp (double __x)  ; extern double __exp (double __x)  ;
#line 104
extern double frexp (double __x, int *__exponent)  ; extern double __frexp (double __x, int *__exponent)  ;
#line 107
extern double ldexp (double __x, int __exponent)  ; extern double __ldexp (double __x, int __exponent)  ;
#line 110
extern double log (double __x)  ; extern double __log (double __x)  ;
#line 113
extern double log10 (double __x)  ; extern double __log10 (double __x)  ;
#line 116
extern double modf (double __x, double *__iptr)  ; extern double __modf (double __x, double *__iptr)  ;
#line 129
extern double expm1 (double __x)  ; extern double __expm1 (double __x)  ;
#line 132
extern double log1p (double __x)  ; extern double __log1p (double __x)  ;
#line 135
extern double logb (double __x)  ; extern double __logb (double __x)  ;
#line 142
extern double exp2 (double __x)  ; extern double __exp2 (double __x)  ;
#line 145
extern double log2 (double __x)  ; extern double __log2 (double __x)  ;
#line 154
extern double pow (double __x, double __y)  ; extern double __pow (double __x, double __y)  ;
#line 157
extern double sqrt (double __x)  ; extern double __sqrt (double __x)  ;
#line 163
extern double hypot (double __x, double __y)  ; extern double __hypot (double __x, double __y)  ;
#line 170
extern double cbrt (double __x)  ; extern double __cbrt (double __x)  ;
#line 179
extern double ceil (double __x)   __attribute__ ((const)); extern double __ceil (double __x)   __attribute__ ((const));
#line 182
extern double fabs (double __x)   __attribute__ ((const)); extern double __fabs (double __x)   __attribute__ ((const));
#line 185
extern double floor (double __x)   __attribute__ ((const)); extern double __floor (double __x)   __attribute__ ((const));
#line 188
extern double fmod (double __x, double __y)  ; extern double __fmod (double __x, double __y)  ;
#line 193
extern int __isinf (double __value)   __attribute__ ((const));
#line 196
extern int __finite (double __value)   __attribute__ ((const));
#line 202
extern int isinf (double __value)   __attribute__ ((const));
#line 205
extern int finite (double __value)   __attribute__ ((const));
#line 208
extern double drem (double __x, double __y)  ; extern double __drem (double __x, double __y)  ;
#line 212
extern double significand (double __x)  ; extern double __significand (double __x)  ;
#line 218
extern double copysign (double __x, double __y)   __attribute__ ((const)); extern double __copysign (double __x, double __y)   __attribute__ ((const));
#line 225
extern double nan (const char *__tagb)   __attribute__ ((const)); extern double __nan (const char *__tagb)   __attribute__ ((const));
#line 231
extern int __isnan (double __value)   __attribute__ ((const));
#line 235
extern int isnan (double __value)   __attribute__ ((const));
#line 238
extern double j0 (double)  ; extern double __j0 (double)  ;
extern double j1 (double)  ; extern double __j1 (double)  ;
extern double jn (int, double)  ; extern double __jn (int, double)  ;
extern double y0 (double)  ; extern double __y0 (double)  ;
extern double y1 (double)  ; extern double __y1 (double)  ;
extern double yn (int, double)  ; extern double __yn (int, double)  ;
#line 250
extern double erf (double)  ; extern double __erf (double)  ;
extern double erfc (double)  ; extern double __erfc (double)  ;
extern double lgamma (double)  ; extern double __lgamma (double)  ;
#line 259
extern double tgamma (double)  ; extern double __tgamma (double)  ;
#line 265
extern double gamma (double)  ; extern double __gamma (double)  ;
#line 272
extern double lgamma_r (double, int *__signgamp)  ; extern double __lgamma_r (double, int *__signgamp)  ;
#line 280
extern double rint (double __x)  ; extern double __rint (double __x)  ;
#line 283
extern double nextafter (double __x, double __y)   __attribute__ ((const)); extern double __nextafter (double __x, double __y)   __attribute__ ((const));
extern double nexttoward (double __x, long double __y)   __attribute__ ((const)); extern double __nexttoward (double __x, long double __y)   __attribute__ ((const));
#line 289
extern double remainder (double __x, double __y)  ; extern double __remainder (double __x, double __y)  ;
#line 293
extern double scalbn (double __x, int __n)  ; extern double __scalbn (double __x, int __n)  ;
#line 297
extern int ilogb (double __x)  ; extern int __ilogb (double __x)  ;
#line 302
extern double scalbln (double __x, long int __n)  ; extern double __scalbln (double __x, long int __n)  ;
#line 306
extern double nearbyint (double __x)  ; extern double __nearbyint (double __x)  ;
#line 310
extern double round (double __x)   __attribute__ ((const)); extern double __round (double __x)   __attribute__ ((const));
#line 314
extern double trunc (double __x)   __attribute__ ((const)); extern double __trunc (double __x)   __attribute__ ((const));
#line 319
extern double remquo (double __x, double __y, int *__quo)  ; extern double __remquo (double __x, double __y, int *__quo)  ;
#line 326
extern long int lrint (double __x)  ; extern long int __lrint (double __x)  ;
extern long long int llrint (double __x)  ; extern long long int __llrint (double __x)  ;
#line 331
extern long int lround (double __x)  ; extern long int __lround (double __x)  ;
extern long long int llround (double __x)  ; extern long long int __llround (double __x)  ;
#line 336
extern double fdim (double __x, double __y)  ; extern double __fdim (double __x, double __y)  ;
#line 339
extern double fmax (double __x, double __y)  ; extern double __fmax (double __x, double __y)  ;
#line 342
extern double fmin (double __x, double __y)  ; extern double __fmin (double __x, double __y)  ;
#line 346
extern int __fpclassify (double __value)
#line 350
extern int __signbit (double __value)
#line 355
extern double fma (double __x, double __y, double __z)  ; extern double __fma (double __x, double __y, double __z)  ;
#line 364
extern double scalb (double __x, double __n)  ; extern double __scalb (double __x, double __n)  ;
extern float acosf (float __x)  ; extern float __acosf (float __x)  ;
extern float asinf (float __x)  ; extern float __asinf (float __x)  ;
extern float atanf (float __x)  ; extern float __atanf (float __x)  ;
extern float atan2f (float __y, float __x)  ; extern float __atan2f (float __y, float __x)  ;
#line 64
extern float cosf (float __x)  ; extern float __cosf (float __x)  ;
extern float sinf (float __x)  ; extern float __sinf (float __x)  ;
extern float tanf (float __x)  ; extern float __tanf (float __x)  ;
#line 73
extern float coshf (float __x)  ; extern float __coshf (float __x)  ;
extern float sinhf (float __x)  ; extern float __sinhf (float __x)  ;
extern float tanhf (float __x)  ; extern float __tanhf (float __x)  ;
#line 89
extern float acoshf (float __x)  ; extern float __acoshf (float __x)  ;
extern float asinhf (float __x)  ; extern float __asinhf (float __x)  ;
extern float atanhf (float __x)  ; extern float __atanhf (float __x)  ;
#line 101
extern float expf (float __x)  ; extern float __expf (float __x)  ;
#line 104
extern float frexpf (float __x, int *__exponent)  ; extern float __frexpf (float __x, int *__exponent)  ;
#line 107
extern float ldexpf (float __x, int __exponent)  ; extern float __ldexpf (float __x, int __exponent)  ;
#line 110
extern float logf (float __x)  ; extern float __logf (float __x)  ;
#line 113
extern float log10f (float __x)  ; extern float __log10f (float __x)  ;
#line 116
extern float modff (float __x, float *__iptr)  ; extern float __modff (float __x, float *__iptr)  ;
#line 129
extern float expm1f (float __x)  ; extern float __expm1f (float __x)  ;
#line 132
extern float log1pf (float __x)  ; extern float __log1pf (float __x)  ;
#line 135
extern float logbf (float __x)  ; extern float __logbf (float __x)  ;
#line 142
extern float exp2f (float __x)  ; extern float __exp2f (float __x)  ;
#line 145
extern float log2f (float __x)  ; extern float __log2f (float __x)  ;
#line 154
extern float powf (float __x, float __y)  ; extern float __powf (float __x, float __y)  ;
#line 157
extern float sqrtf (float __x)  ; extern float __sqrtf (float __x)  ;
#line 163
extern float hypotf (float __x, float __y)  ; extern float __hypotf (float __x, float __y)  ;
#line 170
extern float cbrtf (float __x)  ; extern float __cbrtf (float __x)  ;
#line 179
extern float ceilf (float __x)   __attribute__ ((const)); extern float __ceilf (float __x)   __attribute__ ((const));
#line 182
extern float fabsf (float __x)   __attribute__ ((const)); extern float __fabsf (float __x)   __attribute__ ((const));
#line 185
extern float floorf (float __x)   __attribute__ ((const)); extern float __floorf (float __x)   __attribute__ ((const));
#line 188
extern float fmodf (float __x, float __y)  ; extern float __fmodf (float __x, float __y)  ;
#line 193
extern int __isinff (float __value)   __attribute__ ((const));
#line 196
extern int __finitef (float __value)   __attribute__ ((const));
#line 202
extern int isinff (float __value)   __attribute__ ((const));
#line 205
extern int finitef (float __value)   __attribute__ ((const));
#line 208
extern float dremf (float __x, float __y)  ; extern float __dremf (float __x, float __y)  ;
#line 212
extern float significandf (float __x)  ; extern float __significandf (float __x)  ;
#line 218
extern float copysignf (float __x, float __y)   __attribute__ ((const)); extern float __copysignf (float __x, float __y)   __attribute__ ((const));
#line 225
extern float nanf (const char *__tagb)   __attribute__ ((const)); extern float __nanf (const char *__tagb)   __attribute__ ((const));
#line 231
extern int __isnanf (float __value)   __attribute__ ((const));
#line 235
extern int isnanf (float __value)   __attribute__ ((const));
#line 238
extern float j0f (float)  ; extern float __j0f (float)  ;
extern float j1f (float)  ; extern float __j1f (float)  ;
extern float jnf (int, float)  ; extern float __jnf (int, float)  ;
extern float y0f (float)  ; extern float __y0f (float)  ;
extern float y1f (float)  ; extern float __y1f (float)  ;
extern float ynf (int, float)  ; extern float __ynf (int, float)  ;
#line 250
extern float erff (float)  ; extern float __erff (float)  ;
extern float erfcf (float)  ; extern float __erfcf (float)  ;
extern float lgammaf (float)  ; extern float __lgammaf (float)  ;
#line 259
extern float tgammaf (float)  ; extern float __tgammaf (float)  ;
#line 265
extern float gammaf (float)  ; extern float __gammaf (float)  ;
#line 272
extern float lgammaf_r (float, int *__signgamp)  ; extern float __lgammaf_r (float, int *__signgamp)  ;
#line 280
extern float rintf (float __x)  ; extern float __rintf (float __x)  ;
#line 283
extern float nextafterf (float __x, float __y)   __attribute__ ((const)); extern float __nextafterf (float __x, float __y)   __attribute__ ((const));
extern float nexttowardf (float __x, long double __y)   __attribute__ ((const)); extern float __nexttowardf (float __x, long double __y)   __attribute__ ((const));
#line 289
extern float remainderf (float __x, float __y)  ; extern float __remainderf (float __x, float __y)  ;
#line 293
extern float scalbnf (float __x, int __n)  ; extern float __scalbnf (float __x, int __n)  ;
#line 297
extern int ilogbf (float __x)  ; extern int __ilogbf (float __x)  ;
#line 302
extern float scalblnf (float __x, long int __n)  ; extern float __scalblnf (float __x, long int __n)  ;
#line 306
extern float nearbyintf (float __x)  ; extern float __nearbyintf (float __x)  ;
#line 310
extern float roundf (float __x)   __attribute__ ((const)); extern float __roundf (float __x)   __attribute__ ((const));
#line 314
extern float truncf (float __x)   __attribute__ ((const)); extern float __truncf (float __x)   __attribute__ ((const));
#line 319
extern float remquof (float __x, float __y, int *__quo)  ; extern float __remquof (float __x, float __y, int *__quo)  ;
#line 326
extern long int lrintf (float __x)  ; extern long int __lrintf (float __x)  ;
extern long long int llrintf (float __x)  ; extern long long int __llrintf (float __x)  ;
#line 331
extern long int lroundf (float __x)  ; extern long int __lroundf (float __x)  ;
extern long long int llroundf (float __x)  ; extern long long int __llroundf (float __x)  ;
#line 336
extern float fdimf (float __x, float __y)  ; extern float __fdimf (float __x, float __y)  ;
#line 339
extern float fmaxf (float __x, float __y)  ; extern float __fmaxf (float __x, float __y)  ;
#line 342
extern float fminf (float __x, float __y)  ; extern float __fminf (float __x, float __y)  ;
#line 346
extern int __fpclassifyf (float __value)
#line 350
extern int __signbitf (float __value)
#line 355
extern float fmaf (float __x, float __y, float __z)  ; extern float __fmaf (float __x, float __y, float __z)  ;
#line 364
extern float scalbf (float __x, float __n)  ; extern float __scalbf (float __x, float __n)  ;
extern long double acosl (long double __x)  ; extern long double __acosl (long double __x)  ;
extern long double asinl (long double __x)  ; extern long double __asinl (long double __x)  ;
extern long double atanl (long double __x)  ; extern long double __atanl (long double __x)  ;
extern long double atan2l (long double __y, long double __x)  ; extern long double __atan2l (long double __y, long double __x)  ;
#line 64
extern long double cosl (long double __x)  ; extern long double __cosl (long double __x)  ;
extern long double sinl (long double __x)  ; extern long double __sinl (long double __x)  ;
extern long double tanl (long double __x)  ; extern long double __tanl (long double __x)  ;
#line 73
extern long double coshl (long double __x)  ; extern long double __coshl (long double __x)  ;
extern long double sinhl (long double __x)  ; extern long double __sinhl (long double __x)  ;
extern long double tanhl (long double __x)  ; extern long double __tanhl (long double __x)  ;
#line 89
extern long double acoshl (long double __x)  ; extern long double __acoshl (long double __x)  ;
extern long double asinhl (long double __x)  ; extern long double __asinhl (long double __x)  ;
extern long double atanhl (long double __x)  ; extern long double __atanhl (long double __x)  ;
#line 101
extern long double expl (long double __x)  ; extern long double __expl (long double __x)  ;
#line 104
extern long double frexpl (long double __x, int *__exponent)  ; extern long double __frexpl (long double __x, int *__exponent)  ;
#line 107
extern long double ldexpl (long double __x, int __exponent)  ; extern long double __ldexpl (long double __x, int __exponent)  ;
#line 110
extern long double logl (long double __x)  ; extern long double __logl (long double __x)  ;
#line 113
extern long double log10l (long double __x)  ; extern long double __log10l (long double __x)  ;
#line 116
extern long double modfl (long double __x, long double *__iptr)  ; extern long double __modfl (long double __x, long double *__iptr)  ;
#line 129
extern long double expm1l (long double __x)  ; extern long double __expm1l (long double __x)  ;
#line 132
extern long double log1pl (long double __x)  ; extern long double __log1pl (long double __x)  ;
#line 135
extern long double logbl (long double __x)  ; extern long double __logbl (long double __x)  ;
#line 142
extern long double exp2l (long double __x)  ; extern long double __exp2l (long double __x)  ;
#line 145
extern long double log2l (long double __x)  ; extern long double __log2l (long double __x)  ;
#line 154
extern long double powl (long double __x, long double __y)  ; extern long double __powl (long double __x, long double __y)  ;
#line 157
extern long double sqrtl (long double __x)  ; extern long double __sqrtl (long double __x)  ;
#line 163
extern long double hypotl (long double __x, long double __y)  ; extern long double __hypotl (long double __x, long double __y)  ;
#line 170
extern long double cbrtl (long double __x)  ; extern long double __cbrtl (long double __x)  ;
#line 179
extern long double ceill (long double __x)   __attribute__ ((const)); extern long double __ceill (long double __x)   __attribute__ ((const));
#line 182
extern long double fabsl (long double __x)   __attribute__ ((const)); extern long double __fabsl (long double __x)   __attribute__ ((const));
#line 185
extern long double floorl (long double __x)   __attribute__ ((const)); extern long double __floorl (long double __x)   __attribute__ ((const));
#line 188
extern long double fmodl (long double __x, long double __y)  ; extern long double __fmodl (long double __x, long double __y)  ;
#line 193
extern int __isinfl (long double __value)   __attribute__ ((const));
#line 196
extern int __finitel (long double __value)   __attribute__ ((const));
#line 202
extern int isinfl (long double __value)   __attribute__ ((const));
#line 205
extern int finitel (long double __value)   __attribute__ ((const));
#line 208
extern long double dreml (long double __x, long double __y)  ; extern long double __dreml (long double __x, long double __y)  ;
#line 212
extern long double significandl (long double __x)  ; extern long double __significandl (long double __x)  ;
#line 218
extern long double copysignl (long double __x, long double __y)   __attribute__ ((const)); extern long double __copysignl (long double __x, long double __y)   __attribute__ ((const));
#line 225
extern long double nanl (const char *__tagb)   __attribute__ ((const)); extern long double __nanl (const char *__tagb)   __attribute__ ((const));
#line 231
extern int __isnanl (long double __value)   __attribute__ ((const));
#line 235
extern int isnanl (long double __value)   __attribute__ ((const));
#line 238
extern long double j0l (long double)  ; extern long double __j0l (long double)  ;
extern long double j1l (long double)  ; extern long double __j1l (long double)  ;
extern long double jnl (int, long double)  ; extern long double __jnl (int, long double)  ;
extern long double y0l (long double)  ; extern long double __y0l (long double)  ;
extern long double y1l (long double)  ; extern long double __y1l (long double)  ;
extern long double ynl (int, long double)  ; extern long double __ynl (int, long double)  ;
#line 250
extern long double erfl (long double)  ; extern long double __erfl (long double)  ;
extern long double erfcl (long double)  ; extern long double __erfcl (long double)  ;
extern long double lgammal (long double)  ; extern long double __lgammal (long double)  ;
#line 259
extern long double tgammal (long double)  ; extern long double __tgammal (long double)  ;
#line 265
extern long double gammal (long double)  ; extern long double __gammal (long double)  ;
#line 272
extern long double lgammal_r (long double, int *__signgamp)  ; extern long double __lgammal_r (long double, int *__signgamp)  ;
#line 280
extern long double rintl (long double __x)  ; extern long double __rintl (long double __x)  ;
#line 283
extern long double nextafterl (long double __x, long double __y)   __attribute__ ((const)); extern long double __nextafterl (long double __x, long double __y)   __attribute__ ((const));
extern long double nexttowardl (long double __x, long double __y)   __attribute__ ((const)); extern long double __nexttowardl (long double __x, long double __y)   __attribute__ ((const));
#line 289
extern long double remainderl (long double __x, long double __y)  ; extern long double __remainderl (long double __x, long double __y)  ;
#line 293
extern long double scalbnl (long double __x, int __n)  ; extern long double __scalbnl (long double __x, int __n)  ;
#line 297
extern int ilogbl (long double __x)  ; extern int __ilogbl (long double __x)  ;
#line 302
extern long double scalblnl (long double __x, long int __n)  ; extern long double __scalblnl (long double __x, long int __n)  ;
#line 306
extern long double nearbyintl (long double __x)  ; extern long double __nearbyintl (long double __x)  ;
#line 310
extern long double roundl (long double __x)   __attribute__ ((const)); extern long double __roundl (long double __x)   __attribute__ ((const));
#line 314
extern long double truncl (long double __x)   __attribute__ ((const)); extern long double __truncl (long double __x)   __attribute__ ((const));
#line 319
extern long double remquol (long double __x, long double __y, int *__quo)  ; extern long double __remquol (long double __x, long double __y, int *__quo)  ;
#line 326
extern long int lrintl (long double __x)  ; extern long int __lrintl (long double __x)  ;
extern long long int llrintl (long double __x)  ; extern long long int __llrintl (long double __x)  ;
#line 331
extern long int lroundl (long double __x)  ; extern long int __lroundl (long double __x)  ;
extern long long int llroundl (long double __x)  ; extern long long int __llroundl (long double __x)  ;
#line 336
extern long double fdiml (long double __x, long double __y)  ; extern long double __fdiml (long double __x, long double __y)  ;
#line 339
extern long double fmaxl (long double __x, long double __y)  ; extern long double __fmaxl (long double __x, long double __y)  ;
#line 342
extern long double fminl (long double __x, long double __y)  ; extern long double __fminl (long double __x, long double __y)  ;
#line 346
extern int __fpclassifyl (long double __value)
#line 350
extern int __signbitl (long double __value)
#line 355
extern long double fmal (long double __x, long double __y, long double __z)  ; extern long double __fmal (long double __x, long double __y, long double __z)  ;
#line 364
extern long double scalbl (long double __x, long double __n)  ; extern long double __scalbl (long double __x, long double __n)  ;
#line 157 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/math.h"
extern int signgam;
#line 198
enum
    FP_NAN,
    FP_INFINITE,
    FP_ZERO,
    FP_SUBNORMAL,
    FP_NORMAL
#line 291
typedef enum
  _IEEE_ = -1,
  _SVID_,
  _XOPEN_,
  _POSIX_,
  _ISOC_
} _LIB_VERSION_TYPE;
#line 303
extern _LIB_VERSION_TYPE _LIB_VERSION;
#line 316
struct exception
    int type;
    char *name;
    double arg1;
    double arg2;
    double retval;
#line 329
extern int matherr (struct exception *__exc);
          Defined "HAVE_MATH_H" to "1"
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
      Found math #defines, like M_PI
TEST check from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/socket.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 45
#line 49
#line 61
#line 66
#line 71
#line 76
#line 81
#line 87
#line 99
#line 105
#line 110
#line 116
#line 123
#line 76
#line 92
#line 104
#line 195
#line 201
#line 29
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
#line 55
#line 67
typedef struct
#line 75
#line 78
  } fd_set;
#line 85
#line 109
#line 121
__extension__
__extension__
__extension__
#line 236
#line 240
#line 244
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
#line 44 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/uio.h"
struct iovec
    void *iov_base;
    size_t iov_len;
#line 40 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/uio.h"
extern ssize_t readv (int __fd, const struct iovec *__iovec, int __count)
#line 51
extern ssize_t writev (int __fd, const struct iovec *__iovec, int __count)
#line 66
extern ssize_t preadv (int __fd, const struct iovec *__iovec, int __count,
		       __off_t __offset) ;
#line 78
extern ssize_t pwritev (int __fd, const struct iovec *__iovec, int __count,
			__off_t __offset) ;
#line 35 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/socket.h"
typedef __socklen_t socklen_t;
#line 40
enum __socket_type
  SOCK_STREAM = 1,
#line 45
  SOCK_DGRAM = 2,
#line 48
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
#line 55
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
#line 65
  SOCK_CLOEXEC = 02000000,
#line 68
  SOCK_NONBLOCK = 04000
#line 71
#line 29 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sockaddr.h"
typedef unsigned short int sa_family_t;
#line 174 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/socket.h"
struct sockaddr
    sa_family_t sa_family;
    char sa_data[14];
#line 187
struct sockaddr_storage
    sa_family_t ss_family;
    unsigned long int __ss_align;
    char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
#line 196
enum
    MSG_OOB		= 0x01,
    MSG_PEEK		= 0x02,
    MSG_DONTROUTE	= 0x04,
#line 209
    MSG_CTRUNC		= 0x08,
    MSG_PROXY		= 0x10,
    MSG_TRUNC		= 0x20,
    MSG_DONTWAIT	= 0x40,
    MSG_EOR		= 0x80,
    MSG_WAITALL		= 0x100,
    MSG_FIN		= 0x200,
    MSG_SYN		= 0x400,
    MSG_CONFIRM		= 0x800,
    MSG_RST		= 0x1000,
    MSG_ERRQUEUE	= 0x2000,
    MSG_NOSIGNAL	= 0x4000,
    MSG_MORE		= 0x8000,
    MSG_WAITFORONE	= 0x10000,
#line 238
    MSG_CMSG_CLOEXEC	= 0x40000000
#line 242
#line 247
struct msghdr
    void *msg_name;
    socklen_t msg_namelen;
    struct iovec *msg_iov;
    size_t msg_iovlen;
    void *msg_control;
    size_t msg_controllen;
#line 261
    int msg_flags;
#line 274
struct cmsghdr
    size_t cmsg_len;
#line 281
    int cmsg_level;
    int cmsg_type;
    __extension__ unsigned char __cmsg_data [];
#line 304
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
				      struct cmsghdr *__cmsg) ;
#line 331
enum
    SCM_RIGHTS = 0x01
#line 339
#line 411
struct linger
    int l_onoff;
    int l_linger;
#line 425
extern int recvmmsg (int __fd, struct mmsghdr *__vmessages,
		     unsigned int __vlen, int __flags,
		     const struct timespec *__tmo);
#line 45 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/socket.h"
struct osockaddr
    unsigned short int sa_family;
    unsigned char sa_data[14];
#line 54
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
#line 105
extern int socket (int __domain, int __type, int __protocol) ;
#line 111
extern int socketpair (int __domain, int __type, int __protocol,
		       int __fds[2]) ;
#line 115
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
#line 119
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
			socklen_t *__restrict __len) ;
#line 129
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
#line 133
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
#line 141
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
#line 148
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
#line 155
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
		       int __flags, const struct sockaddr * __addr,
		       socklen_t __addr_len);
#line 166
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
			 int __flags, struct sockaddr *__restrict __addr,
			 socklen_t *__restrict __addr_len);
#line 176
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
			int __flags);
#line 184
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
#line 190
extern int getsockopt (int __fd, int __level, int __optname,
		       void *__restrict __optval,
		       socklen_t *__restrict __optlen) ;
#line 197
extern int setsockopt (int __fd, int __level, int __optname,
		       const void *__optval, socklen_t __optlen) ;
#line 204
extern int listen (int __fd, int __n) ;
#line 214
extern int accept (int __fd, struct sockaddr *__restrict __addr,
#line 232
extern int shutdown (int __fd, int __how) ;
#line 237
extern int sockatmark (int __fd) ;
#line 245
extern int isfdtype (int __fd, int __fdtype) ;
          Defined "HAVE_SYS_SOCKET_H" to "1"
Checking for header: sys/types.h
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.headers  /tmp/petsc-ITHdGX/config.headers/conftest.c
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 45
#line 49
#line 61
#line 66
#line 71
#line 76
#line 81
#line 87
#line 99
#line 105
#line 110
#line 116
#line 123
#line 76
#line 92
#line 104
#line 211 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include/stddef.h"
typedef unsigned long size_t;
#line 195
#line 201
#line 29
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
#line 55
#line 67
typedef struct
#line 75
#line 78
  } fd_set;
#line 85
#line 109
#line 121
__extension__
__extension__
__extension__
#line 236
#line 240
#line 244
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
          Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: malloc.h
stdout:
#line 149 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include/stddef.h"
typedef long int ptrdiff_t;
#line 211
#line 323
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 45 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdio.h"
struct _IO_FILE;
#line 49
typedef struct _IO_FILE FILE;
#line 65
typedef struct _IO_FILE __FILE;
#line 83 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/wchar.h"
typedef struct
  int __count;
  union
    unsigned int __wch;
#line 93
    char __wchb[4];
  } __value;
} __mbstate_t;
#line 22 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/_G_config.h"
typedef struct
  __off_t __pos;
  __mbstate_t __state;
} _G_fpos_t;
typedef struct
  __off64_t __pos;
} _G_fpos64_t;
#line 53
typedef int _G_int16_t __attribute__ ((__mode__ (__HI__)));
typedef int _G_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int _G_uint16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int _G_uint32_t __attribute__ ((__mode__ (__SI__)));
#line 70 "/soft/compilers/ibmcmp-may2013/vac/bg/12.1/include/stdarg.h"
typedef __builtin_va_list __gnuc_va_list;
#line 79
typedef __builtin_va_list va_list;
#line 170 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/libio.h"
struct _IO_jump_t;  struct _IO_FILE;
#line 180
typedef void _IO_lock_t;
#line 186
struct _IO_marker {
  struct _IO_marker *_next;
  struct _IO_FILE *_sbuf;
#line 192
  int _pos;
#line 203
#line 206
enum __codecvt_result
  __codecvt_ok,
  __codecvt_partial,
  __codecvt_error,
  __codecvt_noconv
#line 271
struct _IO_FILE {
  int _flags;
#line 277
  char* _IO_read_ptr;
  char* _IO_read_end;
  char* _IO_read_base;
  char* _IO_write_base;
  char* _IO_write_ptr;
  char* _IO_write_end;
  char* _IO_buf_base;
  char* _IO_buf_end;
  char *_IO_save_base;
  char *_IO_backup_base;
  char *_IO_save_end;
  struct _IO_marker *_markers;
  struct _IO_FILE *_chain;
  int _fileno;
#line 298
  int _flags2;
  __off_t _old_offset;
#line 304
  unsigned short _cur_column;
  signed char _vtable_offset;
  char _shortbuf[1];
#line 310
  _IO_lock_t *_lock;
#line 319
  __off64_t _offset;
#line 328
  void *__pad1;
  void *__pad2;
  void *__pad3;
  void *__pad4;
  size_t __pad5;
  int _mode;
  char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
#line 341
typedef struct _IO_FILE _IO_FILE;
#line 344
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
#line 364
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
#line 372
typedef __ssize_t __io_write_fn (void *__cookie, const char *__buf,
				 size_t __n);
#line 381
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
#line 384
typedef int __io_close_fn (void *__cookie);
#line 416
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
#line 460
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) ;
extern int _IO_ferror (_IO_FILE *__fp) ;
extern int _IO_peekc_locked (_IO_FILE *__fp);
#line 471
extern void _IO_flockfile (_IO_FILE *) ;
extern void _IO_funlockfile (_IO_FILE *) ;
extern int _IO_ftrylockfile (_IO_FILE *) ;
#line 490
extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
			__gnuc_va_list, int *__restrict);
extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
			 __gnuc_va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) ;
#line 91 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdio.h"
#line 103
#line 111
typedef _G_fpos_t fpos_t;
#line 165
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
#line 175
extern int remove (const char *__filename) ;
extern int rename (const char *__old, const char *__new) ;
#line 182
extern int renameat (int __oldfd, const char *__old, int __newfd,
#line 192
extern FILE *tmpfile (void) ;
#line 206
extern char *tmpnam (char *__s)  ;
#line 212
extern char *tmpnam_r (char *__s)  ;
#line 224
extern char *tempnam (const char *__dir, const char *__pfx)
#line 234
extern int fclose (FILE *__stream);
#line 239
extern int fflush (FILE *__stream);
#line 249
extern int fflush_unlocked (FILE *__stream);
#line 269
extern FILE *fopen (const char *__restrict __filename,
		    const char *__restrict __modes) ;
#line 275
extern FILE *freopen (const char *__restrict __filename,
		      const char *__restrict __modes,
		      FILE *__restrict __stream) ;
#line 303
extern FILE *fdopen (int __fd, const char *__modes)  ;
#line 316
extern FILE *fmemopen (void *__s, size_t __len, const char *__modes)
#line 322
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc)  ;
#line 329
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) ;
#line 333
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
		    int __modes, size_t __n) ;
#line 340
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
		       size_t __size) ;
#line 344
extern void setlinebuf (FILE *__stream) ;
#line 353
extern int fprintf (FILE *__restrict __stream,
		    const char *__restrict __format, ...);
#line 359
extern int printf (const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
		    const char *__restrict __format, ...) ;
#line 368
extern int vfprintf (FILE *__restrict __s, const char *__restrict __format,
		     __gnuc_va_list __arg);
#line 374
extern int vprintf (const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, const char *__restrict __format,
		     __gnuc_va_list __arg) ;
#line 383
extern int snprintf (char *__restrict __s, size_t __maxlen,
      __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
      __attribute__ ((__format__ (__printf__, 3, 0)));
#line 414
extern int vdprintf (int __fd, const char *__restrict __fmt,
     __attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, const char *__restrict __fmt, ...)
     __attribute__ ((__format__ (__printf__, 2, 3)));
#line 427
extern int fscanf (FILE *__restrict __stream,
#line 433
extern int scanf (const char *__restrict __format, ...) ;
extern int sscanf (const char *__restrict __s,
#line 445
extern int
fscanf (FILE *__restrict __stream, const char *__restrict __format, ...) _Pragma("map(fscanf, \"__isoc99_fscanf\")") ;
extern int
scanf (const char *__restrict __format, ...) _Pragma("map(scanf, \"__isoc99_scanf\")") ;
extern int
sscanf (const char *__restrict __s, const char *__restrict __format, ...)   _Pragma("map(sscanf, \"__isoc99_sscanf\")");
#line 473
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format,
     __attribute__ ((__format__ (__scanf__, 2, 0))) ;
#line 481
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg)
     __attribute__ ((__format__ (__scanf__, 1, 0))) ;
#line 485
extern int vsscanf (const char *__restrict __s,
      __attribute__ ((__format__ (__scanf__, 2, 0)));
#line 496
extern int
#line 499
vfscanf (FILE *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) _Pragma("map(vfscanf, \"__isoc99_vfscanf\")")
extern int
vscanf (const char *__restrict __format, __gnuc_va_list __arg) _Pragma("map(vscanf, \"__isoc99_vscanf\")")
extern int
#line 507
vsscanf (const char *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg)   _Pragma("map(vsscanf, \"__isoc99_vsscanf\")")
#line 533
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
#line 540
extern int getchar (void);
#line 552
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
#line 563
extern int fgetc_unlocked (FILE *__stream);
#line 575
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
#line 582
extern int putchar (int __c);
#line 596
extern int fputc_unlocked (int __c, FILE *__stream);
#line 604
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
#line 612
extern int getw (FILE *__stream);
#line 615
extern int putw (int __w, FILE *__stream);
#line 624
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
#line 632
extern char *gets (char *__s) ;
#line 658
extern __ssize_t __getdelim (char **__restrict __lineptr,
			       size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
#line 671
extern __ssize_t getline (char **__restrict __lineptr,
#line 682
extern int fputs (const char *__restrict __s, FILE *__restrict __stream);
#line 688
extern int puts (const char *__s);
#line 695
extern int ungetc (int __c, FILE *__stream);
#line 702
extern size_t fread (void *__restrict __ptr, size_t __size,
		     size_t __n, FILE *__restrict __stream) ;
#line 708
extern size_t fwrite (const void *__restrict __ptr, size_t __size,
		      size_t __n, FILE *__restrict __s) ;
#line 730
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (const void *__restrict __ptr, size_t __size,
#line 742
extern int fseek (FILE *__stream, long int __off, int __whence);
#line 747
extern long int ftell (FILE *__stream) ;
#line 752
extern void rewind (FILE *__stream);
#line 766
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
#line 771
extern __off_t ftello (FILE *__stream) ;
#line 791
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
#line 796
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
#line 819
extern void clearerr (FILE *__stream) ;
extern int feof (FILE *__stream)  ;
extern int ferror (FILE *__stream)  ;
#line 828
extern void clearerr_unlocked (FILE *__stream) ;
extern int feof_unlocked (FILE *__stream)  ;
extern int ferror_unlocked (FILE *__stream)  ;
#line 839
extern void perror (const char *__s);
#line 27 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sys_errlist.h"
extern int sys_nerr;
extern const char *const sys_errlist[];
#line 851 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdio.h"
extern int fileno (FILE *__stream)  ;
#line 856
extern int fileno_unlocked (FILE *__stream)  ;
#line 866
extern FILE *popen (const char *__command, const char *__modes) ;
#line 872
extern int pclose (FILE *__stream);
#line 878
extern char *ctermid (char *__s) ;
#line 906
extern void flockfile (FILE *__stream) ;
#line 910
extern int ftrylockfile (FILE *__stream)  ;
#line 913
extern void funlockfile (FILE *__stream) ;
#line 51 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/malloc.h"
#line 54
#line 62
#line 66
#line 69
#line 72
extern void *memalign (size_t __alignment, size_t __size)
#line 76
#line 81
extern void * pvalloc (size_t __size)
#line 86
extern void *(*__morecore) (ptrdiff_t __size);
#line 89
extern void *__default_morecore (ptrdiff_t __size)
       __attribute__ ((__malloc__));
#line 94
struct mallinfo {
  int arena;
  int ordblks;
  int smblks;
  int hblks;
  int hblkhd;
  int usmblks;
  int fsmblks;
  int uordblks;
  int fordblks;
  int keepcost;
#line 108
extern struct mallinfo mallinfo (void)  ;
#line 135
extern int mallopt (int __param, int __val)  ;
#line 139
extern int malloc_trim (size_t __pad)  ;
#line 143
extern size_t malloc_usable_size (void *__ptr)  ;
#line 146
extern void malloc_stats (void)  ;
#line 149
extern int malloc_info (int __options, FILE *__fp);
#line 152
extern void *malloc_get_state (void)  ;
#line 156
extern int malloc_set_state (void *__ptr)  ;
#line 161
extern void (*__malloc_initialize_hook) (void);
extern void (*__free_hook)
(void *__ptr, const void *);
extern void *(*__malloc_hook)
(size_t __size, const void *);
extern void *(*__realloc_hook)
(void *__ptr, size_t __size, const void *);
extern void *(*__memalign_hook)
(size_t __alignment, size_t __size, const void *);
extern void (*__after_morecore_hook) (void);
#line 175
extern void __malloc_check_init (void)  ;
          Defined "HAVE_MALLOC_H" to "1"
stdout:
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
#line 37
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
#line 53
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 134
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
#line 158
typedef int __clockid_t;
#line 161
typedef void * __timer_t;
#line 164
typedef long int __blksize_t;
#line 169
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
#line 173
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
#line 177
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
#line 184
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
#line 189
typedef long int __intptr_t;
#line 192
typedef unsigned int __socklen_t;
#line 60 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
typedef __clock_t clock_t;
#line 76
typedef __time_t time_t;
#line 92
typedef __clockid_t clockid_t;
#line 104
typedef __timer_t timer_t;
#line 120
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 133
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
#line 146
  long int tm_gmtoff;
#line 152
#line 161
struct itimerspec
#line 168
struct sigevent;
#line 174
typedef __pid_t pid_t;
#line 183
#line 186
#line 189
#line 193
#line 199
#line 28 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/xlocale.h"
typedef struct __locale_struct
  struct __locale_data *__locales[13];
#line 34
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
#line 39
  const char *__names[13];
} *__locale_t;
#line 43
typedef __locale_t locale_t;
			  __locale_t __loc) ;
#line 233
#line 237
#line 243
#line 248
#line 255
#line 258
#line 266
#line 270
#line 276
#line 283
#line 287
#line 291
#line 298
#line 313
#line 316
#line 319
#line 328
#line 333
#line 336
#line 339
#line 347
#line 352
#line 357
#line 362
#line 365
#line 370
#line 374
Checking for header: Direct.h
Possible ERROR while running preprocessor: exit code 256
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <Direct.h> not found.
Source:
#include <Direct.h>
Checking for header: Ws2tcpip.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <Ws2tcpip.h> not found.
Source:
#include <Ws2tcpip.h>
Checking for header: endian.h
          Defined "HAVE_ENDIAN_H" to "1"
Checking for header: ieeefp.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <ieeefp.h> not found.
Source:
#include <ieeefp.h>
Checking for header: strings.h
stdout:
#line 41 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/strings.h"
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
      __attribute__ ((__pure__));
#line 45
extern void bcopy (const void *__src, void *__dest, size_t __n) ;
#line 48
extern void bzero (void *__s, size_t __n) ;
#line 74
extern char *index (const char *__s, int __c)
      __attribute__ ((__pure__)) ;
#line 102
extern char *rindex (const char *__s, int __c)
#line 110
extern int ffs (int __i)  __attribute__ ((const));
#line 114
extern int strcasecmp (const char *__s1, const char *__s2)
#line 118
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
#line 34
#line 39
} *__locale_t;
#line 43
#line 129 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/strings.h"
extern int strcasecmp_l (const char *__s1, const char *__s2,
			 __locale_t __loc)
extern int strncasecmp_l (const char *__s1, const char *__s2,
			  size_t __n, __locale_t __loc)
          Defined "HAVE_STRINGS_H" to "1"
Checking for header: sched.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 120
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 37 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sched.h"
#line 74 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sched.h"
struct sched_param
    int __sched_priority;
#line 83
extern int clone (int (*__fn) (void *__arg), void *__child_stack,
		  int __flags, void *__arg, ...) ;
#line 87
extern int unshare (int __flags) ;
#line 90
extern int sched_getcpu (void) ;
#line 101
struct __sched_param
#line 116
typedef unsigned long int __cpu_mask;
#line 123
typedef struct
  __cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
#line 201
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
extern cpu_set_t *__sched_cpualloc (size_t __count)  ;
extern void __sched_cpufree (cpu_set_t *__set) ;
#line 51 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sched.h"
extern int sched_setparam (__pid_t __pid, const struct sched_param *__param)
#line 55
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) ;
#line 58
extern int sched_setscheduler (__pid_t __pid, int __policy,
			       const struct sched_param *__param) ;
#line 62
extern int sched_getscheduler (__pid_t __pid) ;
#line 65
extern int sched_yield (void) ;
#line 68
extern int sched_get_priority_max (int __algorithm) ;
#line 71
extern int sched_get_priority_min (int __algorithm) ;
#line 74
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) ;
          Defined "HAVE_SCHED_H" to "1"
Checking for header: cxxabi.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <cxxabi.h> not found.
Source:
#include <cxxabi.h>
Checking for header: sys/systeminfo.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <sys/systeminfo.h> not found.
Source:
#include <sys/systeminfo.h>
Checking for header: dos.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <dos.h> not found.
Source:
#include <dos.h>
Checking for header: WindowsX.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <WindowsX.h> not found.
Source:
#include <WindowsX.h>
Checking for header: sys/sysinfo.h
stdout:
#line 11 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/kernel.h"
struct sysinfo {
	long uptime;
	unsigned long loads[3];
	unsigned long totalram;
	unsigned long freeram;
	unsigned long sharedram;
	unsigned long bufferram;
	unsigned long totalswap;
	unsigned long freeswap;
	unsigned short procs;
	unsigned short pad;
	unsigned long totalhigh;
	unsigned long freehigh;
	unsigned int mem_unit;
	char _f[20-2*sizeof(long)-sizeof(int)];
#line 60
struct module;
void mark_hardware_unsupported(const char *msg);
void mark_tech_preview(const char *msg, struct module *mod);
#line 30 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/sysinfo.h"
extern int sysinfo (struct sysinfo *__info) ;
#line 34
extern int get_nprocs_conf (void) ;
#line 37
extern int get_nprocs (void) ;
#line 41
extern long int get_phys_pages (void) ;
#line 44
extern long int get_avphys_pages (void) ;
stdout:
struct sysinfo {
	long uptime;
	unsigned short pad;
#line 60
struct module;
#line 34
#line 37
#line 41
#line 44
extern long int get_avphys_pages (void) ;stderr:
"/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/kernel.h", line 46.9: 1506-312 (W) Compiler internal name __FUNCTION__ has been defined as a macro.
"/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/kernel.h", line 46.9: 1506-236 (W) Macro name __FUNCTION__ has been redefined.
Source:
#include <sys/sysinfo.h>
Checking for header: sys/wait.h
stdout:
#line 24 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigset.h"
typedef int __sig_atomic_t;
#line 29
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
#line 104
extern int __sigismember (const __sigset_t *, int);
extern int __sigaddset (__sigset_t *, int);
extern int __sigdelset (__sigset_t *, int);
#line 41 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
typedef __sig_atomic_t sig_atomic_t;
#line 50
typedef __sigset_t sigset_t;
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 62 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
#line 68
typedef __uid_t uid_t;
#line 120 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 33 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/siginfo.h"
typedef union sigval
    int sival_int;
    void *sival_ptr;
  } sigval_t;
#line 51
typedef struct siginfo
    int si_signo;
    int si_errno;
    int si_code;
    union
	int _pad[((128 / sizeof (int)) - 4)];
#line 63
	struct
	    __pid_t si_pid;
	    __uid_t si_uid;
	  } _kill;
#line 70
	struct
	    int si_tid;
	    int si_overrun;
	    sigval_t si_sigval;
	  } _timer;
#line 78
	struct
	    __pid_t si_pid;
	    __uid_t si_uid;
	    sigval_t si_sigval;
	  } _rt;
#line 86
	struct
	    __pid_t si_pid;
	    __uid_t si_uid;
	    int si_status;
	    __clock_t si_utime;
	    __clock_t si_stime;
	  } _sigchld;
#line 96
	struct
	    void *si_addr;
	  } _sigfault;
#line 102
	struct
	    long int si_band;
	    int si_fd;
	  } _sigpoll;
      } _sifields;
  } siginfo_t;
#line 129
enum
  SI_ASYNCNL = -60,
  SI_TKILL = -6,
  SI_SIGIO,
  SI_ASYNCIO,
  SI_MESGQ,
  SI_TIMER,
  SI_QUEUE,
  SI_USER,
  SI_KERNEL = 0x80
#line 153
enum
  ILL_ILLOPC = 1,
  ILL_ILLOPN,
  ILL_ILLADR,
  ILL_ILLTRP,
  ILL_PRVOPC,
  ILL_PRVREG,
  ILL_COPROC,
  ILL_BADSTK
#line 174
enum
  FPE_INTDIV = 1,
  FPE_INTOVF,
  FPE_FLTDIV,
  FPE_FLTOVF,
  FPE_FLTUND,
  FPE_FLTRES,
  FPE_FLTINV,
  FPE_FLTSUB
#line 195
enum
  SEGV_MAPERR = 1,
  SEGV_ACCERR
#line 204
enum
  BUS_ADRALN = 1,
  BUS_ADRERR,
  BUS_OBJERR
#line 215
enum
  TRAP_BRKPT = 1,
  TRAP_TRACE
#line 224
enum
  CLD_EXITED = 1,
  CLD_KILLED,
  CLD_DUMPED,
  CLD_TRAPPED,
  CLD_STOPPED,
  CLD_CONTINUED
#line 241
enum
  POLL_IN = 1,
  POLL_OUT,
  POLL_MSG,
  POLL_ERR,
  POLL_PRI,
  POLL_HUP
#line 273
typedef struct sigevent
    sigval_t sigev_value;
    int sigev_signo;
    int sigev_notify;
    union
	int _pad[((64 / sizeof (int)) - 4)];
#line 285
	__pid_t _tid;
	struct
	    void (*_function) (sigval_t);
	    void *_attribute;
	  } _sigev_thread;
      } _sigev_un;
  } sigevent_t;
#line 300
enum
  SIGEV_SIGNAL = 0,
  SIGEV_NONE,
  SIGEV_THREAD,
#line 309
  SIGEV_THREAD_ID = 4
#line 84 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
typedef void (*__sighandler_t) (int);
#line 89
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
#line 101
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
#line 126
extern int kill (__pid_t __pid, int __sig) ;
#line 133
extern int killpg (__pid_t __pgrp, int __sig) ;
#line 138
extern int raise (int __sig) ;
#line 143
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) ;
#line 150
extern void psignal (int __sig, const char *__s);
#line 155
extern void psiginfo (const siginfo_t *__pinfo, const char *__s);
#line 168
extern int __sigpause (int __sig_or_mask, int __is_sig);
#line 196
extern int sigblock (int __mask)  __attribute__ ((__deprecated__));
#line 199
extern int sigsetmask (int __mask)  __attribute__ ((__deprecated__));
#line 202
extern int siggetmask (void)  __attribute__ ((__deprecated__));
#line 216
typedef __sighandler_t sig_t;
#line 222
extern int sigemptyset (sigset_t *__set)  ;
#line 225
extern int sigfillset (sigset_t *__set)  ;
#line 228
extern int sigaddset (sigset_t *__set, int __signo)  ;
#line 231
extern int sigdelset (sigset_t *__set, int __signo)  ;
#line 234
extern int sigismember (const sigset_t *__set, int __signo)
#line 25 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigaction.h"
struct sigaction
#line 29
    union
	__sighandler_t sa_handler;
	void (*sa_sigaction) (int, siginfo_t *, void *);
    __sigaction_handler;
#line 44
    __sigset_t sa_mask;
#line 47
    int sa_flags;
#line 50
    void (*sa_restorer) (void);
#line 255 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int sigprocmask (int __how, const sigset_t *__restrict __set,
			sigset_t *__restrict __oset) ;
#line 263
extern int sigsuspend (const sigset_t *__set) ;
#line 266
extern int sigaction (int __sig, const struct sigaction *__restrict __act,
		      struct sigaction *__restrict __oact) ;
#line 270
extern int sigpending (sigset_t *__set)  ;
#line 277
extern int sigwait (const sigset_t *__restrict __set, int *__restrict __sig)
#line 285
extern int sigwaitinfo (const sigset_t *__restrict __set,
			siginfo_t *__restrict __info) ;
#line 293
extern int sigtimedwait (const sigset_t *__restrict __set,
			 siginfo_t *__restrict __info,
			 const struct timespec *__restrict __timeout)
#line 300
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
#line 310
extern const char *const _sys_siglist[65];
extern const char *const sys_siglist[65];
#line 314
struct sigvec
    __sighandler_t sv_handler;
    int sv_mask;
    int sv_flags;
#line 334
extern int sigvec (int __sig, const struct sigvec *__vec,
		   struct sigvec *__ovec) ;
#line 29 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/ptrace.h"
struct pt_regs {
	unsigned long gpr[32];
	unsigned long nip;
	unsigned long msr;
	unsigned long orig_gpr3;
	unsigned long ctr;
	unsigned long link;
	unsigned long xer;
	unsigned long ccr;
	unsigned long softe;
#line 44
	unsigned long trap;
#line 47
	unsigned long dar;
	unsigned long dsisr;
	unsigned long result;
#line 19 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm-generic/int-l64.h"
typedef signed char __s8;
typedef unsigned char __u8;
typedef signed short __s16;
typedef unsigned short __u16;
typedef signed int __s32;
typedef unsigned int __u32;
typedef signed long __s64;
typedef unsigned long __u64;
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/types.h"
typedef unsigned int umode_t;
#line 36
typedef struct {
	__u32 u[4];
} __attribute__((aligned(16))) __vector128;
#line 36 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/posix_types.h"
typedef struct {
	unsigned long fds_bits [(1024/(8 * sizeof(unsigned long)))];
} __kernel_fd_set;
#line 41
typedef void (*__kernel_sighandler_t)(int);
#line 44
typedef int __kernel_key_t;
typedef int __kernel_mqd_t;
#line 10 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/posix_types.h"
typedef unsigned long	__kernel_ino_t;
typedef unsigned int	__kernel_mode_t;
typedef long		__kernel_off_t;
typedef int		__kernel_pid_t;
typedef unsigned int	__kernel_uid_t;
typedef unsigned int	__kernel_gid_t;
typedef long		__kernel_ptrdiff_t;
typedef long		__kernel_time_t;
typedef long		__kernel_clock_t;
typedef int		__kernel_timer_t;
typedef int		__kernel_clockid_t;
typedef long		__kernel_suseconds_t;
typedef int		__kernel_daddr_t;
typedef char *		__kernel_caddr_t;
typedef unsigned short	__kernel_uid16_t;
typedef unsigned short	__kernel_gid16_t;
typedef unsigned int	__kernel_uid32_t;
typedef unsigned int	__kernel_gid32_t;
typedef unsigned int	__kernel_old_uid_t;
typedef unsigned int	__kernel_old_gid_t;
#line 32
typedef unsigned long  	__kernel_nlink_t;
typedef int             __kernel_ipc_pid_t;
typedef unsigned long	__kernel_size_t;
typedef long		__kernel_ssize_t;
typedef unsigned long	__kernel_old_dev_t;
#line 46
typedef long long	__kernel_loff_t;
#line 53
typedef struct {
	int	val[2];
} __kernel_fsid_t;
#line 27 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/types.h"
typedef __u16  __le16;
typedef __u16  __be16;
typedef __u32  __le32;
typedef __u32  __be32;
typedef __u64  __le64;
typedef __u64  __be64;
typedef __u16  __sum16;
typedef __u32  __wsum;
#line 95 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/elf.h"
typedef unsigned long elf_greg_t64;
typedef elf_greg_t64 elf_gregset_t64[48];
typedef unsigned int elf_greg_t32;
typedef elf_greg_t32 elf_gregset_t32[48];
typedef elf_gregset_t32 compat_elf_gregset_t;
#line 123
  typedef elf_greg_t64 elf_greg_t;
  typedef elf_gregset_t64 elf_gregset_t;
#line 132
typedef double elf_fpreg_t;
typedef elf_fpreg_t elf_fpregset_t[33];
#line 154
typedef __vector128 elf_vrreg_t;
typedef elf_vrreg_t elf_vrregset_t[34];
typedef elf_vrreg_t elf_vrregset_t32[33];
typedef elf_fpreg_t elf_vsrreghalf_t32[32];
#line 300
struct ppc64_opd_entry
	unsigned long funcaddr;
	unsigned long r2;
#line 16 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/sigcontext.h"
struct sigcontext {
	unsigned long	_unused[4];
	int		signal;
	int		_pad0;
	unsigned long	handler;
	unsigned long	oldmask;
	struct pt_regs	*regs;
	elf_gregset_t	gp_regs;
	elf_fpregset_t	fp_regs;
#line 82
	elf_vrreg_t	*v_regs;
	long		vmx_reserve[34+34+32+1];
#line 342 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int sigreturn (struct sigcontext *__scp) ;
#line 354 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int siginterrupt (int __sig, int __interrupt) ;
#line 26 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigstack.h"
struct sigstack
    void *ss_sp;
    int ss_onstack;
#line 34
enum
  SS_ONSTACK = 1,
  SS_DISABLE
#line 50
typedef struct sigaltstack
    void *ss_sp;
    int ss_flags;
    size_t ss_size;
  } stack_t;
#line 78 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/ucontext.h"
typedef unsigned long gregset_t[48];
typedef double fpregset_t[33];
#line 84
typedef struct _libc_vscr
	unsigned int __pad[3];
	unsigned int vscr_word;
} vscr_t;
#line 92
typedef struct _libc_vrstate
	unsigned int	vrregs[32][4];
	vscr_t		vscr;
	unsigned int	vrsave;
} vrregset_t  __attribute__((__aligned__(16)));
typedef struct {
	unsigned long	__unused[4];
	int		signal;
	int		__pad0;
	gregset_t	gp_regs;
	fpregset_t	fp_regs;
#line 128
	vrregset_t	*v_regs;
#line 132
} mcontext_t;
#line 138
typedef struct ucontext
    unsigned long int uc_flags;
    struct ucontext *uc_link;
    stack_t uc_stack;
#line 175
    sigset_t    uc_sigmask;
    mcontext_t  uc_mcontext;
  } ucontext_t;
#line 365 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
#line 370
extern int sigaltstack (const struct sigaltstack *__restrict __ss,
			struct sigaltstack *__restrict __oss) ;
#line 51 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
#line 54
typedef union
  char __size[56];
  long int __align__workaround;
} pthread_attr_t;
#line 62
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 77
typedef union
  struct __pthread_mutex_s
    volatile int __lock;
    volatile unsigned int __count;
    volatile int __owner;
    unsigned int __nusers;
#line 89
    int __kind;
    int __spins;
    __pthread_list_t __list;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
} pthread_mutexattr_t;
#line 116
typedef union
  struct
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align__workaround;
} pthread_cond_t;
typedef union
  char __size[4];
} pthread_condattr_t;
#line 141
typedef unsigned int pthread_key_t;
#line 145
typedef int pthread_once_t;
#line 151
typedef union
  struct
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
#line 168
    unsigned int __flags;
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
} pthread_rwlockattr_t;
#line 202
typedef volatile int pthread_spinlock_t;
#line 207
typedef union
  char __size[32];
} pthread_barrier_t;
typedef union
  char __size[4];
} pthread_barrierattr_t;
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigthread.h"
extern int pthread_sigmask (int __how,
			    const __sigset_t *__restrict __newmask,
			    __sigset_t *__restrict __oldmask);
#line 36
extern int pthread_kill (pthread_t __threadid, int __signo) ;
#line 402 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int __libc_current_sigrtmin (void) ;
extern int __libc_current_sigrtmax (void) ;
#line 33 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/resource.h"
enum __rlimit_resource
  RLIMIT_CPU = 0,
#line 40
  RLIMIT_FSIZE = 1,
#line 44
  RLIMIT_DATA = 2,
#line 48
  RLIMIT_STACK = 3,
#line 52
  RLIMIT_CORE = 4,
#line 59
  __RLIMIT_RSS = 5,
#line 63
  RLIMIT_NOFILE = 7,
  __RLIMIT_OFILE = RLIMIT_NOFILE,
#line 69
  RLIMIT_AS = 9,
#line 73
  __RLIMIT_NPROC = 6,
#line 77
  __RLIMIT_MEMLOCK = 8,
#line 81
  __RLIMIT_LOCKS = 10,
#line 85
  __RLIMIT_SIGPENDING = 11,
#line 89
  __RLIMIT_MSGQUEUE = 12,
#line 95
  __RLIMIT_NICE = 13,
#line 100
  __RLIMIT_RTPRIO = 14,
#line 103
  __RLIMIT_NLIMITS = 15,
  __RLIM_NLIMITS = __RLIMIT_NLIMITS
#line 107
#line 127
typedef __rlim_t rlim_t;
#line 135
struct rlimit
    rlim_t rlim_cur;
    rlim_t rlim_max;
#line 154
enum __rusage_who
  RUSAGE_SELF = 0,
#line 161
  RUSAGE_CHILDREN = -1
#line 172
#line 75 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/time.h"
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
#line 178 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/resource.h"
struct rusage
    struct timeval ru_utime;
    struct timeval ru_stime;
    long int ru_maxrss;
#line 188
    long int ru_ixrss;
    long int ru_idrss;
    long int ru_isrss;
#line 195
    long int ru_minflt;
    long int ru_majflt;
    long int ru_nswap;
#line 202
    long int ru_inblock;
    long int ru_oublock;
    long int ru_msgsnd;
    long int ru_msgrcv;
    long int ru_nsignals;
#line 214
    long int ru_nvcsw;
#line 217
    long int ru_nivcsw;
#line 226
enum __priority_which
  PRIO_PROCESS = 0,
  PRIO_PGRP = 1,
  PRIO_USER = 2
#line 28 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/resource.h"
typedef __id_t id_t;
#line 43
typedef int __rlimit_resource_t;
typedef int __rusage_who_t;
typedef int __priority_which_t;
#line 51
extern int getrlimit (__rlimit_resource_t __resource,
		      struct rlimit *__rlimits) ;
#line 70
extern int setrlimit (__rlimit_resource_t __resource,
		      const struct rlimit *__rlimits) ;
#line 88
extern int getrusage (__rusage_who_t __who, struct rusage *__usage) ;
#line 94
extern int getpriority (__priority_which_t __which, id_t __who) ;
#line 98
extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
#line 63 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/wait.h"
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
#line 67 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/waitstatus.h"
union wait
    int w_status;
    struct
#line 79
	unsigned int:16;
	unsigned int __w_retcode:8;
	unsigned int __w_coredump:1;
	unsigned int __w_termsig:7;
      } __wait_terminated;
    struct
#line 93
	unsigned int:16;
	unsigned int __w_stopsig:8;
	unsigned int __w_stopval:8;
      } __wait_stopped;
#line 102 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/wait.h"
typedef enum
  P_ALL,
  P_PID,
  P_PGID
} idtype_t;
#line 116
extern __pid_t wait (__WAIT_STATUS __stat_loc);
#line 139
extern __pid_t waitpid (__pid_t __pid, int *__stat_loc, int __options);
#line 155
extern int waitid (idtype_t __idtype, __id_t __id, siginfo_t *__infop,
		   int __options);
#line 162
struct rusage;
#line 169
extern __pid_t wait3 (__WAIT_STATUS __stat_loc, int __options,
		      struct rusage * __usage) ;
#line 175
extern __pid_t wait4 (__pid_t __pid, __WAIT_STATUS __stat_loc, int __options,
          Defined "HAVE_SYS_WAIT_H" to "1"
Checking for header: stdlib.h
stdout:
#line 323
typedef int wchar_t;
union wait
    int w_status;
    struct
#line 79
	unsigned int:16;
    struct
#line 93
	unsigned int:16;
      } __wait_stopped;
#line 68 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
typedef union
    union wait *__uptr;
    int *__iptr;
#line 98
typedef struct
    int quot;
    int rem;
  } div_t;
#line 106
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
#line 118
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
#line 140
extern size_t __ctype_get_mb_cur_max (void)  ;
#line 145
extern double atof (const char *__nptr)
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
#line 158
__extension__ extern long long int atoll (const char *__nptr)
#line 165
extern double strtod (const char *__restrict __nptr,
		      char **__restrict __endptr)
#line 173
extern float strtof (const char *__restrict __nptr,
		     char **__restrict __endptr)   ;
extern long double strtold (const char *__restrict __nptr,
#line 184
extern long int strtol (const char *__restrict __nptr,
			char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
#line 195
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
#line 209
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
#line 311
extern char *l64a (long int __n)  ;
#line 314
extern long int a64l (const char *__s)
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 34 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
#line 45
typedef __loff_t loff_t;
#line 49
typedef __ino_t ino_t;
#line 61
typedef __dev_t dev_t;
#line 66
typedef __gid_t gid_t;
#line 71
typedef __mode_t mode_t;
#line 76
typedef __nlink_t nlink_t;
#line 81
#line 87
typedef __off_t off_t;
#line 99
#line 105
#line 110
typedef __ssize_t ssize_t;
#line 116
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
#line 123
typedef __key_t key_t;
#line 76
#line 92
#line 104
#line 151 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
#line 195
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
#line 201
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
#line 29
typedef struct
  } __sigset_t;
#line 38 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
#line 49 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
typedef __suseconds_t suseconds_t;
#line 55
typedef long int __fd_mask;
#line 67
typedef struct
#line 75
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
#line 78
  } fd_set;
#line 85
typedef __fd_mask fd_mask;
#line 109
extern int select (int __nfds, fd_set *__restrict __readfds,
		   fd_set *__restrict __writefds,
		   fd_set *__restrict __exceptfds,
		   struct timeval *__restrict __timeout);
#line 121
extern int pselect (int __nfds, fd_set *__restrict __readfds,
		    const struct timespec *__restrict __timeout,
		    const __sigset_t *__restrict __sigmask);
#line 30 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/sysmacros.h"
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
					       unsigned int __minor)
#line 229 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __blksize_t blksize_t;
#line 236
typedef __blkcnt_t blkcnt_t;
#line 240
typedef __fsblkcnt_t fsblkcnt_t;
#line 244
typedef __fsfilcnt_t fsfilcnt_t;
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
#line 327 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
extern long int random (void) ;
#line 330
extern void srandom (unsigned int __seed) ;
#line 336
extern char *initstate (unsigned int __seed, char *__statebuf,
			size_t __statelen)  ;
#line 341
extern char *setstate (char *__statebuf)  ;
#line 349
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
		     int32_t *__restrict __result)  ;
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
			size_t __statelen,
			struct random_data *__restrict __buf)
extern int setstate_r (char *__restrict __statebuf,
#line 380
extern int rand (void) ;
extern void srand (unsigned int __seed) ;
#line 387
extern int rand_r (unsigned int *__seed) ;
#line 395
extern double drand48 (void) ;
extern double erand48 (unsigned short int __xsubi[3])  ;
#line 399
extern long int lrand48 (void) ;
extern long int nrand48 (unsigned short int __xsubi[3])
#line 404
extern long int mrand48 (void) ;
extern long int jrand48 (unsigned short int __xsubi[3])
#line 409
extern void srand48 (long int __seedval) ;
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7])  ;
#line 418
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    unsigned long long int __a;
#line 428
extern int drand48_r (struct drand48_data *__restrict __buffer,
		      double *__restrict __result)  ;
extern int erand48_r (unsigned short int __xsubi[3],
#line 435
extern int lrand48_r (struct drand48_data *__restrict __buffer,
		      long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
#line 444
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
#line 453
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
		     struct drand48_data *__buffer)  ;
extern int lcong48_r (unsigned short int __param[7],
#line 471
extern void *malloc (size_t __size)  __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
#line 485
extern void *realloc (void *__ptr, size_t __size)
      __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) ;
#line 493
extern void cfree (void *__ptr) ;
#line 33 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/alloca.h"
extern void *alloca (size_t __size) ;
#line 503 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdlib.h"
extern void *valloc (size_t __size)  __attribute__ ((__malloc__)) ;
#line 508
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
#line 514
extern void abort (void)  __attribute__ ((__noreturn__));
#line 518
extern int atexit (void (*__func) (void))  ;
#line 536
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
#line 544
extern void exit (int __status)  __attribute__ ((__noreturn__));
#line 560
extern void _Exit (int __status)  __attribute__ ((__noreturn__));
#line 567
extern char *getenv (const char *__name)   ;
#line 572
extern char *__secure_getenv (const char *__name)
#line 579
extern int putenv (char *__string)  ;
#line 585
extern int setenv (const char *__name, const char *__value, int __replace)
#line 589
extern int unsetenv (const char *__name)  ;
#line 596
extern int clearenv (void) ;
#line 606
extern char *mktemp (char *__template)   ;
#line 620
extern int mkstemp (char *__template)  ;
#line 642
extern int mkstemps (char *__template, int __suffixlen)  ;
#line 663
extern char *mkdtemp (char *__template)   ;
#line 717
extern int system (const char *__command) ;
#line 734
extern char *realpath (const char *__restrict __name,
		       char *__restrict __resolved)  ;
#line 742
typedef int (*__compar_fn_t) (const void *, const void *);
#line 755
extern void *bsearch (const void *__key, const void *__base,
		      size_t __nmemb, size_t __size, __compar_fn_t __compar)
#line 761
extern void qsort (void *__base, size_t __nmemb, size_t __size,
		   __compar_fn_t __compar) ;
#line 771
extern int abs (int __x)  __attribute__ ((const)) ;
extern long int labs (long int __x)  __attribute__ ((const)) ;
#line 776
__extension__ extern long long int llabs (long long int __x)
#line 785
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
#line 793
__extension__ extern lldiv_t lldiv (long long int __numer,
				    long long int __denom)
#line 808
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
		   int *__restrict __sign)   ;
#line 814
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
#line 820
extern char *gcvt (double __value, int __ndigit, char *__buf)
#line 826
extern char *qecvt (long double __value, int __ndigit,
		    int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
#line 838
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
		   int *__restrict __sign, char *__restrict __buf,
		   size_t __len)  ;
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
		   size_t __len)  ;
extern int qecvt_r (long double __value, int __ndigit,
		    int *__restrict __decpt, int *__restrict __sign,
		    char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
#line 860
extern int mblen (const char *__s, size_t __n)  ;
#line 863
extern int mbtowc (wchar_t *__restrict __pwc,
		   const char *__restrict __s, size_t __n)  ;
#line 867
extern int wctomb (char *__s, wchar_t __wchar)  ;
#line 871
extern size_t mbstowcs (wchar_t *__restrict  __pwcs,
extern size_t wcstombs (char *__restrict __s,
			const wchar_t *__restrict __pwcs, size_t __n)
#line 885
extern int rpmatch (const char *__response)   ;
#line 896
extern int getsubopt (char **__restrict __optionp,
		      char *const *__restrict __tokens,
		      char **__restrict __valuep)
#line 948
extern int getloadavg (double __loadavg[], int __nelem)
          Defined "HAVE_STDLIB_H" to "1"
Checking for header: pthread.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 76 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
#line 120
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct sched_param
#line 83
#line 87
#line 90
#line 101
#line 116
#line 123
typedef struct
} cpu_set_t;
#line 201
#line 55
#line 58
#line 62
#line 65
#line 68
#line 71
#line 74
#line 92
#line 104
#line 133
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
#line 146
  long int tm_gmtoff;
  const char *tm_zone;
#line 152
#line 161
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
#line 168
struct sigevent;
#line 183
extern clock_t clock (void) ;
#line 186
extern time_t time (time_t *__timer) ;
#line 189
extern double difftime (time_t __time1, time_t __time0)
#line 193
extern time_t mktime (struct tm *__tp) ;
#line 199
extern size_t strftime (char *__restrict __s, size_t __maxsize,
			const struct tm *__restrict __tp) ;
#line 34
#line 39
} *__locale_t;
#line 43
#line 217 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
			  const struct tm *__restrict __tp,
			  __locale_t __loc) ;
#line 233
extern struct tm *gmtime (const time_t *__timer) ;
#line 237
extern struct tm *localtime (const time_t *__timer) ;
#line 243
extern struct tm *gmtime_r (const time_t *__restrict __timer,
#line 248
extern struct tm *localtime_r (const time_t *__restrict __timer,
#line 255
extern char *asctime (const struct tm *__tp) ;
#line 258
extern char *ctime (const time_t *__timer) ;
#line 266
extern char *asctime_r (const struct tm *__restrict __tp,
#line 270
extern char *ctime_r (const time_t *__restrict __timer,
#line 276
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
#line 283
extern char *tzname[2];
#line 287
extern void tzset (void) ;
#line 291
extern int daylight;
extern long int timezone;
#line 298
extern int stime (const time_t *__when) ;
#line 313
extern time_t timegm (struct tm *__tp) ;
#line 316
extern time_t timelocal (struct tm *__tp) ;
#line 319
extern int dysize (int __year)   __attribute__ ((const));
#line 328
extern int nanosleep (const struct timespec *__requested_time,
		      struct timespec *__remaining);
#line 333
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) ;
#line 336
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) ;
#line 339
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
#line 347
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
			    const struct timespec *__req,
			    struct timespec *__rem);
#line 352
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) ;
#line 357
extern int timer_create (clockid_t __clock_id,
			 struct sigevent *__restrict __evp,
			 timer_t *__restrict __timerid) ;
#line 362
extern int timer_delete (timer_t __timerid) ;
#line 365
extern int timer_settime (timer_t __timerid, int __flags,
			  const struct itimerspec *__restrict __value,
			  struct itimerspec *__restrict __ovalue) ;
#line 370
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
#line 374
extern int timer_getoverrun (timer_t __timerid) ;
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
#line 44 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/setjmp.h"
typedef long int __jmp_buf[64] __attribute__ ((__aligned__ (16)));
#line 34 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/pthread.h"
enum
  PTHREAD_CREATE_JOINABLE,
  PTHREAD_CREATE_DETACHED
#line 44
enum
  PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_ADAPTIVE_NP
  PTHREAD_MUTEX_NORMAL = PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE = PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK = PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_DEFAULT = PTHREAD_MUTEX_NORMAL
#line 61
#line 66
enum
  PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_STALLED_NP = PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_ROBUST,
  PTHREAD_MUTEX_ROBUST_NP = PTHREAD_MUTEX_ROBUST
#line 115
enum
  PTHREAD_RWLOCK_PREFER_READER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
  PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
#line 147
enum
  PTHREAD_INHERIT_SCHED,
  PTHREAD_EXPLICIT_SCHED
#line 157
enum
  PTHREAD_SCOPE_SYSTEM,
  PTHREAD_SCOPE_PROCESS
#line 167
enum
  PTHREAD_PROCESS_PRIVATE,
  PTHREAD_PROCESS_SHARED
#line 182
struct _pthread_cleanup_buffer
  void (*__routine) (void *);
  void *__arg;
  int __canceltype;
  struct _pthread_cleanup_buffer *__prev;
#line 191
enum
  PTHREAD_CANCEL_ENABLE,
  PTHREAD_CANCEL_DISABLE
enum
  PTHREAD_CANCEL_DEFERRED,
  PTHREAD_CANCEL_ASYNCHRONOUS
#line 225
extern int pthread_create (pthread_t *__restrict __newthread,
			   const pthread_attr_t *__restrict __attr,
			   void *(*__start_routine) (void *),
			   void *__restrict __arg)  ;
#line 234
extern void pthread_exit (void *__retval) __attribute__ ((__noreturn__));
#line 242
extern int pthread_join (pthread_t __th, void **__thread_return);
#line 263
extern int pthread_detach (pthread_t __th) ;
#line 267
extern pthread_t pthread_self (void)  __attribute__ ((const));
#line 270
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2) ;
#line 278
extern int pthread_attr_init (pthread_attr_t *__attr)  ;
#line 281
extern int pthread_attr_destroy (pthread_attr_t *__attr)
#line 285
extern int pthread_attr_getdetachstate (const pthread_attr_t *__attr,
					int *__detachstate)
#line 290
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
					int __detachstate)
#line 296
extern int pthread_attr_getguardsize (const pthread_attr_t *__attr,
				      size_t *__guardsize)
#line 301
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
				      size_t __guardsize)
#line 307
extern int pthread_attr_getschedparam (const pthread_attr_t *__restrict
				       __attr,
				       struct sched_param *__restrict __param)
#line 313
extern int pthread_attr_setschedparam (pthread_attr_t *__restrict __attr,
				       const struct sched_param *__restrict
				       __param)  ;
#line 318
extern int pthread_attr_getschedpolicy (const pthread_attr_t *__restrict
					__attr, int *__restrict __policy)
#line 323
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
#line 327
extern int pthread_attr_getinheritsched (const pthread_attr_t *__restrict
					 __attr, int *__restrict __inherit)
#line 332
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
					 int __inherit)
#line 338
extern int pthread_attr_getscope (const pthread_attr_t *__restrict __attr,
				  int *__restrict __scope)
#line 343
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
#line 347
extern int pthread_attr_getstackaddr (const pthread_attr_t *__restrict
				      __attr, void **__restrict __stackaddr)
#line 355
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
				      void *__stackaddr)
#line 360
extern int pthread_attr_getstacksize (const pthread_attr_t *__restrict
				      __attr, size_t *__restrict __stacksize)
#line 367
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
				      size_t __stacksize)
#line 373
extern int pthread_attr_getstack (const pthread_attr_t *__restrict __attr,
				  void **__restrict __stackaddr,
#line 381
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
				  size_t __stacksize)  ;
#line 413
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
#line 418
extern int pthread_getschedparam (pthread_t __target_thread,
				  int *__restrict __policy,
#line 424
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
#line 478
extern int pthread_once (pthread_once_t *__once_control,
			 void (*__init_routine) (void)) ;
#line 490
extern int pthread_setcancelstate (int __state, int *__oldstate);
#line 494
extern int pthread_setcanceltype (int __type, int *__oldtype);
#line 497
extern int pthread_cancel (pthread_t __th);
#line 502
extern void pthread_testcancel (void);
#line 507
typedef struct
  struct
    __jmp_buf __cancel_jmp_buf;
    int __mask_was_saved;
  } __cancel_jmp_buf[1];
  void *__pad[4];
} __pthread_unwind_buf_t __attribute__ ((__aligned__));
#line 524
struct __pthread_cleanup_frame
  void (*__cancel_routine) (void *);
  void *__cancel_arg;
  int __do_it;
  int __cancel_type;
#line 664
extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
#line 676
extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
#line 717
extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
     __attribute__ ((__weak__))
#line 726
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) ;
#line 733
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
			       const pthread_mutexattr_t *__mutexattr)
#line 738
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
#line 742
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
#line 746
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
#line 751
extern int pthread_mutex_timedlock (pthread_mutex_t *__restrict __mutex,
				    __abstime)  ;
#line 757
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
#line 762
extern int pthread_mutex_getprioceiling (const pthread_mutex_t *
					 __restrict __mutex,
					 int *__restrict __prioceiling)
#line 769
extern int pthread_mutex_setprioceiling (pthread_mutex_t *__restrict __mutex,
					 int __prioceiling,
					 int *__restrict __old_ceiling)
#line 777
extern int pthread_mutex_consistent (pthread_mutex_t *__mutex)
#line 790
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
#line 794
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
#line 798
extern int pthread_mutexattr_getpshared (const pthread_mutexattr_t *
					 __restrict __attr,
					 int *__restrict __pshared)
#line 804
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
					 int __pshared)
#line 810
extern int pthread_mutexattr_gettype (const pthread_mutexattr_t *__restrict
				      __attr, int *__restrict __kind)
#line 817
extern int pthread_mutexattr_settype (pthread_mutexattr_t *__attr, int __kind)
#line 822
extern int pthread_mutexattr_getprotocol (const pthread_mutexattr_t *
					  __restrict __attr,
					  int *__restrict __protocol)
#line 829
extern int pthread_mutexattr_setprotocol (pthread_mutexattr_t *__attr,
					  int __protocol)
#line 834
extern int pthread_mutexattr_getprioceiling (const pthread_mutexattr_t *
					     __restrict __attr,
#line 840
extern int pthread_mutexattr_setprioceiling (pthread_mutexattr_t *__attr,
					     int __prioceiling)
#line 846
extern int pthread_mutexattr_getrobust (const pthread_mutexattr_t *__attr,
					int *__robustness)
#line 856
extern int pthread_mutexattr_setrobust (pthread_mutexattr_t *__attr,
					int __robustness)
#line 872
extern int pthread_rwlock_init (pthread_rwlock_t *__restrict __rwlock,
				const pthread_rwlockattr_t *__restrict
				__attr)  ;
#line 877
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
#line 881
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
#line 885
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
#line 890
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t *__restrict __rwlock,
				       __abstime)  ;
#line 896
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
#line 900
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
#line 905
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t *__restrict __rwlock,
				       __abstime)  ;
#line 911
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
#line 918
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
#line 922
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
#line 926
extern int pthread_rwlockattr_getpshared (const pthread_rwlockattr_t *
					  __restrict __attr,
#line 932
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
					  int __pshared)
#line 937
extern int pthread_rwlockattr_getkind_np (const pthread_rwlockattr_t *
					  __restrict __attr,
					  int *__restrict __pref)
#line 943
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
					  int __pref)  ;
#line 952
extern int pthread_cond_init (pthread_cond_t *__restrict __cond,
			      const pthread_condattr_t *__restrict
			      __cond_attr)  ;
#line 957
extern int pthread_cond_destroy (pthread_cond_t *__cond)
#line 961
extern int pthread_cond_signal (pthread_cond_t *__cond)
#line 965
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
#line 973
extern int pthread_cond_wait (pthread_cond_t *__restrict __cond,
			      pthread_mutex_t *__restrict __mutex)
#line 984
extern int pthread_cond_timedwait (pthread_cond_t *__restrict __cond,
				   __abstime) ;
#line 992
extern int pthread_condattr_init (pthread_condattr_t *__attr)
#line 996
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
#line 1000
extern int pthread_condattr_getpshared (const pthread_condattr_t *
					__restrict __attr,
#line 1006
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
					int __pshared)  ;
#line 1011
extern int pthread_condattr_getclock (const pthread_condattr_t *
				      __restrict __attr,
				      __clockid_t *__restrict __clock_id)
#line 1017
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
				      __clockid_t __clock_id)
#line 1028
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
#line 1032
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
#line 1036
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
#line 1040
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
#line 1044
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
#line 1052
extern int pthread_barrier_init (pthread_barrier_t *__restrict __barrier,
				 const pthread_barrierattr_t *__restrict
				 __attr, unsigned int __count)
#line 1058
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
#line 1062
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
#line 1067
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
#line 1071
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
#line 1075
extern int pthread_barrierattr_getpshared (const pthread_barrierattr_t *
					   __restrict __attr,
#line 1081
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
					   int __pshared)
#line 1095
extern int pthread_key_create (pthread_key_t *__key,
			       void (*__destr_function) (void *))
#line 1100
extern int pthread_key_delete (pthread_key_t __key) ;
#line 1103
extern void *pthread_getspecific (pthread_key_t __key) ;
#line 1106
extern int pthread_setspecific (pthread_key_t __key,
				const void *__pointer)  ;
#line 1112
extern int pthread_getcpuclockid (pthread_t __thread_id,
				  __clockid_t *__clock_id)
#line 1129
extern int pthread_atfork (void (*__prepare) (void),
			   void (*__parent) (void),
			   void (*__child) (void)) ;
          Defined "HAVE_PTHREAD_H" to "1"
TEST check from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: setjmp.h
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.headers  /tmp/petsc-ITHdGX/config.headers/conftest.c
stdout:
#line 29
typedef struct
  } __sigset_t;
#line 35 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/setjmp.h"
#line 41
    __jmp_buf __jmpbuf;
    __sigset_t __saved_mask;
#line 49
typedef struct __jmp_buf_tag jmp_buf[1];
#line 53
extern int setjmp (jmp_buf __env) ;
#line 60
extern int __sigsetjmp (struct __jmp_buf_tag __env[1], int __savemask) ;
#line 65
extern int _setjmp (struct __jmp_buf_tag __env[1]) ;
#line 82
extern void longjmp (struct __jmp_buf_tag __env[1], int __val)
#line 91
extern void _longjmp (struct __jmp_buf_tag __env[1], int __val)
#line 100
typedef struct __jmp_buf_tag sigjmp_buf[1];
#line 110
extern void siglongjmp (sigjmp_buf __env, int __val)
#line 17 "/soft/compilers/ibmcmp-may2013/vac/bg/12.1/include/setjmp.h"
#pragma reachable(setjmp)
#pragma reachable(_setjmp)
#pragma reachable(__sigsetjmp)
          Defined "HAVE_SETJMP_H" to "1"
Checking for header: sys/utsname.h
stdout:
#line 49 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/utsname.h"
struct utsname
    char sysname[65];
#line 55
    char nodename[65];
#line 58
    char release[65];
    char version[65];
#line 63
    char machine[65];
#line 70
    char __domainname[65];
#line 73
#line 82
extern int uname (struct utsname *__name) ;
          Defined "HAVE_SYS_UTSNAME_H" to "1"
Checking for header: machine/endian.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <machine/endian.h> not found.
Source:
#include "confdefs.h"
#include "conffix.h"
#include <machine/endian.h>
Checking for header: limits.h
          Defined "HAVE_LIMITS_H" to "1"
Checking for header: fcntl.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 45
#line 49
#line 61
#line 66
#line 71
#line 76
#line 81
#line 87
#line 99
#line 105
#line 110
#line 116
#line 123
#line 76
#line 92
#line 104
#line 211 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include/stddef.h"
typedef unsigned long size_t;
#line 195
#line 201
#line 29
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
#line 55
#line 67
typedef struct
#line 75
#line 78
  } fd_set;
#line 85
#line 109
#line 121
__extension__
__extension__
__extension__
#line 236
#line 240
#line 244
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
#line 150 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/fcntl.h"
struct flock
    short int l_type;
    short int l_whence;
    __off_t l_start;
    __off_t l_len;
#line 161
    __pid_t l_pid;
#line 143 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/stat.h"
struct stat
    __dev_t st_dev;
    __ino_t st_ino;
#line 151
    __nlink_t st_nlink;
    __mode_t st_mode;
    __uid_t st_uid;
    __gid_t st_gid;
    int __pad2;
    __dev_t st_rdev;
    __off_t st_size;
#line 162
    __blksize_t st_blksize;
#line 165
    __blkcnt_t st_blocks;
#line 176
    struct timespec st_atim;
    struct timespec st_mtim;
    struct timespec st_ctim;
#line 190
    unsigned long int __unused4;
    unsigned long int __unused5;
    unsigned long int __unused6;
#line 122 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/fcntl.h"
extern int fcntl (int __fd, int __cmd, ...);
#line 131
extern int open (const char *__file, int __oflag, ...) ;
#line 155
extern int openat (int __fd, const char *__file, int __oflag, ...)
#line 177
extern int creat (const char *__file, __mode_t __mode) ;
#line 206
extern int lockf (int __fd, int __cmd, __off_t __len);
#line 223
extern int posix_fadvise (int __fd, __off_t __offset, __off_t __len,
			  int __advise) ;
#line 245
extern int posix_fallocate (int __fd, __off_t __offset, __off_t __len);
          Defined "HAVE_FCNTL_H" to "1"
Checking for header: string.h
stdout:
#line 44 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/string.h"
extern void *memcpy (void *__restrict __dest,
		     const void *__restrict __src, size_t __n)
#line 49
extern void *memmove (void *__dest, const void *__src, size_t __n)
#line 57
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
		      int __c, size_t __n)
#line 65
extern void *memset (void *__s, int __c, size_t __n)  ;
#line 68
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
#line 95
extern void *memchr (const void *__s, int __c, size_t __n)
#line 128
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
		      const char *__restrict __src, size_t __n)
#line 136
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
		      size_t __n)  ;
#line 143
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
#line 150
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
#line 34
#line 39
} *__locale_t;
#line 43
#line 165 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/string.h"
extern int strcoll_l (const char *__s1, const char *__s2, __locale_t __l)
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
			 __locale_t __l)  ;
#line 175
extern char *strdup (const char *__s)
#line 183
extern char *strndup (const char *__string, size_t __n)
#line 235
extern char *strchr (const char *__s, int __c)
#line 262
extern char *strrchr (const char *__s, int __c)
#line 284
extern size_t strcspn (const char *__s, const char *__reject)
#line 288
extern size_t strspn (const char *__s, const char *__accept)
#line 314
extern char *strpbrk (const char *__s, const char *__accept)
#line 342
extern char *strstr (const char *__haystack, const char *__needle)
#line 348
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
#line 354
extern char *__strtok_r (char *__restrict __s,
			 const char *__restrict __delim,
			 char **__restrict __save_ptr)
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
#line 399
extern size_t strlen (const char *__s)
#line 406
extern size_t strnlen (const char *__string, size_t __maxlen)
#line 413
extern char *strerror (int __errnum) ;
#line 427
extern int
strerror_r (int __errnum, char *__buf, size_t __buflen)   _Pragma("map(strerror_r, \"__xpg_strerror_r\")") ;
#line 445
extern char *strerror_l (int __errnum, __locale_t __l) ;
#line 451
extern void __bzero (void *__s, size_t __n)  ;
#line 455
#line 459
#line 462
#line 489
#line 517
#line 523
#line 536
#line 540
#line 559
extern char *strsep (char **__restrict __stringp,
#line 566
extern char *strsignal (int __sig) ;
#line 569
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
#line 576
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
          Defined "HAVE_STRING_H" to "1"
Checking for header: sys/times.h
stdout:
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
#line 37
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
#line 53
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 134
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
#line 158
typedef int __clockid_t;
#line 161
typedef void * __timer_t;
#line 164
typedef long int __blksize_t;
#line 169
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
#line 173
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
#line 177
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
#line 184
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
#line 189
typedef long int __intptr_t;
#line 192
typedef unsigned int __socklen_t;
#line 60 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
typedef __clock_t clock_t;
#line 35 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/times.h"
struct tms
    clock_t tms_utime;
    clock_t tms_stime;
    clock_t tms_cutime;
    clock_t tms_cstime;
#line 49
extern clock_t times (struct tms *__buffer) ;
          Defined "HAVE_SYS_TIMES_H" to "1"
Checking for header: io.h
Possible ERROR while running preprocessor: exit code 256
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <io.h> not found.
Source:
#include <io.h>
Checking for header: stdint.h
stdout:
#line 37 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdint.h"
typedef signed char		int8_t;
typedef short int		int16_t;
typedef int			int32_t;
typedef long int		int64_t;
#line 49
typedef unsigned char		uint8_t;
typedef unsigned short int	uint16_t;
typedef unsigned int		uint32_t;
#line 56
typedef unsigned long int	uint64_t;
#line 66
typedef signed char		int_least8_t;
typedef short int		int_least16_t;
typedef int			int_least32_t;
typedef long int		int_least64_t;
#line 77
typedef unsigned char		uint_least8_t;
typedef unsigned short int	uint_least16_t;
typedef unsigned int		uint_least32_t;
typedef unsigned long int	uint_least64_t;
#line 91
typedef signed char		int_fast8_t;
typedef long int		int_fast16_t;
typedef long int		int_fast32_t;
typedef long int		int_fast64_t;
#line 104
typedef unsigned char		uint_fast8_t;
typedef unsigned long int	uint_fast16_t;
typedef unsigned long int	uint_fast32_t;
typedef unsigned long int	uint_fast64_t;
#line 120
typedef long int		intptr_t;
#line 123
typedef unsigned long int	uintptr_t;
#line 135
typedef long int		intmax_t;
typedef unsigned long int	uintmax_t;
          Defined "HAVE_STDINT_H" to "1"
Checking for header: pwd.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 39 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/pwd.h"
#line 44
#line 50
struct passwd
  char *pw_name;
  char *pw_passwd;
  __uid_t pw_uid;
  __gid_t pw_gid;
  char *pw_gecos;
  char *pw_dir;
  char *pw_shell;
#line 45 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdio.h"
struct _IO_FILE;
#line 49
typedef struct _IO_FILE FILE;
#line 73 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/pwd.h"
extern void setpwent (void);
#line 79
extern void endpwent (void);
#line 85
extern struct passwd *getpwent (void);
#line 95
extern struct passwd *fgetpwent (FILE *__stream);
#line 103
extern int putpwent (const struct passwd *__restrict __p,
		     FILE *__restrict __f);
#line 111
extern struct passwd *getpwuid (__uid_t __uid);
#line 117
extern struct passwd *getpwnam (const char *__name);
#line 140
extern int getpwent_r (struct passwd *__restrict __resultbuf,
		       char *__restrict __buffer, size_t __buflen,
		       struct passwd **__restrict __result);
#line 145
extern int getpwuid_r (__uid_t __uid,
extern int getpwnam_r (const char *__restrict __name,
#line 164
extern int fgetpwent_r (FILE *__restrict __stream,
          Defined "HAVE_PWD_H" to "1"
Checking for header: float.h
          Defined "HAVE_FLOAT_H" to "1"
Checking for header: sys/param.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 45
#line 49
#line 61
#line 66
#line 71
#line 76
#line 81
#line 87
#line 99
typedef __pid_t pid_t;
#line 105
#line 110
#line 116
#line 123
#line 76
typedef __time_t time_t;
#line 92
typedef __clockid_t clockid_t;
#line 104
typedef __timer_t timer_t;
#line 195
#line 201
#line 29
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
#line 55
#line 67
typedef struct
#line 75
#line 78
  } fd_set;
#line 85
#line 109
#line 121
__extension__
__extension__
__extension__
#line 236
#line 240
#line 244
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
          Defined "HAVE_SYS_PARAM_H" to "1"
Checking for header: netdb.h
stdout:
#line 49
#line 56
#line 66
#line 77
#line 91
#line 104
#line 120
#line 123
#line 135
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 45
#line 49
#line 61
#line 66
#line 71
#line 76
#line 81
typedef __uid_t uid_t;
#line 87
#line 99
#line 105
#line 110
#line 116
#line 123
#line 76
#line 92
#line 104
#line 201
#line 24 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigset.h"
typedef int __sig_atomic_t;
#line 29
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
typedef __sigset_t sigset_t;
#line 120 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
#line 55
#line 67
typedef struct
#line 75
#line 78
  } fd_set;
#line 85
#line 109
#line 121
__extension__
__extension__
__extension__
#line 236
#line 240
#line 244
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
#line 44 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/uio.h"
struct iovec
    void *iov_base;
    size_t iov_len;
#line 40 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/uio.h"
extern ssize_t readv (int __fd, const struct iovec *__iovec, int __count)
#line 51
extern ssize_t writev (int __fd, const struct iovec *__iovec, int __count)
#line 66
extern ssize_t preadv (int __fd, const struct iovec *__iovec, int __count,
		       __off_t __offset) ;
#line 78
extern ssize_t pwritev (int __fd, const struct iovec *__iovec, int __count,
			__off_t __offset) ;
#line 35 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/socket.h"
typedef __socklen_t socklen_t;
#line 40
enum __socket_type
  SOCK_STREAM = 1,
#line 45
  SOCK_DGRAM = 2,
#line 48
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
#line 55
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
#line 65
  SOCK_CLOEXEC = 02000000,
#line 68
  SOCK_NONBLOCK = 04000
#line 71
#line 29 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sockaddr.h"
typedef unsigned short int sa_family_t;
#line 174 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/socket.h"
struct sockaddr
    sa_family_t sa_family;
    char sa_data[14];
#line 187
struct sockaddr_storage
    sa_family_t ss_family;
    unsigned long int __ss_align;
    char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
#line 196
enum
    MSG_OOB		= 0x01,
    MSG_PEEK		= 0x02,
    MSG_DONTROUTE	= 0x04,
#line 209
    MSG_CTRUNC		= 0x08,
    MSG_PROXY		= 0x10,
    MSG_TRUNC		= 0x20,
    MSG_DONTWAIT	= 0x40,
    MSG_EOR		= 0x80,
    MSG_WAITALL		= 0x100,
    MSG_FIN		= 0x200,
    MSG_SYN		= 0x400,
    MSG_CONFIRM		= 0x800,
    MSG_RST		= 0x1000,
    MSG_ERRQUEUE	= 0x2000,
    MSG_NOSIGNAL	= 0x4000,
    MSG_MORE		= 0x8000,
    MSG_WAITFORONE	= 0x10000,
#line 238
    MSG_CMSG_CLOEXEC	= 0x40000000
#line 242
#line 247
struct msghdr
    void *msg_name;
    socklen_t msg_namelen;
    struct iovec *msg_iov;
    size_t msg_iovlen;
    void *msg_control;
    size_t msg_controllen;
#line 261
    int msg_flags;
#line 274
struct cmsghdr
    size_t cmsg_len;
#line 281
    int cmsg_level;
    int cmsg_type;
    __extension__ unsigned char __cmsg_data [];
#line 304
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
				      struct cmsghdr *__cmsg) ;
#line 331
enum
    SCM_RIGHTS = 0x01
#line 339
#line 411
struct linger
    int l_onoff;
    int l_linger;
#line 425
extern int recvmmsg (int __fd, struct mmsghdr *__vmessages,
		     unsigned int __vlen, int __flags,
		     const struct timespec *__tmo);
#line 45 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/socket.h"
struct osockaddr
    unsigned short int sa_family;
    unsigned char sa_data[14];
#line 54
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
#line 105
extern int socket (int __domain, int __type, int __protocol) ;
#line 111
extern int socketpair (int __domain, int __type, int __protocol,
		       int __fds[2]) ;
#line 115
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
#line 119
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
			socklen_t *__restrict __len) ;
#line 129
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
#line 133
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
#line 141
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
#line 148
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
#line 155
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
		       int __flags, const struct sockaddr * __addr,
		       socklen_t __addr_len);
#line 166
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
			 int __flags, struct sockaddr *__restrict __addr,
			 socklen_t *__restrict __addr_len);
#line 176
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
			int __flags);
#line 184
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
#line 190
extern int getsockopt (int __fd, int __level, int __optname,
		       void *__restrict __optval,
		       socklen_t *__restrict __optlen) ;
#line 197
extern int setsockopt (int __fd, int __level, int __optname,
		       const void *__optval, socklen_t __optlen) ;
#line 204
extern int listen (int __fd, int __n) ;
#line 214
extern int accept (int __fd, struct sockaddr *__restrict __addr,
#line 232
extern int shutdown (int __fd, int __how) ;
#line 237
extern int sockatmark (int __fd) ;
#line 245
extern int isfdtype (int __fd, int __fdtype) ;
#line 32 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/netinet/in.h"
enum
    IPPROTO_IP = 0,
    IPPROTO_HOPOPTS = 0,
    IPPROTO_ICMP = 1,
    IPPROTO_IGMP = 2,
    IPPROTO_IPIP = 4,
    IPPROTO_TCP = 6,
    IPPROTO_EGP = 8,
    IPPROTO_PUP = 12,
    IPPROTO_UDP = 17,
    IPPROTO_IDP = 22,
    IPPROTO_TP = 29,
    IPPROTO_DCCP = 33,
    IPPROTO_IPV6 = 41,
    IPPROTO_ROUTING = 43,
    IPPROTO_FRAGMENT = 44,
    IPPROTO_RSVP = 46,
    IPPROTO_GRE = 47,
    IPPROTO_ESP = 50,
    IPPROTO_AH = 51,
    IPPROTO_ICMPV6 = 58,
    IPPROTO_NONE = 59,
    IPPROTO_DSTOPTS = 60,
    IPPROTO_MTP = 92,
    IPPROTO_ENCAP = 98,
    IPPROTO_PIM = 103,
    IPPROTO_COMP = 108,
    IPPROTO_SCTP = 132,
    IPPROTO_UDPLITE = 136,
    IPPROTO_RAW = 255,
    IPPROTO_MAX
#line 97
typedef uint16_t in_port_t;
#line 100
enum
    IPPORT_ECHO = 7,
    IPPORT_DISCARD = 9,
    IPPORT_SYSTAT = 11,
    IPPORT_DAYTIME = 13,
    IPPORT_NETSTAT = 15,
    IPPORT_FTP = 21,
    IPPORT_TELNET = 23,
    IPPORT_SMTP = 25,
    IPPORT_TIMESERVER = 37,
    IPPORT_NAMESERVER = 42,
    IPPORT_WHOIS = 43,
    IPPORT_MTP = 57,
    IPPORT_TFTP = 69,
    IPPORT_RJE = 77,
    IPPORT_FINGER = 79,
    IPPORT_TTYLINK = 87,
    IPPORT_SUPDUP = 95,
#line 122
    IPPORT_EXECSERVER = 512,
    IPPORT_LOGINSERVER = 513,
    IPPORT_CMDSERVER = 514,
    IPPORT_EFSSERVER = 520,
#line 128
    IPPORT_BIFFUDP = 512,
    IPPORT_WHOSERVER = 513,
    IPPORT_ROUTESERVER = 520,
#line 133
    IPPORT_RESERVED = 1024,
#line 136
    IPPORT_USERRESERVED = 5000
#line 141
typedef uint32_t in_addr_t;
struct in_addr
    in_addr_t s_addr;
#line 198
struct in6_addr
    union
	uint8_t	__u6_addr8[16];
	uint16_t __u6_addr16[8];
	uint32_t __u6_addr32[4];
      } __in6_u;
#line 213
extern const struct in6_addr in6addr_any;
extern const struct in6_addr in6addr_loopback;
#line 225
struct sockaddr_in
    sa_family_t sin_family;
    in_port_t sin_port;
    struct in_addr sin_addr;
#line 232
    unsigned char sin_zero[sizeof (struct sockaddr) -
			   (sizeof (unsigned short int)) -
			   sizeof (in_port_t) -
			   sizeof (struct in_addr)];
#line 239
struct sockaddr_in6
    sa_family_t sin6_family;
    in_port_t sin6_port;
    uint32_t sin6_flowinfo;
    struct in6_addr sin6_addr;
    uint32_t sin6_scope_id;
#line 251
struct ip_mreq
    struct in_addr imr_multiaddr;
#line 257
    struct in_addr imr_interface;
struct ip_mreq_source
#line 266
#line 269
    struct in_addr imr_sourceaddr;
#line 275
struct ipv6_mreq
    struct in6_addr ipv6mr_multiaddr;
#line 281
    unsigned int ipv6mr_interface;
#line 287
struct group_req
    uint32_t gr_interface;
#line 293
    struct sockaddr_storage gr_group;
struct group_source_req
    uint32_t gsr_interface;
#line 302
    struct sockaddr_storage gsr_group;
#line 305
    struct sockaddr_storage gsr_source;
#line 310
struct ip_msfilter
    struct in_addr imsf_multiaddr;
#line 316
    struct in_addr imsf_interface;
#line 319
    uint32_t imsf_fmode;
#line 322
    uint32_t imsf_numsrc;
    struct in_addr imsf_slist[1];
#line 331
struct group_filter
    uint32_t gf_interface;
#line 337
    struct sockaddr_storage gf_group;
#line 340
    uint32_t gf_fmode;
#line 343
    uint32_t gf_numsrc;
    struct sockaddr_storage gf_slist[1];
#line 98 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/in.h"
struct ip_opts
    struct in_addr ip_dst;
    char ip_opts[40];
#line 105
struct ip_mreqn
    struct in_addr imr_address;
    int	imr_ifindex;
#line 113
struct in_pktinfo
    int ipi_ifindex;
    struct in_addr ipi_spec_dst;
    struct in_addr ipi_addr;
#line 371 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/netinet/in.h"
extern uint32_t ntohl (uint32_t __netlong)  __attribute__ ((const));
extern uint16_t ntohs (uint16_t __netshort)
extern uint32_t htonl (uint32_t __hostlong)
extern uint16_t htons (uint16_t __hostshort)
#line 446
extern int bindresvport (int __sockfd, struct sockaddr_in *__sock_in) ;
#line 449
extern int bindresvport6 (int __sockfd, struct sockaddr_in6 *__sock_in)
#line 46 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/rpc/netdb.h"
struct rpcent
  char *r_name;
  char **r_aliases;
  int r_number;
extern void setrpcent (int __stayopen) ;
extern void endrpcent (void) ;
extern struct rpcent *getrpcbyname (const char *__name) ;
extern struct rpcent *getrpcbynumber (int __number) ;
extern struct rpcent *getrpcent (void) ;
#line 60
extern int getrpcbyname_r (const char *__name, struct rpcent *__result_buf,
			   char *__buffer, size_t __buflen,
			   struct rpcent **__result) ;
extern int getrpcbynumber_r (int __number, struct rpcent *__result_buf,
extern int getrpcent_r (struct rpcent *__result_buf, char *__buffer,
			size_t __buflen, struct rpcent **__result) ;
#line 27 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/netdb.h"
struct netent
  char *n_name;
  char **n_aliases;
  int n_addrtype;
  uint32_t n_net;
#line 62 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/netdb.h"
extern int *__h_errno_location (void)  __attribute__ ((const));
#line 93
extern void herror (const char *__str) ;
#line 96
extern const char *hstrerror (int __err_num) ;
#line 101
struct hostent
  char *h_name;
  char **h_aliases;
  int h_addrtype;
  int h_length;
  char **h_addr_list;
#line 111
#line 118
extern void sethostent (int __stay_open);
#line 124
extern void endhostent (void);
#line 131
extern struct hostent *gethostent (void);
#line 138
extern struct hostent *gethostbyaddr (const void *__addr, __socklen_t __len,
				      int __type);
#line 145
extern struct hostent *gethostbyname (const char *__name);
#line 156
extern struct hostent *gethostbyname2 (const char *__name, int __af);
#line 168
extern int gethostent_r (struct hostent *__restrict __result_buf,
			 char *__restrict __buf, size_t __buflen,
			 struct hostent **__restrict __result,
			 int *__restrict __h_errnop);
extern int gethostbyaddr_r (const void *__restrict __addr, __socklen_t __len,
			    int __type,
extern int gethostbyname_r (const char *__restrict __name,
extern int gethostbyname2_r (const char *__restrict __name, int __af,
#line 199
extern void setnetent (int __stay_open);
#line 205
extern void endnetent (void);
#line 212
extern struct netent *getnetent (void);
#line 219
extern struct netent *getnetbyaddr (uint32_t __net, int __type);
#line 225
extern struct netent *getnetbyname (const char *__name);
#line 238
extern int getnetent_r (struct netent *__restrict __result_buf,
			struct netent **__restrict __result,
extern int getnetbyaddr_r (uint32_t __net, int __type,
extern int getnetbyname_r (const char *__restrict __name,
#line 258
struct servent
  char *s_name;
  char **s_aliases;
  int s_port;
  char *s_proto;
#line 271
extern void setservent (int __stay_open);
#line 277
extern void endservent (void);
#line 284
extern struct servent *getservent (void);
#line 291
extern struct servent *getservbyname (const char *__name,
				      const char *__proto);
#line 299
extern struct servent *getservbyport (int __port, const char *__proto);
#line 310
extern int getservent_r (struct servent *__restrict __result_buf,
			 struct servent **__restrict __result);
extern int getservbyname_r (const char *__restrict __name,
			    const char *__restrict __proto,
extern int getservbyport_r (int __port, const char *__restrict __proto,
#line 328
struct protoent
  char *p_name;
  char **p_aliases;
  int p_proto;
#line 340
extern void setprotoent (int __stay_open);
#line 346
extern void endprotoent (void);
#line 353
extern struct protoent *getprotoent (void);
#line 359
extern struct protoent *getprotobyname (const char *__name);
#line 365
extern struct protoent *getprotobynumber (int __proto);
#line 376
extern int getprotoent_r (struct protoent *__restrict __result_buf,
			  struct protoent **__restrict __result);
extern int getprotobyname_r (const char *__restrict __name,
extern int getprotobynumber_r (int __proto,
#line 397
extern int setnetgrent (const char *__netgroup);
#line 405
extern void endnetgrent (void);
#line 414
extern int getnetgrent (char **__restrict __hostp,
			char **__restrict __userp,
			char **__restrict __domainp);
#line 425
extern int innetgr (const char *__netgroup, const char *__host,
		    const char *__user, const char *__domain);
#line 434
extern int getnetgrent_r (char **__restrict __hostp,
			  char **__restrict __domainp,
			  char *__restrict __buffer, size_t __buflen);
#line 453
extern int rcmd (char **__restrict __ahost, unsigned short int __rport,
		 const char *__restrict __locuser,
		 const char *__restrict __remuser,
		 const char *__restrict __cmd, int *__restrict __fd2p);
#line 465
extern int rcmd_af (char **__restrict __ahost, unsigned short int __rport,
		    const char *__restrict __cmd, int *__restrict __fd2p,
		    sa_family_t __af);
#line 481
extern int rexec (char **__restrict __ahost, int __rport,
		  const char *__restrict __pass,
#line 493
extern int rexec_af (char **__restrict __ahost, int __rport,
		     sa_family_t __af);
#line 507
extern int ruserok (const char *__rhost, int __suser,
		    const char *__remuser, const char *__locuser);
#line 517
extern int ruserok_af (const char *__rhost, int __suser,
		       const char *__remuser, const char *__locuser,
		       sa_family_t __af);
#line 530
extern int iruserok (uint32_t __raddr, int __suser,
#line 541
extern int iruserok_af (const void *__raddr, int __suser,
			sa_family_t __af);
#line 553
extern int rresvport (int *__alport);
#line 562
extern int rresvport_af (int *__alport, sa_family_t __af);
#line 569
struct addrinfo
  int ai_flags;
  int ai_family;
  int ai_socktype;
  int ai_protocol;
  socklen_t ai_addrlen;
  struct sockaddr *ai_addr;
  char *ai_canonname;
  struct addrinfo *ai_next;
#line 664
extern int getaddrinfo (const char *__restrict __name,
			const char *__restrict __service,
			const struct addrinfo *__restrict __req,
			struct addrinfo **__restrict __pai);
#line 670
extern void freeaddrinfo (struct addrinfo *__ai) ;
#line 673
extern const char *gai_strerror (int __ecode) ;
#line 679
extern int getnameinfo (const struct sockaddr *__restrict __sa,
			socklen_t __salen, char *__restrict __host,
			socklen_t __hostlen, char *__restrict __serv,
			socklen_t __servlen, unsigned int __flags);
          Defined "HAVE_NETDB_H" to "1"
Checking for header: search.h
stdout:
#line 45 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/search.h"
extern void insque (void *__elem, void *__prev) ;
#line 48
extern void remque (void *__elem) ;
#line 55
#line 63
typedef enum
    FIND,
    ENTER
ACTION;
typedef struct entry
    char *key;
    void *data;
ENTRY;
#line 78
struct _ENTRY;
#line 88
extern ENTRY *hsearch (ENTRY __item, ACTION __action) ;
#line 91
extern int hcreate (size_t __nel) ;
#line 94
extern void hdestroy (void) ;
#line 119
typedef enum
  preorder,
  postorder,
  endorder,
  leaf
VISIT;
#line 130
extern void *tsearch (const void *__key, void **__rootp,
		      __compar_fn_t __compar);
#line 135
extern void *tfind (const void *__key, void *const *__rootp,
#line 139
extern void *tdelete (const void *__restrict __key,
		      void **__restrict __rootp,
#line 145
typedef void (*__action_fn_t) (const void *__nodep, VISIT __value,
			       int __level);
#line 151
extern void twalk (const void *__root, __action_fn_t __action);
#line 165
extern void *lfind (const void *__key, const void *__base,
		    size_t *__nmemb, size_t __size, __compar_fn_t __compar);
#line 170
extern void *lsearch (const void *__key, void *__base,
          Defined "HAVE_SEARCH_H" to "1"
Checking for header: mathimf.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <mathimf.h> not found.
Source:
#include <mathimf.h>
Checking for header: sys/procfs.h
stdout:
#line 29
typedef struct
  } __sigset_t;
#line 104
extern int __sigismember (const __sigset_t *, int);
extern int __sigaddset (__sigset_t *, int);
extern int __sigdelset (__sigset_t *, int);
#line 41 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
typedef __sig_atomic_t sig_atomic_t;
#line 50
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 62 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
#line 68
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 33 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/siginfo.h"
typedef union sigval
    int sival_int;
    void *sival_ptr;
  } sigval_t;
#line 51
typedef struct siginfo
    int si_signo;
    int si_errno;
    int si_code;
    union
	int _pad[((128 / sizeof (int)) - 4)];
#line 63
	struct
	    __pid_t si_pid;
	    __uid_t si_uid;
	  } _kill;
#line 70
	struct
	    int si_tid;
	    int si_overrun;
	    sigval_t si_sigval;
	  } _timer;
#line 78
	struct
	    __pid_t si_pid;
	    __uid_t si_uid;
	    sigval_t si_sigval;
	  } _rt;
#line 86
	struct
	    __pid_t si_pid;
	    __uid_t si_uid;
	    int si_status;
	    __clock_t si_utime;
	    __clock_t si_stime;
	  } _sigchld;
#line 96
	struct
	    void *si_addr;
	  } _sigfault;
#line 102
	struct
	    long int si_band;
	    int si_fd;
	  } _sigpoll;
      } _sifields;
  } siginfo_t;
#line 129
enum
  SI_ASYNCNL = -60,
  SI_TKILL = -6,
  SI_SIGIO,
  SI_ASYNCIO,
  SI_MESGQ,
  SI_TIMER,
  SI_QUEUE,
  SI_USER,
  SI_KERNEL = 0x80
#line 153
enum
  ILL_ILLOPC = 1,
  ILL_ILLOPN,
  ILL_ILLADR,
  ILL_ILLTRP,
  ILL_PRVOPC,
  ILL_PRVREG,
  ILL_COPROC,
  ILL_BADSTK
#line 174
enum
  FPE_INTDIV = 1,
  FPE_INTOVF,
  FPE_FLTDIV,
  FPE_FLTOVF,
  FPE_FLTUND,
  FPE_FLTRES,
  FPE_FLTINV,
  FPE_FLTSUB
#line 195
enum
  SEGV_MAPERR = 1,
  SEGV_ACCERR
#line 204
enum
  BUS_ADRALN = 1,
  BUS_ADRERR,
  BUS_OBJERR
#line 215
enum
  TRAP_BRKPT = 1,
  TRAP_TRACE
#line 224
enum
  CLD_EXITED = 1,
  CLD_KILLED,
  CLD_DUMPED,
  CLD_TRAPPED,
  CLD_STOPPED,
  CLD_CONTINUED
#line 241
enum
  POLL_IN = 1,
  POLL_OUT,
  POLL_MSG,
  POLL_ERR,
  POLL_PRI,
  POLL_HUP
#line 273
typedef struct sigevent
    sigval_t sigev_value;
    int sigev_signo;
    int sigev_notify;
    union
	int _pad[((64 / sizeof (int)) - 4)];
#line 285
	__pid_t _tid;
	struct
	    void (*_function) (sigval_t);
	    void *_attribute;
	  } _sigev_thread;
      } _sigev_un;
  } sigevent_t;
#line 300
enum
  SIGEV_SIGNAL = 0,
  SIGEV_NONE,
  SIGEV_THREAD,
#line 309
  SIGEV_THREAD_ID = 4
#line 84 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
typedef void (*__sighandler_t) (int);
#line 89
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
#line 101
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
#line 126
extern int kill (__pid_t __pid, int __sig) ;
#line 133
extern int killpg (__pid_t __pgrp, int __sig) ;
#line 138
extern int raise (int __sig) ;
#line 143
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) ;
#line 150
extern void psignal (int __sig, const char *__s);
#line 155
extern void psiginfo (const siginfo_t *__pinfo, const char *__s);
#line 168
extern int __sigpause (int __sig_or_mask, int __is_sig);
#line 196
extern int sigblock (int __mask)  __attribute__ ((__deprecated__));
#line 199
extern int sigsetmask (int __mask)  __attribute__ ((__deprecated__));
#line 202
extern int siggetmask (void)  __attribute__ ((__deprecated__));
#line 216
typedef __sighandler_t sig_t;
#line 222
extern int sigemptyset (sigset_t *__set)  ;
#line 225
extern int sigfillset (sigset_t *__set)  ;
#line 228
extern int sigaddset (sigset_t *__set, int __signo)  ;
#line 231
extern int sigdelset (sigset_t *__set, int __signo)  ;
#line 234
extern int sigismember (const sigset_t *__set, int __signo)
#line 25 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigaction.h"
struct sigaction
#line 29
    union
	__sighandler_t sa_handler;
	void (*sa_sigaction) (int, siginfo_t *, void *);
    __sigaction_handler;
#line 44
    __sigset_t sa_mask;
#line 47
    int sa_flags;
#line 50
    void (*sa_restorer) (void);
#line 255 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int sigprocmask (int __how, const sigset_t *__restrict __set,
			sigset_t *__restrict __oset) ;
#line 263
extern int sigsuspend (const sigset_t *__set) ;
#line 266
extern int sigaction (int __sig, const struct sigaction *__restrict __act,
		      struct sigaction *__restrict __oact) ;
#line 270
extern int sigpending (sigset_t *__set)  ;
#line 277
extern int sigwait (const sigset_t *__restrict __set, int *__restrict __sig)
#line 285
extern int sigwaitinfo (const sigset_t *__restrict __set,
			siginfo_t *__restrict __info) ;
#line 293
extern int sigtimedwait (const sigset_t *__restrict __set,
			 siginfo_t *__restrict __info,
			 const struct timespec *__restrict __timeout)
#line 300
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
#line 310
extern const char *const _sys_siglist[65];
extern const char *const sys_siglist[65];
#line 314
struct sigvec
    __sighandler_t sv_handler;
    int sv_mask;
    int sv_flags;
#line 334
extern int sigvec (int __sig, const struct sigvec *__vec,
		   struct sigvec *__ovec) ;
#line 29 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/ptrace.h"
struct pt_regs {
	unsigned long gpr[32];
	unsigned long nip;
	unsigned long msr;
	unsigned long orig_gpr3;
	unsigned long ctr;
	unsigned long link;
	unsigned long xer;
	unsigned long ccr;
	unsigned long softe;
#line 44
	unsigned long trap;
#line 47
	unsigned long dar;
	unsigned long dsisr;
	unsigned long result;
#line 19 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm-generic/int-l64.h"
typedef signed char __s8;
typedef unsigned char __u8;
typedef signed short __s16;
typedef unsigned short __u16;
typedef signed int __s32;
typedef unsigned int __u32;
typedef signed long __s64;
typedef unsigned long __u64;
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/types.h"
typedef unsigned int umode_t;
#line 36
typedef struct {
	__u32 u[4];
} __attribute__((aligned(16))) __vector128;
#line 36 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/posix_types.h"
typedef struct {
	unsigned long fds_bits [(1024/(8 * sizeof(unsigned long)))];
} __kernel_fd_set;
#line 41
typedef void (*__kernel_sighandler_t)(int);
#line 44
typedef int __kernel_key_t;
typedef int __kernel_mqd_t;
#line 10 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/posix_types.h"
typedef unsigned long	__kernel_ino_t;
typedef unsigned int	__kernel_mode_t;
typedef long		__kernel_off_t;
typedef int		__kernel_pid_t;
typedef unsigned int	__kernel_uid_t;
typedef unsigned int	__kernel_gid_t;
typedef long		__kernel_ptrdiff_t;
typedef long		__kernel_time_t;
typedef long		__kernel_clock_t;
typedef int		__kernel_timer_t;
typedef int		__kernel_clockid_t;
typedef long		__kernel_suseconds_t;
typedef int		__kernel_daddr_t;
typedef char *		__kernel_caddr_t;
typedef unsigned short	__kernel_uid16_t;
typedef unsigned short	__kernel_gid16_t;
typedef unsigned int	__kernel_uid32_t;
typedef unsigned int	__kernel_gid32_t;
typedef unsigned int	__kernel_old_uid_t;
typedef unsigned int	__kernel_old_gid_t;
#line 32
typedef unsigned long  	__kernel_nlink_t;
typedef int             __kernel_ipc_pid_t;
typedef unsigned long	__kernel_size_t;
typedef long		__kernel_ssize_t;
typedef unsigned long	__kernel_old_dev_t;
#line 46
typedef long long	__kernel_loff_t;
#line 53
typedef struct {
	int	val[2];
} __kernel_fsid_t;
#line 27 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/types.h"
typedef __u16  __le16;
typedef __u16  __be16;
typedef __u32  __le32;
typedef __u32  __be32;
typedef __u64  __le64;
typedef __u64  __be64;
typedef __u16  __sum16;
typedef __u32  __wsum;
#line 95 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/elf.h"
typedef unsigned long elf_greg_t64;
typedef elf_greg_t64 elf_gregset_t64[48];
typedef unsigned int elf_greg_t32;
typedef elf_greg_t32 elf_gregset_t32[48];
typedef elf_gregset_t32 compat_elf_gregset_t;
#line 123
  typedef elf_greg_t64 elf_greg_t;
  typedef elf_gregset_t64 elf_gregset_t;
#line 132
typedef double elf_fpreg_t;
typedef elf_fpreg_t elf_fpregset_t[33];
#line 154
typedef __vector128 elf_vrreg_t;
typedef elf_vrreg_t elf_vrregset_t[34];
typedef elf_vrreg_t elf_vrregset_t32[33];
typedef elf_fpreg_t elf_vsrreghalf_t32[32];
#line 300
struct ppc64_opd_entry
	unsigned long funcaddr;
	unsigned long r2;
#line 16 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/asm/sigcontext.h"
struct sigcontext {
	unsigned long	_unused[4];
	int		signal;
	int		_pad0;
	unsigned long	handler;
	unsigned long	oldmask;
	struct pt_regs	*regs;
	elf_gregset_t	gp_regs;
	elf_fpregset_t	fp_regs;
#line 82
	elf_vrreg_t	*v_regs;
	long		vmx_reserve[34+34+32+1];
#line 342 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int sigreturn (struct sigcontext *__scp) ;
#line 354 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int siginterrupt (int __sig, int __interrupt) ;
#line 26 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigstack.h"
struct sigstack
    void *ss_sp;
    int ss_onstack;
#line 34
enum
  SS_ONSTACK = 1,
  SS_DISABLE
#line 50
typedef struct sigaltstack
    void *ss_sp;
    int ss_flags;
    size_t ss_size;
  } stack_t;
#line 78 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/ucontext.h"
typedef unsigned long gregset_t[48];
typedef double fpregset_t[33];
#line 84
typedef struct _libc_vscr
	unsigned int __pad[3];
	unsigned int vscr_word;
} vscr_t;
#line 92
typedef struct _libc_vrstate
	unsigned int	vrregs[32][4];
	vscr_t		vscr;
	unsigned int	vrsave;
} vrregset_t  __attribute__((__aligned__(16)));
typedef struct {
	unsigned long	__unused[4];
	int		signal;
	int		__pad0;
	gregset_t	gp_regs;
	fpregset_t	fp_regs;
#line 128
	vrregset_t	*v_regs;
#line 132
} mcontext_t;
#line 138
typedef struct ucontext
    unsigned long int uc_flags;
    struct ucontext *uc_link;
    stack_t uc_stack;
#line 175
    sigset_t    uc_sigmask;
    mcontext_t  uc_mcontext;
  } ucontext_t;
#line 365 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
#line 370
extern int sigaltstack (const struct sigaltstack *__restrict __ss,
			struct sigaltstack *__restrict __oss) ;
#line 51 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
#line 54
typedef union
  char __size[56];
  long int __align__workaround;
} pthread_attr_t;
#line 62
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 77
typedef union
  struct __pthread_mutex_s
    volatile int __lock;
    volatile unsigned int __count;
    volatile int __owner;
    unsigned int __nusers;
#line 89
    int __kind;
    int __spins;
    __pthread_list_t __list;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
} pthread_mutexattr_t;
#line 116
typedef union
  struct
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align__workaround;
} pthread_cond_t;
typedef union
  char __size[4];
} pthread_condattr_t;
#line 141
typedef unsigned int pthread_key_t;
#line 145
typedef int pthread_once_t;
#line 151
typedef union
  struct
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
#line 168
    unsigned int __flags;
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
} pthread_rwlockattr_t;
#line 202
typedef volatile int pthread_spinlock_t;
#line 207
typedef union
  char __size[32];
} pthread_barrier_t;
typedef union
  char __size[4];
} pthread_barrierattr_t;
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigthread.h"
extern int pthread_sigmask (int __how,
			    const __sigset_t *__restrict __newmask,
			    __sigset_t *__restrict __oldmask);
#line 36
extern int pthread_kill (pthread_t __threadid, int __signo) ;
#line 402 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/signal.h"
extern int __libc_current_sigrtmin (void) ;
extern int __libc_current_sigrtmax (void) ;
#line 76 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
#line 75 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/time.h"
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
#line 49 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
typedef __suseconds_t suseconds_t;
#line 55
typedef long int __fd_mask;
#line 67
typedef struct
#line 75
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
#line 78
  } fd_set;
#line 85
typedef __fd_mask fd_mask;
#line 109
extern int select (int __nfds, fd_set *__restrict __readfds,
		   fd_set *__restrict __writefds,
		   fd_set *__restrict __exceptfds,
		   struct timeval *__restrict __timeout);
#line 121
extern int pselect (int __nfds, fd_set *__restrict __readfds,
		    const struct timespec *__restrict __timeout,
		    const __sigset_t *__restrict __sigmask);
#line 57 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/time.h"
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
#line 73
extern int gettimeofday (struct timeval *__restrict __tv,
			 __timezone_ptr_t __tz)  ;
#line 79
extern int settimeofday (const struct timeval *__tv,
			 const struct timezone *__tz)
#line 87
extern int adjtime (const struct timeval *__delta,
		    struct timeval *__olddelta) ;
#line 93
enum __itimer_which
    ITIMER_REAL = 0,
#line 99
    ITIMER_VIRTUAL = 1,
#line 103
    ITIMER_PROF = 2
#line 109
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
#line 122
typedef int __itimer_which_t;
#line 127
extern int getitimer (__itimer_which_t __which,
		      struct itimerval *__value) ;
#line 133
extern int setitimer (__itimer_which_t __which,
		      const struct itimerval *__restrict __new,
		      struct itimerval *__restrict __old) ;
#line 140
extern int utimes (const char *__file, const struct timeval __tvp[2])
#line 145
extern int lutimes (const char *__file, const struct timeval __tvp[2])
#line 149
extern int futimes (int __fd, const struct timeval __tvp[2]) ;
#line 34 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
#line 45
typedef __loff_t loff_t;
#line 49
typedef __ino_t ino_t;
#line 61
typedef __dev_t dev_t;
#line 66
typedef __gid_t gid_t;
#line 71
typedef __mode_t mode_t;
#line 76
typedef __nlink_t nlink_t;
#line 87
typedef __off_t off_t;
#line 105
typedef __id_t id_t;
#line 110
typedef __ssize_t ssize_t;
#line 116
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
#line 123
typedef __key_t key_t;
#line 92
#line 104
#line 151 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
#line 195
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
#line 201
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
#line 30 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/sysmacros.h"
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
					       unsigned int __minor)
#line 229 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __blksize_t blksize_t;
#line 236
typedef __blkcnt_t blkcnt_t;
#line 240
typedef __fsblkcnt_t fsblkcnt_t;
#line 244
typedef __fsfilcnt_t fsfilcnt_t;
#line 26 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/user.h"
struct user {
	struct pt_regs	regs;
	size_t		u_tsize;
	size_t		u_dsize;
	size_t		u_ssize;
	unsigned long	start_code;
	unsigned long	start_data;
	unsigned long	start_stack;
	long int	signal;
	struct regs *	u_ar0;
	unsigned long	magic;
	char		u_comm[32];
#line 62 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/procfs.h"
struct elf_siginfo
    int si_signo;
    int si_code;
    int si_errno;
#line 77
struct elf_prstatus
#line 84
    struct elf_siginfo pr_info;
    short int pr_cursig;
    unsigned long int pr_sigpend;
    unsigned long int pr_sighold;
#line 92
    __pid_t pr_pid;
    __pid_t pr_ppid;
    __pid_t pr_pgrp;
    __pid_t pr_sid;
    struct timeval pr_utime;
    struct timeval pr_stime;
    struct timeval pr_cutime;
    struct timeval pr_cstime;
#line 103
    elf_gregset_t pr_reg;
    int pr_fpvalid;
#line 110
struct elf_prpsinfo
    char pr_state;
    char pr_sname;
    char pr_zomb;
    char pr_nice;
    unsigned long int pr_flag;
    __uid_t pr_uid;
    __gid_t pr_gid;
    __pid_t pr_pid, pr_ppid, pr_pgrp, pr_sid;
    char pr_fname[16];
    char pr_psargs[(80)];
#line 126
typedef void *psaddr_t;
#line 129
typedef elf_gregset_t prgregset_t;
typedef elf_fpregset_t prfpregset_t;
#line 134
typedef __pid_t lwpid_t;
#line 137
typedef struct elf_prstatus prstatus_t;
typedef struct elf_prpsinfo prpsinfo_t;
          Defined "HAVE_SYS_PROCFS_H" to "1"
Checking for header: sys/resource.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 33 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/resource.h"
enum __rlimit_resource
  RLIMIT_CPU = 0,
#line 40
  RLIMIT_FSIZE = 1,
#line 44
  RLIMIT_DATA = 2,
#line 48
  RLIMIT_STACK = 3,
#line 52
  RLIMIT_CORE = 4,
#line 59
  __RLIMIT_RSS = 5,
#line 63
  RLIMIT_NOFILE = 7,
  __RLIMIT_OFILE = RLIMIT_NOFILE,
#line 69
  RLIMIT_AS = 9,
#line 73
  __RLIMIT_NPROC = 6,
#line 77
  __RLIMIT_MEMLOCK = 8,
#line 81
  __RLIMIT_LOCKS = 10,
#line 85
  __RLIMIT_SIGPENDING = 11,
#line 89
  __RLIMIT_MSGQUEUE = 12,
#line 95
  __RLIMIT_NICE = 13,
#line 100
  __RLIMIT_RTPRIO = 14,
#line 103
  __RLIMIT_NLIMITS = 15,
  __RLIM_NLIMITS = __RLIMIT_NLIMITS
#line 107
#line 127
typedef __rlim_t rlim_t;
#line 135
struct rlimit
    rlim_t rlim_cur;
    rlim_t rlim_max;
#line 154
enum __rusage_who
  RUSAGE_SELF = 0,
#line 161
  RUSAGE_CHILDREN = -1
#line 172
struct timeval
    __time_t tv_sec;
#line 178 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/resource.h"
struct rusage
    struct timeval ru_utime;
    struct timeval ru_stime;
    long int ru_maxrss;
#line 188
    long int ru_ixrss;
    long int ru_idrss;
    long int ru_isrss;
#line 195
    long int ru_minflt;
    long int ru_majflt;
    long int ru_nswap;
#line 202
    long int ru_inblock;
    long int ru_oublock;
    long int ru_msgsnd;
    long int ru_msgrcv;
    long int ru_nsignals;
#line 214
    long int ru_nvcsw;
#line 217
    long int ru_nivcsw;
#line 226
enum __priority_which
  PRIO_PROCESS = 0,
  PRIO_PGRP = 1,
  PRIO_USER = 2
#line 28 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/resource.h"
#line 43
typedef int __rlimit_resource_t;
typedef int __rusage_who_t;
typedef int __priority_which_t;
#line 51
extern int getrlimit (__rlimit_resource_t __resource,
		      struct rlimit *__rlimits) ;
#line 70
extern int setrlimit (__rlimit_resource_t __resource,
		      const struct rlimit *__rlimits) ;
#line 88
extern int getrusage (__rusage_who_t __who, struct rusage *__usage) ;
#line 94
extern int getpriority (__priority_which_t __which, id_t __who) ;
#line 98
extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
          Defined "HAVE_SYS_RESOURCE_H" to "1"
Checking for header: unistd.h
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 221 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/unistd.h"
#line 233 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/unistd.h"
#line 238
#line 244
#line 256
typedef __useconds_t useconds_t;
#line 261
#line 268
typedef __intptr_t intptr_t;
#line 275
#line 288
extern int access (const char *__name, int __type)  ;
#line 305
extern int faccessat (int __fd, const char *__file, int __type, int __flag)
#line 331
extern __off_t lseek (int __fd, __off_t __offset, int __whence) ;
#line 350
extern int close (int __fd);
#line 357
extern ssize_t read (int __fd, void *__buf, size_t __nbytes) ;
#line 363
extern ssize_t write (int __fd, const void *__buf, size_t __n) ;
#line 373
extern ssize_t pread (int __fd, void *__buf, size_t __nbytes,
		      __off_t __offset) ;
#line 381
extern ssize_t pwrite (int __fd, const void *__buf, size_t __n,
		       __off_t __offset) ;
#line 414
extern int pipe (int __pipedes[2])  ;
#line 429
extern unsigned int alarm (unsigned int __seconds) ;
#line 441
extern unsigned int sleep (unsigned int __seconds);
#line 449
extern __useconds_t ualarm (__useconds_t __value, __useconds_t __interval)
#line 457
extern int usleep (__useconds_t __useconds);
#line 466
extern int pause (void);
#line 470
extern int chown (const char *__file, __uid_t __owner, __gid_t __group)
#line 475
extern int fchown (int __fd, __uid_t __owner, __gid_t __group)  ;
#line 480
extern int lchown (const char *__file, __uid_t __owner, __gid_t __group)
#line 488
extern int fchownat (int __fd, const char *__file, __uid_t __owner,
		     __gid_t __group, int __flag)
#line 494
extern int chdir (const char *__path)   ;
#line 498
extern int fchdir (int __fd)  ;
#line 508
extern char *getcwd (char *__buf, size_t __size)  ;
#line 522
extern char *getwd (char *__buf)
       __attribute__ ((__deprecated__)) ;
#line 528
extern int dup (int __fd)  ;
#line 531
extern int dup2 (int __fd, int __fd2) ;
#line 540
extern char **__environ;
#line 548
extern int execve (const char *__path, char *const __argv[],
		   char *const __envp[])  ;
#line 554
extern int fexecve (int __fd, char *const __argv[], char *const __envp[])
#line 560
extern int execv (const char *__path, char *const __argv[])
#line 565
extern int execle (const char *__path, const char *__arg, ...)
#line 570
extern int execl (const char *__path, const char *__arg, ...)
#line 575
extern int execvp (const char *__file, char *const __argv[])
#line 581
extern int execlp (const char *__file, const char *__arg, ...)
#line 595
extern int nice (int __inc)  ;
#line 600
extern void _exit (int __status) __attribute__ ((__noreturn__));
#line 26 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/confname.h"
enum
    _PC_LINK_MAX,
    _PC_MAX_CANON,
    _PC_MAX_INPUT,
    _PC_NAME_MAX,
    _PC_PATH_MAX,
    _PC_PIPE_BUF,
    _PC_CHOWN_RESTRICTED,
    _PC_NO_TRUNC,
    _PC_VDISABLE,
    _PC_SYNC_IO,
    _PC_ASYNC_IO,
    _PC_PRIO_IO,
    _PC_SOCK_MAXBUF,
    _PC_FILESIZEBITS,
    _PC_REC_INCR_XFER_SIZE,
    _PC_REC_MAX_XFER_SIZE,
    _PC_REC_MIN_XFER_SIZE,
    _PC_REC_XFER_ALIGN,
    _PC_ALLOC_SIZE_MIN,
    _PC_SYMLINK_MAX,
    _PC_2_SYMLINKS
#line 73
enum
    _SC_ARG_MAX,
    _SC_CHILD_MAX,
    _SC_CLK_TCK,
    _SC_NGROUPS_MAX,
    _SC_OPEN_MAX,
    _SC_STREAM_MAX,
    _SC_TZNAME_MAX,
    _SC_JOB_CONTROL,
    _SC_SAVED_IDS,
    _SC_REALTIME_SIGNALS,
    _SC_PRIORITY_SCHEDULING,
    _SC_TIMERS,
    _SC_ASYNCHRONOUS_IO,
    _SC_PRIORITIZED_IO,
    _SC_SYNCHRONIZED_IO,
    _SC_FSYNC,
    _SC_MAPPED_FILES,
    _SC_MEMLOCK,
    _SC_MEMLOCK_RANGE,
    _SC_MEMORY_PROTECTION,
    _SC_MESSAGE_PASSING,
    _SC_SEMAPHORES,
    _SC_SHARED_MEMORY_OBJECTS,
    _SC_AIO_LISTIO_MAX,
    _SC_AIO_MAX,
    _SC_AIO_PRIO_DELTA_MAX,
    _SC_DELAYTIMER_MAX,
    _SC_MQ_OPEN_MAX,
    _SC_MQ_PRIO_MAX,
    _SC_VERSION,
    _SC_PAGESIZE,
#line 138
    _SC_RTSIG_MAX,
    _SC_SEM_NSEMS_MAX,
    _SC_SEM_VALUE_MAX,
    _SC_SIGQUEUE_MAX,
    _SC_TIMER_MAX,
#line 151
    _SC_BC_BASE_MAX,
    _SC_BC_DIM_MAX,
    _SC_BC_SCALE_MAX,
    _SC_BC_STRING_MAX,
    _SC_COLL_WEIGHTS_MAX,
    _SC_EQUIV_CLASS_MAX,
    _SC_EXPR_NEST_MAX,
    _SC_LINE_MAX,
    _SC_RE_DUP_MAX,
    _SC_CHARCLASS_NAME_MAX,
#line 172
    _SC_2_VERSION,
    _SC_2_C_BIND,
    _SC_2_C_DEV,
    _SC_2_FORT_DEV,
    _SC_2_FORT_RUN,
    _SC_2_SW_DEV,
    _SC_2_LOCALEDEF,
#line 187
    _SC_PII,
    _SC_PII_XTI,
    _SC_PII_SOCKET,
    _SC_PII_INTERNET,
    _SC_PII_OSI,
    _SC_POLL,
    _SC_SELECT,
    _SC_UIO_MAXIOV,
    _SC_IOV_MAX = _SC_UIO_MAXIOV,
    _SC_PII_INTERNET_STREAM,
    _SC_PII_INTERNET_DGRAM,
    _SC_PII_OSI_COTS,
    _SC_PII_OSI_CLTS,
    _SC_PII_OSI_M,
    _SC_T_IOV_MAX,
#line 219
    _SC_THREADS,
    _SC_THREAD_SAFE_FUNCTIONS,
    _SC_GETGR_R_SIZE_MAX,
    _SC_GETPW_R_SIZE_MAX,
    _SC_LOGIN_NAME_MAX,
    _SC_TTY_NAME_MAX,
    _SC_THREAD_DESTRUCTOR_ITERATIONS,
    _SC_THREAD_KEYS_MAX,
    _SC_THREAD_STACK_MIN,
    _SC_THREAD_THREADS_MAX,
    _SC_THREAD_ATTR_STACKADDR,
    _SC_THREAD_ATTR_STACKSIZE,
    _SC_THREAD_PRIORITY_SCHEDULING,
    _SC_THREAD_PRIO_INHERIT,
    _SC_THREAD_PRIO_PROTECT,
    _SC_THREAD_PROCESS_SHARED,
#line 252
    _SC_NPROCESSORS_CONF,
    _SC_NPROCESSORS_ONLN,
    _SC_PHYS_PAGES,
    _SC_AVPHYS_PAGES,
    _SC_ATEXIT_MAX,
    _SC_PASS_MAX,
#line 265
    _SC_XOPEN_VERSION,
    _SC_XOPEN_XCU_VERSION,
    _SC_XOPEN_UNIX,
    _SC_XOPEN_CRYPT,
    _SC_XOPEN_ENH_I18N,
    _SC_XOPEN_SHM,
#line 278
    _SC_2_CHAR_TERM,
    _SC_2_C_VERSION,
    _SC_2_UPE,
#line 285
    _SC_XOPEN_XPG2,
    _SC_XOPEN_XPG3,
    _SC_XOPEN_XPG4,
#line 292
    _SC_CHAR_BIT,
    _SC_CHAR_MAX,
    _SC_CHAR_MIN,
    _SC_INT_MAX,
    _SC_INT_MIN,
    _SC_LONG_BIT,
    _SC_WORD_BIT,
    _SC_MB_LEN_MAX,
    _SC_NZERO,
    _SC_SSIZE_MAX,
    _SC_SCHAR_MAX,
    _SC_SCHAR_MIN,
    _SC_SHRT_MAX,
    _SC_SHRT_MIN,
    _SC_UCHAR_MAX,
    _SC_UINT_MAX,
    _SC_ULONG_MAX,
    _SC_USHRT_MAX,
#line 329
    _SC_NL_ARGMAX,
    _SC_NL_LANGMAX,
    _SC_NL_MSGMAX,
    _SC_NL_NMAX,
    _SC_NL_SETMAX,
    _SC_NL_TEXTMAX,
#line 342
    _SC_XBS5_ILP32_OFF32,
    _SC_XBS5_ILP32_OFFBIG,
    _SC_XBS5_LP64_OFF64,
    _SC_XBS5_LPBIG_OFFBIG,
#line 351
    _SC_XOPEN_LEGACY,
    _SC_XOPEN_REALTIME,
    _SC_XOPEN_REALTIME_THREADS,
#line 358
    _SC_ADVISORY_INFO,
    _SC_BARRIERS,
    _SC_BASE,
    _SC_C_LANG_SUPPORT,
    _SC_C_LANG_SUPPORT_R,
    _SC_CLOCK_SELECTION,
    _SC_CPUTIME,
    _SC_THREAD_CPUTIME,
    _SC_DEVICE_IO,
    _SC_DEVICE_SPECIFIC,
    _SC_DEVICE_SPECIFIC_R,
    _SC_FD_MGMT,
    _SC_FIFO,
    _SC_PIPE,
    _SC_FILE_ATTRIBUTES,
    _SC_FILE_LOCKING,
    _SC_FILE_SYSTEM,
    _SC_MONOTONIC_CLOCK,
    _SC_MULTI_PROCESS,
    _SC_SINGLE_PROCESS,
    _SC_NETWORKING,
    _SC_READER_WRITER_LOCKS,
    _SC_SPIN_LOCKS,
    _SC_REGEXP,
    _SC_REGEX_VERSION,
    _SC_SHELL,
    _SC_SIGNALS,
    _SC_SPAWN,
    _SC_SPORADIC_SERVER,
    _SC_THREAD_SPORADIC_SERVER,
    _SC_SYSTEM_DATABASE,
    _SC_SYSTEM_DATABASE_R,
    _SC_TIMEOUTS,
    _SC_TYPED_MEMORY_OBJECTS,
    _SC_USER_GROUPS,
    _SC_USER_GROUPS_R,
    _SC_2_PBS,
    _SC_2_PBS_ACCOUNTING,
    _SC_2_PBS_LOCATE,
    _SC_2_PBS_MESSAGE,
    _SC_2_PBS_TRACK,
    _SC_SYMLOOP_MAX,
    _SC_STREAMS,
    _SC_2_PBS_CHECKPOINT,
#line 447
    _SC_V6_ILP32_OFF32,
    _SC_V6_ILP32_OFFBIG,
    _SC_V6_LP64_OFF64,
    _SC_V6_LPBIG_OFFBIG,
#line 456
    _SC_HOST_NAME_MAX,
    _SC_TRACE,
    _SC_TRACE_EVENT_FILTER,
    _SC_TRACE_INHERIT,
    _SC_TRACE_LOG,
#line 467
    _SC_LEVEL1_ICACHE_SIZE,
    _SC_LEVEL1_ICACHE_ASSOC,
    _SC_LEVEL1_ICACHE_LINESIZE,
    _SC_LEVEL1_DCACHE_SIZE,
    _SC_LEVEL1_DCACHE_ASSOC,
    _SC_LEVEL1_DCACHE_LINESIZE,
    _SC_LEVEL2_CACHE_SIZE,
    _SC_LEVEL2_CACHE_ASSOC,
    _SC_LEVEL2_CACHE_LINESIZE,
    _SC_LEVEL3_CACHE_SIZE,
    _SC_LEVEL3_CACHE_ASSOC,
    _SC_LEVEL3_CACHE_LINESIZE,
    _SC_LEVEL4_CACHE_SIZE,
    _SC_LEVEL4_CACHE_ASSOC,
    _SC_LEVEL4_CACHE_LINESIZE,
#line 499
    _SC_IPV6 = _SC_LEVEL1_ICACHE_SIZE + 50,
    _SC_RAW_SOCKETS,
#line 504
    _SC_V7_ILP32_OFF32,
    _SC_V7_ILP32_OFFBIG,
    _SC_V7_LP64_OFF64,
    _SC_V7_LPBIG_OFFBIG,
#line 513
    _SC_SS_REPL_MAX,
#line 516
    _SC_TRACE_EVENT_NAME_MAX,
    _SC_TRACE_NAME_MAX,
    _SC_TRACE_SYS_MAX,
    _SC_TRACE_USER_EVENT_MAX,
#line 525
    _SC_XOPEN_STREAMS,
#line 528
    _SC_THREAD_ROBUST_PRIO_INHERIT,
    _SC_THREAD_ROBUST_PRIO_PROTECT
#line 535
enum
    _CS_PATH,
#line 540
    _CS_V6_WIDTH_RESTRICTED_ENVS,
#line 544
    _CS_GNU_LIBC_VERSION,
    _CS_GNU_LIBPTHREAD_VERSION,
#line 549
    _CS_V5_WIDTH_RESTRICTED_ENVS,
#line 553
    _CS_V7_WIDTH_RESTRICTED_ENVS,
#line 557
    _CS_LFS_CFLAGS = 1000,
    _CS_LFS_LDFLAGS,
    _CS_LFS_LIBS,
    _CS_LFS_LINTFLAGS,
    _CS_LFS64_CFLAGS,
    _CS_LFS64_LDFLAGS,
    _CS_LFS64_LIBS,
    _CS_LFS64_LINTFLAGS,
#line 574
    _CS_XBS5_ILP32_OFF32_CFLAGS = 1100,
    _CS_XBS5_ILP32_OFF32_LDFLAGS,
    _CS_XBS5_ILP32_OFF32_LIBS,
    _CS_XBS5_ILP32_OFF32_LINTFLAGS,
    _CS_XBS5_ILP32_OFFBIG_CFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LDFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LIBS,
    _CS_XBS5_ILP32_OFFBIG_LINTFLAGS,
    _CS_XBS5_LP64_OFF64_CFLAGS,
    _CS_XBS5_LP64_OFF64_LDFLAGS,
    _CS_XBS5_LP64_OFF64_LIBS,
    _CS_XBS5_LP64_OFF64_LINTFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_CFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LDFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LIBS,
    _CS_XBS5_LPBIG_OFFBIG_LINTFLAGS,
#line 607
    _CS_POSIX_V6_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LIBS,
    _CS_POSIX_V6_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V6_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V6_LP64_OFF64_CFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LIBS,
    _CS_POSIX_V6_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LINTFLAGS,
#line 640
    _CS_POSIX_V7_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LIBS,
    _CS_POSIX_V7_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V7_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V7_LP64_OFF64_CFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LIBS,
    _CS_POSIX_V7_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LINTFLAGS,
#line 673
    _CS_V6_ENV,
    _CS_V7_ENV
#line 609 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/unistd.h"
extern long int pathconf (const char *__path, int __name)
#line 613
extern long int fpathconf (int __fd, int __name) ;
#line 616
extern long int sysconf (int __name) ;
#line 620
extern size_t confstr (int __name, char *__buf, size_t __len) ;
#line 625
extern __pid_t getpid (void) ;
#line 628
extern __pid_t getppid (void) ;
#line 633
extern __pid_t getpgrp (void) ;
#line 643
extern __pid_t __getpgid (__pid_t __pid) ;
extern __pid_t getpgid (__pid_t __pid) ;
#line 652
extern int setpgid (__pid_t __pid, __pid_t __pgid) ;
#line 669
extern int setpgrp (void) ;
#line 686
extern __pid_t setsid (void) ;
#line 690
extern __pid_t getsid (__pid_t __pid) ;
#line 694
extern __uid_t getuid (void) ;
#line 697
extern __uid_t geteuid (void) ;
#line 700
extern __gid_t getgid (void) ;
#line 703
extern __gid_t getegid (void) ;
#line 708
extern int getgroups (int __size, __gid_t __list[])  ;
#line 719
extern int setuid (__uid_t __uid) ;
#line 724
extern int setreuid (__uid_t __ruid, __uid_t __euid) ;
#line 729
extern int seteuid (__uid_t __uid) ;
#line 736
extern int setgid (__gid_t __gid) ;
#line 741
extern int setregid (__gid_t __rgid, __gid_t __egid) ;
#line 746
extern int setegid (__gid_t __gid) ;
#line 775
extern __pid_t fork (void) ;
#line 783
extern __pid_t vfork (void) ;
#line 789
extern char *ttyname (int __fd) ;
#line 793
extern int ttyname_r (int __fd, char *__buf, size_t __buflen)
#line 798
extern int isatty (int __fd) ;
#line 804
extern int ttyslot (void) ;
#line 809
extern int link (const char *__from, const char *__to)
#line 815
extern int linkat (int __fromfd, const char *__from, int __tofd,
		   const char *__to, int __flags)
#line 822
extern int symlink (const char *__from, const char *__to)
#line 828
extern ssize_t readlink (const char *__restrict __path,
			 char *__restrict __buf, size_t __len)
#line 835
extern int symlinkat (const char *__from, int __tofd,
		      const char *__to)   ;
#line 839
extern ssize_t readlinkat (int __fd, const char *__restrict __path,
#line 845
extern int unlink (const char *__name)  ;
#line 849
extern int unlinkat (int __fd, const char *__name, int __flag)
#line 854
extern int rmdir (const char *__path)  ;
#line 858
extern __pid_t tcgetpgrp (int __fd) ;
#line 861
extern int tcsetpgrp (int __fd, __pid_t __pgrp_id) ;
#line 868
extern char *getlogin (void);
#line 876
extern int getlogin_r (char *__name, size_t __name_len) ;
#line 881
extern int setlogin (const char *__name)  ;
#line 59 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/getopt.h"
extern char *optarg;
#line 73
extern int optind;
#line 78
extern int opterr;
#line 82
extern int optopt;
#line 152
extern int getopt (int ___argc, char *const *___argv, const char *__shortopts)
#line 898 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/unistd.h"
extern int gethostname (char *__name, size_t __len)  ;
#line 905
extern int sethostname (const char *__name, size_t __len)
#line 910
extern int sethostid (long int __id)  ;
#line 916
extern int getdomainname (char *__name, size_t __len)
extern int setdomainname (const char *__name, size_t __len)
#line 925
extern int vhangup (void) ;
#line 928
extern int revoke (const char *__file)   ;
#line 936
extern int profil (unsigned short int *__sample_buffer, size_t __size,
		   size_t __offset, unsigned int __scale)
#line 944
extern int acct (const char *__name) ;
#line 948
extern char *getusershell (void) ;
extern void endusershell (void) ;
extern void setusershell (void) ;
#line 956
extern int daemon (int __nochdir, int __noclose)  ;
#line 963
extern int chroot (const char *__path)   ;
#line 967
extern char *getpass (const char *__prompt) ;
#line 976
extern int fsync (int __fd);
#line 983
extern long int gethostid (void);
#line 986
extern void sync (void) ;
#line 992
extern int getpagesize (void)   __attribute__ ((const));
#line 997
extern int getdtablesize (void) ;
#line 1007
extern int truncate (const char *__file, __off_t __length)
#line 1026
extern int ftruncate (int __fd, __off_t __length)  ;
#line 1047
extern int brk (void *__addr)  ;
#line 1053
extern void *sbrk (intptr_t __delta) ;
#line 1068
extern long int syscall (long int __sysno, ...) ;
#line 1091
extern int lockf (int __fd, int __cmd, __off_t __len) ;
#line 1122
extern int fdatasync (int __fildes);
#line 1151
extern char *ctermid (char *__s) ;
          Defined "HAVE_UNISTD_H" to "1"
TEST check from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: netinet/in.h
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.headers  /tmp/petsc-ITHdGX/config.headers/conftest.c
stdout:
#line 49
#line 56
#line 66
#line 77
#line 91
#line 104
#line 120
#line 123
#line 135
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
#line 37
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
#line 53
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 134
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
#line 158
typedef int __clockid_t;
#line 161
typedef void * __timer_t;
#line 164
typedef long int __blksize_t;
#line 169
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
#line 173
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
#line 177
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
#line 184
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
#line 189
typedef long int __intptr_t;
#line 192
typedef unsigned int __socklen_t;
#line 45
#line 49
#line 61
#line 66
#line 71
#line 76
#line 81
#line 87
#line 99
#line 105
#line 110
#line 116
#line 123
#line 60 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
typedef __clock_t clock_t;
#line 76
#line 92
#line 104
#line 211 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include/stddef.h"
typedef unsigned long size_t;
#line 201
#line 29
typedef struct
  } __sigset_t;
#line 38 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
#line 55
#line 67
typedef struct
#line 75
#line 78
  } fd_set;
#line 85
#line 109
#line 121
__extension__
__extension__
__extension__
#line 236
#line 240
#line 244
#line 54
typedef union
  char __size[56];
} pthread_attr_t;
#line 62
} __pthread_list_t;
#line 77
typedef union
#line 89
    int __kind;
    int __spins;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
#line 116
typedef union
  struct
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
#line 141
#line 145
#line 151
typedef union
  struct
    int __writer;
    int __shared;
#line 168
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
#line 202
#line 207
typedef union
  char __size[32];
typedef union
  char __size[4];
struct iovec
    void *iov_base;
    size_t iov_len;
#line 51
#line 66
		       __off_t __offset) ;
#line 78
			__off_t __offset) ;
#line 40
enum __socket_type
  SOCK_STREAM = 1,
#line 45
  SOCK_DGRAM = 2,
#line 48
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
#line 55
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
#line 65
#line 68
#line 71
struct sockaddr
    char sa_data[14];
#line 187
#line 196
enum
    MSG_OOB		= 0x01,
    MSG_PEEK		= 0x02,
#line 209
    MSG_CTRUNC		= 0x08,
    MSG_PROXY		= 0x10,
    MSG_TRUNC		= 0x20,
    MSG_EOR		= 0x80,
    MSG_FIN		= 0x200,
    MSG_SYN		= 0x400,
    MSG_RST		= 0x1000,
    MSG_MORE		= 0x8000,
#line 238
#line 242
#line 247
struct msghdr
    void *msg_name;
    size_t msg_iovlen;
    void *msg_control;
#line 261
    int msg_flags;
#line 274
struct cmsghdr
    size_t cmsg_len;
#line 281
    int cmsg_level;
    int cmsg_type;
#line 304
#line 331
enum
    SCM_RIGHTS = 0x01
#line 339
#line 411
struct linger
    int l_onoff;
    int l_linger;
#line 425
struct osockaddr
#line 54
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
#line 105
#line 111
		       int __fds[2]) ;
#line 115
#line 119
#line 129
#line 133
#line 141
#line 148
#line 155
#line 166
#line 176
			int __flags);
#line 184
#line 190
#line 197
#line 204
#line 214
#line 232
#line 237
#line 245
enum
    IPPROTO_IP = 0,
    IPPROTO_ICMP = 1,
    IPPROTO_IGMP = 2,
    IPPROTO_IPIP = 4,
    IPPROTO_TCP = 6,
    IPPROTO_EGP = 8,
    IPPROTO_PUP = 12,
    IPPROTO_UDP = 17,
    IPPROTO_IDP = 22,
    IPPROTO_TP = 29,
    IPPROTO_DCCP = 33,
    IPPROTO_IPV6 = 41,
    IPPROTO_RSVP = 46,
    IPPROTO_GRE = 47,
    IPPROTO_ESP = 50,
    IPPROTO_AH = 51,
    IPPROTO_NONE = 59,
    IPPROTO_MTP = 92,
    IPPROTO_ENCAP = 98,
    IPPROTO_PIM = 103,
    IPPROTO_COMP = 108,
    IPPROTO_SCTP = 132,
    IPPROTO_RAW = 255,
    IPPROTO_MAX
#line 97
#line 100
enum
    IPPORT_ECHO = 7,
    IPPORT_DISCARD = 9,
    IPPORT_SYSTAT = 11,
    IPPORT_FTP = 21,
    IPPORT_TELNET = 23,
    IPPORT_SMTP = 25,
    IPPORT_WHOIS = 43,
    IPPORT_MTP = 57,
    IPPORT_TFTP = 69,
    IPPORT_RJE = 77,
    IPPORT_FINGER = 79,
    IPPORT_SUPDUP = 95,
#line 122
#line 128
#line 133
#line 136
#line 141
struct in_addr
    in_addr_t s_addr;
#line 198
struct in6_addr
    union
      } __in6_u;
#line 213
#line 225
struct sockaddr_in
    in_port_t sin_port;
#line 232
#line 239
struct sockaddr_in6
#line 251
struct ip_mreq
#line 257
#line 266
#line 269
#line 275
struct ipv6_mreq
#line 281
#line 287
struct group_req
#line 293
#line 302
#line 305
#line 310
struct ip_msfilter
#line 316
#line 319
#line 322
#line 331
struct group_filter
#line 337
#line 340
    uint32_t gf_fmode;
#line 343
    uint32_t gf_numsrc;
struct ip_opts
    char ip_opts[40];
#line 105
struct ip_mreqn
    int	imr_ifindex;
#line 113
struct in_pktinfo
    int ipi_ifindex;
#line 446
#line 449
          Defined "HAVE_NETINET_IN_H" to "1"
TEST checkRecursiveMacros from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:218)
TESTING: checkRecursiveMacros from config.headers(config/BuildSystem/config/headers.py:218)
  Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.headers/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.headers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.headers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
  return 0;
TEST configureCacheDetails from PETSc.utilities.cacheDetails(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/cacheDetails.py:78)
TESTING: configureCacheDetails from PETSc.utilities.cacheDetails(config/PETSc/utilities/cacheDetails.py:78)
  Try to determine the size and associativity of the cache.
          Pushing language C
                    All intermediate test results are stored in /tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <unistd.h>
long getconf_LEVEL1_DCACHE_SIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_SIZE); return (16 <= val && val <= 2147483647) ? val : 32768; }
int main() {
  return 0;
          Popping language C
        Defined "LEVEL1_DCACHE_SIZE" to "32768"
        Defined "LEVEL1_DCACHE_LINESIZE" to "32"
        Defined "LEVEL1_DCACHE_ASSOC" to "0"
TEST checkMemcmp from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:109)
TESTING: checkMemcmp from config.functions(config/BuildSystem/config/functions.py:109)
  Check for 8-bit clean memcmp
TEST checkSysinfo from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:133)
TESTING: checkSysinfo from config.functions(config/BuildSystem/config/functions.py:133)
  Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
                      All intermediate test results are stored in /tmp/petsc-ITHdGX/config.functions
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.functions/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/config.functions  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.functions/conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.functions/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.functions/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
          Defined "HAVE_SYSINFO" to "1"
Checking for header: linux/kernel.h
stdout:
#line 11 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/kernel.h"
struct sysinfo {
	long uptime;
	unsigned long loads[3];
	unsigned long totalram;
	unsigned long freeram;
	unsigned long sharedram;
	unsigned long bufferram;
	unsigned long totalswap;
	unsigned long freeswap;
	unsigned short procs;
	unsigned short pad;
	unsigned long totalhigh;
	unsigned long freehigh;
	unsigned int mem_unit;
	char _f[20-2*sizeof(long)-sizeof(int)];
#line 60
struct module;
void mark_hardware_unsupported(const char *msg);
void mark_tech_preview(const char *msg, struct module *mod);
Possible ERROR while running preprocessor:
stdout:
struct sysinfo {
	long uptime;
	unsigned short pad;
#line 60
struct module;
void mark_tech_preview(const char *msg, struct module *mod);stderr:
"/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/kernel.h", line 46.9: 1506-312 (W) Compiler internal name __FUNCTION__ has been defined as a macro.
"/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/kernel.h", line 46.9: 1506-236 (W) Macro name __FUNCTION__ has been redefined.
Source:
#include <linux/kernel.h>
Checking for header: sys/sysinfo.h
stdout:
struct sysinfo {
	long uptime;
	unsigned short pad;
#line 60
struct module;
#line 30 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/sysinfo.h"
extern int sysinfo (struct sysinfo *__info) ;
#line 34
extern int get_nprocs_conf (void) ;
#line 37
extern int get_nprocs (void) ;
#line 41
extern long int get_phys_pages (void) ;
#line 44
extern long int get_avphys_pages (void) ;
stdout:
struct sysinfo {
	long uptime;
	unsigned short pad;
#line 60
struct module;
#line 34
#line 37
#line 41
#line 44
extern long int get_avphys_pages (void) ;stderr:
Source:
#include <sys/sysinfo.h>
Checking for header: sys/systeminfo.h
Possible ERROR while running preprocessor: exit code 256
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <sys/systeminfo.h> not found.
Source:
#include <sys/systeminfo.h>
Possible ERROR while running compiler: exit code 256
stderr:
"/tmp/petsc-ITHdGX/config.functions/conftest.c", line 13.4: 1506-205 (S) #error "Cannot check sysinfo without special headers"
Source:
#ifdef HAVE_LINUX_KERNEL_H
#  include <linux/kernel.h>
#  include <linux/sys.h>
#  ifdef HAVE_SYS_SYSINFO_H
#    include <sys/sysinfo.h>
#  endif
#elif defined(HAVE_SYS_SYSTEMINFO_H)
#  include <sys/systeminfo.h>
#else
#  error "Cannot check sysinfo without special headers"
#endif
int main() {
char buf[10]; long count=10; sysinfo(1, buf, count);
  return 0;
          Compile failed inside link
TEST checkVPrintf from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:156)
TESTING: checkVPrintf from config.functions(config/BuildSystem/config/functions.py:156)
  Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
Checking for functions [vprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vprintf) || defined (__stub___vprintf)
vprintf_will_always_fail_with_ENOSYS();
#else
vprintf();
#endif
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_VPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vprintf( "%d", Argp );
  return 0;
                Pushing language C
                Popping language C
TEST checkVFPrintf from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:163)
TESTING: checkVFPrintf from config.functions(config/BuildSystem/config/functions.py:163)
  Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
Checking for functions [vfprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vfprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vfprintf) || defined (__stub___vfprintf)
vfprintf_will_always_fail_with_ENOSYS();
#else
vfprintf();
#endif
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_VFPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vfprintf(stdout, "%d", Argp );
  return 0;
                Pushing language C
                Popping language C
TEST checkVSNPrintf from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:170)
TESTING: checkVSNPrintf from config.functions(config/BuildSystem/config/functions.py:170)
  Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
Checking for functions [_vsnprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _vsnprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__vsnprintf) || defined (__stub____vsnprintf)
_vsnprintf_will_always_fail_with_ENOSYS();
#else
_vsnprintf();
#endif
  return 0;
                  Pushing language C
                  Popping language C
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `_vsnprintf'
Checking for functions [vsnprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vsnprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vsnprintf) || defined (__stub___vsnprintf)
#else
vsnprintf();
#endif
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_VSNPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
vsnprintf(str,5, "%d", Argp );
  return 0;
                Pushing language C
                Popping language C
TEST checkNanosleep from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:214)
TESTING: checkNanosleep from config.functions(config/BuildSystem/config/functions.py:214)
  Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
 tp.tv_sec = 0;
 tp.tv_nsec = (long)(1e9);
 nanosleep(&tp,0);
  return 0;
                Pushing language C
                Popping language C
        Defined "HAVE_NANOSLEEP" to "1"
TEST checkSignalHandlerType from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:190)
TESTING: checkSignalHandlerType from config.functions(config/BuildSystem/config/functions.py:190)
  Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
        Pushing language Cxx
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.functions/conftest.o -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+    /tmp/petsc-ITHdGX/config.functions/conftest.cc
Successful compile:
Source:
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
  return 0;
                Pushing language CXX
                Popping language CXX
Executing: mpixlcxx_r  -o /tmp/petsc-ITHdGX/config.functions/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+ /tmp/petsc-ITHdGX/config.functions/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
        Defined "SIGNAL_CAST" to " "
        Popping language Cxx
TEST checkFreeReturnType from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:200)
TESTING: checkFreeReturnType from config.functions(config/BuildSystem/config/functions.py:200)
  Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
stderr:
"/tmp/petsc-ITHdGX/config.functions/conftest.c", line 6.25: 1506-068 (S) Operation between types "int" and "void" is not allowed.
Source:
#include <stdlib.h>
int main() {
int ierr; void *p; ierr = free(p); return 0;
  return 0;
TEST checkVariableArgumentLists from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:206)
TESTING: checkVariableArgumentLists from config.functions(config/BuildSystem/config/functions.py:206)
  Checks whether the variable argument list functionality is working
Successful compile:
Source:
#include <stdarg.h>
int main() {
  va_list l1, l2;
  va_copy(l1, l2);
  return 0;
  return 0;
                Pushing language C
                Popping language C
        Defined "HAVE_VA_COPY" to "1"
TEST checkClassify from config.functions(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/functions.py:88)
TESTING: checkClassify from config.functions(config/BuildSystem/config/functions.py:88)
  Recursive decompose to rapidly classify functions as found or missing
    To confirm that a function is missing, we require a compile/link
    failure with only that function in a compilation unit.  In contrast,
    we can confirm that many functions are present by compiling them all
    together in a large compilation unit.  We optimistically compile
    everything together, then trim all functions that were named in the
    error message and bisect the result.  The trimming is only an
    optimization to increase the likelihood of a big-batch compile
    succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [rand getdomainname _sleep snprintf realpath dlsym bzero _getcwd getwd uname _lseek sleep _access lseek usleep _intel_fast_memset dlclose gethostname clock get_nprocs access _snprintf dlerror mkstemp fork getpagesize sbreak memalign sigset getcwd gethostbyname gettimeofday readlink PXFGETARG sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times _intel_fast_memcpy time sysctlbyname stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char getdomainname();
char _sleep();
char snprintf();
char realpath();
char dlsym();
char bzero();
char _getcwd();
char getwd();
char uname();
char _lseek();
char sleep();
char _access();
char lseek();
char usleep();
char _intel_fast_memset();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char access();
char _snprintf();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
char sbreak();
char memalign();
char sigset();
char getcwd();
char gethostbyname();
char gettimeofday();
char readlink();
char PXFGETARG();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char _intel_fast_memcpy();
char time();
char sysctlbyname();
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
#else
snprintf();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
#else
sleep();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
#if defined (__stub_lseek) || defined (__stub___lseek)
#else
lseek();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub__intel_fast_memset) || defined (__stub____intel_fast_memset)
_intel_fast_memset_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_get_nprocs) || defined (__stub___get_nprocs)
get_nprocs_will_always_fail_with_ENOSYS();
#else
get_nprocs();
#endif
#if defined (__stub_access) || defined (__stub___access)
#else
access();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_mkstemp) || defined (__stub___mkstemp)
mkstemp_will_always_fail_with_ENOSYS();
#else
mkstemp();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub_sigset) || defined (__stub___sigset)
sigset_will_always_fail_with_ENOSYS();
#else
sigset();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
#else
getcwd();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_gettimeofday) || defined (__stub___gettimeofday)
gettimeofday_will_always_fail_with_ENOSYS();
#else
gettimeofday();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_sigaction) || defined (__stub___sigaction)
sigaction_will_always_fail_with_ENOSYS();
#else
sigaction();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_memmove) || defined (__stub___memmove)
memmove_will_always_fail_with_ENOSYS();
#else
memmove();
#endif
#if defined (__stub_signal) || defined (__stub___signal)
signal_will_always_fail_with_ENOSYS();
#else
signal();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub_times) || defined (__stub___times)
times_will_always_fail_with_ENOSYS();
#else
times();
#endif
#if defined (__stub__intel_fast_memcpy) || defined (__stub____intel_fast_memcpy)
_intel_fast_memcpy_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub_sysctlbyname) || defined (__stub___sysctlbyname)
sysctlbyname_will_always_fail_with_ENOSYS();
#else
sysctlbyname();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x12c): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x4c): warning: the `getwd' function is dangerous and should not be used.
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x1c): undefined reference to `_sleep'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x44): undefined reference to `_getcwd'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x5c): undefined reference to `_lseek'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x6c): undefined reference to `_access'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x84): undefined reference to `_intel_fast_memset'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xb4): undefined reference to `_snprintf'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xdc): undefined reference to `sbreak'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x114): undefined reference to `PXFGETARG'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x16c): undefined reference to `_intel_fast_memcpy'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x17c): undefined reference to `sysctlbyname'
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0x184): undefined reference to `stricmp'
Checking for functions [rand getdomainname realpath dlsym bzero uname usleep dlclose gethostname clock get_nprocs dlerror mkstemp fork]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char realpath();
char dlsym();
char bzero();
char uname();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char dlerror();
char mkstemp();
char fork();
#ifdef __cplusplus
#endif
int main() {
#else
rand();
#endif
#else
getdomainname();
#endif
#else
realpath();
#endif
#else
dlsym();
#endif
#else
bzero();
#endif
#else
uname();
#endif
#else
usleep();
#endif
#else
dlclose();
#endif
#else
gethostname();
#endif
#else
clock();
#endif
#else
get_nprocs();
#endif
#else
dlerror();
#endif
#else
mkstemp();
#endif
#else
fork();
#endif
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_RAND" to "1"
                Defined "HAVE_GETDOMAINNAME" to "1"
                Defined "HAVE_REALPATH" to "1"
                Defined "HAVE_DLSYM" to "1"
                Defined "HAVE_BZERO" to "1"
                Defined "HAVE_UNAME" to "1"
                Defined "HAVE_USLEEP" to "1"
                Defined "HAVE_DLCLOSE" to "1"
                Defined "HAVE_GETHOSTNAME" to "1"
                Defined "HAVE_CLOCK" to "1"
                Defined "HAVE_GET_NPROCS" to "1"
                Defined "HAVE_DLERROR" to "1"
                Defined "HAVE_MKSTEMP" to "1"
                Defined "HAVE_FORK" to "1"
Checking for functions [getpagesize memalign sigset gethostbyname gettimeofday readlink sigaction strcasecmp drand48 socket memmove signal popen getrusage times]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getpagesize();
char memalign();
char sigset();
char readlink();
char sigaction();
char strcasecmp();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
#ifdef __cplusplus
#endif
int main() {
#else
getpagesize();
#endif
#else
memalign();
#endif
#else
sigset();
#endif
#else
gethostbyname();
#endif
#else
gettimeofday();
#endif
#else
readlink();
#endif
#else
sigaction();
#endif
#else
strcasecmp();
#endif
#else
drand48();
#endif
#else
socket();
#endif
#else
memmove();
#endif
#else
signal();
#endif
#else
popen();
#endif
#else
getrusage();
#endif
#else
times();
#endif
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_GETPAGESIZE" to "1"
                Defined "HAVE_MEMALIGN" to "1"
                Defined "HAVE_SIGSET" to "1"
                Defined "HAVE_GETHOSTBYNAME" to "1"
                Defined "HAVE_GETTIMEOFDAY" to "1"
                Defined "HAVE_READLINK" to "1"
                Defined "HAVE_SIGACTION" to "1"
                Defined "HAVE_STRCASECMP" to "1"
                Defined "HAVE_DRAND48" to "1"
                Defined "HAVE_SOCKET" to "1"
                Defined "HAVE_MEMMOVE" to "1"
                Defined "HAVE_SIGNAL" to "1"
                Defined "HAVE_POPEN" to "1"
                Defined "HAVE_GETRUSAGE" to "1"
                Defined "HAVE_TIMES" to "1"
Checking for functions [_sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `_sleep'
Checking for functions [snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_SNPRINTF" to "1"
Checking for functions [_getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `_getcwd'
Checking for functions [getwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getwd();
#ifdef __cplusplus
#endif
int main() {
#else
getwd();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): warning: the `getwd' function is dangerous and should not be used.
                Defined "HAVE_GETWD" to "1"
Checking for functions [_lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `_lseek'
Checking for functions [sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_SLEEP" to "1"
Checking for functions [_access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `_access'
Checking for functions [lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_LSEEK" to "1"
Checking for functions [_intel_fast_memset]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `_intel_fast_memset'
Checking for functions [access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_ACCESS" to "1"
Checking for functions [_snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `_snprintf'
Checking for functions [sbreak]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `sbreak'
Checking for functions [getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_GETCWD" to "1"
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `PXFGETARG'
Checking for functions [dlopen]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char dlopen();
#ifdef __cplusplus
#endif
int main() {
#else
dlopen();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
                Defined "HAVE_DLOPEN" to "1"
Checking for functions [_intel_fast_memcpy]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `_intel_fast_memcpy'
Checking for functions [time]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char time();
#ifdef __cplusplus
#endif
int main() {
#else
time();
#endif
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_TIME" to "1"
Checking for functions [sysctlbyname]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
sysctlbyname();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `sysctlbyname'
Checking for functions [stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `stricmp'
TEST configureFeatureTestMacros from PETSc.utilities.featureTestMacros(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/featureTestMacros.py:13)
TESTING: configureFeatureTestMacros from PETSc.utilities.featureTestMacros(config/PETSc/utilities/featureTestMacros.py:13)
  Checks if certain feature test macros are support
                  All intermediate test results are stored in /tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros/conftest.c
stderr:
"/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros/conftest.c", line 4.10: 1506-296 (S) #include file <sysctl.h> not found.
Source:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
  return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
  return 0;
        Defined "_BSD_SOURCE" to "1"
Successful compile:
Source:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
  return 0;
        Defined "_GNU_SOURCE" to "1"
TEST configureMemorySize from PETSc.utilities.getResidentSetSize(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/getResidentSetSize.py:31)
TESTING: configureMemorySize from PETSc.utilities.getResidentSetSize(config/PETSc/utilities/getResidentSetSize.py:31)
  Try to determine how to measure the memory usage
TEST configureFPTrap from PETSc.utilities.FPTrap(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/FPTrap.py:27)
TESTING: configureFPTrap from PETSc.utilities.FPTrap(config/PETSc/utilities/FPTrap.py:27)
  Checking the handling of floating point traps
Checking for header: sigfpe.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <sigfpe.h> not found.
Source:
#include <sigfpe.h>
Checking for header: fpxcp.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <fpxcp.h> not found.
Source:
#include <fpxcp.h>
Checking for header: floatingpoint.h
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <floatingpoint.h> not found.
Source:
#include <floatingpoint.h>
TEST check_siginfo_t from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:46)
TESTING: check_siginfo_t from config.types(config/BuildSystem/config/types.py:46)
  Checks if siginfo_t exists in signal.h. This check is for windows, and C89 check.
Checking for type: siginfo_t
                    All intermediate test results are stored in /tmp/petsc-ITHdGX/config.types
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.types/conftest.o -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.types/conftest.c
Successful compile:
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
#endif
int main() {
siginfo_t a;;
  return 0;
siginfo_t found
        Defined "HAVE_SIGINFO_T" to "1"
TEST check__int64 from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:52)
TESTING: check__int64 from config.types(config/BuildSystem/config/types.py:52)
  Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
__int64 a;;
  return 0;
__int64 found
        Defined "HAVE___INT64" to "1"
TEST checkSizeTypes from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:58)
TESTING: checkSizeTypes from config.types(config/BuildSystem/config/types.py:58)
  Checks for types associated with sizes, such as size_t.
Checking for type: size_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
size_t a;;
  return 0;
size_t found
TEST checkFileTypes from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:68)
TESTING: checkFileTypes from config.types(config/BuildSystem/config/types.py:68)
  Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
mode_t a;;
  return 0;
mode_t found
Checking for type: off_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
off_t a;;
  return 0;
off_t found
TEST checkIntegerTypes from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:63)
TESTING: checkIntegerTypes from config.types(config/BuildSystem/config/types.py:63)
  Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
int32_t a;;
  return 0;
int32_t found
TEST checkPID from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:74)
TESTING: checkPID from config.types(config/BuildSystem/config/types.py:74)
  Checks for pid_t, and defines it if necessary
Checking for type: pid_t
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
pid_t a;;
  return 0;
pid_t found
TEST checkUID from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:78)
TESTING: checkUID from config.types(config/BuildSystem/config/types.py:78)
  Checks for uid_t and gid_t, and defines them if necessary
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/config.headers  /tmp/petsc-ITHdGX/config.types/conftest.c
stdout:
#line 37
#line 53
#line 134
#line 158
#line 161
#line 164
#line 169
#line 173
#line 177
#line 184
#line 189
#line 192
#line 34 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
#line 45
typedef __loff_t loff_t;
#line 49
typedef __ino_t ino_t;
#line 61
typedef __dev_t dev_t;
#line 66
typedef __gid_t gid_t;
#line 71
typedef __mode_t mode_t;
#line 76
typedef __nlink_t nlink_t;
#line 81
typedef __uid_t uid_t;
#line 87
typedef __off_t off_t;
#line 99
typedef __pid_t pid_t;
#line 105
typedef __id_t id_t;
#line 110
typedef __ssize_t ssize_t;
#line 116
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
#line 123
typedef __key_t key_t;
#line 76
typedef __time_t time_t;
#line 92
typedef __clockid_t clockid_t;
#line 104
typedef __timer_t timer_t;
#line 151 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
#line 195
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
#line 201
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
#line 24 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sigset.h"
typedef int __sig_atomic_t;
#line 29
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
typedef __sigset_t sigset_t;
#line 120 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 75 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/time.h"
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
#line 49 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/select.h"
typedef __suseconds_t suseconds_t;
#line 55
typedef long int __fd_mask;
#line 67
typedef struct
#line 75
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
#line 78
  } fd_set;
#line 85
typedef __fd_mask fd_mask;
#line 109
extern int select (int __nfds, fd_set *__restrict __readfds,
		   fd_set *__restrict __writefds,
		   fd_set *__restrict __exceptfds,
		   struct timeval *__restrict __timeout);
#line 121
extern int pselect (int __nfds, fd_set *__restrict __readfds,
		    const struct timespec *__restrict __timeout,
		    const __sigset_t *__restrict __sigmask);
#line 30 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/sysmacros.h"
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
					       unsigned int __minor)
#line 229 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/types.h"
typedef __blksize_t blksize_t;
#line 236
typedef __blkcnt_t blkcnt_t;
#line 240
typedef __fsblkcnt_t fsblkcnt_t;
#line 244
typedef __fsfilcnt_t fsfilcnt_t;
#line 51 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
#line 54
typedef union
  char __size[56];
  long int __align__workaround;
} pthread_attr_t;
#line 62
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 77
typedef union
  struct __pthread_mutex_s
    volatile int __lock;
    volatile unsigned int __count;
    volatile int __owner;
    unsigned int __nusers;
#line 89
    int __kind;
    int __spins;
    __pthread_list_t __list;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
} pthread_mutexattr_t;
#line 116
typedef union
  struct
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align__workaround;
} pthread_cond_t;
typedef union
  char __size[4];
} pthread_condattr_t;
#line 141
typedef unsigned int pthread_key_t;
#line 145
typedef int pthread_once_t;
#line 151
typedef union
  struct
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
#line 168
    unsigned int __flags;
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
} pthread_rwlockattr_t;
#line 202
typedef volatile int pthread_spinlock_t;
#line 207
typedef union
  char __size[32];
} pthread_barrier_t;
typedef union
  char __size[4];
} pthread_barrierattr_t;
TEST checkSignal from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:85)
TESTING: checkSignal from config.types(config/BuildSystem/config/types.py:85)
  Checks the return type of signal() and defines RETSIGTYPE to that type name
Successful compile:
Source:
#include <signal.h>
#ifdef signal
#undef signal
#endif
#ifdef __cplusplus
extern "C" void (*signal (int, void(*)(int)))(int);
#else
void (*signal())();
#endif
int main() {
  return 0;
        Defined "RETSIGTYPE" to "void"
TEST checkC99Complex from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:106)
TESTING: checkC99Complex from config.types(config/BuildSystem/config/types.py:106)
  Check for complex numbers in in C99 std
       Note that since PETSc source code uses _Complex we test specifically for that, not complex
Successful compile:
Source:
#include <complex.h>
int main() {
double _Complex x;
 x = I;
  return 0;
Successful compile:
Source:
int main() {
double _Complex x;
 x = I;
  return 0;
                Pushing language C
                Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.types/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.types/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
        Defined "HAVE_C99_COMPLEX" to "1"
TEST checkCxxComplex from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:117)
TESTING: checkCxxComplex from config.types(config/BuildSystem/config/types.py:117)
  Check for complex numbers in namespace std
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.types/conftest.o -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.types  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+    /tmp/petsc-ITHdGX/config.types/conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
  return 0;
Executing: mpixlcxx_r  -o /tmp/petsc-ITHdGX/config.types/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+ /tmp/petsc-ITHdGX/config.types/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
        Defined "HAVE_CXX_COMPLEX" to "1"
TEST checkFortranKind from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:138)
TESTING: checkFortranKind from config.types(config/BuildSystem/config/types.py:138)
  Checks whether selected_int_kind etc work USE_FORTRANKIND
        Pushing language FC
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.types/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.types  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.types/conftest.F
stderr:
** main   === End of Compilation 1 ===
1501-510  Compilation successful for file conftest.F.
Source:
      program main
        integer(kind=selected_int_kind(10)) i
        real(kind=selected_real_kind(10)) d
      end
        Defined "USE_FORTRANKIND" to "1"
        Popping language FC
TEST checkFortranDReal from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:150)
TESTING: checkFortranDReal from config.types(config/BuildSystem/config/types.py:150)
  Checks whether dreal is provided in Fortran, and if not defines MISSING_DREAL
        Pushing language FC
stderr:
"/tmp/petsc-ITHdGX/config.types/conftest.F", line 3.17: 1513-041 (S) Arguments of the wrong type were specified for the INTRINSIC procedure "dreal".
1501-511  Compilation failed for file conftest.F.
Source:
      program main
      double precision d
      d = dreal(3.0)
      end
        Defined "MISSING_DREAL" to "1"
        Popping language FC
TEST checkConst from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:158)
TESTING: checkConst from config.types(config/BuildSystem/config/types.py:158)
  Checks for working const, and if not found defines it to empty string
stderr:
"/tmp/petsc-ITHdGX/config.types/conftest.c", line 7.43: 1506-359 (I) Automatic variable x contains a const member and is not initialized.  It will be initialized to zero.
Source:
int main() {
    /* Ultrix mips cc rejects this.  */
    typedef int charset[2]; const charset x;
    /* SunOS 4.1.1 cc rejects this.  */
    char const *const *ccp;
    char **p;
    /* NEC SVR4.0.2 mips cc rejects this.  */
    struct point {int x, y;};
    static struct point const zero = {0,0};
    /* AIX XL C 1.02.0.0 rejects this.
    It does not let you subtract one const X* pointer from another in an arm
    of an if-expression whose if-part is not a constant expression */
    const char *g = "string";
    ccp = &g + (g ? g-g : 0);
    /* HPUX 7.0 cc rejects these. */
    ++ccp;
    p = (char**) ccp;
    ccp = (char const *const *) p;
    /* This section avoids unused variable warnings */
    if (zero.x);
    if (x[0]);
    { /* SCO 3.2v4 cc rejects this.  */
      char *t;
      char const *s = 0 ? (char *) 0 : (char const *) 0;
      *t++ = 0;
      if (*s);
    { /* Someone thinks the Sun supposedly-ANSI compiler will reject this.  */
      int x[] = {25, 17};
      const int *foo = &x[0];
      ++foo;
    { /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
      typedef const int *iptr;
      iptr p = 0;
      ++p;
    { /* AIX XL C 1.02.0.0 rejects this saying
      "k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
      struct s { int j; const int *ap[3]; };
      struct s *b; b->j = 5;
    { /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
      const int foo = 10;
      /* Get rid of unused variable warning */
      if (foo);
  return 0;
TEST checkEndian from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:214)
TESTING: checkEndian from config.types(config/BuildSystem/config/types.py:214)
  If the machine is big endian, defines WORDS_BIGENDIAN
Successful compile:
Source:
#ifdef HAVE_SYS_PARAM_H
  #include <sys/param.h>
#endif
int main() {
#if !BYTE_ORDER || !BIG_ENDIAN || !LITTLE_ENDIAN
  bogus endian macros
#endif
  return 0;
Successful compile:
Source:
#endif
int main() {
#if BYTE_ORDER != BIG_ENDIAN
  not big endian
#endif
  return 0;
        Defined "WORDS_BIGENDIAN" to "1"
TEST checkSizeof from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:267)
TESTING: checkSizeof from config.types(config/BuildSystem/config/types.py:267)
  Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: char
          Defined "SIZEOF_CHAR" to "1"
Checking for size of type: void *
          Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: short
          Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
          Defined "SIZEOF_INT" to "4"
Checking for size of type: long
          Defined "SIZEOF_LONG" to "8"
Checking for size of type: long long
          Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: float
          Defined "SIZEOF_FLOAT" to "4"
Checking for size of type: double
          Defined "SIZEOF_DOUBLE" to "8"
Checking for size of type: size_t
          Defined "SIZEOF_SIZE_T" to "8"
TEST checkBitsPerByte from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:318)
TESTING: checkBitsPerByte from config.types(config/BuildSystem/config/types.py:318)
  Determine the nubmer of bits per byte and define BITS_PER_BYTE
        Defined "BITS_PER_BYTE" to "8"
TEST checkVisibility from config.types(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/types.py:364)
TESTING: checkVisibility from config.types(config/BuildSystem/config/types.py:364)
TEST configureMemAlign from PETSc.utilities.memAlign(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/memAlign.py:30)
TESTING: configureMemAlign from PETSc.utilities.memAlign(config/PETSc/utilities/memAlign.py:30)
  Choose alignment
        Defined "MEMALIGN" to "16"
      Memory alignment is 16
TEST configureCHUD from PETSc.utilities.CHUD(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/CHUD.py:25)
TESTING: configureCHUD from PETSc.utilities.CHUD(config/PETSc/utilities/CHUD.py:25)
  Determines if the Apple CHUD hardware monitoring utilities are available
Executing: uname -s
stdout: Linux
TEST check from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:145)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:145)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
        Checking for functions [socket] in library ['socket', 'nsl'] []
          Pushing language C
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.types  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.libraries/conftest.c
Successful compile:
Source:
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  -lsocket -lnsl -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
stderr:
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: cannot find -lsocket
          Popping language C
        Checking for functions [handle_sigfpes] in library ['fpe'] []
          Pushing language C
Successful compile:
Source:
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  -lfpe -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
stderr:
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: cannot find -lfpe
          Popping language C
          Pushing language C
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
  return 0;
                  Pushing language C
                  Popping language C
stderr:
          Popping language C
          Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
stderr:
          Popping language C
TEST checkMath from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:250)
TESTING: checkMath from config.libraries(config/BuildSystem/config/libraries.py:250)
  Check for sin() in libm, the math library
        Checking for functions [sin floor log10 pow] in library [''] []
          Pushing language C
Successful compile:
Source:
double sin(double);
static void _check_sin() { double x = 0,y; y = sin(x);
double floor(double);
static void _check_floor() { double x = 0,y; y = floor(x);
double log10(double);
static void _check_log10() { double x = 0,y; y = log10(x);
double pow(double, double);
static void _check_pow() { double x = 0,y ; y = pow(x, x);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o   -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
          Popping language C
      Math functions are linked in by default
TEST checkMathErf from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:266)
TESTING: checkMathErf from config.libraries(config/BuildSystem/config/libraries.py:266)
  Check for erf() in libm, the math library
        Checking for functions [erf] in library [] []
          Pushing language C
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
double erf(double);
static void _check_erf() { double x = 0,y; y = erf(x);
int main() {
_check_erf();;
  return 0;
                  Pushing language C
                  Popping language C
          Popping language C
      erf() found
        Defined "HAVE_ERF" to "1"
TEST checkMathTgamma from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:275)
TESTING: checkMathTgamma from config.libraries(config/BuildSystem/config/libraries.py:275)
  Check for tgama() in libm, the math library
        Checking for functions [tgamma] in library [] []
          Pushing language C
Successful compile:
Source:
double tgamma(double);
static void _check_tgamma() { double x = 0,y; y = tgamma(x);
int main() {
_check_tgamma();;
  return 0;
                  Pushing language C
                  Popping language C
          Popping language C
      tgamma() found
        Defined "HAVE_TGAMMA" to "1"
TEST checkMathFenv from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:284)
TESTING: checkMathFenv from config.libraries(config/BuildSystem/config/libraries.py:284)
  Checks if <fenv.h> can be used with FE_DFL_ENV
        Checking for functions [fesetenv] in library [] []
          Pushing language C
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
  return 0;
                  Pushing language C
                  Popping language C
          Popping language C
        Defined "HAVE_FENV_H" to "1"
TEST checkCompression from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:292)
TESTING: checkCompression from config.libraries(config/BuildSystem/config/libraries.py:292)
  Check for libz, the compression library
        Checking for functions [compress uncompress] in library [''] []
          Pushing language C
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
int   compress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
static void _check_compress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret =   compress(dest, &destLen, source, sourceLen);
int uncompress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
static void _check_uncompress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret = uncompress(dest, &destLen, source, sourceLen);
int main() {
_check_compress();
_check_uncompress();;
  return 0;
                  Pushing language C
                  Popping language C
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0x24): undefined reference to `compress'
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0x44): undefined reference to `uncompress'
          Popping language C
        Checking for functions [compress uncompress] in library ['z'] []
          Pushing language C
Successful compile:
Source:
int main() {
_check_compress();
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  -lz -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
stderr:
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: cannot find -lz
          Popping language C
        Checking for functions [compress uncompress] in library ['zlib.lib'] []
          Pushing language C
Successful compile:
Source:
int main() {
_check_compress();
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  zlib.lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
Possible ERROR while running linker: exit code 64512
stderr:
/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/.orig/bgxlc_r: 1501-218 (W) file zlib.lib contains an incorrect file suffix
/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/.orig/bgxlc_r: 1501-228 (W) input file zlib.lib not found
          Popping language C
      Warning: No compression library found
TEST checkRealtime from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:313)
TESTING: checkRealtime from config.libraries(config/BuildSystem/config/libraries.py:313)
  Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
        Checking for functions [clock_gettime] in library [''] []
          Pushing language C
Successful compile:
Source:
#include <time.h>
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
int main() {
_check_clock_gettime();;
  return 0;
                  Pushing language C
                  Popping language C
          Popping language C
      realtime functions are linked in by default
TEST checkDynamic from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:329)
TESTING: checkDynamic from config.libraries(config/BuildSystem/config/libraries.py:329)
  Check for the header and libraries necessary for dynamic library manipulation
        Checking for functions [dlopen] in library ['dl'] []
          Pushing language C
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  -ldl -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
          Defined "HAVE_LIBDL" to "1"
          Popping language C
Checking for header: dlfcn.h
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/config.headers  /tmp/petsc-ITHdGX/config.headers/conftest.c
stdout:
#line 211 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include/stddef.h"
typedef unsigned long size_t;
#line 57 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/dlfcn.h"
extern void *dlopen (const char *__file, int __mode) ;
#line 61
extern int dlclose (void *__handle)  ;
#line 65
extern void *dlsym (void *__restrict __handle,
		    const char *__restrict __name)  ;
#line 72
extern int dladdrrange(void *handle, void **addrp, int *sizep);
#line 89
extern char *dlerror (void) ;
          Defined "HAVE_DLFCN_H" to "1"
TEST configureTimers from PETSc.utilities.timer(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/timer.py:35)
TESTING: configureTimers from PETSc.utilities.timer(config/PETSc/utilities/timer.py:35)
  Sets PETSC_HAVE_FAST_MPI_WTIME PETSC_USE_READ_REAL_TIME PETSC_USE_MICROSOFT_TIME.
          Checking for functions [MPI_CRAY_barrier] in library [''] []
            Pushing language C
Successful compile:
Source:
char MPI_CRAY_barrier();
static void _check_MPI_CRAY_barrier() { MPI_CRAY_barrier(); }
int main() {
_check_MPI_CRAY_barrier();;
  return 0;
                    Pushing language C
                    Popping language C
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): undefined reference to `MPI_CRAY_barrier'
            Popping language C
        Cray-MPI test failure
TEST configureMissingDefines from PETSc.utilities.missing(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/missing.py:39)
TESTING: configureMissingDefines from PETSc.utilities.missing(config/PETSc/utilities/missing.py:39)
  Checks for limits
                  All intermediate test results are stored in /tmp/petsc-ITHdGX/PETSc.utilities.missing
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/PETSc.utilities.missing/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.types  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/PETSc.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_LIMITS_H
  #include <limits.h>
#endif
int main() {
int i=INT_MAX;
if (i);
  return 0;
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/PETSc.utilities.missing/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/PETSc.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_FLOAT_H
  #include <float.h>
#endif
int main() {
double d=DBL_MAX;
if (d);
  return 0;
TEST configureMissingUtypeTypedefs from PETSc.utilities.missing(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/missing.py:49)
TESTING: configureMissingUtypeTypedefs from PETSc.utilities.missing(config/PETSc/utilities/missing.py:49)
   Checks if u_short is undefined
Successful compile:
Source:
int main() {
u_short foo;
  return 0;
TEST configureMissingFunctions from PETSc.utilities.missing(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/missing.py:55)
TESTING: configureMissingFunctions from PETSc.utilities.missing(config/PETSc/utilities/missing.py:55)
  Checks for SOCKETS
TEST configureMissingSignals from PETSc.utilities.missing(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/missing.py:75)
TESTING: configureMissingSignals from PETSc.utilities.missing(config/PETSc/utilities/missing.py:75)
  Check for missing signals, and define MISSING_<signal name> if necessary
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
  return 0;
TEST configureMissingGetdomainnamePrototype from PETSc.utilities.missing(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/missing.py:92)
TESTING: configureMissingGetdomainnamePrototype from PETSc.utilities.missing(config/PETSc/utilities/missing.py:92)
Successful compile:
Source:
#define _BSD_SOURCE
#define _GNU_SOURCE
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
char test[10];
if (getdomainname_ptr(test,10)) return 1;
  return 0;
        Pushing language Cxx
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/PETSc.utilities.missing/conftest.o -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+    /tmp/petsc-ITHdGX/PETSc.utilities.missing/conftest.cc
Possible ERROR while running compiler: exit code 256
stderr:
"/tmp/petsc-ITHdGX/PETSc.utilities.missing/conftest.cc", line 4.9: 1540-0848 (S) The macro name "_GNU_SOURCE" is already defined with a different definition.
Source:
#define _BSD_SOURCE
#define _GNU_SOURCE
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
  return 0;
          Compile failed inside link
stderr:
Source:
#define _BSD_SOURCE
#define _GNU_SOURCE
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,int) = getdomainname;
char test[10];
  return 0;
        Added prototype #include <stddef.h>
int getdomainname(char *, size_t); to language extern C
        Popping language Cxx
TEST configureMissingSrandPrototype from PETSc.utilities.missing(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/missing.py:117)
TESTING: configureMissingSrandPrototype from PETSc.utilities.missing(config/PETSc/utilities/missing.py:117)
Successful compile:
Source:
#define _BSD_SOURCE
#define _GNU_SOURCE
#ifdef PETSC_HAVE_STDLIB_H
#include <stdlib.h>
#endif
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
  return 0;
stderr:
Source:
#define _BSD_SOURCE
#define _GNU_SOURCE
#include <stdlib.h>
#endif
int main() {
long int seed=10;
srand48_ptr(seed);
  return 0;
        Added prototype double drand48(void); to language extern C
        Added prototype void   srand48(long int); to language extern C
TEST configureMissingIntelFastPrototypes from PETSc.utilities.missing(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/missing.py:141)
TESTING: configureMissingIntelFastPrototypes from PETSc.utilities.missing(config/PETSc/utilities/missing.py:141)
TEST configureFortranCommandLine from PETSc.utilities.fortranCommandLine(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/fortranCommandLine.py:27)
TESTING: configureFortranCommandLine from PETSc.utilities.fortranCommandLine(config/PETSc/utilities/fortranCommandLine.py:27)
  Check for the mechanism to retrieve command line arguments in Fortran
        Pushing language FC
        Checking for functions [] in library [''] []
          Pushing language FC
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.types  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.libraries/conftest.F
stderr:
Source:
      program main
      integer i
      character*(80) arg
       call get_command_argument(i,arg)
      end
                  Pushing language FC
                  Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.libraries/conftest.o   -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
          Popping language FC
        Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
        Popping language FC
        Pushing language C
        Checking for functions [get_command_argument] in library [''] ['-L/bgsys/drivers/V1R2M0/ppc64/spi/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib', '-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64', '-L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib', '-L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64', '-Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64', '-lmpichf90', '-lxlf90_r', '-lxlomp_ser', '-lxlfmath', '-lm', '-lm']
          Pushing language C
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.libraries  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.libraries/conftest.c
Successful compile:
Source:
char get_command_argument();
static void _check_get_command_argument() { get_command_argument(); }
int main() {
_check_get_command_argument();;
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -lmpichf90 -lxlf90_r -lxlomp_ser -lxlfmath -lm -lm -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): undefined reference to `get_command_argument'
          Popping language C
        Checking for functions [getarg] in library [''] ['-L/bgsys/drivers/V1R2M0/ppc64/spi/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib', '-L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib', '-L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64', '-L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64', '-L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc', '-L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib', '-L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64', '-Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64', '-lmpichf90', '-lxlf90_r', '-lxlomp_ser', '-lxlfmath', '-lm', '-lm']
          Pushing language C
Successful compile:
Source:
char getarg();
static void _check_getarg() { getarg(); }
int main() {
_check_getarg();;
  return 0;
                  Pushing language C
                  Popping language C
          Popping language C
        Defined "HAVE_GETARG" to "1"
Checking for functions [ipxfargc_]
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.functions/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.libraries  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.functions/conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char ipxfargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_ipxfargc_) || defined (__stub___ipxfargc_)
ipxfargc__will_always_fail_with_ENOSYS();
#else
ipxfargc_();
#endif
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.functions/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.functions/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl  -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -lmpichf90 -lxlf90_r -lxlomp_ser -lxlfmath -lm -lm
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `ipxfargc_'
Checking for functions [f90_unix_MP_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char f90_unix_MP_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_f90_unix_MP_iargc) || defined (__stub___f90_unix_MP_iargc)
f90_unix_MP_iargc_will_always_fail_with_ENOSYS();
#else
#endif
  return 0;
                  Pushing language C
                  Popping language C
stderr:
/tmp/petsc-ITHdGX/config.functions/conftest.o:(.text+0xc): undefined reference to `f90_unix_MP_iargc'
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
  return 0;
                  Pushing language C
                  Popping language C
stderr:
Checking for functions [iargc_]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char iargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_iargc_) || defined (__stub___iargc_)
iargc__will_always_fail_with_ENOSYS();
#else
iargc_();
#endif
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_IARGC_" to "1"
        Defined "HAVE_BGL_IARGC" to "1"
        Popping language C
TEST configureMake from config.packages.make(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/make.py:61)
TESTING: configureMake from config.packages.make(config/BuildSystem/config/packages/make.py:61)
  Check for user specified make - or gmake, make
Checking for program /usr/lib64/qt-3.3/bin/gmake...not found
Checking for program /home/adams/bin/gmake...not found
Checking for program /soft/environment/softenv-1.6.2/bin/gmake...not found
Checking for program /bin/gmake...not found
Checking for program /usr/bin/gmake...found
          Defined make macro "MAKE" to "/usr/bin/gmake"
TEST configureCheckGNUMake from config.packages.make(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/make.py:79)
TESTING: configureCheckGNUMake from config.packages.make(config/BuildSystem/config/packages/make.py:79)
  Check for GNU make
Checking for program /usr/lib64/qt-3.3/bin/strings...not found
Checking for program /home/adams/bin/strings...not found
Checking for program /soft/environment/softenv-1.6.2/bin/strings...not found
Checking for program /bin/strings...not found
Checking for program /usr/bin/strings...found
Executing: /usr/bin/strings /usr/bin/gmake
stdout:
/lib64/ld64.so.1
N$"p&
3q(h
_start`
$}<H*
+x|{
#x9`
p}KI
}aIj|
}?Kx
+x|}
(}$Kx
}ESx~
Ij9!
}$Kx
#x|}
})Zy9`
@x	'
}+J.y*
}+J.y*
 x	O
 x	O
Jy9
Ij;A
U# 6|c
 6|c
}KX0}k
}KX0}k
}KX0}k
}KX0}k
Jy9
}`[xx
Jy9
}`HP8
 }e[xx
}@8P9!
}ESx}k
}c[x
}h[xA
}f[x9
sx}%Kx~$
x~\8PzR
(x	?
$x	>$y)
~y Q
}KX0}k
}KX0}k
p}).p} HP
80T
:})XP|
}#KxK
 x	O
 x	O
Jy9
}+Kx
})[xy l
})[xy ]
})[xy UN
})[xy M
})[xy E
})[xy >
})[xy 6N
})[xy
 }i[x/
y+UN
 x	_
Px	W
xx	W
}+Kx
}+Kx
}KX0}k
}KX0}k
}KX0}k
}KX0}k
+x9
x}{[x
|	Z.x
Jy9
(y Q
Jy9
}#KxH
}#KxH
@}dHP9k
(P}$Kxx
@}dHP9k
Ij9A
p}CSx
}+KxA
}+Kx/
3x9)
48!
|c(P|c
#y|y
}#Kx
Jy9
p}@Jx|
 }9H
}+J.y*
}?HP
 }|J
GY.|
$}GP*/
UJ >}P
}HP.}k
}9 at P|
@P})H
};HP
}=Kx
}=Kx
}K[xy`]
U) >}0
#y|}
}+J.y*
x}\Sx};KxH
(}4J
$}:J
x}1Kx{
};KxK
Jy9
(}jX
}iKx})
}K[x}i
 })P*
}#Kx
}#Kx
}#Kx
p}J8P}J
P8U*
x}J at PUJ
}i[x
0}#Kx
}]HP
 }?Kx/
#x|}
xy >
Cx|
d}KR
}c[x8
I*9
}+Q*
x||H*K
Jy9
}+J.y+
Jy9
d}KR
|kH*;
x}kPPUk
}:Kx
}:Kx
}<Kx
@y+M
sx:+
}#Kx8
$}.H*|
Jx1`
}+H*}7
}# P
 @9)
}KX0}k
}KX0}k
}#KxK
#y|}
}=KxB
H at yJ
}}[x
}\Sx
}KX0}k
}KX0}k
#x|}
(P|v
P~vI
 |	Jxy+O
}u[x
}?XP;Z
}}[x
}}[x
Jy9
})Zy9`
}i[x
H@|w
}i[x
Uk >}p
U) >}0
}+Kx|
}j[x}+KxA
sx|o
}$Kx
}<Kx
}(Kx9)
}KR.yF
X} Kx
}+J.y'
}+J.y*
}$Kx8
{x~i
}$Kx8
}$Kx~
}#Kx8
}+J.y'
}$Kx
}$Kx8
x}#Kx
}+J.y+
}iZ.yg
}$Kx8
}$KxK
}$KxK
}#KxK
}CSxK
l|iZ
y@&Ny`
`y@&N
}#Kx
}$KxK
}$KxK
Jy9
}ISx`
}+Kx
}\SxK
}CSx
}CSx
}CSx
 8!!P
HQ|d
HP8`
Fx	M
(}IZ
\}ISxH
}`[x
y at UN
 x	O
}JZy9`
y at UN
 y*O
d}+KxK
}*KxK
<}#Kx8
}*Kx
}#Kx8
\}KSxK
}CSx8
}=XP})
y)>GA
{x:@
p}IZx})PP})
{H8x
y`UN
}=Kx
}=Kx
xy UN
}=Kx
}=Kx
}i[xK
}#KxK
+x;
}9KxA
Jy9
}KX0}k
}KX0}k
}(HP
}5Kx~
}8Kx
}<Kx/)
Jy9
}KX0}k
}KX0}k
#x|}
#x|}
Jy9
xy =
}#Kx|
|c(P|c
(x	/
>$x
d})XP
x}k.p})
p})XP
U*80U+
:}kPP|
x}+J
}7Kx
({@&N{
{K&Ne)
}kH8`
xy &N
xyk'
xy`=
#x|}
}jZ.yh
}+Kx/
} Kx
|iJx}+
v}`Jx|
H@/
}` P|
Jx}+
v}`Jx|
+xx
}+HP
#x|d
touch: Archive `%s' does not exist
touch: `%s' is not a valid archive
touch:
touch: Member `%s' does not exist in `%s'
touch: Bad return code from ar_member_touch on `%s'
attempt to use unsupported feature: `%s'
!<arch>
ARFILENAMES/
#  commands to execute
 (built-in):
 (from `%s', line %lu):
	%.*s
*** [%s] Archive member `%s' may be bogus; not deleted
*** Archive member `%s' may be bogus; not deleted
*** [%s] Deleting file `%s'
*** Deleting file `%s'
unlink:
kill
$(MAKE)
${MAKE}
.SUFFIXES
SUFFIXES
ARFLAGS
CHECKOUT,v
+$(if $(wildcard $@),,$(CO) $(COFLAGS) $< $@)
COFLAGS
$(CC) -E
$(FC)
F77FLAGS
$(FFLAGS)
LINT
lint
YACC
yacc
MAKEINFO
makeinfo
TEXI2DVI
texi2dvi
WEAVE
weave
CWEAVE
cweave
TANGLE
tangle
CTANGLE
ctangle
rm -f
LINK.o
$(CC) $(LDFLAGS) $(TARGET_ARCH)
COMPILE.c
$(CC) $(CFLAGS) $(CPPFLAGS) $(TARGET_ARCH) -c
LINK.c
$(CC) $(CFLAGS) $(CPPFLAGS) $(LDFLAGS) $(TARGET_ARCH)
COMPILE.cc
$(CXX) $(CXXFLAGS) $(CPPFLAGS) $(TARGET_ARCH) -c
COMPILE.C
$(COMPILE.cc)
COMPILE.cpp
LINK.cc
$(CXX) $(CXXFLAGS) $(CPPFLAGS) $(LDFLAGS) $(TARGET_ARCH)
LINK.C
$(LINK.cc)
LINK.cpp
YACC.y
$(YACC) $(YFLAGS)
LEX.l
$(LEX) $(LFLAGS) -t
COMPILE.f
$(FC) $(FFLAGS) $(TARGET_ARCH) -c
LINK.f
$(FC) $(FFLAGS) $(LDFLAGS) $(TARGET_ARCH)
COMPILE.F
$(FC) $(FFLAGS) $(CPPFLAGS) $(TARGET_ARCH) -c
LINK.F
$(FC) $(FFLAGS) $(CPPFLAGS) $(LDFLAGS) $(TARGET_ARCH)
COMPILE.r
$(FC) $(FFLAGS) $(RFLAGS) $(TARGET_ARCH) -c
LINK.r
$(FC) $(FFLAGS) $(RFLAGS) $(LDFLAGS) $(TARGET_ARCH)
COMPILE.def
$(M2C) $(M2FLAGS) $(DEFFLAGS) $(TARGET_ARCH)
COMPILE.mod
$(M2C) $(M2FLAGS) $(MODFLAGS) $(TARGET_ARCH)
COMPILE.p
$(PC) $(PFLAGS) $(CPPFLAGS) $(TARGET_ARCH) -c
LINK.p
$(PC) $(PFLAGS) $(CPPFLAGS) $(LDFLAGS) $(TARGET_ARCH)
LINK.s
$(CC) $(ASFLAGS) $(LDFLAGS) $(TARGET_MACH)
COMPILE.s
$(AS) $(ASFLAGS) $(TARGET_MACH)
LINK.S
$(CC) $(ASFLAGS) $(CPPFLAGS) $(LDFLAGS) $(TARGET_MACH)
COMPILE.S
$(CC) $(ASFLAGS) $(CPPFLAGS) $(TARGET_MACH) -c
PREPROCESS.S
$(CC) -E $(CPPFLAGS)
PREPROCESS.F
$(FC) $(FFLAGS) $(CPPFLAGS) $(TARGET_ARCH) -F
PREPROCESS.r
$(FC) $(FFLAGS) $(RFLAGS) $(TARGET_ARCH) -F
LINT.c
$(LINT) $(LINTFLAGS) $(CPPFLAGS) $(TARGET_ARCH)
OUTPUT_OPTION
-o $@
.LIBPATTERNS
lib%.so lib%.a
$(AR) $(ARFLAGS) $@ $<
%.out
@rm -f $@
 cp $< $@
%.w %.ch
$(CTANGLE) $^ $@
%.tex
$(CWEAVE) $^ $@
$(CHECKOUT,v)
RCS/%,v
RCS/%
$(GET) $(GFLAGS) $(SCCS_OUTPUT_OPTION) $<
SCCS/s.%
$(LINK.o) $^ $(LOADLIBES) $(LDLIBS) -o $@
$(LINK.s) $^ $(LOADLIBES) $(LDLIBS) -o $@
$(LINK.S) $^ $(LOADLIBES) $(LDLIBS) -o $@
$(LINK.c) $^ $(LOADLIBES) $(LDLIBS) -o $@
$(LINK.cc) $^ $(LOADLIBES) $(LDLIBS) -o $@
$(LINK.C) $^ $(LOADLIBES) $(LDLIBS) -o $@
.cpp
$(LINK.cpp) $^ $(LOADLIBES) $(LDLIBS) -o $@
$(LINK.f) $^ $(LOADLIBES) $(LDLIBS) -o $@
$(LINK.p) $^ $(LOADLIBES) $(LDLIBS) -o $@
$(LINK.F) $^ $(LOADLIBES) $(LDLIBS) -o $@
$(LINK.r) $^ $(LOADLIBES) $(LDLIBS) -o $@
.mod
$(COMPILE.mod) -o $@ -e $@ $^
.def.sym
$(COMPILE.def) -o $@ $<
cat $< >$@
 chmod a+x $@
.s.o
$(COMPILE.s) -o $@ $<
.S.o
$(COMPILE.S) -o $@ $<
.c.o
$(COMPILE.c) $(OUTPUT_OPTION) $<
.cc.o
$(COMPILE.cc) $(OUTPUT_OPTION) $<
.C.o
$(COMPILE.C) $(OUTPUT_OPTION) $<
.cpp.o
$(COMPILE.cpp) $(OUTPUT_OPTION) $<
.f.o
$(COMPILE.f) $(OUTPUT_OPTION) $<
.p.o
$(COMPILE.p) $(OUTPUT_OPTION) $<
.F.o
$(COMPILE.F) $(OUTPUT_OPTION) $<
.r.o
$(COMPILE.r) $(OUTPUT_OPTION) $<
.mod.o
$(COMPILE.mod) -o $@ $<
.c.ln
$(LINT.c) -C$* $<
.y.ln
$(YACC.y) $<
 $(LINT.c) -C$* y.tab.c
 $(RM) y.tab.c
.l.ln
@$(RM) $*.c
 $(LEX.l) $< > $*.c
$(LINT.c) -i $*.c -o $@
 $(RM) $*.c
.y.c
$(YACC.y) $<
 mv -f y.tab.c $@
.l.c
@$(RM) $@
 $(LEX.l) $< > $@
.F.f
$(PREPROCESS.F) $(OUTPUT_OPTION) $<
.r.f
$(PREPROCESS.r) $(OUTPUT_OPTION) $<
.l.r
$(LEX.l) $< > $@
 mv -f lex.yy.r $@
.S.s
$(PREPROCESS.S) $< > $@
.texinfo.info
$(MAKEINFO) $(MAKEINFO_FLAGS) $< -o $@
.texi.info
.txinfo.info
.tex.dvi
$(TEX) $<
.texinfo.dvi
$(TEXI2DVI) $(TEXI2DVI_FLAGS) $<
.texi.dvi
.txinfo.dvi
.w.c
$(CTANGLE) $< - $@
.web.p
$(TANGLE) $<
.w.tex
$(CWEAVE) $< - $@
.web.tex
$(WEAVE) $<
# Directories
# %s: could not be stat'd.
# %s (device %ld, inode %ld): could not be opened.
 files,
 impossibilities
 so far.
 impossibilities in %lu directories.
unterminated variable reference
warning: undefined variable `%.*s'
Recursive variable `%s' references itself (eventually)
print_file
enter_file
lookup_file
# Files
# files hash-table stats:
%04d-%02d-%02d %02d:%02d:%02d
.%09d
# Not a target:
%s:%s
 | %s
#  Precious file (prerequisite of .PRECIOUS).
#  Phony target (prerequisite of .PHONY).
#  Command-line target.
#  A default, MAKEFILES, or -include/sinclude makefile.
#  Implicit rule search has been done.
#  Implicit rule search has not been done.
#  Implicit/static pattern stem: `%s'
#  File is an intermediate prerequisite.
#  Also makes:
#  Modification time never checked.
#  File does not exist.
#  File is very old.
#  Last modified %s
#  File has been updated.
#  File has not been updated.
#  Commands currently running (THIS IS A BUG).
#  Dependencies commands running (THIS IS A BUG).
#  Successfully updated.
question_flag
file.c
#  Needs to be updated (-q is set).
#  Failed to be updated.
#  Invalid value in `update_status' member!
%s: Timestamp out of range; substituting %s
Current time
*** Deleting intermediate file `%s'
Removing intermediate files...
Commands were specified for file `%s' at %s:%lu,
Commands for file `%s' were found by implicit rule search,
but `%s' is now considered the same file as `%s'.
Commands for `%s' will be ignored in favor of those for `%s'.
can't rename single-colon `%s' to double-colon `%s'
can't rename double-colon `%s' to single-colon `%s'
*name != '\0'
.PRECIOUS
.LOW_RESOLUTION_TIME
.PHONY
.INTERMEDIATE
.SECONDARY
.EXPORT_ALL_VARIABLES
.IGNORE
.SILENT
.NOTPARALLEL
undefined
recursive
simple
Internal error: func_error: '%s'
%s: '%s'
insufficient number of arguments (%d) to function `%s'
unimplemented on this platform: function `%s'
default
environment
file
environment override
command line
override
automatic
non-numeric first argument to `wordlist' function
non-numeric second argument to `wordlist' function
invalid first argument to `wordlist' function: `%d'
non-numeric first argument to `word' function
first argument to `word' function must be greater than 0
suffix
basename
addprefix
%s:%lu:
pipe
fork
Cleaning up temporary batch file %s
filter
unterminated call to function `%s': missing `%c'
abspath
addsuffix
notdir
subst
filter-out
findstring
firstword
flavor
join
lastword
patsubst
realpath
shell
sort
strip
wildcard
word
wordlist
words
origin
foreach
call
error
warning
value
eval
Avoiding implicit rule recursion.
Trying pattern rule with stem `%.*s'.
Rejecting impossible implicit prerequisite `%s'.
Rejecting impossible rule prerequisite `%s'.
Trying implicit prerequisite `%s'.
Trying rule prerequisite `%s'.
Found prerequisite `%s' as VPATH `%s'
Looking for a rule with intermediate file `%s'.
Looking for an implicit rule for `%s'.
Looking for archive-member implicit rule for `%s'.
construct_command_argv_internal
start_waiting_job
ap <= end
job.c
%s (line %d) Bad shell context (!unixy && !batch_mode_shell)
$(SHELL)
$(IFS)
%s: Command not found
SHELL
%s: Shell program not found
execvp:
INTERNAL: Freeing child 0x%08lx (%s) but no tokens left!
write jobserver
Released token for child 0x%08lx (%s).
/bin/sh
vfork
cannot enforce load limits on this operating system
cannot enforce load limit:
getloadavg
Estimated system load = %f (actual = %f) (max requested = %f)
Putting child 0x%08lx (%s) PID %ld%s on the chain.
 (remote)
f->command_state == cs_finished
[%s] Error %d (ignored)
*** [%s] Error %d
 (core dumped)
*** [%s] %s%s
*** Waiting for unfinished jobs....
Live child 0x%08lx (%s) PID %ld %s
remote_status
wait
Reaping losing child 0x%08lx PID %ld %s
Reaping winning child 0x%08lx PID %ld %s
Cleaning up temp batch file %s
.DELETE_ON_ERROR
Removing child 0x%08lx PID %ld%s from chain.
don't
Need a job token; we %shave children
Duplicate the job FD
INTERNAL: no children as we go to sleep on read
Obtained token for child 0x%08lx (%s).
read jobs pipe EOF
read jobs pipe
Read returned EBADF.
break
case
continue
exec
exit
export
login
logout
read
readonly
shift
switch
test
times
trap
umask
while
$(-*-command-variables-*-)
$(MAKEOVERRIDES)
main
%s: Entering an unknown directory
%s: Leaving an unknown directory
%s: Entering directory `%s'
%s: Leaving directory `%s'
%s[%u]: Entering an unknown directory
%s[%u]: Leaving an unknown directory
%s[%u]: Entering directory `%s'
%s[%u]: Leaving directory `%s'
%sGNU Make %s
%sCopyright (C) 2006  Free Software Foundation, Inc.
%sThis is free software; see the source for copying conditions.
%sThere is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
%sPARTICULAR PURPOSE.
%sThis program built for %s
%sThis program built for %s (%s)
# Make data base, printed on %s
# Finished Make data base on %s
INTERNAL: Exiting with %u jobserver tokens (should be 0)!
write
INTERNAL: Exiting with %u jobserver tokens available; should be %u!
empty string invalid as file name
MAKECMDGOALS
the `-%c' option requires a non-empty string argument
the `-%c' option requires a positive integral argument
Usage: %s [options] [target] ...
Report bugs to <bug-make at gnu.org>
MFLAGS
MAKEFLAGS
make
/usr/share/locale
getcwd
.VARIABLES
.FEATURES
target-specific order-only second-expansion else-if
archives
jobserver
check-symlink
MAKE_RESTARTS
unknown debug level specification `%s'
MAKE_COMMAND
MAKE
$(MAKE_COMMAND)
MAKEOVERRIDES
${-*-command-variables-*-}
MAKELEVEL
CURDIR
Makefile from standard input specified twice.
TMPDIR
/tmp
GmXXXXXX
fopen (temporary file)
fwrite (temporary file)
.DEFAULT
.DEFAULT_GOAL
internal error: multiple --jobserver-fds options
%d,%d
internal error: invalid --jobserver-fds string `%s'
warning: -jN forced in submake: disabling jobserver mode.
dup jobserver
warning: jobserver unavailable: using -j1.  Add `+' to parent make rule.
More parallel jobs (-jN) than this platform can handle requested.
Resetting to single job (-j1) mode.
creating jobs pipe
init jobserver pipe
Updating makefiles....
Makefile `%s' might loop; not remaking it.
Failed to remake makefile `%s'.
Included makefile `%s' was not found.
Makefile `%s' was not found
chdir
Re-executing[%u]:
%s=%u
MAKE_RESTARTS=
MAKE_RESTARTS=%u
main.c
unlink (temporary file):
.DEFAULT_GOAL contains more than one target
No targets specified and no makefile found
No targets
Updating goal targets....
warning:  Clock skew detected.  Your build may be incomplete.
Couldn't change back to original directory.
always-make
directory
basic
debug
environment-overrides
help
ignore-errors
include-dir
jobs
jobserver-fds
keep-going
load-average
check-symlink-times
just-print
old-file
print-data-base
question
no-builtin-rules
no-builtin-variables
silent
no-keep-going
touch
version
print-directory
no-print-directory
what-if
warn-undefined-variables
quiet
stop
new-file
assume-new
assume-old
max-load
dry-run
recon
makefile
Options:
  -b, -m                      Ignored for compatibility.
  -B, --always-make           Unconditionally make all targets.
  -C DIRECTORY, --directory=DIRECTORY
                              Change to DIRECTORY before doing anything.
  -d                          Print lots of debugging information.
  --debug[=FLAGS]             Print various types of debugging information.
  -e, --environment-overrides
                              Environment variables override makefiles.
  -f FILE, --file=FILE, --makefile=FILE
                              Read FILE as a makefile.
  -h, --help                  Print this message and exit.
  -i, --ignore-errors         Ignore errors from commands.
  -I DIRECTORY, --include-dir=DIRECTORY
                              Search DIRECTORY for included makefiles.
  -j [N], --jobs[=N]          Allow N jobs at once; infinite jobs with no arg.
  -k, --keep-going            Keep going when some targets can't be made.
  -l [N], --load-average[=N], --max-load[=N]
                              Don't start multiple jobs unless load is below N.
  -L, --check-symlink-times   Use the latest mtime between symlinks and target.
  -n, --just-print, --dry-run, --recon
                              Don't actually run any commands; just print them.
  -o FILE, --old-file=FILE, --assume-old=FILE
                              Consider FILE to be very old and don't remake it.
  -p, --print-data-base       Print make's internal database.
  -q, --question              Run no commands; exit status says if up to date.
  -r, --no-builtin-rules      Disable the built-in implicit rules.
  -R, --no-builtin-variables  Disable the built-in variable settings.
  -s, --silent, --quiet       Don't echo commands.
  -S, --no-keep-going, --stop
                              Turns off -k.
  -t, --touch                 Touch targets instead of remaking them.
  -v, --version               Print the version number of make and exit.
  -w, --print-directory       Print the current directory.
  --no-print-directory        Turn off -w, even if it was turned on implicitly.
  -W FILE, --what-if=FILE, --new-file=FILE, --assume-new=FILE
                              Consider FILE to be infinitely new.
  --warn-undefined-variables  Warn when an undefined variable is referenced.
hash_strfree
hash_strdup
hash_savestring
d == h
misc.c
%s:%lu: ***
%s: ***
%s[%u]: ***
.  Stop.
virtual memory exhausted
h->count != 0
%s: %s
%s:
%s[%u]:
write error: %s
write error
%s%s: %s
eval
record_target_var
$(HOME)
HOME
/usr/include
.INCLUDE_DIRS
warning: NUL character seen; rest of line ignored
define
endef
Extraneous text after `endef' directive
missing `endef', unterminated `define'
ifdef
ifndef
ifeq
ifneq
else
endif
Extraneous text after `%s' directive
extraneous `%s'
only one `else' per conditional
prerequisites cannot be defined in command scripts
.POSIX
.SECONDEXPANSION
mixed implicit and static pattern rules
mixed implicit and normal rules
target `%s' doesn't match the target pattern
target file `%s' has both : and :: entries
target `%s' given more than once in the same rule.
warning: overriding commands for target `%s'
warning: ignoring old commands for target `%s'
invalid syntax in conditional
extraneous `endef'
empty variable name
empty `override' directive
invalid `override' directive
unexport
vpath
include
-include
sinclude
commands commence before first target
missing rule before commands
missing separator%s
 (did you mean TAB instead of 8 spaces?)
*p2 != '\0'
read.c
v != 0
Malformed target-specific variable definition
missing target pattern
multiple target patterns
target pattern contains no `%%'
missing `endif'
Reading makefile `%s'
 (no default goal)
 (search path)
 (don't care)
 (no ~ expansion)
MAKEFILE_LIST
Reading makefiles...
$(MAKEFILES)
/usr/gnu/include
/usr/local/include
GNUmakefile
Makefile
update_file_1
lstat:
readlink:
$(strip $(.LIBPATTERNS))
.LIBPATTERNS element `%s' is not a pattern
%s/%s
Warning: File `%s' has modification time %.2g s in the future
touch %s
touch: open:
touch: fstat:
touch: read:
touch: lseek:
touch: write:
%sNo rule to make target `%s'%s
%sNo rule to make target `%s', needed by `%s'%s
Pruning file `%s'.
Considering target file `%s'.
Recently tried and failed to update file `%s'.
File `%s' was considered already.
Still updating file `%s'.
Finished updating file `%s'.
File `%s' does not exist.
*** Warning: .LOW_RESOLUTION_TIME file `%s' has a high resolution time stamp
Found an implicit rule for `%s'.
No implicit rule found for `%s'.
Using default commands for `%s'.
Circular %s <- %s dependency dropped.
Finished prerequisites of target file `%s'.
The prerequisites of `%s' are being made.
Giving up on target file `%s'.
Target `%s' not remade because of errors.
Prerequisite `%s' is order-only for target `%s'.
Prerequisite `%s' of target `%s' does not exist.
Prerequisite `%s' is newer than target `%s'.
Prerequisite `%s' is older than target `%s'.
Target `%s' is double-colon and has no prerequisites.
No commands for `%s' and no prerequisites actually changed.
Making `%s' due to always-make flag.
No need to remake target `%s'
; using VPATH name `%s'
Must remake target `%s'.
  Ignoring VPATH name `%s'.
Commands of `%s' are being run.
Failed to remake target file `%s'.
Successfully remade target file `%s'.
Target file `%s' needs remade under -q.
file->update_status >= 0 && file->update_status <= 2
remake.c
Nothing to be done for `%s'.
`%s' is up to date.
/lib
/usr/lib
/usr/lib64
# Implicit Rules
# No implicit rules.
# %u implicit rules, %u
 (%.1f%%)
 terminal.
BUG: num_pattern_rules wrong!  %u != %u
(%.o)
add_string
%s # of strings in strcache: %d
%s # of strcache buffers: %d
%s strcache size: total = %d / max = %d / min = %d / avg = %d
%s strcache free: total = %d / max = %d / min = %d / avg = %d
best->bytesfree > len
strcache.c
pop_variable_scope
environment under -e
define %s
endef
%s %s=
$(subst ,,%s)
# variable set hash-table stats:
# Variables
# Pattern-specific Variable Values
%s :
# %u pattern-specific variable values
# No pattern-specific variable values.
current_variable_set_list->next != ((void *)0)
variable.c
%s%s%s
MAKE_VERSION
MAKEFILES
$(patsubst %/,%,$(dir $@))
$(patsubst %/,%,$(dir $%))
$(patsubst %/,%,$(dir $*))
$(patsubst %/,%,$(dir $<))
$(patsubst %/,%,$(dir $?))
$(patsubst %/,%,$(dir $^))
$(patsubst %/,%,$(dir $+))
$(notdir $@)
$(notdir $%)
$(notdir $*)
$(notdir $<)
$(notdir $?)
$(notdir $^)
$(notdir $+)
3.81
powerpc64-redhat-linux-gnu
# VPATH Search Paths
vpath %s
%s%c
# No `vpath' search paths.
# %u `vpath' search paths.
# No general (`VPATH' variable) search path.
# General (`VPATH' variable) search path:
$(strip $(VPATH))
$(strip $(GPATH))
Load=%ld/%ld=%.0f%%,
Rehash=%d,
Collisions=%ld/%ld=%.0f%%
can't allocate %ld bytes for hash table: memory exhausted
A~	F
A~	F
A~	F
A~	F
A~	F
.out .a .ln .o .c .cc .C .cpp .p .f .F .r .y .l .s .S .mod .sym .def .h .info .dvi .tex .texinfo .texi .txinfo .w .ch .web .sh .elc .el
;(/bin/sh
 -c
hNnk(
3}\p
3|U@
3|VP
3xl`
3x\@
3x]0
3|T0
3|U@
3}Ip
3}L@
3}Ip
3xQ\
3|cP
3|e
3xPP
3{}P
3xQ\
libc.so.6
fflush
strcpy
__rawmemchr
__printf_chk
fnmatch
readdir
_IO_putc
setlocale
strsignal
strncmp
optind
strrchr
wait
pipe
__strdup
dcgettext
closedir
sigprocmask
__stack_chk_fail
__lxstat
unlink
realloc
abort
stdin
_exit
getpid
kill
__assert_fail
mkstemp
strtod
strtol
feof
getloadavg
fgets
getpwnam
calloc
strlen
sigemptyset
memset
glob
strstr
__errno_location
chdir
memcmp
dup2
__fprintf_chk
sigaddset
ctime
putenv
stdout
fputs
lseek
memcpy
fclose
malloc
strcat
remove
__strncpy_chk
opendir
getenv
__ctype_b_loc
sscanf
optarg
stderr
alarm
getlogin
readlink
setrlimit
getopt_long
execvp
__fxstat
__realpath_chk
getcwd
fwrite
fread
gettimeofday
sigaction
waitpid
localtime
strchr
vfork
__vfprintf_chk
fdopen
qsort
__strcpy_chk
__ctype_tolower_loc
setvbuf
fcntl
__sprintf_chk
bsd_signal
__xstat
getrlimit
memmove
bindtextdomain
opterr
strcmp
strerror
__libc_start_main
ferror
globfree
__environ
__cxa_atexit
GLIBC_2.4
GLIBC_2.3.4
GLIBC_2.3
/lib64/ld64.so.1
        Defined make macro "MAKE_IS_GNUMAKE" to "1"
        Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
        Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
        Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
TEST configureMakeNP from config.packages.make(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/make.py:121)
TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:121)
  check no of cores on the build machine [perhaps to do make '-j ncores']
      module multiprocessing found 48 cores: using make_np = 32
        Defined make macro "MAKE_NP" to "32"
    Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/gmake  --print-directory"
    Defined make macro "OMAKE" to "/usr/bin/gmake  --no-print-directory"
    Pushing language C
TEST configureLibrary from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:744)
TESTING: configureLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:744)
  Calls the regular package configureLibrary and then does an additional test needed by MPI
        Checking for a functional MPI
        Checking for library in Package specific search directory MPI: []
            Checking for functions [MPI_Init MPI_Comm_create] in library [] []
              Pushing language C
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.libraries  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.libraries/conftest.c
Successful compile:
Source:
char MPI_Init();
static void _check_MPI_Init() { MPI_Init(); }
char MPI_Comm_create();
static void _check_MPI_Comm_create() { MPI_Comm_create(); }
int main() {
_check_MPI_Init();
_check_MPI_Comm_create();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
        Checking for headers Package specific search directory MPI: []
            Pushing language C
TEST checkInclude from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['mpi.h'] in []
              Checking include with compiler flags var CPPFLAGS []
stdout:
#line 37 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdint.h"
typedef signed char		int8_t;
typedef short int		int16_t;
typedef int			int32_t;
typedef long int		int64_t;
#line 49
typedef unsigned char		uint8_t;
typedef unsigned short int	uint16_t;
typedef unsigned int		uint32_t;
#line 56
typedef unsigned long int	uint64_t;
#line 66
typedef signed char		int_least8_t;
typedef short int		int_least16_t;
typedef int			int_least32_t;
typedef long int		int_least64_t;
#line 77
typedef unsigned char		uint_least8_t;
typedef unsigned short int	uint_least16_t;
typedef unsigned int		uint_least32_t;
typedef unsigned long int	uint_least64_t;
#line 91
typedef signed char		int_fast8_t;
typedef long int		int_fast16_t;
typedef long int		int_fast32_t;
typedef long int		int_fast64_t;
#line 104
typedef unsigned char		uint_fast8_t;
typedef unsigned long int	uint_fast16_t;
typedef unsigned long int	uint_fast32_t;
typedef unsigned long int	uint_fast64_t;
#line 120
typedef long int		intptr_t;
#line 123
typedef unsigned long int	uintptr_t;
#line 135
typedef long int		intmax_t;
typedef unsigned long int	uintmax_t;
#line 83 "/bgsys/drivers/V1R2M0/ppc64/comm/xl/include/mpi.h"
typedef int MPI_Datatype;
#line 102
static const MPI_Datatype mpich_mpi_char                              = ((MPI_Datatype)0x4c000101);
static const MPI_Datatype mpich_mpi_signed_char                = ((MPI_Datatype)0x4c000118);
static const MPI_Datatype mpich_mpi_unsigned_char            = ((MPI_Datatype)0x4c000102);
static const MPI_Datatype mpich_mpi_wchar                          = ((MPI_Datatype)0x4c00040e);
static const MPI_Datatype mpich_mpi_short                            = ((MPI_Datatype)0x4c000203);
static const MPI_Datatype mpich_mpi_unsigned_short          = ((MPI_Datatype)0x4c000204);
static const MPI_Datatype mpich_mpi_int                                = ((MPI_Datatype)0x4c000405);
static const MPI_Datatype mpich_mpi_unsigned                      = ((MPI_Datatype)0x4c000406);
static const MPI_Datatype mpich_mpi_long                              = ((MPI_Datatype)0x4c000807);
static const MPI_Datatype mpich_mpi_unsigned_long            = ((MPI_Datatype)0x4c000808);
static const MPI_Datatype mpich_mpi_float                            = ((MPI_Datatype)0x4c00040a);
static const MPI_Datatype mpich_mpi_double                          = ((MPI_Datatype)0x4c00080b);
static const MPI_Datatype mpich_mpi_long_double                = ((MPI_Datatype)0x4c00100c);
static const MPI_Datatype mpich_mpi_long_long_int            = ((MPI_Datatype)0x4c000809);
static const MPI_Datatype mpich_mpi_unsigned_long_long  = ((MPI_Datatype)0x4c000819);
#line 138
struct mpich_struct_mpi_float_int       { float f; int i; };
struct mpich_struct_mpi_double_int      { double d; int i; };
struct mpich_struct_mpi_long_int        { long l; int i; };
struct mpich_struct_mpi_short_int       { short s; int i; };
struct mpich_struct_mpi_2int            { int i1; int i2; };
struct mpich_struct_mpi_long_double_int { long double ld; int i; };
static const MPI_Datatype mpich_mpi_float_int              = ((MPI_Datatype)0x8c000000);
static const MPI_Datatype mpich_mpi_double_int            = ((MPI_Datatype)0x8c000001);
static const MPI_Datatype mpich_mpi_long_int                = ((MPI_Datatype)0x8c000002);
static const MPI_Datatype mpich_mpi_short_int              = ((MPI_Datatype)0x8c000003);
static const MPI_Datatype mpich_mpi_2int                        = ((MPI_Datatype)0x4c000816);
static const MPI_Datatype mpich_mpi_long_double_int  = ((MPI_Datatype)0x8c000004);
#line 198
static const MPI_Datatype mpich_mpi_int8_t      = ((MPI_Datatype)0x4c000137);
static const MPI_Datatype mpich_mpi_int16_t    = ((MPI_Datatype)0x4c000238);
static const MPI_Datatype mpich_mpi_int32_t    = ((MPI_Datatype)0x4c000439);
static const MPI_Datatype mpich_mpi_int64_t    = ((MPI_Datatype)0x4c00083a);
static const MPI_Datatype mpich_mpi_uint8_t    = ((MPI_Datatype)0x4c00013b);
static const MPI_Datatype mpich_mpi_uint16_t  = ((MPI_Datatype)0x4c00023c);
static const MPI_Datatype mpich_mpi_uint32_t  = ((MPI_Datatype)0x4c00043d);
static const MPI_Datatype mpich_mpi_uint64_t  = ((MPI_Datatype)0x4c00083e);
#line 214
static const MPI_Datatype mpich_mpi_c_bool                           = ((MPI_Datatype)0x4c00013f);
static const MPI_Datatype mpich_mpi_c_float_complex         = ((MPI_Datatype)0x4c000840);
static const MPI_Datatype mpich_mpi_c_double_complex       = ((MPI_Datatype)0x4c001041);
static const MPI_Datatype mpich_mpi_c_long_double_complex  = ((MPI_Datatype)0x4c002042);
#line 229
typedef int MPI_Comm;
#line 234
typedef int MPI_Group;
#line 238
typedef int MPI_Win;
#line 246
typedef struct ADIOI_FileD *MPI_File;
#line 250
typedef int MPI_Op;
#line 306
static const MPI_Datatype mpich_mpi_datatype_null  = ((MPI_Datatype)0x0c000000);
#line 319
typedef enum MPIR_Win_flavor_e {
    MPIX_WIN_FLAVOR_CREATE      = 1,
    MPIX_WIN_FLAVOR_ALLOCATE    = 2,
    MPIX_WIN_FLAVOR_DYNAMIC     = 3,
    MPIX_WIN_FLAVOR_SHARED      = 4
} MPIR_Win_flavor_t;
#line 327
typedef enum MPIR_Win_model_e {
    MPIX_WIN_SEPARATE   = 1,
    MPIX_WIN_UNIFIED    = 2
} MPIR_Win_model_t;
#line 336
typedef enum MPIR_Topo_type { MPI_GRAPH=1, MPI_CART=2, MPI_DIST_GRAPH=3 } MPIR_Topo_type;
#line 339
extern int * const MPI_UNWEIGHTED;
#line 355
typedef void (MPI_Handler_function) ( MPI_Comm *, int *, ... );
typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *, void *,
					  void *, int *);
typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *, void *,
					  void *, int *);
typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int, void *, void *);
typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *, void *, void *,
					 int *);
typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
typedef void (MPI_File_errhandler_function)(MPI_File *, int *, ...);
typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn;
typedef MPI_File_errhandler_function MPI_File_errhandler_fn;
typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn;
#line 383
typedef int MPI_Errhandler;
#line 404
typedef int MPI_Request;
#line 407
typedef int MPIX_Message;
#line 410
typedef void (MPI_User_function) ( void *, void *, int *, MPI_Datatype * );
#line 413
typedef int (MPI_Copy_function) ( MPI_Comm, int, void *, void *, void *, int * );
typedef int (MPI_Delete_function) ( MPI_Comm, int, void *, void * );
#line 458
enum MPIR_Combiner_enum {
    MPI_COMBINER_NAMED            = 1,
    MPI_COMBINER_DUP              = 2,
    MPI_COMBINER_CONTIGUOUS       = 3,
    MPI_COMBINER_VECTOR           = 4,
    MPI_COMBINER_HVECTOR_INTEGER  = 5,
    MPI_COMBINER_HVECTOR          = 6,
    MPI_COMBINER_INDEXED          = 7,
    MPI_COMBINER_HINDEXED_INTEGER = 8,
    MPI_COMBINER_HINDEXED         = 9,
    MPI_COMBINER_INDEXED_BLOCK    = 10,
    MPIX_COMBINER_HINDEXED_BLOCK  = 11,
    MPI_COMBINER_STRUCT_INTEGER   = 12,
    MPI_COMBINER_STRUCT           = 13,
    MPI_COMBINER_SUBARRAY         = 14,
    MPI_COMBINER_DARRAY           = 15,
    MPI_COMBINER_F90_REAL         = 16,
    MPI_COMBINER_F90_COMPLEX      = 17,
    MPI_COMBINER_F90_INTEGER      = 18,
    MPI_COMBINER_RESIZED          = 19
#line 481
typedef int MPI_Info;
#line 507
typedef long MPI_Aint;
typedef int MPI_Fint;
static const MPI_Datatype mpich_mpi_aint      = ((MPI_Datatype)0x4c000843);
#line 523
typedef long long MPI_Offset;
static const MPI_Datatype mpich_mpi_offset  = ((MPI_Datatype)0x4c000844);
#line 528
typedef struct MPI_Status {
    int count;
    int cancelled;
    int MPI_SOURCE;
    int MPI_TAG;
    int MPI_ERROR;
} MPI_Status;
#line 538
struct MPIR_T_enum;
typedef struct MPIR_T_enum * MPIX_T_enum;
struct MPIR_T_cvar_handle;
typedef struct MPIR_T_cvar_handle * MPIX_T_cvar_handle;
struct MPIR_T_pvar_handle;
typedef struct MPIR_T_pvar_handle * MPIX_T_pvar_handle;
struct MPIR_T_pvar_session;
typedef struct MPIR_T_pvar_session * MPIX_T_pvar_session;
#line 548
extern struct MPIR_T_pvar_handle * const MPIX_T_PVAR_ALL_HANDLES;
#line 557
enum MPIR_T_verbosity_t {
#line 560
    MPIX_T_VERBOSITY_INVALID = 0,
#line 563
    MPIX_T_VERBOSITY_USER_BASIC = 221,
    MPIX_T_VERBOSITY_USER_DETAIL,
    MPIX_T_VERBOSITY_USER_ALL,
    MPIX_T_VERBOSITY_TUNER_BASIC,
    MPIX_T_VERBOSITY_TUNER_DETAIL,
    MPIX_T_VERBOSITY_TUNER_ALL,
    MPIX_T_VERBOSITY_MPIDEV_BASIC,
    MPIX_T_VERBOSITY_MPIDEV_DETAIL,
    MPIX_T_VERBOSITY_MPIDEV_ALL
enum MPIR_T_bind_t {
#line 579
    MPIX_T_BIND_INVALID = 0,
#line 582
    MPIX_T_BIND_NO_OBJECT = 9700,
    MPIX_T_BIND_MPI_COMM,
    MPIX_T_BIND_MPI_DATATYPE,
    MPIX_T_BIND_MPI_ERRHANDLER,
    MPIX_T_BIND_MPI_FILE,
    MPIX_T_BIND_MPI_GROUP,
    MPIX_T_BIND_MPI_OP,
    MPIX_T_BIND_MPI_REQUEST,
    MPIX_T_BIND_MPI_WIN,
    MPIX_T_BIND_MPI_MESSAGE,
    MPIX_T_BIND_MPI_INFO
enum MPIR_T_scope_t {
#line 598
    MPIX_T_SCOPE_INVALID = 0,
#line 601
    MPIX_T_SCOPE_READONLY = 60439,
    MPIX_T_SCOPE_LOCAL,
    MPIX_T_SCOPE_GROUP,
    MPIX_T_SCOPE_GROUP_EQ,
    MPIX_T_SCOPE_ALL,
    MPIX_T_SCOPE_ALL_EQ
enum MPIR_T_pvar_class_t {
#line 612
    MPIX_T_PVAR_CLASS_INVALID = 0,
#line 615
    MPIX_T_PVAR_CLASS_STATE = 240,
    MPIX_T_PVAR_CLASS_LEVEL,
    MPIX_T_PVAR_CLASS_SIZE,
    MPIX_T_PVAR_CLASS_PERCENTAGE,
    MPIX_T_PVAR_CLASS_HIGHWATERMARK,
    MPIX_T_PVAR_CLASS_LOWWATERMARK,
    MPIX_T_PVAR_CLASS_COUNTER,
    MPIX_T_PVAR_CLASS_AGGREGATE,
    MPIX_T_PVAR_CLASS_TIMER,
    MPIX_T_PVAR_CLASS_GENERIC
#line 675
extern  MPI_Fint * MPI_F_STATUS_IGNORE;
extern  MPI_Fint * MPI_F_STATUSES_IGNORE;
#line 694
typedef int (MPI_Grequest_cancel_function)(void *, int);
typedef int (MPI_Grequest_free_function)(void *);
typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
#line 788
typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype, int,
             void *, MPI_Offset, void *);
typedef int (MPI_Datarep_extent_function)(MPI_Datatype datatype, MPI_Aint *,
					  void *);
#line 811
int MPI_Send( void*, int, MPI_Datatype, int, int, MPI_Comm) ;
int MPI_Recv(void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Status *) ;
int MPI_Get_count( MPI_Status *, MPI_Datatype, int *);
int MPI_Bsend( void*, int, MPI_Datatype, int, int, MPI_Comm) ;
int MPI_Ssend( void*, int, MPI_Datatype, int, int, MPI_Comm) ;
int MPI_Rsend( void*, int, MPI_Datatype, int, int, MPI_Comm) ;
int MPI_Buffer_attach( void*, int);
int MPI_Buffer_detach( void*, int *);
int MPI_Isend( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int MPI_Ibsend( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int MPI_Issend( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int MPI_Irsend( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int MPI_Irecv(void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int MPI_Wait(MPI_Request *, MPI_Status *);
int MPI_Test(MPI_Request *, int *, MPI_Status *);
int MPI_Request_free(MPI_Request *);
int MPI_Waitany(int, MPI_Request *, int *, MPI_Status *);
int MPI_Testany(int, MPI_Request *, int *, int *, MPI_Status *);
int MPI_Waitall(int, MPI_Request *, MPI_Status *);
int MPI_Testall(int, MPI_Request *, int *, MPI_Status *);
int MPI_Waitsome(int, MPI_Request *, int *, int *, MPI_Status *);
int MPI_Testsome(int, MPI_Request *, int *, int *, MPI_Status *);
int MPI_Iprobe(int, int, MPI_Comm, int *, MPI_Status *);
int MPI_Probe(int, int, MPI_Comm, MPI_Status *);
int MPI_Cancel(MPI_Request *);
int MPI_Test_cancelled( MPI_Status *, int *);
int MPI_Send_init( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int MPI_Bsend_init( void*, int, MPI_Datatype, int,int, MPI_Comm, MPI_Request *) ;
int MPI_Ssend_init( void*, int, MPI_Datatype, int,int, MPI_Comm, MPI_Request *) ;
int MPI_Rsend_init( void*, int, MPI_Datatype, int,int, MPI_Comm, MPI_Request *) ;
int MPI_Recv_init(void*, int, MPI_Datatype, int,int, MPI_Comm, MPI_Request *) ;
int MPI_Start(MPI_Request *);
int MPI_Startall(int, MPI_Request *);
int MPI_Sendrecv( void *, int, MPI_Datatype,int, int, void *, int, MPI_Datatype, int, int, MPI_Comm, MPI_Status *)  ;
int MPI_Sendrecv_replace(void*, int, MPI_Datatype, int, int, int, int, MPI_Comm, MPI_Status *) ;
int MPI_Type_contiguous(int, MPI_Datatype, MPI_Datatype *);
int MPI_Type_vector(int, int, int, MPI_Datatype, MPI_Datatype *);
int MPI_Type_hvector(int, int, MPI_Aint, MPI_Datatype, MPI_Datatype *);
int MPI_Type_indexed(int,  int *,  int *, MPI_Datatype, MPI_Datatype *);
int MPI_Type_hindexed(int,  int *,  MPI_Aint *, MPI_Datatype, MPI_Datatype *);
int MPI_Type_struct(int,  int *,  MPI_Aint *,  MPI_Datatype *, MPI_Datatype *);
int MPI_Address( void*, MPI_Aint *);
int MPI_Type_extent(MPI_Datatype, MPI_Aint *);
#line 858
int MPI_Type_size(MPI_Datatype, int *);
int MPI_Type_lb(MPI_Datatype, MPI_Aint *);
int MPI_Type_ub(MPI_Datatype, MPI_Aint *);
int MPI_Type_commit(MPI_Datatype *);
int MPI_Type_free(MPI_Datatype *);
int MPI_Get_elements( MPI_Status *, MPI_Datatype, int *);
int MPI_Pack( void*, int, MPI_Datatype, void *, int, int *,  MPI_Comm) ;
int MPI_Unpack( void*, int, int *, void *, int, MPI_Datatype, MPI_Comm) ;
int MPI_Pack_size(int, MPI_Datatype, MPI_Comm, int *);
int MPI_Barrier(MPI_Comm );
int MPI_Bcast(void*, int, MPI_Datatype, int, MPI_Comm) ;
int MPI_Gather( void* , int, MPI_Datatype, void*, int, MPI_Datatype, int, MPI_Comm)  ;
int MPI_Gatherv( void* , int, MPI_Datatype, void*,  int *,
                 int *, MPI_Datatype, int, MPI_Comm)  ;
int MPI_Scatter( void* , int, MPI_Datatype, void*, int, MPI_Datatype, int, MPI_Comm)  ;
int MPI_Scatterv( void* ,  int *,  int *,  MPI_Datatype, void*, int, MPI_Datatype, int, MPI_Comm)  ;
int MPI_Allgather( void* , int, MPI_Datatype, void*, int, MPI_Datatype, MPI_Comm)  ;
int MPI_Allgatherv( void* , int, MPI_Datatype, void*,  int *,
                    int *, MPI_Datatype, MPI_Comm)  ;
int MPI_Alltoall( void* , int, MPI_Datatype, void*, int, MPI_Datatype, MPI_Comm)  ;
int MPI_Alltoallv( void* ,  int *,  int *, MPI_Datatype,
                  void*,  int *,  int *, MPI_Datatype, MPI_Comm)  ;
int MPI_Reduce( void* , void*, int, MPI_Datatype, MPI_Op, int, MPI_Comm)  ;
int MPI_Op_create(MPI_User_function *, int, MPI_Op *);
int MPI_Op_free( MPI_Op *);
int MPI_Allreduce( void*, void*, int, MPI_Datatype, MPI_Op, MPI_Comm)  ;
int MPI_Reduce_scatter( void* , void*,  int *, MPI_Datatype, MPI_Op, MPI_Comm)  ;
int MPI_Scan( void* , void*, int, MPI_Datatype, MPI_Op, MPI_Comm)  ;
int MPI_Group_size(MPI_Group, int *);
int MPI_Group_rank(MPI_Group, int *);
int MPI_Group_translate_ranks (MPI_Group, int,  int *, MPI_Group, int *);
int MPI_Group_compare(MPI_Group, MPI_Group, int *);
int MPI_Comm_group(MPI_Comm, MPI_Group *);
int MPI_Group_union(MPI_Group, MPI_Group, MPI_Group *);
int MPI_Group_intersection(MPI_Group, MPI_Group, MPI_Group *);
int MPI_Group_difference(MPI_Group, MPI_Group, MPI_Group *);
int MPI_Group_incl(MPI_Group, int,  int *, MPI_Group *);
int MPI_Group_excl(MPI_Group, int,  int *, MPI_Group *);
int MPI_Group_range_incl(MPI_Group, int, int [][3], MPI_Group *);
int MPI_Group_range_excl(MPI_Group, int, int [][3], MPI_Group *);
int MPI_Group_free(MPI_Group *);
int MPI_Comm_size(MPI_Comm, int *);
int MPI_Comm_rank(MPI_Comm, int *);
int MPI_Comm_compare(MPI_Comm, MPI_Comm, int *);
int MPI_Comm_dup(MPI_Comm, MPI_Comm *);
int MPI_Comm_create(MPI_Comm, MPI_Group, MPI_Comm *);
int MPI_Comm_split(MPI_Comm, int, int, MPI_Comm *);
int MPI_Comm_free(MPI_Comm *);
int MPI_Comm_test_inter(MPI_Comm, int *);
int MPI_Comm_remote_size(MPI_Comm, int *);
int MPI_Comm_remote_group(MPI_Comm, MPI_Group *);
int MPI_Intercomm_create(MPI_Comm, int, MPI_Comm, int, int, MPI_Comm * );
int MPI_Intercomm_merge(MPI_Comm, int, MPI_Comm *);
int MPI_Keyval_create(MPI_Copy_function *, MPI_Delete_function *, int *, void*);
int MPI_Keyval_free(int *);
int MPI_Attr_put(MPI_Comm, int, void*);
int MPI_Attr_get(MPI_Comm, int, void *, int *);
int MPI_Attr_delete(MPI_Comm, int);
int MPI_Topo_test(MPI_Comm, int *);
int MPI_Cart_create(MPI_Comm, int,  int *,  int *, int, MPI_Comm *);
int MPI_Dims_create(int, int, int *);
int MPI_Graph_create(MPI_Comm, int,  int *,  int *, int, MPI_Comm *);
int MPI_Graphdims_get(MPI_Comm, int *, int *);
int MPI_Graph_get(MPI_Comm, int, int, int *, int *);
int MPI_Cartdim_get(MPI_Comm, int *);
int MPI_Cart_get(MPI_Comm, int, int *, int *, int *);
int MPI_Cart_rank(MPI_Comm,  int *, int *);
int MPI_Cart_coords(MPI_Comm, int, int, int *);
int MPI_Graph_neighbors_count(MPI_Comm, int, int *);
int MPI_Graph_neighbors(MPI_Comm, int, int, int *);
int MPI_Cart_shift(MPI_Comm, int, int, int *, int *);
int MPI_Cart_sub(MPI_Comm,  int *, MPI_Comm *);
int MPI_Cart_map(MPI_Comm, int,  int *,  int *, int *);
int MPI_Graph_map(MPI_Comm, int,  int *,  int *, int *);
int MPI_Get_processor_name(char *, int *);
int MPI_Get_version(int *, int *);
int MPI_Errhandler_create(MPI_Handler_function *, MPI_Errhandler *);
int MPI_Errhandler_set(MPI_Comm, MPI_Errhandler);
int MPI_Errhandler_get(MPI_Comm, MPI_Errhandler *);
int MPI_Errhandler_free(MPI_Errhandler *);
int MPI_Error_string(int, char *, int *);
int MPI_Error_class(int, int *);
double MPI_Wtime(void);
double MPI_Wtick(void);
double PMPI_Wtime(void);
double PMPI_Wtick(void);
int MPI_Init(int *, char ***);
int MPI_Finalize(void);
int MPI_Initialized(int *);
int MPI_Abort(MPI_Comm, int);
#line 955
int MPI_Pcontrol(const int, ...);
int MPIR_Dup_fn ( MPI_Comm, int, void *, void *, void *, int * );
#line 963
int MPI_Close_port( char *);
int MPI_Comm_accept( char *, MPI_Info, int, MPI_Comm, MPI_Comm *);
int MPI_Comm_connect( char *, MPI_Info, int, MPI_Comm, MPI_Comm *);
int MPI_Comm_disconnect(MPI_Comm *);
int MPI_Comm_get_parent(MPI_Comm *);
int MPI_Comm_join(int, MPI_Comm *);
int MPI_Comm_spawn( char *, char *[], int, MPI_Info, int, MPI_Comm, MPI_Comm *,
                   int []);
int MPI_Comm_spawn_multiple(int, char *[], char **[],  int [],  MPI_Info [], int,
			    MPI_Comm, MPI_Comm *, int []);
int MPI_Lookup_name( char *, MPI_Info, char *);
int MPI_Open_port(MPI_Info, char *);
int MPI_Publish_name( char *, MPI_Info,  char *);
int MPI_Unpublish_name( char *, MPI_Info,  char *);
#line 979
int MPI_Accumulate( void *, int, MPI_Datatype, int, MPI_Aint, int,
                   MPI_Datatype,  MPI_Op, MPI_Win) ;
int MPI_Get(void *, int, MPI_Datatype, int, MPI_Aint, int, MPI_Datatype,
            MPI_Win) ;
int MPI_Put( void *, int, MPI_Datatype, int, MPI_Aint, int, MPI_Datatype,
            MPI_Win) ;
int MPI_Win_complete(MPI_Win);
int MPI_Win_create(void *, MPI_Aint, int, MPI_Info, MPI_Comm, MPI_Win *);
int MPI_Win_fence(int, MPI_Win);
int MPI_Win_free(MPI_Win *);
int MPI_Win_get_group(MPI_Win, MPI_Group *);
int MPI_Win_lock(int, int, int, MPI_Win);
int MPI_Win_post(MPI_Group, int, MPI_Win);
int MPI_Win_start(MPI_Group, int, MPI_Win);
int MPI_Win_test(MPI_Win, int *);
int MPI_Win_unlock(int, MPI_Win);
int MPI_Win_wait(MPI_Win);
#line 998
int MPIX_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info,
                      MPI_Comm comm, void *baseptr, MPI_Win *win);
int MPIX_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
int MPIX_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int MPIX_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int MPIX_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int MPIX_Win_detach(MPI_Win win, const void *base);
int MPIX_Get_accumulate(const void *origin_addr, int origin_count,
                        MPI_Datatype origin_datatype, void *result_addr, int result_count,
                        MPI_Datatype result_datatype, int target_rank, MPI_Aint target_disp,
                        int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win);
int MPIX_Fetch_and_op(const void *origin_addr, void *result_addr,
                      MPI_Datatype datatype, int target_rank, MPI_Aint target_disp,
int MPIX_Compare_and_swap(const void *origin_addr, const void *compare_addr,
                          void *result_addr, MPI_Datatype datatype, int target_rank,
                          MPI_Aint target_disp, MPI_Win win);
int MPIX_Rput(const void *origin_addr, int origin_count,
              MPI_Datatype origin_datatype, int target_rank, MPI_Aint target_disp,
              int target_count, MPI_Datatype target_datatype, MPI_Win win,
              MPI_Request *request);
int MPIX_Rget(void *origin_addr, int origin_count,
int MPIX_Raccumulate(const void *origin_addr, int origin_count,
                     int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win,
int MPIX_Rget_accumulate(const void *origin_addr, int origin_count,
int MPIX_Win_lock_all(int assert, MPI_Win win);
int MPIX_Win_unlock_all(MPI_Win win);
int MPIX_Win_flush(int rank, MPI_Win win);
int MPIX_Win_flush_all(MPI_Win win);
int MPIX_Win_flush_local(int rank, MPI_Win win);
int MPIX_Win_flush_local_all(MPI_Win win);
int MPIX_Win_sync(MPI_Win win);
#line 1045
int MPI_Alltoallw( void *,  int [],  int [],
                   MPI_Datatype [], void *,  int [],
		   int [],  MPI_Datatype [], MPI_Comm);
int MPI_Exscan( void *, void *, int, MPI_Datatype, MPI_Op, MPI_Comm)  ;
#line 1051
int MPI_Add_error_class(int *);
int MPI_Add_error_code(int, int *);
int MPI_Add_error_string(int,  char *);
int MPI_Comm_call_errhandler(MPI_Comm, int);
int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *,
                           MPI_Comm_delete_attr_function *, int *, void *);
int MPI_Comm_delete_attr(MPI_Comm, int);
int MPI_Comm_free_keyval(int *);
int MPI_Comm_get_attr(MPI_Comm, int, void *, int *);
int MPI_Comm_get_name(MPI_Comm, char *, int *);
int MPI_Comm_set_attr(MPI_Comm, int, void *);
int MPI_Comm_set_name(MPI_Comm,  char *);
int MPI_File_call_errhandler(MPI_File, int);
int MPI_Grequest_complete(MPI_Request);
int MPI_Grequest_start(MPI_Grequest_query_function *,
                       MPI_Grequest_free_function *,
                       MPI_Grequest_cancel_function *, void *, MPI_Request *);
int MPI_Init_thread(int *, char ***, int, int *);
int MPI_Is_thread_main(int *);
int MPI_Query_thread(int *);
int MPI_Status_set_cancelled(MPI_Status *, int);
int MPI_Status_set_elements(MPI_Status *, MPI_Datatype, int);
int MPI_Type_create_keyval(MPI_Type_copy_attr_function *,
                           MPI_Type_delete_attr_function *, int *, void *);
int MPI_Type_delete_attr(MPI_Datatype, int);
int MPI_Type_dup(MPI_Datatype, MPI_Datatype *);
int MPI_Type_free_keyval(int *);
int MPI_Type_get_attr(MPI_Datatype, int, void *, int *);
int MPI_Type_get_contents(MPI_Datatype, int, int, int, int [], MPI_Aint [],
                          MPI_Datatype []);
int MPI_Type_get_envelope(MPI_Datatype, int *, int *, int *, int *);
int MPI_Type_get_name(MPI_Datatype, char *, int *);
int MPI_Type_set_attr(MPI_Datatype, int, void *);
int MPI_Type_set_name(MPI_Datatype,  char *);
int MPI_Type_match_size( int, int, MPI_Datatype *);
int MPI_Win_call_errhandler(MPI_Win, int);
int MPI_Win_create_keyval(MPI_Win_copy_attr_function *,
                         MPI_Win_delete_attr_function *, int *, void *);
int MPI_Win_delete_attr(MPI_Win, int);
int MPI_Win_free_keyval(int *);
int MPI_Win_get_attr(MPI_Win, int, void *, int *);
int MPI_Win_get_name(MPI_Win, char *, int *);
int MPI_Win_set_attr(MPI_Win, int, void *);
int MPI_Win_set_name(MPI_Win,  char *);
#line 1116
int MPI_Alloc_mem(MPI_Aint, MPI_Info info, void *baseptr);
int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *, MPI_Errhandler *);
int MPI_Comm_get_errhandler(MPI_Comm, MPI_Errhandler *);
int MPI_Comm_set_errhandler(MPI_Comm, MPI_Errhandler);
int MPI_File_create_errhandler(MPI_File_errhandler_function *, MPI_Errhandler *);
int MPI_File_get_errhandler(MPI_File, MPI_Errhandler *);
int MPI_File_set_errhandler(MPI_File, MPI_Errhandler);
int MPI_Finalized(int *);
int MPI_Free_mem(void *);
int MPI_Get_address( void *, MPI_Aint *);
int MPI_Info_create(MPI_Info *);
int MPI_Info_delete(MPI_Info,  char *);
int MPI_Info_dup(MPI_Info, MPI_Info *);
int MPI_Info_free(MPI_Info *info);
int MPI_Info_get(MPI_Info,  char *, int, char *, int *);
int MPI_Info_get_nkeys(MPI_Info, int *);
int MPI_Info_get_nthkey(MPI_Info, int, char *);
int MPI_Info_get_valuelen(MPI_Info,  char *, int *, int *);
int MPI_Info_set(MPI_Info,  char *,  char *);
int MPI_Pack_external( char *,  void *, int, MPI_Datatype, void *,
                      MPI_Aint, MPI_Aint *) ;
int MPI_Pack_external_size( char *, int, MPI_Datatype, MPI_Aint *);
int MPI_Request_get_status(MPI_Request, int *, MPI_Status *);
int MPI_Status_c2f( MPI_Status *, MPI_Fint *);
int MPI_Status_f2c( MPI_Fint *, MPI_Status *);
int MPI_Type_create_darray(int, int, int,  int [],  int [],
                            int [],  int [], int,
int MPI_Type_create_hindexed(int,  int [],  MPI_Aint [], MPI_Datatype,
                             MPI_Datatype *);
int MPI_Type_create_hvector(int, int, MPI_Aint, MPI_Datatype, MPI_Datatype *);
int MPI_Type_create_indexed_block(int, int,  int [], MPI_Datatype,
                                  MPI_Datatype *);
int MPIX_Type_create_hindexed_block(int, int, const MPI_Aint [], MPI_Datatype, MPI_Datatype *);
int MPI_Type_create_resized(MPI_Datatype, MPI_Aint, MPI_Aint, MPI_Datatype *);
int MPI_Type_create_struct(int,  int [],  MPI_Aint [],
                            MPI_Datatype [], MPI_Datatype *);
int MPI_Type_create_subarray(int,  int [],  int [],  int [],
int MPI_Type_get_extent(MPI_Datatype, MPI_Aint *, MPI_Aint *);
int MPI_Type_get_true_extent(MPI_Datatype, MPI_Aint *, MPI_Aint *);
int MPI_Unpack_external( char *,  void *, MPI_Aint, MPI_Aint *, void *,
                        int, MPI_Datatype) ;
int MPI_Win_create_errhandler(MPI_Win_errhandler_function *, MPI_Errhandler *);
int MPI_Win_get_errhandler(MPI_Win, MPI_Errhandler *);
int MPI_Win_set_errhandler(MPI_Win, MPI_Errhandler);
#line 1166
int MPI_Type_create_f90_integer( int, MPI_Datatype * );
int MPI_Type_create_f90_real( int, int, MPI_Datatype * );
int MPI_Type_create_f90_complex( int, int, MPI_Datatype * );
#line 1171
int MPI_Reduce_local( void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype, MPI_Op op)  ;
int MPI_Op_commutative(MPI_Op op, int *commute);
int MPI_Reduce_scatter_block( void *sendbuf, void *recvbuf, int recvcount, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)  ;
int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree,  int [],  int [], int outdegree,  int [],  int [], MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
int MPI_Dist_graph_create(MPI_Comm comm_old, int n,  int [],  int [],  int [],  int [], MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
int MPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int [], int [], int maxoutdegree, int [], int []);
#line 1180
int MPIX_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPIX_Message *message, MPI_Status *status);
int MPIX_Imrecv(void *buf, int count, MPI_Datatype datatype, MPIX_Message *message, MPI_Request *request) ;
int MPIX_Mprobe(int source, int tag, MPI_Comm comm, MPIX_Message *message, MPI_Status *status);
int MPIX_Mrecv(void *buf, int count, MPI_Datatype datatype, MPIX_Message *message, MPI_Status *status) ;
#line 1186
int MPIX_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
#line 1189
int MPIX_Ibarrier(MPI_Comm comm, MPI_Request *request);
int MPIX_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm, MPI_Request *request) ;
int MPIX_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, const int *recvcounts, const int *displs, MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Iscatterv(const void *sendbuf, const int *sendcounts, const int *displs, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, const int *recvcounts, const int *displs, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Ialltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls, MPI_Datatype sendtype, void *recvbuf, const int *recvcounts, const int *rdispls, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Ialltoallw(const void *sendbuf, const int *sendcounts, const int *sdispls, const MPI_Datatype *sendtypes, void *recvbuf, const int *recvcounts, const int *rdispls, const MPI_Datatype *recvtypes, MPI_Comm comm, MPI_Request *request);
int MPIX_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int *recvcounts, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)  ;
#line 1208
int MPIX_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, const int recvcounts[], const int displs[], MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[], MPI_Datatype sendtype, void *recvbuf, const int recvcounts[], const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int MPIX_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[], const MPI_Datatype sendtypes[], void *recvbuf, const int recvcounts[], const MPI_Aint rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm, MPI_Request *request);
int MPIX_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm)  ;
int MPIX_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, const int recvcounts[], const int displs[], MPI_Datatype recvtype, MPI_Comm comm)  ;
int MPIX_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm)  ;
int MPIX_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[], MPI_Datatype sendtype, void *recvbuf, const int recvcounts[], const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm)  ;
int MPIX_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[], const MPI_Datatype sendtypes[], void *recvbuf, const int recvcounts[], const MPI_Aint rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
#line 1220
int MPIX_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
#line 1223
int MPIX_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm * newcomm);
#line 1226
int MPIX_Comm_group_failed(MPI_Comm, MPI_Group *);
int MPIX_Comm_remote_group_failed(MPI_Comm, MPI_Group *);
int MPIX_Comm_reenable_anysource(MPI_Comm, MPI_Group *);
#line 1231
struct mpixi_mutex_s;
typedef struct mpixi_mutex_s * MPIX_Mutex;
int MPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int MPIX_Mutex_free(MPIX_Mutex *hdl);
int MPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int MPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
#line 1244
int MPIX_T_init_thread(int required, int *provided);
int MPIX_T_finalize(void);
int MPIX_T_enum_get_info(MPIX_T_enum enumtype, int num, char *name, int *name_len);
int MPIX_T_enum_get_item(MPIX_T_enum enumtype, int num, int *value, char *name, int *name_len);
int MPIX_T_cvar_get_num(int *num_cvar);
int MPIX_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity, MPI_Datatype *datatype, MPIX_T_enum *enumtype, char *desc, int *desc_len, int *bind, int *scope);
int MPIX_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPIX_T_cvar_handle *handle, int *count);
int MPIX_T_cvar_handle_free(MPIX_T_cvar_handle *handle);
int MPIX_T_cvar_read(MPIX_T_cvar_handle handle, void *buf);
int MPIX_T_cvar_write(MPIX_T_cvar_handle handle, void *buf);
int MPIX_T_pvar_get_num(int *num_pvar);
int MPIX_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class, MPI_Datatype *datatype, MPIX_T_enum *enumtype, char *desc, int *desc_len, int *bind, int *readonly, int *continuous, int *atomic);
int MPIX_T_pvar_session_create(MPIX_T_pvar_session *session);
int MPIX_T_pvar_session_free(MPIX_T_pvar_session *session);
int MPIX_T_pvar_handle_alloc(MPIX_T_pvar_session session, int pvar_index, void *obj_handle, MPIX_T_pvar_handle *handle, int *count);
int MPIX_T_pvar_handle_free(MPIX_T_pvar_session session, MPIX_T_pvar_handle *handle);
int MPIX_T_pvar_start(MPIX_T_pvar_session session, MPIX_T_pvar_handle handle);
int MPIX_T_pvar_stop(MPIX_T_pvar_session session, MPIX_T_pvar_handle handle);
int MPIX_T_pvar_read(MPIX_T_pvar_session session, MPIX_T_pvar_handle handle, void *buf);
int MPIX_T_pvar_write(MPIX_T_pvar_session session, MPIX_T_pvar_handle handle, void *buf);
int MPIX_T_pvar_reset(MPIX_T_pvar_session session, MPIX_T_pvar_handle handle);
int MPIX_T_pvar_readreset(MPIX_T_pvar_session session, MPIX_T_pvar_handle handle, void *buf);
int MPIX_T_category_get_num(int *num_cat);
int MPIX_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len, int *num_controlvars, int *num_pvars, int *num_categories);
int MPIX_T_category_get_cvars(int cat_index, int len, int indices[]);
int MPIX_T_category_get_pvars(int cat_index[], int len, int indices[]);
int MPIX_T_category_get_categories(int cat_index, int len, int indices[]);
int MPIX_T_category_changed(int *stamp);
#line 1280
int PMPI_Send( void*, int, MPI_Datatype, int, int, MPI_Comm) ;
int PMPI_Recv(void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Status *) ;
int PMPI_Get_count( MPI_Status *, MPI_Datatype, int *);
int PMPI_Bsend( void*, int, MPI_Datatype, int, int, MPI_Comm) ;
int PMPI_Ssend( void*, int, MPI_Datatype, int, int, MPI_Comm) ;
int PMPI_Rsend( void*, int, MPI_Datatype, int, int, MPI_Comm) ;
int PMPI_Buffer_attach( void* buffer, int);
int PMPI_Buffer_detach( void* buffer, int *);
int PMPI_Isend( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Ibsend( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Issend( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Irsend( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Irecv(void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Wait(MPI_Request *, MPI_Status *);
int PMPI_Test(MPI_Request *, int *, MPI_Status *);
int PMPI_Request_free(MPI_Request *);
int PMPI_Waitany(int, MPI_Request *, int *, MPI_Status *);
int PMPI_Testany(int, MPI_Request *, int *, int *, MPI_Status *);
int PMPI_Waitall(int, MPI_Request *, MPI_Status *);
int PMPI_Testall(int, MPI_Request *, int *, MPI_Status *);
int PMPI_Waitsome(int, MPI_Request *, int *, int *, MPI_Status *);
int PMPI_Testsome(int, MPI_Request *, int *, int *, MPI_Status *);
int PMPI_Iprobe(int, int, MPI_Comm, int *, MPI_Status *);
int PMPI_Probe(int, int, MPI_Comm, MPI_Status *);
int PMPI_Cancel(MPI_Request *);
int PMPI_Test_cancelled( MPI_Status *, int *);
int PMPI_Send_init( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Bsend_init( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Ssend_init( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Rsend_init( void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Recv_init(void*, int, MPI_Datatype, int, int, MPI_Comm, MPI_Request *) ;
int PMPI_Start(MPI_Request *);
int PMPI_Startall(int, MPI_Request *);
int PMPI_Sendrecv( void *, int, MPI_Datatype, int, int, void *, int, MPI_Datatype, int, int, MPI_Comm, MPI_Status *)  ;
int PMPI_Sendrecv_replace(void*, int, MPI_Datatype, int, int, int, int, MPI_Comm, MPI_Status *) ;
int PMPI_Type_contiguous(int, MPI_Datatype, MPI_Datatype *);
int PMPI_Type_vector(int, int, int, MPI_Datatype, MPI_Datatype *);
int PMPI_Type_hvector(int, int, MPI_Aint, MPI_Datatype, MPI_Datatype *);
int PMPI_Type_indexed(int,  int *,  int *, MPI_Datatype, MPI_Datatype *);
int PMPI_Type_hindexed(int,  int *,  MPI_Aint *, MPI_Datatype, MPI_Datatype *);
int PMPI_Type_struct(int,  int *,  MPI_Aint *,  MPI_Datatype *, MPI_Datatype *);
int PMPI_Address( void*, MPI_Aint *);
int PMPI_Type_extent(MPI_Datatype, MPI_Aint *);
int PMPI_Type_size(MPI_Datatype, int *);
int PMPI_Type_lb(MPI_Datatype, MPI_Aint *);
int PMPI_Type_ub(MPI_Datatype, MPI_Aint *);
int PMPI_Type_commit(MPI_Datatype *);
int PMPI_Type_free(MPI_Datatype *);
int PMPI_Get_elements( MPI_Status *, MPI_Datatype, int *);
int PMPI_Pack( void*, int, MPI_Datatype, void *, int, int *,  MPI_Comm) ;
int PMPI_Unpack( void*, int, int *, void *, int, MPI_Datatype, MPI_Comm) ;
int PMPI_Pack_size(int, MPI_Datatype, MPI_Comm, int *);
int PMPI_Barrier(MPI_Comm );
int PMPI_Bcast(void* buffer, int, MPI_Datatype, int, MPI_Comm );
int PMPI_Gather( void* , int, MPI_Datatype, void*, int, MPI_Datatype, int, MPI_Comm)  ;
int PMPI_Gatherv( void* , int, MPI_Datatype, void*,  int *,  int *, MPI_Datatype, int, MPI_Comm)  ;
int PMPI_Scatter( void* , int, MPI_Datatype, void*, int, MPI_Datatype, int, MPI_Comm)  ;
int PMPI_Scatterv( void* ,  int *,  int *, MPI_Datatype, void*, int, MPI_Datatype, int, MPI_Comm)  ;
int PMPI_Allgather( void* , int, MPI_Datatype, void*, int, MPI_Datatype, MPI_Comm)  ;
int PMPI_Allgatherv( void* , int, MPI_Datatype, void*,  int *,
int PMPI_Alltoall( void* , int, MPI_Datatype, void*, int, MPI_Datatype, MPI_Comm)  ;
int PMPI_Alltoallv( void* ,  int *,  int *, MPI_Datatype,
int PMPI_Reduce( void* , void*, int, MPI_Datatype, MPI_Op, int, MPI_Comm)  ;
int PMPI_Op_create(MPI_User_function *, int, MPI_Op *);
int PMPI_Op_free( MPI_Op *);
int PMPI_Allreduce( void* , void*, int, MPI_Datatype, MPI_Op, MPI_Comm)  ;
int PMPI_Reduce_scatter( void* , void*,  int *, MPI_Datatype, MPI_Op, MPI_Comm)  ;
int PMPI_Scan( void* , void*, int, MPI_Datatype, MPI_Op, MPI_Comm)  ;
int PMPI_Group_size(MPI_Group, int *);
int PMPI_Group_rank(MPI_Group, int *);
int PMPI_Group_translate_ranks(MPI_Group, int,  int *, MPI_Group, int *);
int PMPI_Group_compare(MPI_Group, MPI_Group, int *);
int PMPIX_Comm_group_failed(MPI_Comm, MPI_Group *);
int PMPIX_Comm_reenable_anysource(MPI_Comm, MPI_Group *);
int PMPIX_Comm_remote_group_failed(MPI_Comm, MPI_Group *);
int PMPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int PMPIX_Mutex_free(MPIX_Mutex *hdl);
int PMPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int PMPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
int PMPI_Comm_group(MPI_Comm, MPI_Group *);
int PMPI_Group_union(MPI_Group, MPI_Group, MPI_Group *);
int PMPI_Group_intersection(MPI_Group, MPI_Group, MPI_Group *);
int PMPI_Group_difference(MPI_Group, MPI_Group, MPI_Group *);
int PMPI_Group_incl(MPI_Group, int,  int *, MPI_Group *);
int PMPI_Group_excl(MPI_Group, int,  int *, MPI_Group *);
int PMPI_Group_range_incl(MPI_Group, int, int [][3], MPI_Group *);
int PMPI_Group_range_excl(MPI_Group, int, int [][3], MPI_Group *);
int PMPI_Group_free(MPI_Group *);
int PMPI_Comm_size(MPI_Comm, int *);
int PMPI_Comm_rank(MPI_Comm, int *);
int PMPI_Comm_compare(MPI_Comm, MPI_Comm, int *);
int PMPI_Comm_dup(MPI_Comm, MPI_Comm *);
int PMPI_Comm_create(MPI_Comm, MPI_Group, MPI_Comm *);
int PMPI_Comm_split(MPI_Comm, int, int, MPI_Comm *);
int PMPI_Comm_free(MPI_Comm *);
int PMPI_Comm_test_inter(MPI_Comm, int *);
int PMPI_Comm_remote_size(MPI_Comm, int *);
int PMPI_Comm_remote_group(MPI_Comm, MPI_Group *);
int PMPI_Intercomm_create(MPI_Comm, int, MPI_Comm, int, int, MPI_Comm *);
int PMPI_Intercomm_merge(MPI_Comm, int, MPI_Comm *);
int PMPI_Keyval_create(MPI_Copy_function *, MPI_Delete_function *, int *, void*);
int PMPI_Keyval_free(int *);
int PMPI_Attr_put(MPI_Comm, int, void*);
int PMPI_Attr_get(MPI_Comm, int, void *, int *);
int PMPI_Attr_delete(MPI_Comm, int);
int PMPI_Topo_test(MPI_Comm, int *);
int PMPI_Cart_create(MPI_Comm, int,  int *,  int *, int, MPI_Comm *);
int PMPI_Dims_create(int, int, int *);
int PMPI_Graph_create(MPI_Comm, int,  int *,  int *, int, MPI_Comm *);
int PMPI_Graphdims_get(MPI_Comm, int *, int *);
int PMPI_Graph_get(MPI_Comm, int, int, int *, int *);
int PMPI_Cartdim_get(MPI_Comm, int *);
int PMPI_Cart_get(MPI_Comm, int, int *, int *, int *);
int PMPI_Cart_rank(MPI_Comm,  int *, int *);
int PMPI_Cart_coords(MPI_Comm, int, int, int *);
int PMPI_Graph_neighbors_count(MPI_Comm, int, int *);
int PMPI_Graph_neighbors(MPI_Comm, int, int, int *);
int PMPI_Cart_shift(MPI_Comm, int, int, int *, int *);
int PMPI_Cart_sub(MPI_Comm,  int *, MPI_Comm *);
int PMPI_Cart_map(MPI_Comm, int,  int *,  int *, int *);
int PMPI_Graph_map(MPI_Comm, int,  int *,  int *, int *);
int PMPI_Get_processor_name(char *, int *);
int PMPI_Get_version(int *, int *);
int PMPI_Errhandler_create(MPI_Handler_function *, MPI_Errhandler *);
int PMPI_Errhandler_set(MPI_Comm, MPI_Errhandler);
int PMPI_Errhandler_get(MPI_Comm, MPI_Errhandler *);
int PMPI_Errhandler_free(MPI_Errhandler *);
int PMPI_Error_string(int, char *, int *);
int PMPI_Error_class(int, int *);
#line 1413
int PMPI_Init(int *, char ***);
int PMPI_Finalize(void);
int PMPI_Initialized(int *);
int PMPI_Abort(MPI_Comm, int);
int PMPI_Pcontrol(const int, ...);
#line 1423
int PMPI_Close_port( char *);
int PMPI_Comm_accept( char *, MPI_Info, int, MPI_Comm, MPI_Comm *);
int PMPI_Comm_connect( char *, MPI_Info, int, MPI_Comm, MPI_Comm *);
int PMPI_Comm_disconnect(MPI_Comm *);
int PMPI_Comm_get_parent(MPI_Comm *);
int PMPI_Comm_join(int, MPI_Comm *);
int PMPI_Comm_spawn( char *, char *[], int, MPI_Info, int, MPI_Comm, MPI_Comm *,
                   int []);
int PMPI_Comm_spawn_multiple(int, char *[], char **[],  int [],  MPI_Info [], int,
int PMPI_Lookup_name( char *, MPI_Info, char *);
int PMPI_Open_port(MPI_Info, char *);
int PMPI_Publish_name( char *, MPI_Info,  char *);
int PMPI_Unpublish_name( char *, MPI_Info,  char *);
#line 1439
int PMPI_Accumulate( void *, int, MPI_Datatype, int, MPI_Aint, int,
int PMPI_Get(void *, int, MPI_Datatype, int, MPI_Aint, int, MPI_Datatype,
	    MPI_Win) ;
int PMPI_Put( void *, int, MPI_Datatype, int, MPI_Aint, int, MPI_Datatype,
	    MPI_Win) ;
int PMPI_Win_complete(MPI_Win);
int PMPI_Win_create(void *, MPI_Aint, int, MPI_Info, MPI_Comm, MPI_Win *);
int PMPI_Win_fence(int, MPI_Win);
int PMPI_Win_free(MPI_Win *);
int PMPI_Win_get_group(MPI_Win, MPI_Group *);
int PMPI_Win_lock(int, int, int, MPI_Win);
int PMPI_Win_post(MPI_Group, int, MPI_Win);
int PMPI_Win_start(MPI_Group, int, MPI_Win);
int PMPI_Win_test(MPI_Win, int *);
int PMPI_Win_unlock(int, MPI_Win);
int PMPI_Win_wait(MPI_Win);
#line 1458
int PMPIX_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info,
int PMPIX_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
int PMPIX_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int PMPIX_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int PMPIX_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int PMPIX_Win_detach(MPI_Win win, const void *base);
int PMPIX_Get_accumulate(const void *origin_addr, int origin_count,
int PMPIX_Fetch_and_op(const void *origin_addr, void *result_addr,
int PMPIX_Compare_and_swap(const void *origin_addr, const void *compare_addr,
int PMPIX_Rput(const void *origin_addr, int origin_count,
int PMPIX_Rget(void *origin_addr, int origin_count,
int PMPIX_Raccumulate(const void *origin_addr, int origin_count,
int PMPIX_Rget_accumulate(const void *origin_addr, int origin_count,
int PMPIX_Win_lock_all(int assert, MPI_Win win);
int PMPIX_Win_unlock_all(MPI_Win win);
int PMPIX_Win_flush(int rank, MPI_Win win);
int PMPIX_Win_flush_all(MPI_Win win);
int PMPIX_Win_flush_local(int rank, MPI_Win win);
int PMPIX_Win_flush_local_all(MPI_Win win);
int PMPIX_Win_sync(MPI_Win win);
#line 1504
int PMPI_Alltoallw( void *,  int [],  int [],
int PMPI_Exscan( void *, void *, int, MPI_Datatype, MPI_Op, MPI_Comm)  ;
#line 1510
int PMPI_Add_error_class(int *);
int PMPI_Add_error_code(int, int *);
int PMPI_Add_error_string(int,  char *);
int PMPI_Comm_call_errhandler(MPI_Comm, int);
int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *,
int PMPI_Comm_delete_attr(MPI_Comm, int);
int PMPI_Comm_free_keyval(int *);
int PMPI_Comm_get_attr(MPI_Comm, int, void *, int *);
int PMPI_Comm_get_name(MPI_Comm, char *, int *);
int PMPI_Comm_set_attr(MPI_Comm, int, void *);
int PMPI_Comm_set_name(MPI_Comm,  char *);
int PMPI_File_call_errhandler(MPI_File, int);
int PMPI_Grequest_complete(MPI_Request);
int PMPI_Grequest_start(MPI_Grequest_query_function *,
int PMPI_Init_thread(int *, char ***, int, int *);
int PMPI_Is_thread_main(int *);
int PMPI_Query_thread(int *);
int PMPI_Status_set_cancelled(MPI_Status *, int);
int PMPI_Status_set_elements(MPI_Status *, MPI_Datatype, int);
int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *,
int PMPI_Type_delete_attr(MPI_Datatype, int);
int PMPI_Type_dup(MPI_Datatype, MPI_Datatype *);
int PMPI_Type_free_keyval(int *);
int PMPI_Type_get_attr(MPI_Datatype, int, void *, int *);
int PMPI_Type_get_contents(MPI_Datatype, int, int, int, int [], MPI_Aint [],
                          MPI_Datatype []);
int PMPI_Type_get_envelope(MPI_Datatype, int *, int *, int *, int *);
int PMPI_Type_get_name(MPI_Datatype, char *, int *);
int PMPI_Type_set_attr(MPI_Datatype, int, void *);
int PMPI_Type_set_name(MPI_Datatype,  char *);
int PMPI_Type_match_size( int, int, MPI_Datatype *);
int PMPI_Win_call_errhandler(MPI_Win, int);
int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *,
int PMPI_Win_delete_attr(MPI_Win, int);
int PMPI_Win_free_keyval(int *);
int PMPI_Win_get_attr(MPI_Win, int, void *, int *);
int PMPI_Win_get_name(MPI_Win, char *, int *);
int PMPI_Win_set_attr(MPI_Win, int, void *);
int PMPI_Win_set_name(MPI_Win,  char *);
#line 1558
int PMPI_Type_create_f90_integer( int, MPI_Datatype * );
int PMPI_Type_create_f90_real( int, int, MPI_Datatype * );
int PMPI_Type_create_f90_complex( int, int, MPI_Datatype * );
#line 1563
int PMPI_Alloc_mem(MPI_Aint, MPI_Info info, void *baseptr);
int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *, MPI_Errhandler *);
int PMPI_Comm_get_errhandler(MPI_Comm, MPI_Errhandler *);
int PMPI_Comm_set_errhandler(MPI_Comm, MPI_Errhandler);
int PMPI_File_create_errhandler(MPI_File_errhandler_function *, MPI_Errhandler *);
int PMPI_File_get_errhandler(MPI_File, MPI_Errhandler *);
int PMPI_File_set_errhandler(MPI_File, MPI_Errhandler);
int PMPI_Finalized(int *);
int PMPI_Free_mem(void *);
int PMPI_Get_address( void *, MPI_Aint *);
int PMPI_Info_create(MPI_Info *);
int PMPI_Info_delete(MPI_Info,  char *);
int PMPI_Info_dup(MPI_Info, MPI_Info *);
int PMPI_Info_free(MPI_Info *info);
int PMPI_Info_get(MPI_Info,  char *, int, char *, int *);
int PMPI_Info_get_nkeys(MPI_Info, int *);
int PMPI_Info_get_nthkey(MPI_Info, int, char *);
int PMPI_Info_get_valuelen(MPI_Info,  char *, int *, int *);
int PMPI_Info_set(MPI_Info,  char *,  char *);
int PMPI_Pack_external( char *,  void *, int, MPI_Datatype, void *,
int PMPI_Pack_external_size( char *, int, MPI_Datatype, MPI_Aint *);
int PMPI_Request_get_status(MPI_Request, int *, MPI_Status *);
int PMPI_Status_c2f( MPI_Status *, MPI_Fint *);
int PMPI_Status_f2c( MPI_Fint *, MPI_Status *);
int PMPI_Type_create_darray(int, int, int,  int [],  int [],
int PMPI_Type_create_hindexed(int,  int [],  MPI_Aint [], MPI_Datatype,
                             MPI_Datatype *);
int PMPI_Type_create_hvector(int, int, MPI_Aint, MPI_Datatype, MPI_Datatype *);
int PMPI_Type_create_indexed_block(int, int,  int [], MPI_Datatype,
                                  MPI_Datatype *);
int PMPIX_Type_create_hindexed_block(int, int, const MPI_Aint [], MPI_Datatype, MPI_Datatype *);
int PMPI_Type_create_resized(MPI_Datatype, MPI_Aint, MPI_Aint, MPI_Datatype *);
int PMPI_Type_create_struct(int,  int [],  MPI_Aint [],
int PMPI_Type_create_subarray(int,  int [],  int [],  int [],
int PMPI_Type_get_extent(MPI_Datatype, MPI_Aint *, MPI_Aint *);
int PMPI_Type_get_true_extent(MPI_Datatype, MPI_Aint *, MPI_Aint *);
int PMPI_Unpack_external( char *,  void *, MPI_Aint, MPI_Aint *, void *,
int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *, MPI_Errhandler *);
int PMPI_Win_get_errhandler(MPI_Win, MPI_Errhandler *);
int PMPI_Win_set_errhandler(MPI_Win, MPI_Errhandler);
int PMPI_Reduce_local( void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype, MPI_Op op)  ;
int PMPI_Op_commutative(MPI_Op op, int *commute);
int PMPI_Reduce_scatter_block( void *sendbuf, void *recvbuf, int recvcount, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)  ;
int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree,  int [],  int [], int outdegree,  int [],  int [], MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
int PMPI_Dist_graph_create(MPI_Comm comm_old, int n,  int [],  int [],  int [],  int [], MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
int PMPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int [], int [], int maxoutdegree, int [], int []);
int PMPIX_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
int PMPIX_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPIX_Message *message, MPI_Status *status);
int PMPIX_Imrecv(void *buf, int count, MPI_Datatype datatype, MPIX_Message *message, MPI_Request *request) ;
int PMPIX_Mprobe(int source, int tag, MPI_Comm comm, MPIX_Message *message, MPI_Status *status);
int PMPIX_Mrecv(void *buf, int count, MPI_Datatype datatype, MPIX_Message *message, MPI_Status *status) ;
int PMPIX_Ibarrier(MPI_Comm comm, MPI_Request *request);
int PMPIX_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm, MPI_Request *request) ;
int PMPIX_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request)  ;
int PMPIX_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, const int *recvcounts, const int *displs, MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request)  ;
int PMPIX_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request)  ;
int PMPIX_Iscatterv(const void *sendbuf, const int *sendcounts, const int *displs, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request)  ;
int PMPIX_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int PMPIX_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, const int *recvcounts, const int *displs, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int PMPIX_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int PMPIX_Ialltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls, MPI_Datatype sendtype, void *recvbuf, const int *recvcounts, const int *rdispls, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)  ;
int PMPIX_Ialltoallw(const void *sendbuf, const int *sendcounts, const int *sdispls, const MPI_Datatype *sendtypes, void *recvbuf, const int *recvcounts, const int *rdispls, const MPI_Datatype *recvtypes, MPI_Comm comm, MPI_Request *request);
int PMPIX_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm, MPI_Request *request)  ;
Found header files ['mpi.h'] in []
            Popping language C
TEST configureConversion from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:214)
TESTING: configureConversion from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:214)
  Check for the functions which convert communicators between C and Fortran
       - Define HAVE_MPI_COMM_F2C and HAVE_MPI_COMM_C2F if they are present
       - Some older MPI 1 implementations are missing these
                        All intermediate test results are stored in /tmp/petsc-ITHdGX/config.packages.MPI
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.packages.MPI/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.packages.MPI  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction   /tmp/petsc-ITHdGX/config.packages.MPI/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <mpi.h>
int main() {
if (MPI_Comm_f2c((MPI_Fint)0));
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.packages.MPI/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.packages.MPI/conftest.o  -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
            Defined "HAVE_MPI_COMM_F2C" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_c2f(MPI_COMM_WORLD));
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_MPI_COMM_C2F" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Fint a;
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_MPI_FINT" to "1"
TEST configureMPI2 from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:182)
TESTING: configureMPI2 from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:182)
  Check for functions added to the interface in MPI-2
Successful compile:
Source:
#include <mpi.h>
int main() {
int flag;if (MPI_Finalized(&flag));
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_MPI_FINALIZED" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Allreduce(MPI_IN_PLACE,0, 1, MPI_INT, MPI_SUM, MPI_COMM_SELF));
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_MPI_IN_PLACE" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
int count=2; int blocklens[2]={0,1}; MPI_Aint indices[2]={0,1}; MPI_Datatype old_types[2]={0,1}; MPI_Datatype *newtype = 0;
                                              if (MPI_Type_create_struct(count, blocklens, indices, old_types, newtype));
  return 0;
                    Pushing language C
                    Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm_errhandler_fn * p_err_fun = 0; MPI_Errhandler * p_errhandler = 0; if (MPI_Comm_create_errhandler(p_err_fun,p_errhandler));
  return 0;
                    Pushing language C
                    Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_set_errhandler(MPI_COMM_WORLD,MPI_ERRORS_RETURN));
  return 0;
                    Pushing language C
                    Popping language C
TEST configureTypes from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:234)
TESTING: configureTypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:234)
  Checking for MPI types
Checking for size of type: MPI_Comm
              Defined "SIZEOF_MPI_COMM" to "4"
Checking for size of type: MPI_Fint
              Defined "SIZEOF_MPI_FINT" to "4"
TEST configureMPITypes from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:246)
TESTING: configureMPITypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:246)
  Checking for MPI Datatype handles
Successful compile:
Source:
#ifdef PETSC_HAVE_STDLIB_H
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_LONG_DOUBLE, &size);
if(ierr || (size == 0)) exit(1);
MPI_Finalize();
  return 0;
            Defined "HAVE_MPI_LONG_DOUBLE" to "1"
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_INT64_T, &size);
MPI_Finalize();
  return 0;
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_C_DOUBLE_COMPLEX, &size);
MPI_Finalize();
  return 0;
            Defined "HAVE_MPI_C_DOUBLE_COMPLEX" to "1"
TEST configureMissingPrototypes from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:320)
TESTING: configureMissingPrototypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:320)
  Checks for missing prototypes, which it adds to petscfix.h
TEST SGIMPICheck from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:630)
TESTING: SGIMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:630)
  Returns true if SGI MPI is used
            Checking for functions [MPI_SGI_barrier] in library [] []
              Pushing language C
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.packages.MPI  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char MPI_SGI_barrier();
static void _check_MPI_SGI_barrier() { MPI_SGI_barrier(); }
int main() {
_check_MPI_SGI_barrier();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): undefined reference to `MPI_SGI_barrier'
              Popping language C
          SGI MPI test failure
TEST CxxMPICheck from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:640)
TESTING: CxxMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:640)
  Make sure C++ can compile and link
            Pushing language Cxx
Checking for header mpi.h
Executing: mpixlcxx_r -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.libraries  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+     /tmp/petsc-ITHdGX/config.libraries/conftest.cc
Successful compile:
Source:
#include <mpi.h>
int main() {
  return 0;
Checking for C++ MPI_Finalize()
            Checking for functions [MPI_Finalize] in library [] []
Successful compile:
Source:
#include <mpi.h>
static void _check_MPI_Finalize() { int ierr;
ierr = MPI_Finalize();; }
int main() {
_check_MPI_Finalize();;
  return 0;
                      Pushing language CXX
                      Popping language CXX
Executing: mpixlcxx_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -+ /tmp/petsc-ITHdGX/config.libraries/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
              Popping language Cxx
TEST FortranMPICheck from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:658)
TESTING: FortranMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:658)
  Make sure fortran include [mpif.h] and library symbols are found
            Pushing language FC
Checking for header mpif.h
Executing: mpixlf90_r -qnosave -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/config.libraries  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction    /tmp/petsc-ITHdGX/config.libraries/conftest.F
Possible ERROR while running compiler:
stderr:
** main   === End of Compilation 1 ===
1501-510  Compilation successful for file conftest.F.
Source:
      program main
       include 'mpif.h'
      end
Checking for fortran mpi_init()
            Checking for functions [] in library [] []
              Pushing language FC
stderr:
Source:
      program main
       include 'mpif.h'
       integer ierr
       call mpi_init(ierr)
      end
                      Pushing language FC
                      Popping language FC
Executing: mpixlf90_r -qnosave  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.libraries/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
              Popping language FC
Checking for mpi.mod
              Pushing language FC
stderr:
Source:
      program main
       use mpi
       integer ierr,rank
       call mpi_init(ierr)
       call mpi_comm_rank(MPI_COMM_WORLD,rank,ierr)
      end
                      Pushing language FC
                      Popping language FC
              Popping language FC
            Defined "HAVE_MPI_F90MODULE" to "1"
            Popping language FC
TEST configureIO from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:683)
TESTING: configureIO from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:683)
  Check for the functions in MPI/IO
       - Define HAVE_MPIIO if they are present
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Aint lb, extent;
if (MPI_Type_get_extent(MPI_INT, &lb, &extent));
  return 0;
                    Pushing language C
                    Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
if (MPI_File_write_all(fh, buf, 1, MPI_INT, &status));
  return 0;
                    Pushing language C
                    Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
if (MPI_File_read_all(fh, buf, 1, MPI_INT, &status));
  return 0;
                    Pushing language C
                    Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Offset disp;
MPI_Info info;
if (MPI_File_set_view(fh, disp, MPI_INT, MPI_INT, "", info));
  return 0;
                    Pushing language C
                    Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
if (MPI_File_open(MPI_COMM_SELF, "", 0, info, &fh));
  return 0;
                    Pushing language C
                    Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
if (MPI_File_close(&fh));
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_MPIIO" to "1"
TEST findMPIInc from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:720)
TESTING: findMPIInc from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:720)
  Find MPI include paths from "mpicc -show"
Executing: mpixlc_r -show
stdout: bgxlc_r -I/bgsys/drivers/V1R2M0/ppc64 -I/bgsys/drivers/V1R2M0/ppc64/comm/sys/include -I/bgsys/drivers/V1R2M0/ppc64/spi/include -I/bgsys/drivers/V1R2M0/ppc64/spi/include/kernel/cnk -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -I/bgsys/drivers/V1R2M0/ppc64/comm/xl/include -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lpthread
          compilers: Checking arg bgxlc_r
          compilers: Checking arg -I/bgsys/drivers/V1R2M0/ppc64
          compilers: Found include directory: /bgsys/drivers/V1R2M0/ppc64
          compilers: Checking arg -I/bgsys/drivers/V1R2M0/ppc64/comm/sys/include
          compilers: Found include directory: /bgsys/drivers/V1R2M0/ppc64/comm/sys/include
          compilers: Checking arg -I/bgsys/drivers/V1R2M0/ppc64/spi/include
          compilers: Found include directory: /bgsys/drivers/V1R2M0/ppc64/spi/include
          compilers: Checking arg -I/bgsys/drivers/V1R2M0/ppc64/spi/include/kernel/cnk
          compilers: Found include directory: /bgsys/drivers/V1R2M0/ppc64/spi/include/kernel/cnk
          compilers: Checking arg -L/bgsys/drivers/V1R2M0/ppc64/spi/lib
          compilers: Checking arg -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib
          compilers: Checking arg -I/bgsys/drivers/V1R2M0/ppc64/comm/xl/include
          compilers: Found include directory: /bgsys/drivers/V1R2M0/ppc64/comm/xl/include
          compilers: Checking arg -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib
          compilers: Checking arg -lmpich
          compilers: Checking arg -lopa
          compilers: Checking arg -lmpl
          compilers: Checking arg -lpami
          compilers: Checking arg -lSPI
          compilers: Checking arg -lSPI_cnk
          compilers: Checking arg -lrt
          compilers: Checking arg -lpthread
          compilers: Checking arg -lstdc++
        Checking for functions [MPI_Alltoallw] in library [] []
          Pushing language C
Successful compile:
Source:
char MPI_Alltoallw();
static void _check_MPI_Alltoallw() { MPI_Alltoallw(); }
int main() {
_check_MPI_Alltoallw();;
  return 0;
                  Pushing language C
                  Popping language C
          Popping language C
        Checking for functions [MPI_Type_create_indexed_block] in library [] []
          Pushing language C
Successful compile:
Source:
char MPI_Type_create_indexed_block();
static void _check_MPI_Type_create_indexed_block() { MPI_Type_create_indexed_block(); }
int main() {
_check_MPI_Type_create_indexed_block();;
  return 0;
                  Pushing language C
                  Popping language C
          Popping language C
        Defined "HAVE_MPI_ALLTOALLW" to "1"
        Checking for functions [MPI_Win_create] in library [] []
          Pushing language C
Successful compile:
Source:
char MPI_Win_create();
static void _check_MPI_Win_create() { MPI_Win_create(); }
int main() {
_check_MPI_Win_create();;
  return 0;
                  Pushing language C
                  Popping language C
          Popping language C
        Defined "HAVE_MPI_WIN_CREATE" to "1"
        Defined "HAVE_MPI_REPLACE" to "1"
              Checking for functions [MPI_Comm_spawn MPI_Type_get_envelope MPI_Type_get_extent MPI_Type_dup MPI_Init_thread MPI_Iallreduce MPI_Ibarrier MPI_Finalized MPI_Exscan] in library [] []
                Pushing language C
Successful compile:
Source:
char MPI_Comm_spawn();
static void _check_MPI_Comm_spawn() { MPI_Comm_spawn(); }
char MPI_Type_get_envelope();
static void _check_MPI_Type_get_envelope() { MPI_Type_get_envelope(); }
char MPI_Type_get_extent();
static void _check_MPI_Type_get_extent() { MPI_Type_get_extent(); }
char MPI_Type_dup();
static void _check_MPI_Type_dup() { MPI_Type_dup(); }
char MPI_Init_thread();
static void _check_MPI_Init_thread() { MPI_Init_thread(); }
char MPI_Iallreduce();
static void _check_MPI_Iallreduce() { MPI_Iallreduce(); }
char MPI_Ibarrier();
static void _check_MPI_Ibarrier() { MPI_Ibarrier(); }
char MPI_Finalized();
static void _check_MPI_Finalized() { MPI_Finalized(); }
char MPI_Exscan();
static void _check_MPI_Exscan() { MPI_Exscan(); }
int main() {
_check_MPI_Comm_spawn();
_check_MPI_Type_get_envelope();
_check_MPI_Type_get_extent();
_check_MPI_Type_dup();
_check_MPI_Init_thread();
_check_MPI_Iallreduce();
_check_MPI_Ibarrier();
_check_MPI_Finalized();
_check_MPI_Exscan();;
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0x34): undefined reference to `MPI_Iallreduce'
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0x3c): undefined reference to `MPI_Ibarrier'
                Popping language C
                Checking for functions [MPI_Comm_spawn MPI_Type_get_envelope MPI_Type_get_extent MPI_Type_dup] in library [] []
                  Pushing language C
Successful compile:
Source:
int main() {
_check_MPI_Type_dup();;
  return 0;
                          Pushing language C
                          Popping language C
                  Popping language C
                Checking for functions [MPI_Init_thread MPI_Iallreduce MPI_Ibarrier MPI_Finalized MPI_Exscan] in library [] []
                  Pushing language C
Successful compile:
Source:
char MPI_Exscan();
int main() {
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0x14): undefined reference to `MPI_Iallreduce'
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0x1c): undefined reference to `MPI_Ibarrier'
                  Popping language C
                  Checking for functions [MPI_Init_thread MPI_Iallreduce] in library [] []
                    Pushing language C
Successful compile:
Source:
int main() {
_check_MPI_Iallreduce();;
  return 0;
                            Pushing language C
                            Popping language C
stderr:
                    Popping language C
                    Checking for functions [MPI_Init_thread] in library [] []
                      Pushing language C
Successful compile:
Source:
int main() {
_check_MPI_Init_thread();;
  return 0;
                              Pushing language C
                              Popping language C
                      Popping language C
                    Checking for functions [MPI_Iallreduce] in library [] []
                      Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                              Pushing language C
                              Popping language C
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): undefined reference to `MPI_Iallreduce'
                      Popping language C
                  Checking for functions [MPI_Ibarrier MPI_Finalized MPI_Exscan] in library [] []
                    Pushing language C
Successful compile:
Source:
char MPI_Exscan();
int main() {
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): undefined reference to `MPI_Ibarrier'
                    Popping language C
                    Checking for functions [MPI_Ibarrier] in library [] []
                      Pushing language C
Successful compile:
Source:
int main() {
_check_MPI_Ibarrier();;
  return 0;
                              Pushing language C
                              Popping language C
stderr:
                      Popping language C
                    Checking for functions [MPI_Finalized] in library [] []
                      Pushing language C
Successful compile:
Source:
int main() {
_check_MPI_Finalized();;
  return 0;
                              Pushing language C
                              Popping language C
                      Popping language C
                    Checking for functions [MPI_Exscan] in library [] []
                      Pushing language C
Successful compile:
Source:
char MPI_Exscan();
int main() {
  return 0;
                              Pushing language C
                              Popping language C
                      Popping language C
        Defined "HAVE_MPI_COMM_SPAWN" to "1"
        Defined "HAVE_MPI_TYPE_GET_ENVELOPE" to "1"
        Defined "HAVE_MPI_TYPE_GET_EXTENT" to "1"
        Defined "HAVE_MPI_TYPE_DUP" to "1"
        Defined "HAVE_MPI_INIT_THREAD" to "1"
        Defined "HAVE_MPI_EXSCAN" to "1"
        Checking for functions [MPIX_Iallreduce] in library [] []
          Pushing language C
Successful compile:
Source:
char MPIX_Iallreduce();
static void _check_MPIX_Iallreduce() { MPIX_Iallreduce(); }
int main() {
_check_MPIX_Iallreduce();;
  return 0;
                  Pushing language C
                  Popping language C
          Popping language C
        Defined "HAVE_MPIX_IALLREDUCE" to "1"
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.packages.MPI/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.packages.MPI  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  -I/bgsys/drivers/V1R2M0/ppc64 -I/bgsys/drivers/V1R2M0/ppc64/comm/sys/include -I/bgsys/drivers/V1R2M0/ppc64/spi/include -I/bgsys/drivers/V1R2M0/ppc64/spi/include/kernel/cnk -I/bgsys/drivers/V1R2M0/ppc64/comm/xl/include /tmp/petsc-ITHdGX/config.packages.MPI/conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
int combiner = MPI_COMBINER_DUP;;
  return 0;
        Defined "HAVE_MPI_COMBINER_DUP" to "1"
        Checking for functions [MPIDI_CH3I_sock_set] in library [] []
          Pushing language C
Successful compile:
Source:
char MPIDI_CH3I_sock_set();
static void _check_MPIDI_CH3I_sock_set() { MPIDI_CH3I_sock_set(); }
int main() {
_check_MPIDI_CH3I_sock_set();;
  return 0;
                  Pushing language C
                  Popping language C
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): undefined reference to `MPIDI_CH3I_sock_set'
          Popping language C
        Checking for functions [MPIDI_CH3I_sock_fixed_nbc_progress] in library [] []
          Pushing language C
Successful compile:
Source:
char MPIDI_CH3I_sock_fixed_nbc_progress();
static void _check_MPIDI_CH3I_sock_fixed_nbc_progress() { MPIDI_CH3I_sock_fixed_nbc_progress(); }
int main() {
_check_MPIDI_CH3I_sock_fixed_nbc_progress();;
  return 0;
                  Pushing language C
                  Popping language C
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): undefined reference to `MPIDI_CH3I_sock_fixed_nbc_progress'
          Popping language C
TEST checkSharedLibrary from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:132)
TESTING: checkSharedLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:132)
  Sets flag indicating if MPI libraries are shared or not and
    determines if MPI libraries CANNOT be used by shared libraries
TEST configureMPIEXEC from config.packages.MPI(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/packages/MPI.py:145)
TESTING: configureMPIEXEC from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:145)
  Checking for mpiexec
            Defined make macro "MPIEXEC" to "Not_appropriate_for_batch_systems_You_must_use_your_batch_system_to_submit_MPI_jobs_speak_with_your_local_sys_admin"
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int init(int argc,  char *argv[]) {
  int isInitialized;
  MPI_Init(&argc, &argv);
  MPI_Initialized(&isInitialized);
  return (int) isInitialized;
                      Pushing language C
                      Popping language C
Executing: /usr/bin/ar  cr /tmp/petsc-ITHdGX/config.packages.MPI/libconftest.a  /tmp/petsc-ITHdGX/config.packages.MPI/conftest.o ; /usr/bin/ranlib /tmp/petsc-ITHdGX/config.packages.MPI/libconftest.a
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int checkInit(void) {
  int isInitialized;
  if (isInitialized) MPI_Finalize();
                      Pushing language C
                      Popping language C
Successful compile:
Source:
#include <stdio.h>
#include <stdlib.h>
#ifdef PETSC_HAVE_DLFCN_H
#include <dlfcn.h>
#endif
int main() {
  int   argc    = 1;
  char *argv[2] = {(char *) "conftest", NULL};
  void *lib;
  int (*init)(int, char **);
  int (*checkInit)(void);
  lib = dlopen("/tmp/petsc-ITHdGX/config.libraries/lib1.a", RTLD_LAZY);
  if (!lib) {
    fprintf(stderr, "Could not open lib1.so: %s\n", dlerror());
    exit(1);
  init = (int (*)(int, char **)) dlsym(lib, "init");
  if (!init) {
    fprintf(stderr, "Could not find initialization function\n");
    exit(1);
  if (!(*init)(argc, argv)) {
    fprintf(stderr, "Could not initialize library\n");
    exit(1);
  lib = dlopen("/tmp/petsc-ITHdGX/config.libraries/lib2.a", RTLD_LAZY);
  if (!lib) {
    fprintf(stderr, "Could not open lib2.so: %s\n", dlerror());
    exit(1);
  checkInit = (int (*)(void)) dlsym(lib, "checkInit");
  if (!checkInit) {
    fprintf(stderr, "Could not find initialization check function\n");
    exit(1);
  if (!(*checkInit)()) {
    fprintf(stderr, "Did not link with shared library\n");
    exit(2);
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl  -ldl
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0x30): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
        Library was shared
    Popping language C
TEST alternateConfigureLibrary from config.packages.cgns(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.cgns(config/BuildSystem/config/package.py:537)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.boost(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.boost(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from config.packages.hdf5(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.hdf5(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from config.packages.netcdf(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.netcdf(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from config.packages.netcdf-cxx(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.netcdf-cxx(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from config.packages.MOAB(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.MOAB(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from config.packages.exodusii(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.exodusii(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from config.packages.thrust(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.thrust(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from config.packages.cusp(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.cusp(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from config.packages.scientificpython(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.scientificpython(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from config.packages.fiat(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from config.packages.fiat(config/BuildSystem/config/package.py:537)
TEST configureScalarType from PETSc.utilities.scalarTypes(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/scalarTypes.py:38)
TESTING: configureScalarType from PETSc.utilities.scalarTypes(config/PETSc/utilities/scalarTypes.py:38)
  Choose between real and complex numbers
        Defined "USE_SCALAR_REAL" to "1"
      Scalar type is real
        Pushing language C
                    All intermediate test results are stored in /tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/config.packages.MPI -I/tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes/conftest.c
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnormal(b);
  return 0;
                Pushing language C
                Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes/conftest.o -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
        Defined "HAVE_ISNORMAL" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnan(b);
  return 0;
                Pushing language C
                Popping language C
        Defined "HAVE_ISNAN" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isinf(b);
  return 0;
                Pushing language C
                Popping language C
        Defined "HAVE_ISINF" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0;int a = _isnan(b);
  return 0;
                Pushing language C
                Popping language C
stderr:
/tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes/conftest.o:(.text+0x1c): undefined reference to `_isnan'
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0;int a = _finite(b);
  return 0;
                Pushing language C
                Popping language C
stderr:
/tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes/conftest.o:(.text+0x1c): undefined reference to `_finite'
        Popping language C
TEST configurePrecision from PETSc.utilities.scalarTypes(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/scalarTypes.py:78)
TESTING: configurePrecision from PETSc.utilities.scalarTypes(config/PETSc/utilities/scalarTypes.py:78)
  Set the default real number precision for PETSc objects
        Defined "USE_REAL_DOUBLE" to "1"
      Precision is double
TEST configureLibraryOptions from PETSc.utilities.libraryOptions(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/libraryOptions.py:48)
TESTING: configureLibraryOptions from PETSc.utilities.libraryOptions(config/PETSc/utilities/libraryOptions.py:48)
  Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE and PETSC_USE_FORTRAN_KERNELS
        Defined "USE_LOG" to "1"
        Defined "USE_INFO" to "1"
        Defined "USE_CTABLE" to "1"
        **********Checking if running on BGL/IBM detected
          Checking for functions [bgl_perfctr_void] in library [''] []
            Pushing language C
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.packages.MPI -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.libraries/conftest.c
Successful compile:
Source:
char bgl_perfctr_void();
static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
int main() {
_check_bgl_perfctr_void();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): undefined reference to `bgl_perfctr_void'
            Popping language C
          Checking for functions [ADIOI_BGL_Open] in library [''] []
            Pushing language C
Successful compile:
Source:
char ADIOI_BGL_Open();
static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
int main() {
_check_ADIOI_BGL_Open();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-ITHdGX/config.libraries/conftest.o:(.text+0xc): undefined reference to `ADIOI_BGL_Open'
            Popping language C
        *********BGL/IBM test failure
        Defined "USE_BACKWARD_LOOP" to "1"
        Defined "USE_FORTRAN_KERNELS" to "1"
        Defined "AssertAlignx(a,b)" to "  "
        Defined "Alignx(a,b)" to "  "
        Defined "USE_64BIT_INDICES" to "1"
        Checking for functions [__floatdidf] in library ['-lgcc_s.1'] []
          Pushing language C
Successful compile:
Source:
char __floatdidf();
static void _check___floatdidf() { __floatdidf(); }
int main() {
_check___floatdidf();;
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  -lgcc_s.1 -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
stderr:
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: cannot find -lgcc_s.1
          Popping language C
TEST configureISColorValueType from PETSc.utilities.libraryOptions(/gpfs/mira-home/adams/petsc/config/PETSc/utilities/libraryOptions.py:92)
TESTING: configureISColorValueType from PETSc.utilities.libraryOptions(config/PETSc/utilities/libraryOptions.py:92)
  Sets PETSC_IS_COLOR_VALUE_TYPE, MPIU_COLORING_VALUE, IS_COLORING_MAX required by ISColor
        Defined "MPIU_COLORING_VALUE" to "MPI_UNSIGNED_SHORT"
        Defined "IS_COLORING_MAX" to "65535"
        Defined "IS_COLOR_VALUE_TYPE" to "short"
TEST alternateConfigureLibrary from PETSc.packages.yaml(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.yaml(config/BuildSystem/config/package.py:537)
    Pushing language C
TEST configureLibrary from PETSc.packages.valgrind(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:479)
TESTING: configureLibrary from PETSc.packages.valgrind(config/BuildSystem/config/package.py:479)
  Find an installation and check if it can work with PETSc
      Checking for a functional valgrind
      Not checking for library in Package specific search directory VALGRIND: [] because no functions given to check for
TEST check from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:145)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:145)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
          No functions to check for in library [] []
      Checking for headers Package specific search directory VALGRIND: []
          Pushing language C
TEST checkInclude from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['valgrind/valgrind.h'] in []
            Checking include with compiler flags var CPPFLAGS []
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/config.headers   /tmp/petsc-ITHdGX/config.headers/conftest.c
Possible ERROR while running preprocessor: exit code 256
stderr:
"/tmp/petsc-ITHdGX/config.headers/conftest.c", line 3.10: 1506-296 (S) #include file <valgrind/valgrind.h> not found.
Source:
#include <valgrind/valgrind.h>
          Popping language C
          Pushing language C
stderr:
Source:
          Popping language C
      Checking for headers Package specific search directory VALGRIND: ['/usr/local/include']
          Pushing language C
Checking for header files ['valgrind/valgrind.h'] in ['/usr/local/include']
            Checking include with compiler flags var CPPFLAGS ['/usr/local/include']
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/config.headers  -I/usr/local/include /tmp/petsc-ITHdGX/config.headers/conftest.c
stderr:
Source:
          Popping language C
          Pushing language C
stderr:
Source:
          Popping language C
      Directory does not exist: /opt/local (while checking "Package specific search directory VALGRIND" for "[]")
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
          It appears you do not have valgrind installed on your system.
          We HIGHLY recommend you install it from www.valgrind.org
          Or install valgrind-devel or equivalent using your package manager.
          Then rerun ./configure
    Popping language C
TEST alternateConfigureLibrary from PETSc.packages.threadcomm(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.threadcomm(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.tetgen(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.tetgen(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.sprng(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.sprng(config/BuildSystem/config/package.py:537)
  PETSc clone, checking for Sowing or if it is needed
Checking for program /usr/lib64/qt-3.3/bin/bfort...not found
Checking for program /home/adams/bin/bfort...not found
Checking for program /soft/environment/softenv-1.6.2/bin/bfort...not found
Checking for program /bin/bfort...not found
Checking for program /usr/bin/bfort...not found
Checking for program /usr/local/bin/bfort...not found
Checking for program /usr/X11R6/bin/bfort...not found
Checking for program /sbin/bfort...not found
Checking for program /usr/sbin/bfort...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/bfort...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/bfort...not found
Checking for program /soft/debuggers/scripts/bin/bfort...not found
Checking for program /soft/cobalt/bin/bfort...not found
Checking for program /soft/accttools/bin/bfort...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/bfort...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/bfort...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/bfort...not found
Checking for program /soft/debuggers/ddt/bin/bfort...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/bfort...not found
Checking for program /soft/buildtools/cmake/current/bin/bfort...not found
Checking for program /soft/perftools/darshan/darshan/bin/bfort...not found
Checking for program /soft/compilers/wrappers/xl/bfort...not found
Checking for program /dbhome/db2cat/sqllib/bin/bfort...not found
Checking for program /dbhome/db2cat/sqllib/adm/bfort...not found
Checking for program /dbhome/db2cat/sqllib/misc/bfort...not found
Checking for program /usr/lpp/mmfs/bin/bfort...not found
Checking for program /opt/ibutils/bin/bfort...not found
Checking for program /home/adams/bfort...not found
Checking for program /home/adams/petsc/bin/win32fe/bfort...not found
Checking for program /usr/lib64/qt-3.3/bin/doctext...not found
Checking for program /home/adams/bin/doctext...not found
Checking for program /soft/environment/softenv-1.6.2/bin/doctext...not found
Checking for program /bin/doctext...not found
Checking for program /usr/bin/doctext...not found
Checking for program /usr/local/bin/doctext...not found
Checking for program /usr/X11R6/bin/doctext...not found
Checking for program /sbin/doctext...not found
Checking for program /usr/sbin/doctext...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/doctext...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/doctext...not found
Checking for program /soft/debuggers/scripts/bin/doctext...not found
Checking for program /soft/cobalt/bin/doctext...not found
Checking for program /soft/accttools/bin/doctext...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/doctext...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/doctext...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/doctext...not found
Checking for program /soft/debuggers/ddt/bin/doctext...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/doctext...not found
Checking for program /soft/buildtools/cmake/current/bin/doctext...not found
Checking for program /soft/perftools/darshan/darshan/bin/doctext...not found
Checking for program /soft/compilers/wrappers/xl/doctext...not found
Checking for program /dbhome/db2cat/sqllib/bin/doctext...not found
Checking for program /dbhome/db2cat/sqllib/adm/doctext...not found
Checking for program /dbhome/db2cat/sqllib/misc/doctext...not found
Checking for program /usr/lpp/mmfs/bin/doctext...not found
Checking for program /opt/ibutils/bin/doctext...not found
Checking for program /home/adams/doctext...not found
Checking for program /home/adams/petsc/bin/win32fe/doctext...not found
Checking for program /usr/lib64/qt-3.3/bin/mapnames...not found
Checking for program /home/adams/bin/mapnames...not found
Checking for program /soft/environment/softenv-1.6.2/bin/mapnames...not found
Checking for program /bin/mapnames...not found
Checking for program /usr/bin/mapnames...not found
Checking for program /usr/local/bin/mapnames...not found
Checking for program /usr/X11R6/bin/mapnames...not found
Checking for program /sbin/mapnames...not found
Checking for program /usr/sbin/mapnames...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/mapnames...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/mapnames...not found
Checking for program /soft/debuggers/scripts/bin/mapnames...not found
Checking for program /soft/cobalt/bin/mapnames...not found
Checking for program /soft/accttools/bin/mapnames...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/mapnames...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/mapnames...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/mapnames...not found
Checking for program /soft/debuggers/ddt/bin/mapnames...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/mapnames...not found
Checking for program /soft/buildtools/cmake/current/bin/mapnames...not found
Checking for program /soft/perftools/darshan/darshan/bin/mapnames...not found
Checking for program /soft/compilers/wrappers/xl/mapnames...not found
Checking for program /dbhome/db2cat/sqllib/bin/mapnames...not found
Checking for program /dbhome/db2cat/sqllib/adm/mapnames...not found
Checking for program /dbhome/db2cat/sqllib/misc/mapnames...not found
Checking for program /usr/lpp/mmfs/bin/mapnames...not found
Checking for program /opt/ibutils/bin/mapnames...not found
Checking for program /home/adams/mapnames...not found
Checking for program /home/adams/petsc/bin/win32fe/mapnames...not found
Checking for program /usr/lib64/qt-3.3/bin/bib2html...not found
Checking for program /home/adams/bin/bib2html...not found
Checking for program /soft/environment/softenv-1.6.2/bin/bib2html...not found
Checking for program /bin/bib2html...not found
Checking for program /usr/bin/bib2html...not found
Checking for program /usr/local/bin/bib2html...not found
Checking for program /usr/X11R6/bin/bib2html...not found
Checking for program /sbin/bib2html...not found
Checking for program /usr/sbin/bib2html...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/bib2html...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/bib2html...not found
Checking for program /soft/debuggers/scripts/bin/bib2html...not found
Checking for program /soft/cobalt/bin/bib2html...not found
Checking for program /soft/accttools/bin/bib2html...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/bib2html...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/bib2html...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/bib2html...not found
Checking for program /soft/debuggers/ddt/bin/bib2html...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/bib2html...not found
Checking for program /soft/buildtools/cmake/current/bin/bib2html...not found
Checking for program /soft/perftools/darshan/darshan/bin/bib2html...not found
Checking for program /soft/compilers/wrappers/xl/bib2html...not found
Checking for program /dbhome/db2cat/sqllib/bin/bib2html...not found
Checking for program /dbhome/db2cat/sqllib/adm/bib2html...not found
Checking for program /dbhome/db2cat/sqllib/misc/bib2html...not found
Checking for program /usr/lpp/mmfs/bin/bib2html...not found
Checking for program /opt/ibutils/bin/bib2html...not found
Checking for program /home/adams/bib2html...not found
Checking for program /home/adams/petsc/bin/win32fe/bib2html...not found
Checking for program /usr/lib64/qt-3.3/bin/pdflatex...not found
Checking for program /home/adams/bin/pdflatex...not found
Checking for program /soft/environment/softenv-1.6.2/bin/pdflatex...not found
Checking for program /bin/pdflatex...not found
Checking for program /usr/bin/pdflatex...not found
Checking for program /usr/local/bin/pdflatex...not found
Checking for program /usr/X11R6/bin/pdflatex...not found
Checking for program /sbin/pdflatex...not found
Checking for program /usr/sbin/pdflatex...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/pdflatex...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/pdflatex...not found
Checking for program /soft/debuggers/scripts/bin/pdflatex...not found
Checking for program /soft/cobalt/bin/pdflatex...not found
Checking for program /soft/accttools/bin/pdflatex...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/pdflatex...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/pdflatex...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/pdflatex...not found
Checking for program /soft/debuggers/ddt/bin/pdflatex...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/pdflatex...not found
Checking for program /soft/buildtools/cmake/current/bin/pdflatex...not found
Checking for program /soft/perftools/darshan/darshan/bin/pdflatex...not found
Checking for program /soft/compilers/wrappers/xl/pdflatex...not found
Checking for program /dbhome/db2cat/sqllib/bin/pdflatex...not found
Checking for program /dbhome/db2cat/sqllib/adm/pdflatex...not found
Checking for program /dbhome/db2cat/sqllib/misc/pdflatex...not found
Checking for program /usr/lpp/mmfs/bin/pdflatex...not found
Checking for program /opt/ibutils/bin/pdflatex...not found
Checking for program /home/adams/pdflatex...not found
Checking for program /home/adams/petsc/bin/win32fe/pdflatex...not found
  Bfort not found. Installing sowing for FortranStubs
      Pushing language C
TEST configureLibrary from PETSc.packages.sowing(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:479)
TESTING: configureLibrary from PETSc.packages.sowing(config/BuildSystem/config/package.py:479)
        Checking for a functional sowing
                Looking for SOWING in directory starting with sowing
                Could not locate an existing copy of sowing:
                  Downloading sowing
                    Downloading http://ftp.mcs.anl.gov/pub/petsc/externalpackages/sowing-1.1.16e.tar.gz to /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_sowing-1.1.16e.tar.gz
                    Extracting /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_sowing-1.1.16e.tar.gz
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages; chmod -R a+r sowing-1.1.16e;find  sowing-1.1.16e -type d -name "*" -exec chmod a+rx {} \;
                    Found a copy of SOWING in sowing-1.1.16e
Have to rebuild sowing, /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/sowing != /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/sowing
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e && ./configure --prefix=/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64
stdout:
checking for ranlib... ranlib
checking for a BSD-compatible install... /usr/bin/install -c
checking whether install works... yes
checking for ar... ar
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking for virtual path format... VPATH
checking for latex... no
checking for gs... /usr/bin/gs
checking for pnmcrop... no
checking for pbmtoxbm... no
checking for ppmtogif... no
checking for pnmquant... no
checking for perl... /usr/bin/perl
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking pwd.h usability... yes
checking pwd.h presence... yes
checking for pwd.h... yes
checking for stdlib.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking for string.h... (cached) yes
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for uid_t in sys/types.h... yes
checking for size_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for vprintf... yes
checking for _doprnt... no
checking for getcwd... yes
checking for gethostname... yes
checking for getwd... yes
checking for mkdir... yes
checking that mkdir accepts -p... yes
checking for uname... yes
checking for gethostbyname... yes
checking how to run the C++ preprocessor... c++ -E
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for realpath... yes
checking for readlink... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating Makerules
config.status: creating src/Makefile
config.status: creating src/sys/Makefile
config.status: creating src/tohtml/Makefile
config.status: creating src/tohtml/tohtmlpath.h
config.status: creating src/tohtml/testing/Makefile
config.status: creating bin/pstoxbm
config.status: creating bin/pstogif
config.status: creating bin/bib2html
config.status: creating src/bfort/Makefile
config.status: creating src/bfort/testing/Makefile
config.status: creating src/textfilt/Makefile
config.status: creating src/doctext/Makefile
config.status: creating src/doctext/docpath.h
config.status: creating src/doctext/test/Makefile
config.status: creating src/mapnames/Makefile
config.status: creating src/bib2html/Makefile
config.status: creating docs/Makefile
config.status: creating docs/doctext/Makefile
config.status: creating include/patchlevel.h
config.status: creating include/textfilt/textpath.h
config.status: creating include/sowingconfig.h
config.status: executing default commands
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e && make &&  make install && make clean
stdout:
(cd src/sys && make )
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/sys'
gcc  -I../../include -I../../include    -c arch.c
gcc  -I../../include -I../../include    -c txt.c
gcc  -I../../include -I../../include    -c daytime.c
gcc  -I../../include -I../../include    -c file.c
gcc  -I../../include -I../../include    -c tr.c
gcc  -I../../include -I../../include    -c getopts.c
ar cr ../../lib/libsowing.a arch.o txt.o daytime.o file.o tr.o getopts.o
ranlib ../../lib/libsowing.a
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/sys'
(cd src/tohtml && make )
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/tohtml'
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c tohtml.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c tex2html.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c search.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c texactio.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c rdaux.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c rdindx.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c label.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c scan.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c refmap.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c style.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c dimen.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c userdef.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c tabular.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c biblio.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c environ.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c math.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c rddefs.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c latexinfo.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c accent.c
gcc -DPSPATH='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/"' -DBMSOURCE='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/"' -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I. -I../../include    -c simpleif.c
gcc   -o tohtml tohtml.o tex2html.o search.o texactio.o rdaux.o rdindx.o label.o scan.o refmap.o style.o dimen.o userdef.o tabular.o biblio.o environ.o math.o rddefs.o latexinfo.o accent.o simpleif.o ../../lib/libsowing.a
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/tohtml'
(cd src/bfort && make )
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/bfort'
gcc -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I../../include    -c bfort.c
gcc -DBASEDEF='"/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt"' -I../../include -I../../include    -c doc.c
gcc   -o bfort bfort.o doc.o ../../lib/libsowing.a
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/bfort'
(cd src/textfilt && make )
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/textfilt'
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c cmdline.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c file.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c instream.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c outstream.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c search.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c maptok.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c textout.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c texthtml.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c textnroff.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c texttex.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c inutil.cc
c++  -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt    -c errhand.cc
ar cr ../../lib/libtfilter.a cmdline.o file.o instream.o outstream.o search.o maptok.o textout.o texthtml.o textnroff.o texttex.o inutil.o errhand.o
ranlib ../../lib/libtfilter.a
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/textfilt'
(cd src/doctext && make )
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/doctext'
c++  -I../../include/textfilt -I../../include -I. -I../../include    -c doctext.cc
c++  -I../../include/textfilt -I../../include -I. -I../../include    -c docutil.cc
c++  -I../../include/textfilt -I../../include -I. -I../../include    -c keyword.cc
c++  -I../../include/textfilt -I../../include -I. -I../../include    -c dotfmat.cc
c++  -I../../include/textfilt -I../../include -I. -I../../include    -c incfiles.cc
c++  -I../../include/textfilt -I../../include -I. -I../../include    -c quotefmt.cc
c++  -I../../include/textfilt -I../../include -I. -I../../include    -c textb.cc
c++  -I../../include/textfilt -I../../include -I. -I../../include    -c docfields.cc
c++   -o doctext doctext.o docutil.o keyword.o dotfmat.o \
	incfiles.o quotefmt.o textb.o docfields.o ../../lib/libtfilter.a
c++  -I../../include/textfilt -I../../include -I. -I../../include    -c doc2lt.cc
c++   -o doc2lt doc2lt.o docutil.o docfields.o ../../lib/libtfilter.a
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/doctext'
make[1]: Nothing to be done for `ALL'.
(cd src/mapnames && make )
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/mapnames'
c++  -I../../include/textfilt -I../../include    -c mapnames.cc
c++   -o mapnames mapnames.o ../../lib/libtfilter.a
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/mapnames'
/usr/bin/install -c bin/bib2html /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/bib2html
/usr/bin/install -c src/doctext/doctext /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/doctext
/usr/bin/install -c src/doctext/doc2lt /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/doc2lt
/usr/bin/install -c src/tohtml/tohtml  /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/tohtml
if [ "`cd bin && pwd`" != "`cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin && pwd`" ] ; then \
	    /usr/bin/install -c bin/pstoxbm /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/pstoxbm ; \
	    /usr/bin/install -c bin/pstogif /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/pstogif ; \
	fi
/usr/bin/install -c src/bfort/bfort /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/bfort
/usr/bin/install -c src/mapnames/mapnames /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/mapnames
if [ "`cd ./share && pwd`" != "`cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share && pwd`" ] ; then \
	    /usr/bin/install -c -m 644    ./share/pstoppm.ps /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/pstoppm.ps ;\
	    /usr/bin/install -c -m 644    ./share/basedefs.txt /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/basedefs.txt ;\
	    /usr/bin/install -c -m 644    ./share/blueball.gif /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/blueball.gif ;\
	    /usr/bin/install -c -m 644    ./share/greenball.gif /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/greenball.gif ;\
	    /usr/bin/install -c -m 644    ./share/purpleball.gif /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/purpleball.gif ;\
	    /usr/bin/install -c -m 644    ./share/redball.gif /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/redball.gif ;\
	    /usr/bin/install -c -m 644    ./share/yellowball.gif /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/yellowball.gif ;\
	    /usr/bin/install -c -m 644    ./share/next.xbm /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/next.xbm ;\
	    /usr/bin/install -c -m 644    ./share/up.xbm /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/up.xbm ;\
	    /usr/bin/install -c -m 644    ./share/previous.xbm /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/previous.xbm ;\
	    /usr/bin/install -c -m 644    ./share/next.gif /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/next.gif ;\
	    /usr/bin/install -c -m 644    ./share/up.gif /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/up.gif ;\
	    /usr/bin/install -c -m 644    ./share/previous.gif /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/previous.gif ;\
	    /usr/bin/install -c -m 644    ./share/html.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/html.def ;\
	    /usr/bin/install -c -m 644    ./share/latex.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/latex.def ;\
	    /usr/bin/install -c -m 644    ./share/nroff.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/nroff.def ;\
	    /usr/bin/install -c -m 644    ./share/refman.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/refman.def ;\
	    /usr/bin/install -c -m 644    ./share/refman.sty /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/refman.sty ;\
	    /usr/bin/install -c -m 644    ./share/doctext/html.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/doctext/html.def ;\
	    /usr/bin/install -c -m 644    ./share/doctext/htmlcolor.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/doctext/htmlcolor.def ;\
	    /usr/bin/install -c -m 644    ./share/doctext/htmltabl.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/doctext/htmltabl.def ;\
	    /usr/bin/install -c -m 644    ./share/doctext/htmlargtbl.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/doctext/htmlargtbl.def ;\
	    /usr/bin/install -c -m 644    ./share/doctext/latex.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/doctext/latex.def ;\
	    /usr/bin/install -c -m 644    ./share/doctext/latexargtbl.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/doctext/latexargtbl.def ;\
	    /usr/bin/install -c -m 644    ./share/doctext/nroff.def /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/doctext/nroff.def ;\
	fi
if [ "`cd ./man/man1 && pwd`" != "`cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/man/man1 && pwd`" ] ; then \
	    /usr/bin/install -c -m 644    ./man/man1/tohtml.1 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/man/man1/tohtml.1 ;\
	    /usr/bin/install -c -m 644    ./man/man1/doctext.1 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/man/man1/doctext.1 ;\
	    /usr/bin/install -c -m 644    ./man/man1/bfort.1 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/man/man1/bfort.1 ;\
	fi
for dir in src docs ; do ( cd $dir && make clean ) ; done
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src'
for dir in sys bfort tohtml doctext textfilt mapnames bib2html ; do ( cd $dir ; make clean ) ; done
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/sys'
rm -f *.o *~
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/sys'
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/bfort'
/bin/rm -f *.o *~ bfort
/bin/rm -f bfort\ win32/debug/*
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/bfort'
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/tohtml'
/bin/rm -f *.o *~ tohtml tortf
/bin/rm -f tohtml\ win32/debug/*
(cd testing && make clean )
make[3]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/tohtml/testing'
/bin/rm -rf test[1-9] test1[0-9] test2[0-9]
/bin/rm -f test[1-9].html latex.err up.xbm down.xbm. next.xbm
/bin/rm -f test1[0-9].html test2[0-9].html
/bin/rm -f test[0-9].htm test[1-2][0-9].htm
/bin/rm -f previous.xbm *.hux img*.xbm
/bin/rm -f inplace subfiles
/bin/rm -f *.ler *.aux *.out
make[3]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/tohtml/testing'
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/tohtml'
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/doctext'
/bin/rm -f *.o *~ doctext doc2lt
(cd test ; if [ -s Makefile ] ; then make clean ; fi )
make[3]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/doctext/test'
/bin/rm -f *.o *~ *.3 *.2 *.html *.tex f1.cit
make[3]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/doctext/test'
/bin/rm -f doctext\ win32/debug/*
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/doctext'
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/textfilt'
/bin/rm -f *.o *~
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/textfilt'
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/mapnames'
/bin/rm -f *.o *~ mapnames ccc
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/mapnames'
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/bib2html'
rm -f tout.htm tout-bib.htm
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src/bib2html'
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/src'
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/docs'
rm -f bfort.ps tohtml.ps install.ps doctext.ps \
	      bfort.pdf tohtml.pdf install.pdf doctext.pdf \
		*.aux *.dvi *.toc *.log *.fn *.hux *.err *.blg *.bbl
(cd doctext&& make clean)
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/docs/doctext'
rm -f *.fn *.aux *.blg *.toc *.lof *.lot *.dvi *.fns *.bbl *.log \
		*.err *.hux doctext.ps doctext.pdf
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/docs/doctext'
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/docs'
/bin/rm -f lib/libsowing.a lib/libtfilter.a
Executing: cp -f /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/sowing-1.1.16e/sowing /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/sowing
                  Defined make macro "BFORT " to "/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/bfort"
                  Defined make macro "DOCTEXT " to "/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/doctext"
                  Defined make macro "MAPNAMES " to "/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/mapnames"
                  Defined make macro "BIB2HTML " to "/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/bib2html"
        Not checking for library in Download SOWING: [] because no functions given to check for
        Checking for headers Download SOWING: ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
TEST checkSharedLibrary from PETSc.packages.sowing(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:533)
TESTING: checkSharedLibrary from PETSc.packages.sowing(config/BuildSystem/config/package.py:533)
  By default we don't care about checking if the library is shared
      Popping language C
           Running /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/bfort to generate fortran stubs
TEST alternateConfigureLibrary from PETSc.packages.saws(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.saws(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.pcbddc(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.pcbddc(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.papi(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.papi(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.pami(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.pami(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.opencl(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.opencl(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.viennacl(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.viennacl(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.mpe(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.mpe(config/BuildSystem/config/package.py:537)
  Disabled Lgrind
TEST alternateConfigureLibrary from PETSc.packages.java(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.java(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.hwloc(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.hwloc(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.opengl(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.opengl(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.glut(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.glut(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.fftw(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.fftw(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.cuda(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.cuda(config/BuildSystem/config/package.py:537)
    Pushing language C
TEST configureLibrary from PETSc.packages.pthread(/gpfs/mira-home/adams/petsc/config/PETSc/packages/pthread.py:27)
TESTING: configureLibrary from PETSc.packages.pthread(config/PETSc/packages/pthread.py:27)
   Checks for pthread_barrier_t, cpu_set_t, and sys/sysctl.h
        Checking for a functional pthread
        Checking for library in Package specific search directory PTHREAD: ['libpthread.a']
            Checking for functions [pthread_create] in library ['libpthread.a'] []
              Pushing language C
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char pthread_create();
static void _check_pthread_create() { pthread_create(); }
int main() {
_check_pthread_create();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  -lpthread -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
              Defined "HAVE_LIBPTHREAD" to "1"
              Popping language C
        Checking for headers Package specific search directory PTHREAD: []
            Pushing language C
Checking for header files ['pthread.h'] in []
stdout:
#line 31 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
#line 37
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
#line 53
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 134
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
#line 158
typedef int __clockid_t;
#line 161
typedef void * __timer_t;
#line 164
typedef long int __blksize_t;
#line 169
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
#line 173
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
#line 177
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
#line 184
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
#line 189
typedef long int __intptr_t;
#line 192
typedef unsigned int __socklen_t;
#line 211 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/include/stddef.h"
typedef unsigned long size_t;
#line 76 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
typedef __time_t time_t;
#line 120
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
#line 37 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sched.h"
typedef __pid_t pid_t;
#line 74 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/sched.h"
struct sched_param
    int __sched_priority;
#line 83
extern int clone (int (*__fn) (void *__arg), void *__child_stack,
		  int __flags, void *__arg, ...) ;
#line 87
extern int unshare (int __flags) ;
#line 90
extern int sched_getcpu (void) ;
#line 101
struct __sched_param
#line 116
typedef unsigned long int __cpu_mask;
#line 123
typedef struct
  __cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
#line 201
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
extern cpu_set_t *__sched_cpualloc (size_t __count)  ;
extern void __sched_cpufree (cpu_set_t *__set) ;
#line 51 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sched.h"
extern int sched_setparam (__pid_t __pid, const struct sched_param *__param)
#line 55
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) ;
#line 58
extern int sched_setscheduler (__pid_t __pid, int __policy,
			       const struct sched_param *__param) ;
#line 62
extern int sched_getscheduler (__pid_t __pid) ;
#line 65
extern int sched_yield (void) ;
#line 68
extern int sched_get_priority_max (int __algorithm) ;
#line 71
extern int sched_get_priority_min (int __algorithm) ;
#line 74
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) ;
#line 60 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
typedef __clock_t clock_t;
#line 92
typedef __clockid_t clockid_t;
#line 104
typedef __timer_t timer_t;
#line 133
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
#line 146
  long int tm_gmtoff;
  const char *tm_zone;
#line 152
#line 161
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
#line 168
struct sigevent;
#line 183
extern clock_t clock (void) ;
#line 186
extern time_t time (time_t *__timer) ;
#line 189
extern double difftime (time_t __time1, time_t __time0)
      __attribute__ ((const));
#line 193
extern time_t mktime (struct tm *__tp) ;
#line 199
extern size_t strftime (char *__restrict __s, size_t __maxsize,
			const char *__restrict __format,
			const struct tm *__restrict __tp) ;
#line 28 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/xlocale.h"
typedef struct __locale_struct
  struct __locale_data *__locales[13];
#line 34
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
#line 39
  const char *__names[13];
} *__locale_t;
#line 43
typedef __locale_t locale_t;
#line 217 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/time.h"
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
			  const struct tm *__restrict __tp,
			  __locale_t __loc) ;
#line 233
extern struct tm *gmtime (const time_t *__timer) ;
#line 237
extern struct tm *localtime (const time_t *__timer) ;
#line 243
extern struct tm *gmtime_r (const time_t *__restrict __timer,
#line 248
extern struct tm *localtime_r (const time_t *__restrict __timer,
#line 255
extern char *asctime (const struct tm *__tp) ;
#line 258
extern char *ctime (const time_t *__timer) ;
#line 266
extern char *asctime_r (const struct tm *__restrict __tp,
			char *__restrict __buf) ;
#line 270
extern char *ctime_r (const time_t *__restrict __timer,
#line 276
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
#line 283
extern char *tzname[2];
#line 287
extern void tzset (void) ;
#line 291
extern int daylight;
extern long int timezone;
#line 298
extern int stime (const time_t *__when) ;
#line 313
extern time_t timegm (struct tm *__tp) ;
#line 316
extern time_t timelocal (struct tm *__tp) ;
#line 319
extern int dysize (int __year)   __attribute__ ((const));
#line 328
extern int nanosleep (const struct timespec *__requested_time,
		      struct timespec *__remaining);
#line 333
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) ;
#line 336
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) ;
#line 339
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
#line 347
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
			    const struct timespec *__req,
			    struct timespec *__rem);
#line 352
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) ;
#line 357
extern int timer_create (clockid_t __clock_id,
			 struct sigevent *__restrict __evp,
			 timer_t *__restrict __timerid) ;
#line 362
extern int timer_delete (timer_t __timerid) ;
#line 365
extern int timer_settime (timer_t __timerid, int __flags,
			  const struct itimerspec *__restrict __value,
			  struct itimerspec *__restrict __ovalue) ;
#line 370
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
#line 374
extern int timer_getoverrun (timer_t __timerid) ;
#line 51 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
#line 54
typedef union
  char __size[56];
  long int __align__workaround;
} pthread_attr_t;
#line 62
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 77
typedef union
  struct __pthread_mutex_s
    volatile int __lock;
    volatile unsigned int __count;
    volatile int __owner;
    unsigned int __nusers;
#line 89
    int __kind;
    int __spins;
    __pthread_list_t __list;
#line 102
  } __data;
  char __size[40];
} pthread_mutex_t;
typedef union
  char __size[4];
} pthread_mutexattr_t;
#line 116
typedef union
  struct
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align__workaround;
} pthread_cond_t;
typedef union
  char __size[4];
} pthread_condattr_t;
#line 141
typedef unsigned int pthread_key_t;
#line 145
typedef int pthread_once_t;
#line 151
typedef union
  struct
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
#line 168
    unsigned int __flags;
  } __data;
#line 188
  char __size[56];
} pthread_rwlock_t;
typedef union
  char __size[8];
} pthread_rwlockattr_t;
#line 202
typedef volatile int pthread_spinlock_t;
#line 207
typedef union
  char __size[32];
} pthread_barrier_t;
typedef union
  char __size[4];
} pthread_barrierattr_t;
#line 44 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/bits/setjmp.h"
typedef long int __jmp_buf[64] __attribute__ ((__aligned__ (16)));
#line 34 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/pthread.h"
enum
  PTHREAD_CREATE_JOINABLE,
  PTHREAD_CREATE_DETACHED
#line 44
enum
  PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_ADAPTIVE_NP
  PTHREAD_MUTEX_NORMAL = PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE = PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK = PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_DEFAULT = PTHREAD_MUTEX_NORMAL
#line 61
#line 66
enum
  PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_STALLED_NP = PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_ROBUST,
  PTHREAD_MUTEX_ROBUST_NP = PTHREAD_MUTEX_ROBUST
#line 115
enum
  PTHREAD_RWLOCK_PREFER_READER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
  PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
#line 147
enum
  PTHREAD_INHERIT_SCHED,
  PTHREAD_EXPLICIT_SCHED
#line 157
enum
  PTHREAD_SCOPE_SYSTEM,
  PTHREAD_SCOPE_PROCESS
#line 167
enum
  PTHREAD_PROCESS_PRIVATE,
  PTHREAD_PROCESS_SHARED
#line 182
struct _pthread_cleanup_buffer
  void (*__routine) (void *);
  void *__arg;
  int __canceltype;
  struct _pthread_cleanup_buffer *__prev;
#line 191
enum
  PTHREAD_CANCEL_ENABLE,
  PTHREAD_CANCEL_DISABLE
enum
  PTHREAD_CANCEL_DEFERRED,
  PTHREAD_CANCEL_ASYNCHRONOUS
#line 225
extern int pthread_create (pthread_t *__restrict __newthread,
			   const pthread_attr_t *__restrict __attr,
			   void *(*__start_routine) (void *),
			   void *__restrict __arg)  ;
#line 234
extern void pthread_exit (void *__retval) __attribute__ ((__noreturn__));
#line 242
extern int pthread_join (pthread_t __th, void **__thread_return);
#line 263
extern int pthread_detach (pthread_t __th) ;
#line 267
extern pthread_t pthread_self (void)  __attribute__ ((const));
#line 270
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2) ;
#line 278
extern int pthread_attr_init (pthread_attr_t *__attr)  ;
#line 281
extern int pthread_attr_destroy (pthread_attr_t *__attr)
#line 285
extern int pthread_attr_getdetachstate (const pthread_attr_t *__attr,
					int *__detachstate)
#line 290
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
					int __detachstate)
#line 296
extern int pthread_attr_getguardsize (const pthread_attr_t *__attr,
				      size_t *__guardsize)
#line 301
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
				      size_t __guardsize)
#line 307
extern int pthread_attr_getschedparam (const pthread_attr_t *__restrict
				       __attr,
				       struct sched_param *__restrict __param)
#line 313
extern int pthread_attr_setschedparam (pthread_attr_t *__restrict __attr,
				       const struct sched_param *__restrict
				       __param)  ;
#line 318
extern int pthread_attr_getschedpolicy (const pthread_attr_t *__restrict
					__attr, int *__restrict __policy)
#line 323
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
#line 327
extern int pthread_attr_getinheritsched (const pthread_attr_t *__restrict
					 __attr, int *__restrict __inherit)
#line 332
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
					 int __inherit)
#line 338
extern int pthread_attr_getscope (const pthread_attr_t *__restrict __attr,
				  int *__restrict __scope)
#line 343
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
#line 347
extern int pthread_attr_getstackaddr (const pthread_attr_t *__restrict
				      __attr, void **__restrict __stackaddr)
       __attribute__ ((__deprecated__));
#line 355
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
				      void *__stackaddr)
#line 360
extern int pthread_attr_getstacksize (const pthread_attr_t *__restrict
				      __attr, size_t *__restrict __stacksize)
#line 367
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
				      size_t __stacksize)
#line 373
extern int pthread_attr_getstack (const pthread_attr_t *__restrict __attr,
				  void **__restrict __stackaddr,
#line 381
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
				  size_t __stacksize)  ;
#line 413
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
#line 418
extern int pthread_getschedparam (pthread_t __target_thread,
				  int *__restrict __policy,
#line 424
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
#line 478
extern int pthread_once (pthread_once_t *__once_control,
			 void (*__init_routine) (void)) ;
#line 490
extern int pthread_setcancelstate (int __state, int *__oldstate);
#line 494
extern int pthread_setcanceltype (int __type, int *__oldtype);
#line 497
extern int pthread_cancel (pthread_t __th);
#line 502
extern void pthread_testcancel (void);
#line 507
typedef struct
  struct
    __jmp_buf __cancel_jmp_buf;
    int __mask_was_saved;
  } __cancel_jmp_buf[1];
  void *__pad[4];
} __pthread_unwind_buf_t __attribute__ ((__aligned__));
#line 524
struct __pthread_cleanup_frame
  void (*__cancel_routine) (void *);
  void *__cancel_arg;
  int __do_it;
  int __cancel_type;
#line 664
extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
#line 676
extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
#line 717
extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
     __attribute__ ((__weak__))
#line 726
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) ;
#line 733
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
			       const pthread_mutexattr_t *__mutexattr)
#line 738
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
#line 742
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
#line 746
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
#line 751
extern int pthread_mutex_timedlock (pthread_mutex_t *__restrict __mutex,
				    const struct timespec *__restrict
				    __abstime)  ;
#line 757
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
#line 762
extern int pthread_mutex_getprioceiling (const pthread_mutex_t *
					 __restrict __mutex,
					 int *__restrict __prioceiling)
#line 769
extern int pthread_mutex_setprioceiling (pthread_mutex_t *__restrict __mutex,
					 int __prioceiling,
					 int *__restrict __old_ceiling)
#line 777
extern int pthread_mutex_consistent (pthread_mutex_t *__mutex)
#line 790
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
#line 794
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
#line 798
extern int pthread_mutexattr_getpshared (const pthread_mutexattr_t *
					 __restrict __attr,
					 int *__restrict __pshared)
#line 804
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
					 int __pshared)
#line 810
extern int pthread_mutexattr_gettype (const pthread_mutexattr_t *__restrict
				      __attr, int *__restrict __kind)
#line 817
extern int pthread_mutexattr_settype (pthread_mutexattr_t *__attr, int __kind)
#line 822
extern int pthread_mutexattr_getprotocol (const pthread_mutexattr_t *
					  __restrict __attr,
					  int *__restrict __protocol)
#line 829
extern int pthread_mutexattr_setprotocol (pthread_mutexattr_t *__attr,
					  int __protocol)
#line 834
extern int pthread_mutexattr_getprioceiling (const pthread_mutexattr_t *
					     __restrict __attr,
#line 840
extern int pthread_mutexattr_setprioceiling (pthread_mutexattr_t *__attr,
					     int __prioceiling)
#line 846
extern int pthread_mutexattr_getrobust (const pthread_mutexattr_t *__attr,
					int *__robustness)
#line 856
extern int pthread_mutexattr_setrobust (pthread_mutexattr_t *__attr,
					int __robustness)
#line 872
extern int pthread_rwlock_init (pthread_rwlock_t *__restrict __rwlock,
				const pthread_rwlockattr_t *__restrict
				__attr)  ;
#line 877
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
#line 881
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
#line 885
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
#line 890
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t *__restrict __rwlock,
				       __abstime)  ;
#line 896
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
#line 900
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
#line 905
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t *__restrict __rwlock,
				       __abstime)  ;
#line 911
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
#line 918
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
#line 922
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
#line 926
extern int pthread_rwlockattr_getpshared (const pthread_rwlockattr_t *
					  __restrict __attr,
#line 932
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
					  int __pshared)
#line 937
extern int pthread_rwlockattr_getkind_np (const pthread_rwlockattr_t *
					  __restrict __attr,
					  int *__restrict __pref)
#line 943
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
					  int __pref)  ;
#line 952
extern int pthread_cond_init (pthread_cond_t *__restrict __cond,
			      const pthread_condattr_t *__restrict
			      __cond_attr)  ;
#line 957
extern int pthread_cond_destroy (pthread_cond_t *__cond)
#line 961
extern int pthread_cond_signal (pthread_cond_t *__cond)
#line 965
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
#line 973
extern int pthread_cond_wait (pthread_cond_t *__restrict __cond,
			      pthread_mutex_t *__restrict __mutex)
#line 984
extern int pthread_cond_timedwait (pthread_cond_t *__restrict __cond,
				   __abstime) ;
#line 992
extern int pthread_condattr_init (pthread_condattr_t *__attr)
#line 996
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
#line 1000
extern int pthread_condattr_getpshared (const pthread_condattr_t *
					__restrict __attr,
#line 1006
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
					int __pshared)  ;
#line 1011
extern int pthread_condattr_getclock (const pthread_condattr_t *
				      __restrict __attr,
				      __clockid_t *__restrict __clock_id)
#line 1017
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
				      __clockid_t __clock_id)
#line 1028
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
#line 1032
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
#line 1036
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
#line 1040
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
#line 1044
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
#line 1052
extern int pthread_barrier_init (pthread_barrier_t *__restrict __barrier,
				 const pthread_barrierattr_t *__restrict
				 __attr, unsigned int __count)
#line 1058
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
#line 1062
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
#line 1067
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
#line 1071
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
#line 1075
extern int pthread_barrierattr_getpshared (const pthread_barrierattr_t *
					   __restrict __attr,
#line 1081
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
					   int __pshared)
#line 1095
extern int pthread_key_create (pthread_key_t *__key,
			       void (*__destr_function) (void *))
#line 1100
extern int pthread_key_delete (pthread_key_t __key) ;
#line 1103
extern void *pthread_getspecific (pthread_key_t __key) ;
#line 1106
extern int pthread_setspecific (pthread_key_t __key,
				const void *__pointer)  ;
#line 1112
extern int pthread_getcpuclockid (pthread_t __thread_id,
				  __clockid_t *__clock_id)
#line 1129
extern int pthread_atfork (void (*__prepare) (void),
			   void (*__parent) (void),
			   void (*__child) (void)) ;
Found header files ['pthread.h'] in []
            Popping language C
                  All intermediate test results are stored in /tmp/petsc-ITHdGX/PETSc.packages.pthread
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/PETSc.packages.pthread/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.packages.MPI -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/PETSc.packages.pthread -I/tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/PETSc.packages.pthread/conftest.c
Successful compile:
Source:
#include <pthread.h>
int main() {
pthread_barrier_t *a;
  return 0;
        Defined "HAVE_PTHREAD_BARRIER_T" to "1"
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/PETSc.packages.pthread/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.packages.MPI -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes -I/tmp/petsc-ITHdGX/PETSc.packages.pthread  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/PETSc.packages.pthread/conftest.c
Successful compile:
Source:
#include <sched.h>
int main() {
cpu_set_t *a;
  return 0;
        Defined "HAVE_SCHED_CPU_SET_T" to "1"
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.packages.pthread -I/tmp/petsc-ITHdGX/config.headers  /tmp/petsc-ITHdGX/PETSc.packages.pthread/conftest.c
stdout:
#line 11 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/kernel.h"
struct sysinfo {
	long uptime;
	unsigned long loads[3];
	unsigned long totalram;
	unsigned long freeram;
	unsigned long sharedram;
	unsigned long bufferram;
	unsigned long totalswap;
	unsigned long freeswap;
	unsigned short procs;
	unsigned short pad;
	unsigned long totalhigh;
	unsigned long freehigh;
	unsigned int mem_unit;
	char _f[20-2*sizeof(long)-sizeof(int)];
#line 60
struct module;
void mark_hardware_unsupported(const char *msg);
void mark_tech_preview(const char *msg, struct module *mod);
#line 32 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/sysctl.h"
struct completion;
#line 39
struct __sysctl_args {
	int *name;
	int nlen;
	void *oldval;
	size_t *oldlenp;
	void *newval;
	size_t newlen;
	unsigned long __unused[4];
#line 55
enum
	CTL_KERN=1,
	CTL_VM=2,
	CTL_NET=3,
	CTL_PROC=4,
	CTL_FS=5,
	CTL_DEBUG=6,
	CTL_DEV=7,
	CTL_BUS=8,
	CTL_ABI=9,
	CTL_CPU=10,
	CTL_ARLAN=254,
	CTL_S390DBF=5677,
	CTL_SUNRPC=7249,
	CTL_PM=9899,
	CTL_FRV=9898,
#line 75
enum
	CTL_BUS_ISA=1
#line 81
enum
	INOTIFY_MAX_USER_INSTANCES=1,
	INOTIFY_MAX_USER_WATCHES=2,
	INOTIFY_MAX_QUEUED_EVENTS=3
#line 89
enum
	KERN_OSTYPE=1,
	KERN_OSRELEASE=2,
	KERN_OSREV=3,
	KERN_VERSION=4,
	KERN_SECUREMASK=5,
	KERN_PROF=6,
	KERN_NODENAME=7,
	KERN_DOMAINNAME=8,
	KERN_PANIC=15,
	KERN_REALROOTDEV=16,
	KERN_SPARC_REBOOT=21,
	KERN_CTLALTDEL=22,
	KERN_PRINTK=23,
	KERN_NAMETRANS=24,
	KERN_PPC_HTABRECLAIM=25,
	KERN_PPC_ZEROPAGED=26,
	KERN_PPC_POWERSAVE_NAP=27,
	KERN_MODPROBE=28,
	KERN_SG_BIG_BUFF=29,
	KERN_ACCT=30,
	KERN_PPC_L2CR=31,
	KERN_RTSIGNR=32,
	KERN_RTSIGMAX=33,
	KERN_SHMMAX=34,
	KERN_MSGMAX=35,
	KERN_MSGMNB=36,
	KERN_MSGPOOL=37,
	KERN_SYSRQ=38,
	KERN_MAX_THREADS=39,
 	KERN_RANDOM=40,
 	KERN_SHMALL=41,
 	KERN_MSGMNI=42,
 	KERN_SEM=43,
 	KERN_SPARC_STOP_A=44,
 	KERN_SHMMNI=45,
	KERN_OVERFLOWUID=46,
	KERN_OVERFLOWGID=47,
	KERN_SHMPATH=48,
	KERN_HOTPLUG=49,
	KERN_IEEE_EMULATION_WARNINGS=50,
	KERN_S390_USER_DEBUG_LOGGING=51,
	KERN_CORE_USES_PID=52,
	KERN_TAINTED=53,
	KERN_CADPID=54,
	KERN_PIDMAX=55,
  	KERN_CORE_PATTERN=56,
	KERN_PANIC_ON_OOPS=57,
	KERN_HPPA_PWRSW=58,
	KERN_HPPA_UNALIGNED=59,
	KERN_PRINTK_RATELIMIT=60,
	KERN_PRINTK_RATELIMIT_BURST=61,
	KERN_PTY=62,
	KERN_NGROUPS_MAX=63,
	KERN_SPARC_SCONS_PWROFF=64,
	KERN_HZ_TIMER=65,
	KERN_UNKNOWN_NMI_PANIC=66,
	KERN_BOOTLOADER_TYPE=67,
	KERN_RANDOMIZE=68,
	KERN_SETUID_DUMPABLE=69,
	KERN_SPIN_RETRY=70,
	KERN_ACPI_VIDEO_FLAGS=71,
	KERN_IA64_UNALIGNED=72,
	KERN_COMPAT_LOG=73,
	KERN_MAX_LOCK_DEPTH=74,
	KERN_NMI_WATCHDOG=75,
	KERN_PANIC_ON_NMI=76,
#line 166
enum
	VM_UNUSED1=1,
	VM_UNUSED2=2,
	VM_UNUSED3=3,
	VM_UNUSED4=4,
	VM_OVERCOMMIT_MEMORY=5,
	VM_UNUSED5=6,
	VM_UNUSED7=7,
	VM_UNUSED8=8,
	VM_UNUSED9=9,
	VM_PAGE_CLUSTER=10,
	VM_DIRTY_BACKGROUND=11,
	VM_DIRTY_RATIO=12,
	VM_DIRTY_WB_CS=13,
	VM_DIRTY_EXPIRE_CS=14,
	VM_NR_PDFLUSH_THREADS=15,
	VM_OVERCOMMIT_RATIO=16,
	VM_PAGEBUF=17,
	VM_HUGETLB_PAGES=18,
	VM_SWAPPINESS=19,
	VM_LOWMEM_RESERVE_RATIO=20,
	VM_MIN_FREE_KBYTES=21,
	VM_MAX_MAP_COUNT=22,
	VM_LAPTOP_MODE=23,
	VM_BLOCK_DUMP=24,
	VM_HUGETLB_GROUP=25,
	VM_VFS_CACHE_PRESSURE=26,
	VM_LEGACY_VA_LAYOUT=27,
	VM_SWAP_TOKEN_TIMEOUT=28,
	VM_DROP_PAGECACHE=29,
	VM_PERCPU_PAGELIST_FRACTION=30,
	VM_ZONE_RECLAIM_MODE=31,
	VM_MIN_UNMAPPED=32,
	VM_PANIC_ON_OOM=33,
	VM_VDSO_ENABLED=34,
	VM_MIN_SLAB=35,
#line 207
enum
	NET_CORE=1,
	NET_ETHER=2,
	NET_802=3,
	NET_UNIX=4,
	NET_IPV4=5,
	NET_IPX=6,
	NET_ATALK=7,
	NET_NETROM=8,
	NET_AX25=9,
	NET_BRIDGE=10,
	NET_ROSE=11,
	NET_IPV6=12,
	NET_X25=13,
	NET_TR=14,
	NET_DECNET=15,
	NET_ECONET=16,
	NET_SCTP=17,
	NET_LLC=18,
	NET_NETFILTER=19,
	NET_DCCP=20,
	NET_IRDA=412,
#line 233
enum
	RANDOM_POOLSIZE=1,
	RANDOM_ENTROPY_COUNT=2,
	RANDOM_READ_THRESH=3,
	RANDOM_WRITE_THRESH=4,
	RANDOM_BOOT_ID=5,
	RANDOM_UUID=6
#line 244
enum
	PTY_MAX=1,
	PTY_NR=2
#line 251
enum
	BUS_ISA_MEM_BASE=1,
	BUS_ISA_PORT_BASE=2,
	BUS_ISA_PORT_SHIFT=3
#line 259
enum
	NET_CORE_WMEM_MAX=1,
	NET_CORE_RMEM_MAX=2,
	NET_CORE_WMEM_DEFAULT=3,
	NET_CORE_RMEM_DEFAULT=4,
	NET_CORE_MAX_BACKLOG=6,
	NET_CORE_FASTROUTE=7,
	NET_CORE_MSG_COST=8,
	NET_CORE_MSG_BURST=9,
	NET_CORE_OPTMEM_MAX=10,
	NET_CORE_HOT_LIST_LENGTH=11,
	NET_CORE_DIVERT_VERSION=12,
	NET_CORE_NO_CONG_THRESH=13,
	NET_CORE_NO_CONG=14,
	NET_CORE_LO_CONG=15,
	NET_CORE_MOD_CONG=16,
	NET_CORE_DEV_WEIGHT=17,
	NET_CORE_SOMAXCONN=18,
	NET_CORE_BUDGET=19,
	NET_CORE_AEVENT_ETIME=20,
	NET_CORE_AEVENT_RSEQTH=21,
	NET_CORE_WARNINGS=22,
#line 291
enum
	NET_UNIX_DESTROY_DELAY=1,
	NET_UNIX_DELETE_DELAY=2,
	NET_UNIX_MAX_DGRAM_QLEN=3,
#line 299
enum
	NET_NF_CONNTRACK_MAX=1,
	NET_NF_CONNTRACK_TCP_TIMEOUT_SYN_SENT=2,
	NET_NF_CONNTRACK_TCP_TIMEOUT_SYN_RECV=3,
	NET_NF_CONNTRACK_TCP_TIMEOUT_ESTABLISHED=4,
	NET_NF_CONNTRACK_TCP_TIMEOUT_FIN_WAIT=5,
	NET_NF_CONNTRACK_TCP_TIMEOUT_CLOSE_WAIT=6,
	NET_NF_CONNTRACK_TCP_TIMEOUT_LAST_ACK=7,
	NET_NF_CONNTRACK_TCP_TIMEOUT_TIME_WAIT=8,
	NET_NF_CONNTRACK_TCP_TIMEOUT_CLOSE=9,
	NET_NF_CONNTRACK_UDP_TIMEOUT=10,
	NET_NF_CONNTRACK_UDP_TIMEOUT_STREAM=11,
	NET_NF_CONNTRACK_ICMP_TIMEOUT=12,
	NET_NF_CONNTRACK_GENERIC_TIMEOUT=13,
	NET_NF_CONNTRACK_BUCKETS=14,
	NET_NF_CONNTRACK_LOG_INVALID=15,
	NET_NF_CONNTRACK_TCP_TIMEOUT_MAX_RETRANS=16,
	NET_NF_CONNTRACK_TCP_LOOSE=17,
	NET_NF_CONNTRACK_TCP_BE_LIBERAL=18,
	NET_NF_CONNTRACK_TCP_MAX_RETRANS=19,
	NET_NF_CONNTRACK_SCTP_TIMEOUT_CLOSED=20,
	NET_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_WAIT=21,
	NET_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_ECHOED=22,
	NET_NF_CONNTRACK_SCTP_TIMEOUT_ESTABLISHED=23,
	NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_SENT=24,
	NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_RECD=25,
	NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_ACK_SENT=26,
	NET_NF_CONNTRACK_COUNT=27,
	NET_NF_CONNTRACK_ICMPV6_TIMEOUT=28,
	NET_NF_CONNTRACK_FRAG6_TIMEOUT=29,
	NET_NF_CONNTRACK_FRAG6_LOW_THRESH=30,
	NET_NF_CONNTRACK_FRAG6_HIGH_THRESH=31,
	NET_NF_CONNTRACK_CHECKSUM=32,
#line 336
enum
	NET_IPV4_FORWARD=8,
	NET_IPV4_DYNADDR=9,
	NET_IPV4_CONF=16,
	NET_IPV4_NEIGH=17,
	NET_IPV4_ROUTE=18,
	NET_IPV4_FIB_HASH=19,
	NET_IPV4_NETFILTER=20,
	NET_IPV4_TCP_TIMESTAMPS=33,
	NET_IPV4_TCP_WINDOW_SCALING=34,
	NET_IPV4_TCP_SACK=35,
	NET_IPV4_TCP_RETRANS_COLLAPSE=36,
	NET_IPV4_DEFAULT_TTL=37,
	NET_IPV4_AUTOCONFIG=38,
	NET_IPV4_NO_PMTU_DISC=39,
	NET_IPV4_TCP_SYN_RETRIES=40,
	NET_IPV4_IPFRAG_HIGH_THRESH=41,
	NET_IPV4_IPFRAG_LOW_THRESH=42,
	NET_IPV4_IPFRAG_TIME=43,
	NET_IPV4_TCP_MAX_KA_PROBES=44,
	NET_IPV4_TCP_KEEPALIVE_TIME=45,
	NET_IPV4_TCP_KEEPALIVE_PROBES=46,
	NET_IPV4_TCP_RETRIES1=47,
	NET_IPV4_TCP_RETRIES2=48,
	NET_IPV4_TCP_FIN_TIMEOUT=49,
	NET_IPV4_IP_MASQ_DEBUG=50,
	NET_TCP_SYNCOOKIES=51,
	NET_TCP_STDURG=52,
	NET_TCP_RFC1337=53,
	NET_TCP_SYN_TAILDROP=54,
	NET_TCP_MAX_SYN_BACKLOG=55,
	NET_IPV4_LOCAL_PORT_RANGE=56,
	NET_IPV4_ICMP_ECHO_IGNORE_ALL=57,
	NET_IPV4_ICMP_ECHO_IGNORE_BROADCASTS=58,
	NET_IPV4_ICMP_SOURCEQUENCH_RATE=59,
	NET_IPV4_ICMP_DESTUNREACH_RATE=60,
	NET_IPV4_ICMP_TIMEEXCEED_RATE=61,
	NET_IPV4_ICMP_PARAMPROB_RATE=62,
	NET_IPV4_ICMP_ECHOREPLY_RATE=63,
	NET_IPV4_ICMP_IGNORE_BOGUS_ERROR_RESPONSES=64,
	NET_IPV4_IGMP_MAX_MEMBERSHIPS=65,
	NET_TCP_TW_RECYCLE=66,
	NET_IPV4_ALWAYS_DEFRAG=67,
	NET_IPV4_TCP_KEEPALIVE_INTVL=68,
	NET_IPV4_INET_PEER_THRESHOLD=69,
	NET_IPV4_INET_PEER_MINTTL=70,
	NET_IPV4_INET_PEER_MAXTTL=71,
	NET_IPV4_INET_PEER_GC_MINTIME=72,
	NET_IPV4_INET_PEER_GC_MAXTIME=73,
	NET_TCP_ORPHAN_RETRIES=74,
	NET_TCP_ABORT_ON_OVERFLOW=75,
	NET_TCP_SYNACK_RETRIES=76,
	NET_TCP_MAX_ORPHANS=77,
	NET_TCP_MAX_TW_BUCKETS=78,
	NET_TCP_FACK=79,
	NET_TCP_REORDERING=80,
	NET_TCP_ECN=81,
	NET_TCP_DSACK=82,
	NET_TCP_MEM=83,
	NET_TCP_WMEM=84,
	NET_TCP_RMEM=85,
	NET_TCP_APP_WIN=86,
	NET_TCP_ADV_WIN_SCALE=87,
	NET_IPV4_NONLOCAL_BIND=88,
	NET_IPV4_ICMP_RATELIMIT=89,
	NET_IPV4_ICMP_RATEMASK=90,
	NET_TCP_TW_REUSE=91,
	NET_TCP_FRTO=92,
	NET_TCP_LOW_LATENCY=93,
	NET_IPV4_IPFRAG_SECRET_INTERVAL=94,
	NET_IPV4_IGMP_MAX_MSF=96,
	NET_TCP_NO_METRICS_SAVE=97,
	NET_TCP_DEFAULT_WIN_SCALE=105,
	NET_TCP_MODERATE_RCVBUF=106,
	NET_TCP_TSO_WIN_DIVISOR=107,
	NET_TCP_BIC_BETA=108,
	NET_IPV4_ICMP_ERRORS_USE_INBOUND_IFADDR=109,
	NET_TCP_CONG_CONTROL=110,
	NET_TCP_ABC=111,
	NET_IPV4_IPFRAG_MAX_DIST=112,
 	NET_TCP_MTU_PROBING=113,
	NET_TCP_BASE_MSS=114,
	NET_IPV4_TCP_WORKAROUND_SIGNED_WINDOWS=115,
	NET_TCP_DMA_COPYBREAK=116,
	NET_TCP_SLOW_START_AFTER_IDLE=117,
	NET_CIPSOV4_CACHE_ENABLE=118,
	NET_CIPSOV4_CACHE_BUCKET_SIZE=119,
	NET_CIPSOV4_RBM_OPTFMT=120,
	NET_CIPSOV4_RBM_STRICTVALID=121,
	NET_TCP_AVAIL_CONG_CONTROL=122,
	NET_TCP_ALLOWED_CONG_CONTROL=123,
	NET_TCP_MAX_SSTHRESH=124,
	NET_TCP_FRTO_RESPONSE=125,
enum {
	NET_IPV4_ROUTE_FLUSH=1,
	NET_IPV4_ROUTE_MIN_DELAY=2,
	NET_IPV4_ROUTE_MAX_DELAY=3,
	NET_IPV4_ROUTE_GC_THRESH=4,
	NET_IPV4_ROUTE_MAX_SIZE=5,
	NET_IPV4_ROUTE_GC_MIN_INTERVAL=6,
	NET_IPV4_ROUTE_GC_TIMEOUT=7,
	NET_IPV4_ROUTE_GC_INTERVAL=8,
	NET_IPV4_ROUTE_REDIRECT_LOAD=9,
	NET_IPV4_ROUTE_REDIRECT_NUMBER=10,
	NET_IPV4_ROUTE_REDIRECT_SILENCE=11,
	NET_IPV4_ROUTE_ERROR_COST=12,
	NET_IPV4_ROUTE_ERROR_BURST=13,
	NET_IPV4_ROUTE_GC_ELASTICITY=14,
	NET_IPV4_ROUTE_MTU_EXPIRES=15,
	NET_IPV4_ROUTE_MIN_PMTU=16,
	NET_IPV4_ROUTE_MIN_ADVMSS=17,
	NET_IPV4_ROUTE_SECRET_INTERVAL=18,
	NET_IPV4_ROUTE_GC_MIN_INTERVAL_MS=19,
enum
	NET_PROTO_CONF_ALL=-2,
	NET_PROTO_CONF_DEFAULT=-3
#line 463
enum
	NET_IPV4_CONF_FORWARDING=1,
	NET_IPV4_CONF_MC_FORWARDING=2,
	NET_IPV4_CONF_PROXY_ARP=3,
	NET_IPV4_CONF_ACCEPT_REDIRECTS=4,
	NET_IPV4_CONF_SECURE_REDIRECTS=5,
	NET_IPV4_CONF_SEND_REDIRECTS=6,
	NET_IPV4_CONF_SHARED_MEDIA=7,
	NET_IPV4_CONF_RP_FILTER=8,
	NET_IPV4_CONF_ACCEPT_SOURCE_ROUTE=9,
	NET_IPV4_CONF_BOOTP_RELAY=10,
	NET_IPV4_CONF_LOG_MARTIANS=11,
	NET_IPV4_CONF_TAG=12,
	NET_IPV4_CONF_ARPFILTER=13,
	NET_IPV4_CONF_MEDIUM_ID=14,
	NET_IPV4_CONF_NOXFRM=15,
	NET_IPV4_CONF_NOPOLICY=16,
	NET_IPV4_CONF_FORCE_IGMP_VERSION=17,
	NET_IPV4_CONF_ARP_ANNOUNCE=18,
	NET_IPV4_CONF_ARP_IGNORE=19,
	NET_IPV4_CONF_PROMOTE_SECONDARIES=20,
	NET_IPV4_CONF_ARP_ACCEPT=21,
	NET_IPV4_CONF_ARP_NOTIFY=22,
	NET_IPV4_CONF_ACCEPT_LOCAL=23,
	NET_IPV4_CONF_SRC_VMARK=24,
	NET_IPV4_CONF_PROXY_ARP_PVLAN=25,
	__NET_IPV4_CONF_MAX
#line 496
enum
	NET_IPV4_NF_CONNTRACK_MAX=1,
	NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_SYN_SENT=2,
	NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_SYN_RECV=3,
	NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_ESTABLISHED=4,
	NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_FIN_WAIT=5,
	NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_CLOSE_WAIT=6,
	NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_LAST_ACK=7,
	NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_TIME_WAIT=8,
	NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_CLOSE=9,
	NET_IPV4_NF_CONNTRACK_UDP_TIMEOUT=10,
	NET_IPV4_NF_CONNTRACK_UDP_TIMEOUT_STREAM=11,
	NET_IPV4_NF_CONNTRACK_ICMP_TIMEOUT=12,
	NET_IPV4_NF_CONNTRACK_GENERIC_TIMEOUT=13,
	NET_IPV4_NF_CONNTRACK_BUCKETS=14,
	NET_IPV4_NF_CONNTRACK_LOG_INVALID=15,
	NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_MAX_RETRANS=16,
	NET_IPV4_NF_CONNTRACK_TCP_LOOSE=17,
	NET_IPV4_NF_CONNTRACK_TCP_BE_LIBERAL=18,
	NET_IPV4_NF_CONNTRACK_TCP_MAX_RETRANS=19,
 	NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_CLOSED=20,
 	NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_WAIT=21,
 	NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_ECHOED=22,
 	NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_ESTABLISHED=23,
 	NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_SENT=24,
 	NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_RECD=25,
 	NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_ACK_SENT=26,
	NET_IPV4_NF_CONNTRACK_COUNT=27,
	NET_IPV4_NF_CONNTRACK_CHECKSUM=28,
#line 529
enum {
	NET_IPV6_CONF=16,
	NET_IPV6_NEIGH=17,
	NET_IPV6_ROUTE=18,
	NET_IPV6_ICMP=19,
	NET_IPV6_BINDV6ONLY=20,
	NET_IPV6_IP6FRAG_HIGH_THRESH=21,
	NET_IPV6_IP6FRAG_LOW_THRESH=22,
	NET_IPV6_IP6FRAG_TIME=23,
	NET_IPV6_IP6FRAG_SECRET_INTERVAL=24,
	NET_IPV6_MLD_MAX_MSF=25,
enum {
	NET_IPV6_ROUTE_FLUSH=1,
	NET_IPV6_ROUTE_GC_THRESH=2,
	NET_IPV6_ROUTE_MAX_SIZE=3,
	NET_IPV6_ROUTE_GC_MIN_INTERVAL=4,
	NET_IPV6_ROUTE_GC_TIMEOUT=5,
	NET_IPV6_ROUTE_GC_INTERVAL=6,
	NET_IPV6_ROUTE_GC_ELASTICITY=7,
	NET_IPV6_ROUTE_MTU_EXPIRES=8,
	NET_IPV6_ROUTE_MIN_ADVMSS=9,
	NET_IPV6_ROUTE_GC_MIN_INTERVAL_MS=10
enum {
	NET_IPV6_FORWARDING=1,
	NET_IPV6_HOP_LIMIT=2,
	NET_IPV6_MTU=3,
	NET_IPV6_ACCEPT_RA=4,
	NET_IPV6_ACCEPT_REDIRECTS=5,
	NET_IPV6_AUTOCONF=6,
	NET_IPV6_DAD_TRANSMITS=7,
	NET_IPV6_RTR_SOLICITS=8,
	NET_IPV6_RTR_SOLICIT_INTERVAL=9,
	NET_IPV6_RTR_SOLICIT_DELAY=10,
	NET_IPV6_USE_TEMPADDR=11,
	NET_IPV6_TEMP_VALID_LFT=12,
	NET_IPV6_TEMP_PREFERED_LFT=13,
	NET_IPV6_REGEN_MAX_RETRY=14,
	NET_IPV6_MAX_DESYNC_FACTOR=15,
	NET_IPV6_MAX_ADDRESSES=16,
	NET_IPV6_FORCE_MLD_VERSION=17,
	NET_IPV6_ACCEPT_RA_DEFRTR=18,
	NET_IPV6_ACCEPT_RA_PINFO=19,
	NET_IPV6_ACCEPT_RA_RTR_PREF=20,
	NET_IPV6_RTR_PROBE_INTERVAL=21,
	NET_IPV6_ACCEPT_RA_RT_INFO_MAX_PLEN=22,
	NET_IPV6_PROXY_NDP=23,
	NET_IPV6_ACCEPT_SOURCE_ROUTE=25,
	__NET_IPV6_MAX
#line 584
enum {
	NET_IPV6_ICMP_RATELIMIT=1
#line 589
enum {
	NET_NEIGH_MCAST_SOLICIT=1,
	NET_NEIGH_UCAST_SOLICIT=2,
	NET_NEIGH_APP_SOLICIT=3,
	NET_NEIGH_RETRANS_TIME=4,
	NET_NEIGH_REACHABLE_TIME=5,
	NET_NEIGH_DELAY_PROBE_TIME=6,
	NET_NEIGH_GC_STALE_TIME=7,
	NET_NEIGH_UNRES_QLEN=8,
	NET_NEIGH_PROXY_QLEN=9,
	NET_NEIGH_ANYCAST_DELAY=10,
	NET_NEIGH_PROXY_DELAY=11,
	NET_NEIGH_LOCKTIME=12,
	NET_NEIGH_GC_INTERVAL=13,
	NET_NEIGH_GC_THRESH1=14,
	NET_NEIGH_GC_THRESH2=15,
	NET_NEIGH_GC_THRESH3=16,
	NET_NEIGH_RETRANS_TIME_MS=17,
	NET_NEIGH_REACHABLE_TIME_MS=18,
	__NET_NEIGH_MAX
#line 612
enum {
	NET_DCCP_DEFAULT=1,
#line 617
enum {
	NET_IPX_PPROP_BROADCASTING=1,
	NET_IPX_FORWARDING=2
#line 623
enum {
	NET_LLC2=1,
	NET_LLC_STATION=2,
#line 629
enum {
	NET_LLC2_TIMEOUT=1,
#line 634
enum {
	NET_LLC_STATION_ACK_TIMEOUT=1,
#line 639
enum {
	NET_LLC2_ACK_TIMEOUT=1,
	NET_LLC2_P_TIMEOUT=2,
	NET_LLC2_REJ_TIMEOUT=3,
	NET_LLC2_BUSY_TIMEOUT=4,
#line 647
enum {
	NET_ATALK_AARP_EXPIRY_TIME=1,
	NET_ATALK_AARP_TICK_TIME=2,
	NET_ATALK_AARP_RETRANSMIT_LIMIT=3,
	NET_ATALK_AARP_RESOLVE_TIME=4
#line 656
enum {
	NET_NETROM_DEFAULT_PATH_QUALITY=1,
	NET_NETROM_OBSOLESCENCE_COUNT_INITIALISER=2,
	NET_NETROM_NETWORK_TTL_INITIALISER=3,
	NET_NETROM_TRANSPORT_TIMEOUT=4,
	NET_NETROM_TRANSPORT_MAXIMUM_TRIES=5,
	NET_NETROM_TRANSPORT_ACKNOWLEDGE_DELAY=6,
	NET_NETROM_TRANSPORT_BUSY_DELAY=7,
	NET_NETROM_TRANSPORT_REQUESTED_WINDOW_SIZE=8,
	NET_NETROM_TRANSPORT_NO_ACTIVITY_TIMEOUT=9,
	NET_NETROM_ROUTING_CONTROL=10,
	NET_NETROM_LINK_FAILS_COUNT=11,
	NET_NETROM_RESET=12
#line 672
enum {
	NET_AX25_IP_DEFAULT_MODE=1,
	NET_AX25_DEFAULT_MODE=2,
	NET_AX25_BACKOFF_TYPE=3,
	NET_AX25_CONNECT_MODE=4,
	NET_AX25_STANDARD_WINDOW=5,
	NET_AX25_EXTENDED_WINDOW=6,
	NET_AX25_T1_TIMEOUT=7,
	NET_AX25_T2_TIMEOUT=8,
	NET_AX25_T3_TIMEOUT=9,
	NET_AX25_IDLE_TIMEOUT=10,
	NET_AX25_N2=11,
	NET_AX25_PACLEN=12,
	NET_AX25_PROTOCOL=13,
	NET_AX25_DAMA_SLAVE_TIMEOUT=14
#line 690
enum {
	NET_ROSE_RESTART_REQUEST_TIMEOUT=1,
	NET_ROSE_CALL_REQUEST_TIMEOUT=2,
	NET_ROSE_RESET_REQUEST_TIMEOUT=3,
	NET_ROSE_CLEAR_REQUEST_TIMEOUT=4,
	NET_ROSE_ACK_HOLD_BACK_TIMEOUT=5,
	NET_ROSE_ROUTING_CONTROL=6,
	NET_ROSE_LINK_FAIL_TIMEOUT=7,
	NET_ROSE_MAX_VCS=8,
	NET_ROSE_WINDOW_SIZE=9,
	NET_ROSE_NO_ACTIVITY_TIMEOUT=10
#line 704
enum {
	NET_X25_RESTART_REQUEST_TIMEOUT=1,
	NET_X25_CALL_REQUEST_TIMEOUT=2,
	NET_X25_RESET_REQUEST_TIMEOUT=3,
	NET_X25_CLEAR_REQUEST_TIMEOUT=4,
	NET_X25_ACK_HOLD_BACK_TIMEOUT=5,
	NET_X25_FORWARD=6
#line 714
enum
	NET_TR_RIF_TIMEOUT=1
#line 720
enum {
	NET_DECNET_NODE_TYPE = 1,
	NET_DECNET_NODE_ADDRESS = 2,
	NET_DECNET_NODE_NAME = 3,
	NET_DECNET_DEFAULT_DEVICE = 4,
	NET_DECNET_TIME_WAIT = 5,
	NET_DECNET_DN_COUNT = 6,
	NET_DECNET_DI_COUNT = 7,
	NET_DECNET_DR_COUNT = 8,
	NET_DECNET_DST_GC_INTERVAL = 9,
	NET_DECNET_CONF = 10,
	NET_DECNET_NO_FC_MAX_CWND = 11,
	NET_DECNET_MEM = 12,
	NET_DECNET_RMEM = 13,
	NET_DECNET_WMEM = 14,
	NET_DECNET_DEBUG_LEVEL = 255
#line 739
enum {
	NET_DECNET_CONF_LOOPBACK = -2,
	NET_DECNET_CONF_DDCMP = -3,
	NET_DECNET_CONF_PPP = -4,
	NET_DECNET_CONF_X25 = -5,
	NET_DECNET_CONF_GRE = -6,
	NET_DECNET_CONF_ETHER = -7
#line 748
#line 751
enum {
	NET_DECNET_CONF_DEV_PRIORITY = 1,
	NET_DECNET_CONF_DEV_T1 = 2,
	NET_DECNET_CONF_DEV_T2 = 3,
	NET_DECNET_CONF_DEV_T3 = 4,
	NET_DECNET_CONF_DEV_FORWARDING = 5,
	NET_DECNET_CONF_DEV_BLKSIZE = 6,
	NET_DECNET_CONF_DEV_STATE = 7
#line 762
enum {
	NET_SCTP_RTO_INITIAL = 1,
	NET_SCTP_RTO_MIN     = 2,
	NET_SCTP_RTO_MAX     = 3,
	NET_SCTP_RTO_ALPHA   = 4,
	NET_SCTP_RTO_BETA    = 5,
	NET_SCTP_VALID_COOKIE_LIFE       =  6,
	NET_SCTP_ASSOCIATION_MAX_RETRANS =  7,
	NET_SCTP_PATH_MAX_RETRANS        =  8,
	NET_SCTP_MAX_INIT_RETRANSMITS    =  9,
	NET_SCTP_HB_INTERVAL             = 10,
	NET_SCTP_PRESERVE_ENABLE         = 11,
	NET_SCTP_MAX_BURST               = 12,
	NET_SCTP_ADDIP_ENABLE		 = 13,
	NET_SCTP_PRSCTP_ENABLE		 = 14,
	NET_SCTP_SNDBUF_POLICY		 = 15,
	NET_SCTP_SACK_TIMEOUT		 = 16,
	NET_SCTP_RCVBUF_POLICY		 = 17,
#line 783
enum {
	NET_BRIDGE_NF_CALL_ARPTABLES = 1,
	NET_BRIDGE_NF_CALL_IPTABLES = 2,
	NET_BRIDGE_NF_CALL_IP6TABLES = 3,
	NET_BRIDGE_NF_FILTER_VLAN_TAGGED = 4,
	NET_BRIDGE_NF_FILTER_PPPOE_TAGGED = 5,
#line 792
enum {
	NET_IRDA_DISCOVERY=1,
	NET_IRDA_DEVNAME=2,
	NET_IRDA_DEBUG=3,
	NET_IRDA_FAST_POLL=4,
	NET_IRDA_DISCOVERY_SLOTS=5,
	NET_IRDA_DISCOVERY_TIMEOUT=6,
	NET_IRDA_SLOT_TIMEOUT=7,
	NET_IRDA_MAX_BAUD_RATE=8,
	NET_IRDA_MIN_TX_TURN_TIME=9,
	NET_IRDA_MAX_TX_DATA_SIZE=10,
	NET_IRDA_MAX_TX_WINDOW=11,
	NET_IRDA_MAX_NOREPLY_TIME=12,
	NET_IRDA_WARN_NOREPLY_TIME=13,
	NET_IRDA_LAP_KEEPALIVE_TIME=14,
#line 811
enum
	FS_NRINODE=1,
	FS_STATINODE=2,
	FS_MAXINODE=3,
	FS_NRDQUOT=4,
	FS_MAXDQUOT=5,
	FS_NRFILE=6,
	FS_MAXFILE=7,
	FS_DENTRY=8,
	FS_NRSUPER=9,
	FS_MAXSUPER=10,
	FS_OVERFLOWUID=11,
	FS_OVERFLOWGID=12,
	FS_LEASES=13,
	FS_DIR_NOTIFY=14,
	FS_LEASE_TIME=15,
	FS_DQSTATS=16,
	FS_XFS=17,
	FS_AIO_NR=18,
	FS_AIO_MAX_NR=19,
	FS_INOTIFY=20,
	FS_OCFS2=988,
#line 837
enum {
	FS_DQ_LOOKUPS = 1,
	FS_DQ_DROPS = 2,
	FS_DQ_READS = 3,
	FS_DQ_WRITES = 4,
	FS_DQ_CACHE_HITS = 5,
	FS_DQ_ALLOCATED = 6,
	FS_DQ_FREE = 7,
	FS_DQ_SYNCS = 8,
	FS_DQ_WARNINGS = 9,
#line 852
enum {
	DEV_CDROM=1,
	DEV_HWMON=2,
	DEV_PARPORT=3,
	DEV_RAID=4,
	DEV_MAC_HID=5,
	DEV_SCSI=6,
	DEV_IPMI=7,
#line 863
enum {
	DEV_CDROM_INFO=1,
	DEV_CDROM_AUTOCLOSE=2,
	DEV_CDROM_AUTOEJECT=3,
	DEV_CDROM_DEBUG=4,
	DEV_CDROM_LOCK=5,
	DEV_CDROM_CHECK_MEDIA=6
#line 873
enum {
	DEV_PARPORT_DEFAULT=-3
#line 878
enum {
	DEV_RAID_SPEED_LIMIT_MIN=1,
	DEV_RAID_SPEED_LIMIT_MAX=2
#line 884
enum {
	DEV_PARPORT_DEFAULT_TIMESLICE=1,
	DEV_PARPORT_DEFAULT_SPINTIME=2
#line 890
enum {
	DEV_PARPORT_SPINTIME=1,
	DEV_PARPORT_BASE_ADDR=2,
	DEV_PARPORT_IRQ=3,
	DEV_PARPORT_DMA=4,
	DEV_PARPORT_MODES=5,
	DEV_PARPORT_DEVICES=6,
	DEV_PARPORT_AUTOPROBE=16
#line 901
enum {
	DEV_PARPORT_DEVICES_ACTIVE=-3,
#line 906
enum {
	DEV_PARPORT_DEVICE_TIMESLICE=1,
#line 911
enum {
	DEV_MAC_HID_KEYBOARD_SENDS_LINUX_KEYCODES=1,
	DEV_MAC_HID_KEYBOARD_LOCK_KEYCODES=2,
	DEV_MAC_HID_MOUSE_BUTTON_EMULATION=3,
	DEV_MAC_HID_MOUSE_BUTTON2_KEYCODE=4,
	DEV_MAC_HID_MOUSE_BUTTON3_KEYCODE=5,
	DEV_MAC_HID_ADB_MOUSE_SENDS_KEYCODES=6
#line 921
enum {
	DEV_SCSI_LOGGING_LEVEL=1,
#line 926
enum {
	DEV_IPMI_POWEROFF_POWERCYCLE=1,
#line 931
enum
	ABI_DEFHANDLER_COFF=1,
	ABI_DEFHANDLER_ELF=2,
	ABI_DEFHANDLER_LCALL7=3,
	ABI_DEFHANDLER_LIBCSO=4,
	ABI_TRACE=5,
	ABI_FAKE_UTSNAME=6,
#line 69 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/sys/sysctl.h"
extern int sysctl (int *__name, int __nlen, void *__oldval,
		   size_t *__oldlenp, void *__newval, size_t __newlen) ;
Possible ERROR while running preprocessor:
stdout:
struct sysinfo {
	long uptime;
	unsigned short pad;
#line 60
struct module;
struct completion;
#line 39
	int *name;
	int nlen;
	void *oldval;
	size_t *oldlenp;
	void *newval;
	size_t newlen;
#line 55
enum
	CTL_KERN=1,
	CTL_VM=2,
	CTL_NET=3,
	CTL_PROC=4,
	CTL_FS=5,
	CTL_DEBUG=6,
	CTL_DEV=7,
	CTL_BUS=8,
	CTL_ABI=9,
	CTL_CPU=10,
	CTL_ARLAN=254,
	CTL_S390DBF=5677,
	CTL_SUNRPC=7249,
	CTL_PM=9899,
	CTL_FRV=9898,
#line 75
enum
	CTL_BUS_ISA=1
#line 81
enum
#line 89
enum
	KERN_OSTYPE=1,
	KERN_OSRELEASE=2,
	KERN_OSREV=3,
	KERN_VERSION=4,
	KERN_SECUREMASK=5,
	KERN_PROF=6,
	KERN_NODENAME=7,
	KERN_DOMAINNAME=8,
	KERN_PANIC=15,
	KERN_CTLALTDEL=22,
	KERN_PRINTK=23,
	KERN_NAMETRANS=24,
	KERN_MODPROBE=28,
	KERN_ACCT=30,
	KERN_PPC_L2CR=31,
	KERN_RTSIGNR=32,
	KERN_RTSIGMAX=33,
	KERN_SHMMAX=34,
	KERN_MSGMAX=35,
	KERN_MSGMNB=36,
	KERN_MSGPOOL=37,
	KERN_SYSRQ=38,
 	KERN_RANDOM=40,
 	KERN_SHMALL=41,
 	KERN_MSGMNI=42,
 	KERN_SEM=43,
 	KERN_SHMMNI=45,
	KERN_SHMPATH=48,
	KERN_HOTPLUG=49,
	KERN_TAINTED=53,
	KERN_CADPID=54,
	KERN_PIDMAX=55,
	KERN_HPPA_PWRSW=58,
	KERN_PTY=62,
	KERN_HZ_TIMER=65,
	KERN_RANDOMIZE=68,
	KERN_SPIN_RETRY=70,
	KERN_COMPAT_LOG=73,
#line 166
enum
	VM_UNUSED1=1,
	VM_UNUSED2=2,
	VM_UNUSED3=3,
	VM_UNUSED4=4,
	VM_UNUSED5=6,
	VM_UNUSED7=7,
	VM_UNUSED8=8,
	VM_UNUSED9=9,
	VM_PAGE_CLUSTER=10,
	VM_DIRTY_RATIO=12,
	VM_DIRTY_WB_CS=13,
	VM_PAGEBUF=17,
	VM_SWAPPINESS=19,
	VM_LAPTOP_MODE=23,
	VM_BLOCK_DUMP=24,
	VM_MIN_UNMAPPED=32,
	VM_PANIC_ON_OOM=33,
	VM_VDSO_ENABLED=34,
	VM_MIN_SLAB=35,
#line 207
enum
	NET_CORE=1,
	NET_ETHER=2,
	NET_802=3,
	NET_UNIX=4,
	NET_IPV4=5,
	NET_IPX=6,
	NET_ATALK=7,
	NET_NETROM=8,
	NET_AX25=9,
	NET_BRIDGE=10,
	NET_ROSE=11,
	NET_IPV6=12,
	NET_X25=13,
	NET_TR=14,
	NET_DECNET=15,
	NET_ECONET=16,
	NET_SCTP=17,
	NET_LLC=18,
	NET_NETFILTER=19,
	NET_DCCP=20,
	NET_IRDA=412,
#line 233
enum
	RANDOM_POOLSIZE=1,
	RANDOM_BOOT_ID=5,
	RANDOM_UUID=6
#line 244
enum
	PTY_MAX=1,
	PTY_NR=2
#line 251
enum
	BUS_ISA_MEM_BASE=1,
#line 259
enum
	NET_CORE_BUDGET=19,
#line 291
enum
#line 299
enum
#line 336
enum
	NET_IPV4_FORWARD=8,
	NET_IPV4_DYNADDR=9,
	NET_IPV4_CONF=16,
	NET_IPV4_NEIGH=17,
	NET_IPV4_ROUTE=18,
	NET_TCP_STDURG=52,
	NET_TCP_RFC1337=53,
	NET_TCP_FACK=79,
	NET_TCP_ECN=81,
	NET_TCP_DSACK=82,
	NET_TCP_MEM=83,
	NET_TCP_WMEM=84,
	NET_TCP_RMEM=85,
	NET_TCP_APP_WIN=86,
	NET_TCP_FRTO=92,
	NET_TCP_ABC=111,
enum {
enum
#line 463
enum
	__NET_IPV4_CONF_MAX
#line 496
enum
#line 529
enum {
	NET_IPV6_CONF=16,
	NET_IPV6_NEIGH=17,
	NET_IPV6_ROUTE=18,
	NET_IPV6_ICMP=19,
enum {
enum {
	NET_IPV6_MTU=3,
	__NET_IPV6_MAX
#line 584
enum {
#line 589
enum {
	__NET_NEIGH_MAX
#line 612
enum {
	NET_DCCP_DEFAULT=1,
#line 617
enum {
#line 623
enum {
	NET_LLC2=1,
	NET_LLC_STATION=2,
#line 629
enum {
	NET_LLC2_TIMEOUT=1,
#line 634
enum {
#line 639
enum {
#line 647
enum {
#line 656
enum {
	NET_NETROM_RESET=12
#line 672
enum {
	NET_AX25_N2=11,
	NET_AX25_PACLEN=12,
#line 690
enum {
	NET_ROSE_MAX_VCS=8,
#line 704
enum {
	NET_X25_FORWARD=6
#line 714
enum
#line 720
enum {
#line 739
enum {
#line 748
#line 751
enum {
#line 762
enum {
#line 783
enum {
#line 792
enum {
	NET_IRDA_DEVNAME=2,
	NET_IRDA_DEBUG=3,
#line 811
enum
	FS_NRINODE=1,
	FS_STATINODE=2,
	FS_MAXINODE=3,
	FS_NRDQUOT=4,
	FS_MAXDQUOT=5,
	FS_NRFILE=6,
	FS_MAXFILE=7,
	FS_DENTRY=8,
	FS_NRSUPER=9,
	FS_MAXSUPER=10,
	FS_OVERFLOWUID=11,
	FS_OVERFLOWGID=12,
	FS_LEASES=13,
	FS_DIR_NOTIFY=14,
	FS_LEASE_TIME=15,
	FS_DQSTATS=16,
	FS_XFS=17,
	FS_AIO_NR=18,
	FS_AIO_MAX_NR=19,
	FS_INOTIFY=20,
	FS_OCFS2=988,
#line 837
enum {
	FS_DQ_LOOKUPS = 1,
	FS_DQ_DROPS = 2,
	FS_DQ_READS = 3,
	FS_DQ_WRITES = 4,
	FS_DQ_FREE = 7,
	FS_DQ_SYNCS = 8,
	FS_DQ_WARNINGS = 9,
#line 852
enum {
	DEV_CDROM=1,
	DEV_HWMON=2,
	DEV_PARPORT=3,
	DEV_RAID=4,
	DEV_MAC_HID=5,
	DEV_SCSI=6,
	DEV_IPMI=7,
#line 863
enum {
	DEV_CDROM_INFO=1,
	DEV_CDROM_DEBUG=4,
	DEV_CDROM_LOCK=5,
#line 873
enum {
#line 878
enum {
#line 884
enum {
#line 890
enum {
	DEV_PARPORT_IRQ=3,
	DEV_PARPORT_DMA=4,
#line 901
enum {
#line 906
enum {
#line 911
enum {
#line 921
enum {
#line 926
enum {
#line 931
enum
	ABI_TRACE=5,
	ABI_FAKE_UTSNAME=6,
		   size_t *__oldlenp, void *__newval, size_t __newlen) ;stderr:
"/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/kernel.h", line 46.9: 1506-312 (W) Compiler internal name __FUNCTION__ has been defined as a macro.
"/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/linux/kernel.h", line 46.9: 1506-236 (W) Macro name __FUNCTION__ has been redefined.
Source:
#include <sys/sysctl.h>
TEST checkSharedLibrary from PETSc.packages.pthread(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:533)
TESTING: checkSharedLibrary from PETSc.packages.pthread(config/BuildSystem/config/package.py:533)
    Popping language C
TEST alternateConfigureLibrary from PETSc.packages.pthreadclasses(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.pthreadclasses(config/BuildSystem/config/package.py:537)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from PETSc.packages.openmp(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.openmp(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.ctetgen(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.ctetgen(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.ccafe(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.ccafe(config/BuildSystem/config/package.py:537)
  PETSc clone, checking for c2html
Checking for program /usr/lib64/qt-3.3/bin/c2html...not found
Checking for program /home/adams/bin/c2html...not found
Checking for program /soft/environment/softenv-1.6.2/bin/c2html...not found
Checking for program /bin/c2html...not found
Checking for program /usr/bin/c2html...not found
Checking for program /usr/local/bin/c2html...not found
Checking for program /usr/X11R6/bin/c2html...not found
Checking for program /sbin/c2html...not found
Checking for program /usr/sbin/c2html...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/gnu-linux/bin/c2html...not found
Checking for program /bgsys/drivers/V1R2M0/ppc64/hlcs/bin/c2html...not found
Checking for program /soft/debuggers/scripts/bin/c2html...not found
Checking for program /soft/cobalt/bin/c2html...not found
Checking for program /soft/accttools/bin/c2html...not found
Checking for program /soft/compilers/ibmcmp-may2013/vac/bg/12.1/bin/c2html...not found
Checking for program /soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bin/c2html...not found
Checking for program /soft/compilers/ibmcmp-may2013/xlf/bg/14.1/bin/c2html...not found
Checking for program /soft/debuggers/ddt/bin/c2html...not found
Checking for program /soft/debuggers/totalview-8.12.0-1-2013-08-27/toolworks/totalview.8.12.0-1/bin/c2html...not found
Checking for program /soft/buildtools/cmake/current/bin/c2html...not found
Checking for program /soft/perftools/darshan/darshan/bin/c2html...not found
Checking for program /soft/compilers/wrappers/xl/c2html...not found
Checking for program /dbhome/db2cat/sqllib/bin/c2html...not found
Checking for program /dbhome/db2cat/sqllib/adm/c2html...not found
Checking for program /dbhome/db2cat/sqllib/misc/c2html...not found
Checking for program /usr/lpp/mmfs/bin/c2html...not found
Checking for program /opt/ibutils/bin/c2html...not found
Checking for program /home/adams/c2html...not found
Checking for program /home/adams/petsc/bin/win32fe/c2html...not found
  Installing c2html
      Pushing language C
TEST configureLibrary from PETSc.packages.c2html(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:479)
TESTING: configureLibrary from PETSc.packages.c2html(config/BuildSystem/config/package.py:479)
  Find an installation and check if it can work with PETSc
        Checking for a functional c2html
                Looking for C2HTML in directory starting with c2html
                Could not locate an existing copy of c2html:
                  ['sowing-1.1.16e']
                  Downloading c2html
                    Downloading http://ftp.mcs.anl.gov/pub/petsc/externalpackages/c2html.tar.gz to /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_c2html.tar.gz
                    Extracting /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_c2html.tar.gz
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages; chmod -R a+r c2html-0.9.4;find  c2html-0.9.4 -type d -name "*" -exec chmod a+rx {} \;
                    Found a copy of C2HTML in c2html-0.9.4
Have to rebuild c2html, /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/c2html-0.9.4/c2html.args != /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/c2html
Checking for program /usr/lib64/qt-3.3/bin/flex...not found
Checking for program /home/adams/bin/flex...not found
Checking for program /soft/environment/softenv-1.6.2/bin/flex...not found
Checking for program /bin/flex...not found
Checking for program /usr/bin/flex...found
                    Defined make macro "FLEX" to "flex"
Checking for program /usr/lib64/qt-3.3/bin/lex...not found
Checking for program /home/adams/bin/lex...not found
Checking for program /soft/environment/softenv-1.6.2/bin/lex...not found
Checking for program /bin/lex...not found
Checking for program /usr/bin/lex...found
                    Defined make macro "LEX" to "lex"
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/c2html-0.9.4 && ./configure --prefix=/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64
stdout:
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for executable suffix...
checking for object suffix... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for a BSD compatible install... /usr/bin/install -c
checking for flex... flex
checking for yywrap in -lfl... yes
checking lex output file root... lex.yy
checking whether yytext is a pointer... yes
checking whether make sets ${MAKE}... yes
checking for yylex in -lfl... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for unistd.h... yes
checking for getopt.h... yes
checking for malloc.h... yes
checking for gcc option to accept ANSI C... none needed
checking for an ANSI C-conforming const... yes
checking for uid_t in sys/types.h... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... (cached) yes
checking for mode_t... yes
checking for off_t... yes
checking for pid_t... yes
checking for size_t... yes
checking for stdlib.h... (cached) yes
checking for getpagesize... yes
checking for working mmap... yes
checking for strftime... yes
checking for strstr... yes
checking for getopt... yes
checking for popen... yes
checking for fileno... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating config.h
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/c2html-0.9.4 && make && make install && make clean
stdout:
flex ./c2html.l
gcc  -O -I. -I. -DCOMPRESSION=1  -o c2html lex.yy.c ./mymain.c ./colors.c -lfl
mkdir -p /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/c2html
/usr/bin/install -c -m 644 ./c2html.1 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/c2html.1
/usr/bin/install -c -m 644 ./AUTHORS /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/c2html/AUTHORS
/usr/bin/install -c -m 644 ./COPYING /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/c2html/COPYING
/usr/bin/install -c -m 644 ./NEWS /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/c2html/NEWS
/usr/bin/install -c -m 644 ./README /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/c2html/README
/usr/bin/install -c -m 644 ./c2html.lsm /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/c2html/c2html.lsm
Installing c2html to /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin
mkdir -p /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin
/usr/bin/install -c c2html /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/c2html
rm -rf *.o *~ lex.yy.c TAGS
Executing: cp -f /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/c2html-0.9.4/c2html.args /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/c2html
                  Defined make macro "C2HTML" to "/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/c2html"
        Not checking for library in Download C2HTML: [] because no functions given to check for
TEST check from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:145)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:145)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
            No functions to check for in library [] []
        Checking for headers Download C2HTML: ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
TEST checkSharedLibrary from PETSc.packages.c2html(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:533)
TESTING: checkSharedLibrary from PETSc.packages.c2html(config/BuildSystem/config/package.py:533)
  By default we don't care about checking if the library is shared
      Popping language C
TEST alternateConfigureLibrary from PETSc.packages.babel(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.babel(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.expat(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.expat(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.PVODE(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.PVODE(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.PARTY(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.PARTY(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.P3Dlib(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.P3Dlib(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.Suggar(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.Suggar(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.Numpy(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.Numpy(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.Matlab(/gpfs/mira-home/adams/petsc/config/PETSc/packages/Matlab.py:36)
TESTING: alternateConfigureLibrary from PETSc.packages.Matlab(config/PETSc/packages/Matlab.py:36)
TEST alternateConfigureLibrary from PETSc.packages.MatlabEngine(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.MatlabEngine(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.Mathematica(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.Mathematica(config/BuildSystem/config/package.py:537)
TEST alternateConfigureLibrary from PETSc.packages.PTScotch(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:537)
TESTING: alternateConfigureLibrary from PETSc.packages.PTScotch(config/BuildSystem/config/package.py:537)
      Pushing language C
TEST configureLibrary from PETSc.packages.cmake(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:479)
TESTING: configureLibrary from PETSc.packages.cmake(config/BuildSystem/config/package.py:479)
        Checking for a functional cmake
                Looking for CMAKE in directory starting with cmake
                Could not locate an existing copy of cmake:
                  ['c2html-0.9.4', 'sowing-1.1.16e']
                  Downloading cmake
                    Downloading http://www.cmake.org/files/v2.8/cmake-2.8.10.2.tar.gz to /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_cmake-2.8.10.2.tar.gz
                    Extracting /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_cmake-2.8.10.2.tar.gz
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages; chmod -R a+r cmake-2.8.10.2;find  cmake-2.8.10.2 -type d -name "*" -exec chmod a+rx {} \;
                    Found a copy of CMAKE in cmake-2.8.10.2
Have to rebuild cmake, /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/cmake.args != /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/cmake
                        Configuring CMake; this may take several minutes
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2 && ./configure --prefix=/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64
stdout:
CMake 2.8.10.2, Copyright 2000-2012 Kitware, Inc.
Found GNU toolchain
C compiler on this system is: gcc
C++ compiler on this system is: g++
Makefile processor on this system is: gmake
g++ is GNU compiler
g++ has setenv
g++ has unsetenv
g++ does not have environ in stdlib.h
g++ has STL in std:: namespace
g++ has ANSI streams
g++ has streams in std:: namespace
g++ has sstream
g++ has operator!=(string, char*)
g++ has stl iterator_traits
g++ has standard template allocator
g++ has allocator<>::rebind<>
g++ does not have non-standard allocator<>::max_size argument
g++ has stl containers supporting allocator objects
g++ has header cstddef
g++ requires template friends to use <>
g++ supports member templates
g++ has standard template specialization syntax
g++ has argument dependent lookup
g++ has struct stat with st_mtim member
g++ has ios::binary openmode
g++ has ANSI for scoping
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmStandardIncludes.cxx -o cmStandardIncludes.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmake.cxx -o cmake.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmakemain.cxx -o cmakemain.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmakewizard.cxx -o cmakewizard.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmCommandArgumentLexer.cxx -o cmCommandArgumentLexer.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmCommandArgumentParser.cxx -o cmCommandArgumentParser.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmCommandArgumentParserHelper.cxx -o cmCommandArgumentParserHelper.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmDefinitions.cxx -o cmDefinitions.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmDepends.cxx -o cmDepends.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmDependsC.cxx -o cmDependsC.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmDocumentationFormatter.cxx -o cmDocumentationFormatter.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmDocumentationFormatterText.cxx -o cmDocumentationFormatterText.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmPolicies.cxx -o cmPolicies.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmProperty.cxx -o cmProperty.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmPropertyMap.cxx -o cmPropertyMap.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmPropertyDefinition.cxx -o cmPropertyDefinition.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmPropertyDefinitionMap.cxx -o cmPropertyDefinitionMap.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmMakeDepend.cxx -o cmMakeDepend.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmMakefile.cxx -o cmMakefile.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmExportFileGenerator.cxx -o cmExportFileGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmExportInstallFileGenerator.cxx -o cmExportInstallFileGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmExportSet.cxx -o cmExportSet.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmExportSetMap.cxx -o cmExportSetMap.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmInstallDirectoryGenerator.cxx -o cmInstallDirectoryGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGeneratedFileStream.cxx -o cmGeneratedFileStream.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGeneratorTarget.cxx -o cmGeneratorTarget.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGeneratorExpressionDAGChecker.cxx -o cmGeneratorExpressionDAGChecker.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGeneratorExpressionEvaluator.cxx -o cmGeneratorExpressionEvaluator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGeneratorExpressionLexer.cxx -o cmGeneratorExpressionLexer.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGeneratorExpressionParser.cxx -o cmGeneratorExpressionParser.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGeneratorExpression.cxx -o cmGeneratorExpression.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGlobalGenerator.cxx -o cmGlobalGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmLocalGenerator.cxx -o cmLocalGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmInstallGenerator.cxx -o cmInstallGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmInstallExportGenerator.cxx -o cmInstallExportGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmInstallFilesGenerator.cxx -o cmInstallFilesGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmInstallScriptGenerator.cxx -o cmInstallScriptGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmInstallTargetGenerator.cxx -o cmInstallTargetGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmScriptGenerator.cxx -o cmScriptGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmSourceFile.cxx -o cmSourceFile.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmSourceFileLocation.cxx -o cmSourceFileLocation.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmSystemTools.cxx -o cmSystemTools.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmTestGenerator.cxx -o cmTestGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmVersion.cxx -o cmVersion.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmFileTimeComparison.cxx -o cmFileTimeComparison.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGlobalUnixMakefileGenerator3.cxx -o cmGlobalUnixMakefileGenerator3.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmLocalUnixMakefileGenerator3.cxx -o cmLocalUnixMakefileGenerator3.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmMakefileExecutableTargetGenerator.cxx -o cmMakefileExecutableTargetGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmMakefileLibraryTargetGenerator.cxx -o cmMakefileLibraryTargetGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmMakefileTargetGenerator.cxx -o cmMakefileTargetGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmMakefileUtilityTargetGenerator.cxx -o cmMakefileUtilityTargetGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmOSXBundleGenerator.cxx -o cmOSXBundleGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmNewLineStyle.cxx -o cmNewLineStyle.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmBootstrapCommands.cxx -o cmBootstrapCommands.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmCommands.cxx -o cmCommands.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmTarget.cxx -o cmTarget.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmTest.cxx -o cmTest.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmCustomCommand.cxx -o cmCustomCommand.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmCustomCommandGenerator.cxx -o cmCustomCommandGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmDocumentVariables.cxx -o cmDocumentVariables.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmCacheManager.cxx -o cmCacheManager.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmListFileCache.cxx -o cmListFileCache.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmComputeLinkDepends.cxx -o cmComputeLinkDepends.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmComputeLinkInformation.cxx -o cmComputeLinkInformation.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmOrderDirectories.cxx -o cmOrderDirectories.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmComputeTargetDepends.cxx -o cmComputeTargetDepends.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmComputeComponentGraph.cxx -o cmComputeComponentGraph.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmExprLexer.cxx -o cmExprLexer.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmExprParser.cxx -o cmExprParser.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmExprParserHelper.cxx -o cmExprParserHelper.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmGlobalNinjaGenerator.cxx -o cmGlobalNinjaGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmLocalNinjaGenerator.cxx -o cmLocalNinjaGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmNinjaTargetGenerator.cxx -o cmNinjaTargetGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmNinjaNormalTargetGenerator.cxx -o cmNinjaNormalTargetGenerator.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmNinjaUtilityTargetGenerator.cxx -o cmNinjaUtilityTargetGenerator.o
gcc -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/cmListFileLexer.c -o cmListFileLexer.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -DKWSYS_NAMESPACE=cmsys  -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/kwsys/Directory.cxx -o Directory.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -DKWSYS_NAMESPACE=cmsys  -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/kwsys/Glob.cxx -o Glob.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -DKWSYS_NAMESPACE=cmsys  -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/kwsys/RegularExpression.cxx -o RegularExpression.o
g++  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -DKWSYS_NAMESPACE=cmsys -DKWSYS_CXX_HAS_SETENV=1 -DKWSYS_CXX_HAS_UNSETENV=1 -DKWSYS_CXX_HAS_ENVIRON_IN_STDLIB_H=0 -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/kwsys/SystemTools.cxx -o SystemTools.o
gcc -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -DKWSYS_NAMESPACE=cmsys  -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/kwsys/ProcessUNIX.c -o ProcessUNIX.o
gcc -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -DKWSYS_NAMESPACE=cmsys -DKWSYS_STRING_C -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/kwsys/String.c -o String.o
gcc -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -DKWSYS_NAMESPACE=cmsys  -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source/kwsys/System.c -o System.o
g++   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Source   -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/Bootstrap.cmk  cmStandardIncludes.o cmake.o cmakemain.o cmakewizard.o cmCommandArgumentLexer.o cmCommandArgumentParser.o cmCommandArgumentParserHelper.o cmDefinitions.o cmDepends.o cmDependsC.o cmDocumentationFormatter.o cmDocumentationFormatterText.o cmPolicies.o cmProperty.o cmPropertyMap.o cmPropertyDefinition.o cmPropertyDefinitionMap.o cmMakeDepend.o cmMakefile.o cmExportFileGenerator.o cmExportInstallFileGenerator.o cmExportSet.o cmExportSetMap.o cmInstallDirectoryGenerator.o cmGeneratedFileStream.o cmGeneratorTarget.o cmGeneratorExpressionDAGChecker.o cmGeneratorExpressionEvaluator.o cmGeneratorExpressionLexer.o cmGeneratorExpressionParser.o cmGeneratorExpression.o cmGlobalGenerator.o cmLocalGenerator.o cmInstallGenerator.o cmInstallExportGenerator.o cmInstallFilesGenerator.o cmInstallScriptGenerator.o cmInstallTargetGenerator.o cmScriptGenerator.o cmSourceFile.o cmSourceFileLocation.o cmSystemTools.o cmTestGenerator.o cmVersion.o cmFileTimeComparison.o cmGlobalUnixMakefileGenerator3.o cmLocalUnixMakefileGenerator3.o cmMakefileExecutableTargetGenerator.o cmMakefileLibraryTargetGenerator.o cmMakefileTargetGenerator.o cmMakefileUtilityTargetGenerator.o cmOSXBundleGenerator.o cmNewLineStyle.o cmBootstrapCommands.o cmCommands.o cmTarget.o cmTest.o cmCustomCommand.o cmCustomCommandGenerator.o cmDocumentVariables.o cmCacheManager.o cmListFileCache.o cmComputeLinkDepends.o cmComputeLinkInformation.o cmOrderDirectories.o cmComputeTargetDepends.o cmComputeComponentGraph.o cmExprLexer.o cmExprParser.o cmExprParserHelper.o cmGlobalNinjaGenerator.o cmLocalNinjaGenerator.o cmNinjaTargetGenerator.o cmNinjaNormalTargetGenerator.o cmNinjaUtilityTargetGenerator.o cmListFileLexer.o Directory.o Glob.o RegularExpression.o SystemTools.o ProcessUNIX.o String.o System.o -o cmake
-- The C compiler identification is GNU 4.4.6
-- The CXX compiler identification is GNU 4.4.6
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/g++
-- Check for working CXX compiler: /usr/bin/g++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Looking for C++ include iostream
-- Looking for C++ include iostream - found
-- Check for STD namespace
-- Check for STD namespace - found
-- Check for ANSI scope
-- Check for ANSI scope - found
-- Check for sstream
-- Check for sstream - found
-- Looking for unsetenv
-- Looking for unsetenv - found
-- Looking for environ
-- Looking for environ - not found
-- Checking whether header cstdio is available
-- Checking whether header cstdio is available - yes
-- Checking for Large File Support
-- Checking for Large File Support - yes
-- Checking whether STL classes are in std namespace
-- Checking whether STL classes are in std namespace - yes
-- Checking whether ANSI stream headers are available
-- Checking whether ANSI stream headers are available - yes
-- Checking whether ANSI streams are in std namespace
-- Checking whether ANSI streams are in std namespace - yes
-- Checking whether ANSI string stream is available
-- Checking whether ANSI string stream is available - yes
-- Checking whether header cstddef is available
-- Checking whether header cstddef is available - yes
-- Checking whether stl string has operator!= for char*
-- Checking whether stl string has operator!= for char* - yes
-- Checking whether stl has iterator_traits
-- Checking whether stl has iterator_traits - yes
-- Checking whether stl has standard template allocator
-- Checking whether stl has standard template allocator - yes
-- Checking for rebind member of stl allocator
-- Checking for rebind member of stl allocator - yes
-- Checking for non-standard argument to stl allocator<>::max_size
-- Checking for non-standard argument to stl allocator<>::max_size - no
-- Checking whether stl containers support allocator objects.
-- Checking whether stl containers support allocator objects. - yes
-- Checking whether ios has binary openmode
-- Checking whether ios has binary openmode - yes
-- Checking whether "<>" is needed for template friends
-- Checking whether "<>" is needed for template friends - yes
-- Checking for member template support
-- Checking for member template support - yes
-- Checking for standard template specialization syntax
-- Checking for standard template specialization syntax - yes
-- Checking whether argument dependent lookup is supported
-- Checking whether argument dependent lookup is supported - yes
-- Checking whether struct stat has st_mtim member
-- Checking whether struct stat has st_mtim member - yes
-- Checking whether C++ compiler has 'long long'
-- Checking whether C++ compiler has 'long long' - yes
-- Checking whether C++ compiler has '__int64'
-- Checking whether C++ compiler has '__int64' - no
-- Checking for C type size macros
-- Checking for C type size macros - compiled
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of char
-- Check size of char - done
-- Check size of __int64
-- Check size of __int64 - failed
-- Checking whether char is signed
-- Checking whether char is signed - no
-- Checking if istream supports long long
-- Checking if istream supports long long - yes
-- Checking if ostream supports long long
-- Checking if ostream supports long long - yes
-- Checking whether C compiler has ptrdiff_t in stddef.h
-- Checking whether C compiler has ptrdiff_t in stddef.h - yes
-- Checking whether C compiler has ssize_t in unistd.h
-- Checking whether C compiler has ssize_t in unistd.h - yes
-- Checking whether CXX compiler has setenv
-- Checking whether CXX compiler has setenv - yes
-- Checking whether CXX compiler has unsetenv
-- Checking whether CXX compiler has unsetenv - yes
-- Checking whether CXX compiler has environ in stdlib.h
-- Checking whether CXX compiler has environ in stdlib.h - no
-- Looking for connect in socket;dl
-- Looking for connect in socket;dl - not found
-- Looking for gethostbyname in c
-- Looking for gethostbyname in c - found
-- Looking for recv in network;dl
-- Looking for recv in network;dl - not found
-- Looking for getch in ws2_32;dl
-- Looking for getch in ws2_32;dl - not found
-- Looking for getch in winmm;dl
-- Looking for getch in winmm;dl - not found
-- Looking for idna_to_ascii_lz in idn;dl
-- Looking for idna_to_ascii_lz in idn;dl - found
-- Looking for dlopen in dl;idn
-- Looking for dlopen in dl;idn - found
-- Looking for process.h
-- Looking for process.h - not found
-- Looking for features.h
-- Looking for features.h - found
-- Looking for include file stdio.h
-- Looking for include file stdio.h - found
-- Looking for 4 include files stdio.h, ..., inttypes.h
-- Looking for 4 include files stdio.h, ..., inttypes.h - found
-- Looking for 5 include files stdio.h, ..., alloca.h
-- Looking for 5 include files stdio.h, ..., alloca.h - found
-- Looking for 6 include files stdio.h, ..., arpa/inet.h
-- Looking for 6 include files stdio.h, ..., arpa/inet.h - found
-- Looking for 7 include files stdio.h, ..., dlfcn.h
-- Looking for 7 include files stdio.h, ..., dlfcn.h - found
-- Looking for 8 include files stdio.h, ..., fcntl.h
-- Looking for 8 include files stdio.h, ..., fcntl.h - found
-- Looking for 9 include files stdio.h, ..., malloc.h
-- Looking for 9 include files stdio.h, ..., malloc.h - found
-- Looking for 10 include files stdio.h, ..., memory.h
-- Looking for 10 include files stdio.h, ..., memory.h - found
-- Looking for 11 include files stdio.h, ..., netdb.h
-- Looking for 11 include files stdio.h, ..., netdb.h - found
-- Looking for 12 include files stdio.h, ..., sys/poll.h
-- Looking for 12 include files stdio.h, ..., sys/poll.h - found
-- Looking for 13 include files stdio.h, ..., assert.h
-- Looking for 13 include files stdio.h, ..., assert.h - found
-- Looking for 14 include files stdio.h, ..., limits.h
-- Looking for 14 include files stdio.h, ..., limits.h - found
-- Looking for 15 include files stdio.h, ..., sys/socket.h
-- Looking for 15 include files stdio.h, ..., sys/socket.h - found
-- Looking for 16 include files stdio.h, ..., netinet/in.h
-- Looking for 16 include files stdio.h, ..., netinet/in.h - found
-- Looking for 17 include files stdio.h, ..., net/if.h
-- Looking for 17 include files stdio.h, ..., net/if.h - found
-- Looking for 18 include files stdio.h, ..., netinet/if_ether.h
-- Looking for 18 include files stdio.h, ..., netinet/if_ether.h - found
-- Looking for 19 include files stdio.h, ..., netinet/tcp.h
-- Looking for 19 include files stdio.h, ..., netinet/tcp.h - found
-- Looking for 20 include files stdio.h, ..., sys/select.h
-- Looking for 20 include files stdio.h, ..., sys/select.h - found
-- Looking for 21 include files stdio.h, ..., utime.h
-- Looking for 21 include files stdio.h, ..., utime.h - found
-- Looking for 23 include files stdio.h, ..., pwd.h
-- Looking for 23 include files stdio.h, ..., pwd.h - found
-- Looking for 24 include files stdio.h, ..., sgtty.h
-- Looking for 24 include files stdio.h, ..., sgtty.h - found
-- Looking for 26 include files stdio.h, ..., stdlib.h
-- Looking for 26 include files stdio.h, ..., stdlib.h - found
-- Looking for 27 include files stdio.h, ..., string.h
-- Looking for 27 include files stdio.h, ..., string.h - found
-- Looking for 28 include files stdio.h, ..., strings.h
-- Looking for 28 include files stdio.h, ..., strings.h - found
-- Looking for 29 include files stdio.h, ..., sys/param.h
-- Looking for 29 include files stdio.h, ..., sys/param.h - found
-- Looking for 30 include files stdio.h, ..., sys/stat.h
-- Looking for 30 include files stdio.h, ..., sys/stat.h - found
-- Looking for 31 include files stdio.h, ..., sys/time.h
-- Looking for 31 include files stdio.h, ..., sys/time.h - found
-- Looking for 32 include files stdio.h, ..., sys/resource.h
-- Looking for 32 include files stdio.h, ..., sys/resource.h - found
-- Looking for 33 include files stdio.h, ..., termios.h
-- Looking for 33 include files stdio.h, ..., termios.h - found
-- Looking for 34 include files stdio.h, ..., termio.h
-- Looking for 34 include files stdio.h, ..., termio.h - found
-- Looking for 35 include files stdio.h, ..., io.h
-- Looking for 35 include files stdio.h, ..., io.h - not found
-- Looking for 35 include files stdio.h, ..., time.h
-- Looking for 35 include files stdio.h, ..., time.h - found
-- Looking for 36 include files stdio.h, ..., unistd.h
-- Looking for 36 include files stdio.h, ..., unistd.h - found
-- Looking for 37 include files stdio.h, ..., sys/utime.h
-- Looking for 37 include files stdio.h, ..., sys/utime.h - not found
-- Looking for 37 include files stdio.h, ..., sockio.h
-- Looking for 37 include files stdio.h, ..., sockio.h - not found
-- Looking for 37 include files stdio.h, ..., sys/sockio.h
-- Looking for 37 include files stdio.h, ..., sys/sockio.h - not found
-- Looking for 37 include files stdio.h, ..., x509.h
-- Looking for 37 include files stdio.h, ..., x509.h - not found
-- Looking for 37 include files stdio.h, ..., locale.h
-- Looking for 37 include files stdio.h, ..., locale.h - found
-- Looking for 38 include files stdio.h, ..., setjmp.h
-- Looking for 38 include files stdio.h, ..., setjmp.h - found
-- Looking for 39 include files stdio.h, ..., signal.h
-- Looking for 39 include files stdio.h, ..., signal.h - found
-- Looking for 40 include files stdio.h, ..., sys/ioctl.h
-- Looking for 40 include files stdio.h, ..., sys/ioctl.h - found
-- Looking for 41 include files stdio.h, ..., sys/utsname.h
-- Looking for 41 include files stdio.h, ..., sys/utsname.h - found
-- Looking for 42 include files stdio.h, ..., idn-free.h
-- Looking for 42 include files stdio.h, ..., idn-free.h - found
-- Looking for 43 include files stdio.h, ..., idna.h
-- Looking for 43 include files stdio.h, ..., idna.h - found
-- Looking for 44 include files stdio.h, ..., tld.h
-- Looking for 44 include files stdio.h, ..., tld.h - found
-- Looking for 45 include files stdio.h, ..., arpa/tftp.h
-- Looking for 45 include files stdio.h, ..., arpa/tftp.h - found
-- Looking for 46 include files stdio.h, ..., errno.h
-- Looking for 46 include files stdio.h, ..., errno.h - found
-- Looking for 47 include files stdio.h, ..., libgen.h
-- Looking for 47 include files stdio.h, ..., libgen.h - found
-- Looking for 48 include files stdio.h, ..., sys/filio.h
-- Looking for 48 include files stdio.h, ..., sys/filio.h - not found
-- Check size of size_t
-- Check size of size_t - done
-- Check size of ssize_t
-- Check size of ssize_t - done
-- Check size of long long
-- Check size of long long - done
-- Check size of long - done
-- Check size of time_t
-- Check size of time_t - done
-- Looking for basename
-- Looking for basename - found
-- Looking for socket
-- Looking for socket - found
-- Looking for poll
-- Looking for poll - found
-- Looking for select
-- Looking for select - found
-- Looking for strdup
-- Looking for strdup - found
-- Looking for strstr
-- Looking for strstr - found
-- Looking for strtok_r
-- Looking for strtok_r - found
-- Looking for strftime
-- Looking for strftime - found
-- Looking for uname
-- Looking for uname - found
-- Looking for strcasecmp
-- Looking for strcasecmp - found
-- Looking for stricmp
-- Looking for stricmp - not found
-- Looking for strcmpi
-- Looking for strcmpi - not found
-- Looking for strncmpi
-- Looking for strncmpi - not found
-- Looking for gethostbyaddr
-- Looking for gethostbyaddr - found
-- Looking for gettimeofday
-- Looking for gettimeofday - found
-- Looking for inet_addr
-- Looking for inet_addr - found
-- Looking for inet_pton
-- Looking for inet_pton - found
-- Looking for inet_ntoa
-- Looking for inet_ntoa - found
-- Looking for inet_ntoa_r
-- Looking for inet_ntoa_r - not found
-- Looking for tcsetattr
-- Looking for tcsetattr - found
-- Looking for tcgetattr
-- Looking for tcgetattr - found
-- Looking for perror
-- Looking for perror - found
-- Looking for closesocket
-- Looking for closesocket - not found
-- Looking for setvbuf
-- Looking for setvbuf - found
-- Looking for sigsetjmp
-- Looking for sigsetjmp - found
-- Looking for getpass_r
-- Looking for getpass_r - not found
-- Looking for strlcat
-- Looking for strlcat - not found
-- Looking for getpwuid
-- Looking for getpwuid - found
-- Looking for geteuid
-- Looking for geteuid - found
-- Looking for utime
-- Looking for utime - found
-- Looking for gmtime_r
-- Looking for gmtime_r - found
-- Looking for localtime_r
-- Looking for localtime_r - found
-- Looking for gethostbyname - found
-- Looking for gethostbyname_r
-- Looking for gethostbyname_r - found
-- Looking for gethostbyaddr_r
-- Looking for gethostbyaddr_r - found
-- Looking for signal
-- Looking for signal - found
-- Looking for SIGALRM
-- Looking for SIGALRM - found
-- Looking for strtoll
-- Looking for strtoll - found
-- Looking for _strtoi64
-- Looking for _strtoi64 - not found
-- Looking for strerror_r
-- Looking for strerror_r - found
-- Looking for siginterrupt
-- Looking for siginterrupt - found
-- Looking for fork
-- Looking for fork - found
-- Looking for pipe
-- Looking for pipe - found
-- Looking for ftruncate
-- Looking for ftruncate - found
-- Looking for getprotobyname
-- Looking for getprotobyname - found
-- Looking for getrlimit
-- Looking for getrlimit - found
-- Looking for idn_free
-- Looking for idn_free - found
-- Looking for idna_strerror
-- Looking for idna_strerror - found
-- Looking for tld_strerror
-- Looking for tld_strerror - found
-- Looking for setlocale
-- Looking for setlocale - found
-- Looking for setrlimit
-- Looking for setrlimit - found
-- Looking for sigaction
-- Looking for sigaction - found
-- Performing Curl Test HAVE_FIONBIO
-- Performing Curl Test HAVE_FIONBIO - Failed
-- Performing Curl Test HAVE_IOCTLSOCKET
-- Performing Curl Test HAVE_IOCTLSOCKET - Failed
-- Performing Curl Test HAVE_IOCTLSOCKET_CASE
-- Performing Curl Test HAVE_IOCTLSOCKET_CASE - Failed
-- Performing Curl Test HAVE_O_NONBLOCK
-- Performing Curl Test HAVE_O_NONBLOCK - Success
-- Performing Curl Test HAVE_SO_NONBLOCK
-- Performing Curl Test HAVE_SO_NONBLOCK - Failed
-- Performing Curl Test TIME_WITH_SYS_TIME
-- Performing Curl Test TIME_WITH_SYS_TIME - Success
-- Performing Curl Test HAVE_O_NONBLOCKHAVE_GETHOSTBYADDR_R_5
-- Performing Curl Test HAVE_O_NONBLOCKHAVE_GETHOSTBYADDR_R_5 - Failed
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_7
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_7 - Failed
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_8
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_8 - Success
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_5_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_5_REENTRANT - Failed
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_7_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_7_REENTRANT - Failed
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_8_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYADDR_R_8_REENTRANT - Success
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_3
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_3 - Failed
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_5
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_5 - Failed
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_6
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_6 - Success
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_3_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_3_REENTRANT - Failed
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_5_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_5_REENTRANT - Failed
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_6_REENTRANT
-- Performing Curl Test HAVE_GETHOSTBYNAME_R_6_REENTRANT - Success
-- Performing Curl Test HAVE_SOCKLEN_T
-- Performing Curl Test HAVE_SOCKLEN_T - Success
-- Performing Curl Test HAVE_IN_ADDR_T
-- Performing Curl Test HAVE_IN_ADDR_T - Success
-- Performing Curl Test STDC_HEADERS
-- Performing Curl Test STDC_HEADERS - Success
-- Performing Curl Test RETSIGTYPE_TEST
-- Performing Curl Test RETSIGTYPE_TEST - Success
-- Performing Curl Test HAVE_INET_NTOA_R_DECL
-- Performing Curl Test HAVE_INET_NTOA_R_DECL - Failed
-- Performing Curl Test HAVE_INET_NTOA_R_DECL_REENTRANT
-- Performing Curl Test HAVE_INET_NTOA_R_DECL_REENTRANT - Failed
-- Performing Curl Test HAVE_GETADDRINFO
-- Performing Curl Test HAVE_GETADDRINFO - Success
-- Performing Curl Test HAVE_FILE_OFFSET_BITS
-- Performing Curl Test HAVE_FILE_OFFSET_BITS - Success
-- Check size of curl_off_t
-- Check size of curl_off_t - done
-- Performing Test curl_cv_recv
-- Performing Test curl_cv_recv - Success
-- Performing Test int recv(int, void *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, void *, size_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, void *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, void *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, void *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, void *, socklen_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, socklen_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, void *, unsigned int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, unsigned int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, void *, unsigned int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, void *, unsigned int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, size_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, socklen_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, socklen_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, unsigned int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, unsigned int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(int, char *, unsigned int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(int, char *, unsigned int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, size_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, socklen_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, socklen_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, unsigned int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, unsigned int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, void *, unsigned int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, void *, unsigned int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, size_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, socklen_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, socklen_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, unsigned int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, unsigned int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(ssize_t, char *, unsigned int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(ssize_t, char *, unsigned int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, size_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, socklen_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, socklen_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, unsigned int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, unsigned int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, void *, unsigned int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, void *, unsigned int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, size_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, size_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, size_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, socklen_t, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, socklen_t, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, socklen_t, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, socklen_t, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, unsigned int, int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, unsigned int, int) (curl_cv_func_recv_test) - Failed
-- Performing Test int recv(SOCKET, char *, unsigned int, unsigned int) (curl_cv_func_recv_test)
-- Performing Test int recv(SOCKET, char *, unsigned int, unsigned int) (curl_cv_func_recv_test) - Failed
-- Performing Test ssize_t recv(int, void *, size_t, int) (curl_cv_func_recv_test)
-- Performing Test ssize_t recv(int, void *, size_t, int) (curl_cv_func_recv_test) - Success
-- Performing Test curl_cv_send
-- Performing Test curl_cv_send - Success
-- Performing Test int send(int, const void *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const void *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const void *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, void *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, void *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, char *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, char *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(int, const char *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(int, const char *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const void *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const void *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const void *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const void *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const void *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const void *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const void *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const void *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const void *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const void *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const void *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const void *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const void *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const void *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const void *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const void *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, void *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, void *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, void *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, void *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, void *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, void *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, void *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, void *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, void *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, void *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, void *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, void *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, void *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, void *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, void *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, void *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, char *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, char *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, char *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, char *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, char *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, char *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, char *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, char *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, char *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, char *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, char *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, char *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, char *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, char *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, char *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, char *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const char *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const char *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const char *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const char *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const char *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const char *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const char *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const char *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const char *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const char *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const char *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const char *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const char *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const char *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(ssize_t, const char *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(ssize_t, const char *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const void *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const void *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const void *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const void *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const void *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const void *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const void *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const void *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const void *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const void *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const void *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const void *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const void *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const void *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const void *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const void *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, void *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, void *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, void *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, void *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, void *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, void *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, void *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, void *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, void *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, void *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, void *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, void *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, void *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, void *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, void *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, void *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, char *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, char *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, char *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, char *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, char *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, char *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, char *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, char *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, char *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const char *, size_t, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const char *, size_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const char *, size_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const char *, size_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const char *, int, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const char *, int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const char *, int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const char *, int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const char *, socklen_t, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const char *, socklen_t, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const char *, socklen_t, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const char *, socklen_t, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const char *, unsigned int, int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const char *, unsigned int, int) (curl_cv_func_send_test) - Failed
-- Performing Test int send(SOCKET, const char *, unsigned int, unsigned int) (curl_cv_func_send_test)
-- Performing Test int send(SOCKET, const char *, unsigned int, unsigned int) (curl_cv_func_send_test) - Failed
-- Performing Test ssize_t send(int, const void *, size_t, int) (curl_cv_func_send_test)
-- Performing Test ssize_t send(int, const void *, size_t, int) (curl_cv_func_send_test) - Success
-- Performing Test HAVE_MSG_NOSIGNAL
-- Performing Test HAVE_MSG_NOSIGNAL - Success
-- Performing Test HAVE_STRUCT_TIMEVAL
-- Performing Test HAVE_STRUCT_TIMEVAL - Success
-- Check size of sig_atomic_t
-- Check size of sig_atomic_t - done
-- Performing Test HAVE_SIG_ATOMIC_T_NOT_VOLATILE
-- Performing Test HAVE_SIG_ATOMIC_T_NOT_VOLATILE - Success
-- Check size of struct sockaddr_storage
-- Check size of struct sockaddr_storage - done
-- Found ZLIB: cmzlib
-- Found BZip2: cmbzip2 (found version "1.0.5")
-- Looking for BZ2_bzCompressInit in cmbzip2
-- Looking for BZ2_bzCompressInit in cmbzip2 - not found
-- Performing Test HAVE_DIRENT_H
-- Performing Test HAVE_DIRENT_H - Success
-- Looking for include files sys/types.h, acl/libacl.h
-- Looking for include files sys/types.h, acl/libacl.h - not found
-- Looking for include files sys/types.h, ctype.h
-- Looking for include files sys/types.h, ctype.h - found
-- Looking for 3 include files sys/types.h, ..., copyfile.h
-- Looking for 3 include files sys/types.h, ..., copyfile.h - not found
-- Looking for 3 include files sys/types.h, ..., direct.h
-- Looking for 3 include files sys/types.h, ..., direct.h - not found
-- Looking for 5 include files sys/types.h, ..., ext2fs/ext2_fs.h
-- Looking for 5 include files sys/types.h, ..., ext2fs/ext2_fs.h - not found
-- Performing Test HAVE_WORKING_EXT2_IOC_GETFLAGS
-- Performing Test HAVE_WORKING_EXT2_IOC_GETFLAGS - Failed
-- Looking for 6 include files sys/types.h, ..., grp.h
-- Looking for 6 include files sys/types.h, ..., grp.h - found
-- Looking for 8 include files sys/types.h, ..., langinfo.h
-- Looking for 8 include files sys/types.h, ..., langinfo.h - found
-- Looking for 10 include files sys/types.h, ..., linux/types.h
-- Looking for 10 include files sys/types.h, ..., linux/types.h - found
-- Looking for 11 include files sys/types.h, ..., linux/fiemap.h
-- Looking for 11 include files sys/types.h, ..., linux/fiemap.h - found
-- Looking for 12 include files sys/types.h, ..., linux/fs.h
-- Looking for 12 include files sys/types.h, ..., linux/fs.h - found
-- Looking for 13 include files sys/types.h, ..., linux/magic.h
-- Looking for 13 include files sys/types.h, ..., linux/magic.h - found
-- Looking for 16 include files sys/types.h, ..., paths.h
-- Looking for 16 include files sys/types.h, ..., paths.h - found
-- Looking for 17 include files sys/types.h, ..., poll.h
-- Looking for 17 include files sys/types.h, ..., poll.h - found
-- Looking for 19 include files sys/types.h, ..., regex.h
-- Looking for 19 include files sys/types.h, ..., regex.h - found
-- Looking for 21 include files sys/types.h, ..., stdarg.h
-- Looking for 21 include files sys/types.h, ..., stdarg.h - found
-- Looking for 26 include files sys/types.h, ..., sys/acl.h
-- Looking for 26 include files sys/types.h, ..., sys/acl.h - not found
-- Looking for 26 include files sys/types.h, ..., sys/cdefs.h
-- Looking for 26 include files sys/types.h, ..., sys/cdefs.h - found
-- Looking for 28 include files sys/types.h, ..., sys/mkdev.h
-- Looking for 28 include files sys/types.h, ..., sys/mkdev.h - not found
-- Looking for 28 include files sys/types.h, ..., sys/mount.h
-- Looking for 28 include files sys/types.h, ..., sys/mount.h - not found
-- Looking for 32 include files sys/types.h, ..., sys/statfs.h
-- Looking for 32 include files sys/types.h, ..., sys/statfs.h - found
-- Looking for 33 include files sys/types.h, ..., sys/statvfs.h
-- Looking for 33 include files sys/types.h, ..., sys/statvfs.h - found
-- Looking for 36 include files sys/types.h, ..., sys/vfs.h
-- Looking for 36 include files sys/types.h, ..., sys/vfs.h - found
-- Looking for 37 include files sys/types.h, ..., sys/wait.h
-- Looking for 37 include files sys/types.h, ..., sys/wait.h - found
-- Looking for 41 include files sys/types.h, ..., wchar.h
-- Looking for 41 include files sys/types.h, ..., wchar.h - found
-- Looking for 42 include files sys/types.h, ..., wctype.h
-- Looking for 42 include files sys/types.h, ..., wctype.h - found
-- Looking for 43 include files sys/types.h, ..., windows.h
-- Looking for 43 include files sys/types.h, ..., windows.h - not found
-- Looking for 43 include files sys/types.h, ..., wincrypt.h
-- Looking for 43 include files sys/types.h, ..., wincrypt.h - not found
-- Looking for 43 include files sys/types.h, ..., winioctl.h
-- Looking for 43 include files sys/types.h, ..., winioctl.h - not found
-- Performing Test SAFE_TO_DEFINE_EXTENSIONS
-- Performing Test SAFE_TO_DEFINE_EXTENSIONS - Success
-- Looking for MD5Init in md
-- Looking for MD5Init in md - not found
-- Looking for _CrtSetReportMode
-- Looking for _CrtSetReportMode - not found
-- Looking for chown
-- Looking for chown - found
-- Looking for chroot
-- Looking for chroot - found
-- Looking for ctime_r
-- Looking for ctime_r - found
-- Looking for fchdir
-- Looking for fchdir - found
-- Looking for fchmod
-- Looking for fchmod - found
-- Looking for fchown
-- Looking for fchown - found
-- Looking for fcntl
-- Looking for fcntl - found
-- Looking for fdopendir
-- Looking for fdopendir - found
-- Looking for fstat
-- Looking for fstat - found
-- Looking for fstatat
-- Looking for fstatat - found
-- Looking for fstatfs
-- Looking for fstatfs - found
-- Looking for fstatvfs
-- Looking for fstatvfs - found
-- Looking for futimens
-- Looking for futimens - found
-- Looking for futimes
-- Looking for futimes - found
-- Looking for futimesat
-- Looking for futimesat - found
-- Looking for getgrgid_r
-- Looking for getgrgid_r - found
-- Looking for getgrnam_r
-- Looking for getgrnam_r - found
-- Looking for getpwnam_r
-- Looking for getpwnam_r - found
-- Looking for getpwuid_r
-- Looking for getpwuid_r - found
-- Looking for getpid
-- Looking for getpid - found
-- Looking for getvfsbyname
-- Looking for getvfsbyname - not found
-- Looking for lchflags
-- Looking for lchflags - not found
-- Looking for lchown
-- Looking for lchown - found
-- Looking for link
-- Looking for link - found
-- Looking for lstat
-- Looking for lstat - found
-- Looking for lutimes
-- Looking for lutimes - found
-- Looking for mbrtowc
-- Looking for mbrtowc - found
-- Looking for mbsnrtowcs
-- Looking for mbsnrtowcs - found
-- Looking for memmove
-- Looking for memmove - found
-- Looking for mkdir
-- Looking for mkdir - found
-- Looking for mkfifo
-- Looking for mkfifo - found
-- Looking for mknod
-- Looking for mknod - found
-- Looking for mkstemp
-- Looking for mkstemp - found
-- Looking for nl_langinfo
-- Looking for nl_langinfo - found
-- Looking for openat
-- Looking for openat - found
-- Looking for readlink
-- Looking for readlink - found
-- Looking for setenv
-- Looking for setenv - found
-- Looking for statfs
-- Looking for statfs - found
-- Looking for statvfs
-- Looking for statvfs - found
-- Looking for strchr
-- Looking for strchr - found
-- Looking for strerror - found
-- Looking for strncpy_s
-- Looking for strncpy_s - not found
-- Looking for strrchr
-- Looking for strrchr - found
-- Looking for symlink
-- Looking for symlink - found
-- Looking for timegm
-- Looking for timegm - found
-- Looking for tzset
-- Looking for tzset - found
-- Looking for utimes
-- Looking for utimes - found
-- Looking for utimensat
-- Looking for utimensat - found
-- Looking for vfork
-- Looking for vfork - found
-- Looking for wcrtomb
-- Looking for wcrtomb - found
-- Looking for wcscmp
-- Looking for wcscmp - found
-- Looking for wcscpy
-- Looking for wcscpy - found
-- Looking for wcslen
-- Looking for wcslen - found
-- Looking for wcsnrtombs
-- Looking for wcsnrtombs - found
-- Looking for wctomb
-- Looking for wctomb - found
-- Looking for _ctime64_s
-- Looking for _ctime64_s - not found
-- Looking for _fseeki64
-- Looking for _fseeki64 - not found
-- Looking for _get_timezone
-- Looking for _get_timezone - not found
-- Looking for _localtime64_s
-- Looking for _localtime64_s - not found
-- Looking for _mkgmtime64
-- Looking for _mkgmtime64 - not found
-- Looking for cygwin_conv_path
-- Looking for cygwin_conv_path - not found
-- Looking for fseeko
-- Looking for fseeko - found
-- Looking for vprintf
-- Looking for vprintf - found
-- Looking for wmemcmp
-- Looking for wmemcmp - found
-- Looking for wmemcpy
-- Looking for wmemcpy - found
-- Performing Test HAVE_READDIR_R
-- Performing Test HAVE_READDIR_R - Success
-- Performing Test HAVE_READLINKAT
-- Performing Test HAVE_READLINKAT - Success
-- Performing Test MAJOR_IN_MKDEV
-- Performing Test MAJOR_IN_MKDEV - Failed
-- Performing Test MAJOR_IN_SYSMACROS
-- Performing Test MAJOR_IN_SYSMACROS - Success
-- Looking for EFTYPE
-- Looking for EFTYPE - not found
-- Looking for EILSEQ
-- Looking for EILSEQ - found
-- Looking for D_MD_ORDER
-- Looking for D_MD_ORDER - not found
-- Looking for INT64_MAX
-- Looking for INT64_MAX - found
-- Looking for INT64_MIN
-- Looking for INT64_MIN - found
-- Looking for UINT32_MAX
-- Looking for UINT32_MAX - found
-- Looking for UINT64_MAX
-- Looking for UINT64_MAX - found
-- Looking for SIZE_MAX
-- Looking for SIZE_MAX - found
-- Looking for SSIZE_MAX
-- Looking for SSIZE_MAX - found
-- Performing Test HAVE_STRUCT_TM_TM_GMTOFF
-- Performing Test HAVE_STRUCT_TM_TM_GMTOFF - Success
-- Performing Test HAVE_STRUCT_TM___TM_GMTOFF
-- Performing Test HAVE_STRUCT_TM___TM_GMTOFF - Failed
-- Performing Test HAVE_STRUCT_STATFS_F_NAMEMAX
-- Performing Test HAVE_STRUCT_STATFS_F_NAMEMAX - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIME
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIME - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIMESPEC_TV_NSEC
-- Performing Test HAVE_STRUCT_STAT_ST_BIRTHTIMESPEC_TV_NSEC - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_MTIMESPEC_TV_NSEC
-- Performing Test HAVE_STRUCT_STAT_ST_MTIMESPEC_TV_NSEC - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_MTIM_TV_NSEC
-- Performing Test HAVE_STRUCT_STAT_ST_MTIM_TV_NSEC - Success
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_N
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_N - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_UMTIME
-- Performing Test HAVE_STRUCT_STAT_ST_UMTIME - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_USEC
-- Performing Test HAVE_STRUCT_STAT_ST_MTIME_USEC - Failed
-- Performing Test HAVE_STRUCT_STAT_ST_BLKSIZE
-- Performing Test HAVE_STRUCT_STAT_ST_BLKSIZE - Success
-- Performing Test HAVE_STRUCT_STAT_ST_FLAGS
-- Performing Test HAVE_STRUCT_STAT_ST_FLAGS - Failed
-- Performing Test HAVE_STRUCT_STATVFS_F_IOSIZE
-- Performing Test HAVE_STRUCT_STATVFS_F_IOSIZE - Failed
-- Check size of short
-- Check size of short - done
-- Check size of int
-- Check size of int - done
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Check size of unsigned - done
-- Check size of unsigned long
-- Check size of unsigned long - done
-- Check size of unsigned long long
-- Check size of unsigned long long - done
-- Check size of unsigned __int64
-- Check size of unsigned __int64 - failed
-- Check size of int16_t
-- Check size of int16_t - done
-- Check size of int32_t
-- Check size of int32_t - done
-- Check size of int64_t
-- Check size of int64_t - done
-- Check size of intmax_t
-- Check size of intmax_t - done
-- Check size of uint8_t
-- Check size of uint8_t - done
-- Check size of uint16_t
-- Check size of uint16_t - done
-- Check size of uint32_t
-- Check size of uint32_t - done
-- Check size of uint64_t
-- Check size of uint64_t - done
-- Check size of uintmax_t
-- Check size of uintmax_t - done
-- Check size of dev_t
-- Check size of dev_t - done
-- Check size of gid_t
-- Check size of gid_t - done
-- Check size of id_t
-- Check size of id_t - done
-- Check size of mode_t
-- Check size of mode_t - done
-- Check size of off_t
-- Check size of off_t - done
-- Check size of uid_t
-- Check size of uid_t - done
-- Check size of pid_t
-- Check size of pid_t - done
-- Check size of intptr_t
-- Check size of intptr_t - done
-- Check size of uintptr_t
-- Check size of uintptr_t - done
-- Check size of wchar_t
-- Check size of wchar_t - done
-- Checking _FILE_OFFSET_BITS for large files
-- Checking _FILE_OFFSET_BITS for large files - not needed
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBC
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBC
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC2
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC2 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC2
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC2 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC2
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC2 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC3
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBC3 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC3
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBC3 -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC3
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBC3 -- not found
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA384_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBSYSTEM
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBSYSTEM -- not found
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBMD
-- Checking support for ARCHIVE_CRYPTO_MD5_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBMD
-- Checking support for ARCHIVE_CRYPTO_RMD160_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBMD
-- Checking support for ARCHIVE_CRYPTO_SHA1_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBMD
-- Checking support for ARCHIVE_CRYPTO_SHA256_LIBMD -- not found
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBMD
-- Checking support for ARCHIVE_CRYPTO_SHA512_LIBMD -- not found
-- Check if the system is big endian
-- Searching 16 bit integer
-- Using unsigned short
-- Check if the system is big endian - big endian
-- Looking for wsyncup in /usr/lib64/libcurses.so
-- Looking for wsyncup in /usr/lib64/libcurses.so - found
-- Looking for elf.h
-- Looking for elf.h - found
-- Looking for a Fortran compiler
-- Looking for a Fortran compiler - /usr/bin/f95
-- Could NOT find Qt4 (missing:  QT_QMAKE_EXECUTABLE QT_MOC_EXECUTABLE QT_RCC_EXECUTABLE QT_UIC_EXECUTABLE QT_INCLUDE_DIR QT_LIBRARY_DIR QT_QTCORE_LIBRARY)
-- Performing Test run_pic_test
-- Performing Test run_pic_test - Success
-- Configuring done
-- Generating done
-- Build files have been written to: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2
CMake has bootstrapped.  Now run gmake.
                        Compiling CMake; this may take several minutes
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2 && /usr/bin/gmake -j 32 && /usr/bin/gmake install && /usr/bin/gmake clean
stdout:
Scanning dependencies of target foo
[  0%] Building CXX object Tests/FindPackageModeMakefileTest/CMakeFiles/foo.dir/foo.cpp.o
Scanning dependencies of target cmsys_c
Linking CXX static library libfoo.a
Scanning dependencies of target cmexpat
[  1%] [  1%] [  1%] Scanning dependencies of target memcheck_fail
Scanning dependencies of target cmcompress
Scanning dependencies of target pseudo_valgrind
[  1%] [  1%] [  1%] Scanning dependencies of target pseudo_purify
Scanning dependencies of target pseudo_BC
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/MD5.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/ProcessUNIX.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/Base64.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/System.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/String.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/Terminal.c.o
Scanning dependencies of target cmbzip2
[  3%] [  3%] [  3%] [  3%] [  3%] [  3%] [  3%] [  3%] Building C object Utilities/cmcompress/CMakeFiles/cmcompress.dir/cmcompress.c.o
Building C object Tests/CTestTestMemcheck/CMakeFiles/pseudo_valgrind.dir/ret0.c.o
Building C object Utilities/cmexpat/CMakeFiles/cmexpat.dir/xmlparse.c.o
Scanning dependencies of target cmIML_test
Building C object Tests/CTestTestMemcheck/CMakeFiles/memcheck_fail.dir/ret1.c.o
Building C object Utilities/cmexpat/CMakeFiles/cmexpat.dir/xmltok.c.o
Scanning dependencies of target cmzlib
Building C object Tests/CTestTestMemcheck/CMakeFiles/pseudo_BC.dir/ret0.c.o
Building C object Utilities/cmexpat/CMakeFiles/cmexpat.dir/xmlrole.c.o
[  3%] Building C object Tests/CTestTestMemcheck/CMakeFiles/pseudo_purify.dir/ret0.c.o
[  3%] [  3%] [  4%] [  4%] [  4%] Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/huffman.c.o
Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/crctable.c.o
Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/compress.c.o
[  4%] Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/blocksort.c.o
Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/randtable.c.o
Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/decompress.c.o
[  4%] [  4%] [  4%] [  5%] Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/bzlib.c.o
[  5%] [  5%] [  5%] Building C object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_ABI_C.c.o
Building C object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test.c.o
Building CXX object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_ABI_CXX.cxx.o
Building C object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_include_C.c.o
[  5%] [  5%] Building CXX object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_INT_CXX.cxx.o
Building C object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_INT_C.c.o
Building CXX object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_include_CXX.cxx.o
Built target foo
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/adler32.c.o
[  6%] Scanning dependencies of target cmForm
[  6%] Linking C executable valgrind
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/compress.c.o
[  6%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/crc32.c.o
Linking C executable purify
Linking C executable memcheck_fail
Linking C executable BC
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/deflate.c.o
[  6%] [  6%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/ProcessUNIX.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_arg.c.o
[  6%] [  7%] [  7%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_attr.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_current.c.o
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/gzio.c.o
[  7%] [  7%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/Base64.c.o
[  7%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_def.c.o
[  7%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/MD5.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_dup.c.o
Linking C static library libcmcompress.a
[  8%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/inffast.c.o
[  9%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/Terminal.c.o
[  9%] [  9%] [  9%] [  9%] Built target pseudo_purify
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_ftchoice.c.o
[ 10%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/inflate.c.o
Built target pseudo_BC
[ 10%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_ftlink.c.o
Building C object Source/kwsys/CMakeFiles/cmsys.dir/System.c.o
[ 10%] [ 10%] [ 10%] [ 10%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/String.c.o
[ 11%] Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/Directory.cxx.o
[ 11%] Built target pseudo_valgrind
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/DynamicLoader.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/Glob.cxx.o
[ 11%] Built target memcheck_fail
[ 11%] [ 11%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_info.c.o
[ 11%] [ 11%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/inftrees.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/RegularExpression.cxx.o
Built target cmcompress
[ 11%] [ 11%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_just.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_link.c.o
[ 12%] [ 12%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/trees.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/SystemTools.cxx.o
[ 12%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/uncompr.c.o
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/zutil.c.o
[ 12%] [ 14%] [ 14%] [ 14%] [ 14%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_max.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/CommandLineArguments.cxx.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_move.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/Registry.cxx.o
[ 14%] Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/IOStream.cxx.o
[ 14%] [ 14%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_newftyp.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/SystemInformation.cxx.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_opts.c.o
[ 14%] Linking CXX executable cmIML_test
[ 15%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_pad.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_page.c.o
[ 15%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_stat.c.o
[ 15%] [ 15%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_type.c.o
[ 16%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_cursor.c.o
[ 16%] [ 16%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_data.c.o
[ 16%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_def.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_driver.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_hook.c.o
[ 17%] [ 17%] [ 17%] [ 17%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_opts.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_user.c.o
[ 17%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_page.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_post.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_req_name.c.o
Linking C static library libcmsys_c.a
[ 17%] [ 18%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_sub.c.o
[ 18%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_scale.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_user.c.o
[ 18%] [ 18%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_alnum.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_win.c.o
[ 19%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_alpha.c.o
[ 19%] [ 19%] [ 19%] [ 19%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_enum.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_int.c.o
[ 20%] [ 20%] Built target cmsys_c
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_ipv4.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_num.c.o
[ 20%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_regex.c.o
Built target cmIML_test
Scanning dependencies of target cmsysTestProcess
Scanning dependencies of target cmsysTestSharedForward
Scanning dependencies of target cmsysTestsC
[ 20%] [ 21%] Building C object Source/kwsys/CMakeFiles/cmsysTestSharedForward.dir/testSharedForward.c.o
[ 21%] Building C object Source/kwsys/CMakeFiles/cmsysTestProcess.dir/testProcess.c.o
[ 21%] Building C object Source/kwsys/CMakeFiles/cmsysTestsC.dir/cmsysTestsC.c.o
Building C object Source/kwsys/CMakeFiles/cmsysTestsC.dir/testEncode.c.o
[ 22%] Building C object Source/kwsys/CMakeFiles/cmsysTestsC.dir/testTerminal.c.o
Linking C static library libcmzlib.a
Linking C static library libcmbzip2.a
Linking C executable cmsysTestsC
[ 22%] [ 22%] Built target cmbzip2
Built target cmzlib
Linking C executable cmsysTestSharedForward
Linking C executable cmsysTestProcess
Linking C static library libcmForm.a
[ 22%] Built target cmsysTestsC
[ 22%] Built target cmsysTestSharedForward
[ 22%] Built target cmsysTestProcess
[ 22%] Built target cmForm
Scanning dependencies of target cmlibarchive
Scanning dependencies of target cmcurl
[ 22%] [ 22%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/base64.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/connect.c.o
Linking C static library libcmexpat.a
[ 22%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/content_encoding.c.o
[ 23%] [ 23%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/dict.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/getinfo.c.o
[ 23%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/easy.c.o
[ 23%] [ 23%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_acl.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostares.c.o
[ 23%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/ftp.c.o
[ 23%] [ 23%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_crypto.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/cookie.c.o
[ 25%] [ 25%] [ 25%] [ 25%] [ 26%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/getenv.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_link_resolver.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hash.c.o
[ 26%] [ 26%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_sparse.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostip.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostip6.c.o
[ 27%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/escape.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_check_magic.c.o
[ 27%] [ 27%] [ 27%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/gtls.c.o
[ 29%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/file.c.o
[ 29%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_copy_stat.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/formdata.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_stat.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_strmode.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_ppmd7.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostip4.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_xattr.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_rb.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostasyn.c.o
[ 29%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_options.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostsyn.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostthre.c.o
[ 29%] [ 29%] [ 29%] [ 31%] [ 31%] [ 31%] [ 31%] Built target cmexpat
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http_chunks.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http_negotiate.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_disk_entry_from_file.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_data_into_fd.c.o
[ 31%] [ 32%] [ 32%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http_digest.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http_ntlm.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/if2ip.c.o
[ 32%] [ 32%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/inet_ntop.c.o
[ 33%] [ 33%] [ 33%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_disk_posix.c.o
[ 34%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_extract.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_disk_set_standard_lookup.c.o
[ 34%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/inet_pton.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/krb4.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/ldap.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_open_fd.c.o
[ 34%] [ 34%] [ 35%] [ 35%] [ 35%] [ 35%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/llist.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_open_filename.c.o
[ 35%] [ 35%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/md5.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_set_options.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_all.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_bzip2.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_open_memory.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_open_file.c.o
[ 36%] [ 36%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/mprintf.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/multi.c.o
[ 36%] [ 36%] [ 36%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/parsedate.c.o
[ 37%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/netrc.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_compress.c.o
[ 37%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_gzip.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_none.c.o
[ 37%] [ 37%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_program.c.o
[ 37%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/progress.c.o
[ 38%] [ 38%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_rpm.c.o
[ 38%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_uu.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/security.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_xz.c.o
[ 39%] [ 39%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/select.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/sendf.c.o
[ 39%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_7zip.c.o
[ 39%] [ 39%] [ 39%] [ 40%] [ 40%] [ 40%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/share.c.o
[ 40%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/socks.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/speedcheck.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_all.c.o
[ 40%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/splay.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_ar.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/sslgen.c.o
[ 41%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/ssh.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_by_code.c.o
[ 42%] [ 42%] [ 42%] [ 42%] [ 42%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_cab.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/ssluse.c.o
[ 43%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/strdup.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_cpio.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_empty.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_iso9660.c.o
[ 43%] [ 43%] [ 43%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_lha.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/strerror.c.o
[ 43%] [ 43%] [ 44%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/strequal.c.o
[ 44%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_mtree.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_rar.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/tftp.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/telnet.c.o
[ 44%] [ 45%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/timeval.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_raw.c.o
[ 45%] [ 45%] [ 46%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/url.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/transfer.c.o
[ 46%] [ 46%] [ 46%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/version.c.o
[ 46%] Linking CXX static library libcmsys.a
[ 47%] [ 47%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_tar.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_xar.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_zip.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_string.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_util.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_string_sprintf.c.o
[ 47%] [ 48%] [ 48%] [ 48%] [ 48%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_virtual.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_disk_set_standard_lookup.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_disk_posix.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_open_fd.c.o
[ 48%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_open_file.c.o
[ 49%] [ 49%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_open_filename.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_open_memory.c.o
[ 49%] [ 49%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_bzip2.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_compress.c.o
[ 49%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_gzip.c.o
[ 49%] [ 50%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_program.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_none.c.o
[ 50%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_xz.c.o
[ 50%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format.c.o
[ 51%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_7zip.c.o
[ 51%] [ 51%] [ 51%] [ 51%] [ 52%] [ 52%] [ 52%] [ 52%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_by_name.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_ar.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_cpio.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_pax.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_mtree.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_gnutar.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_iso9660.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_cpio_newc.c.o
[ 53%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_shar.c.o
[ 53%] [ 53%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_ustar.c.o
[ 53%] Built target cmsys
[ 53%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_xar.c.o
[ 53%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_zip.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/filter_fork.c.o
[ 54%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_options.c.o
Scanning dependencies of target cmsysTestDynload
[ 54%] Building C object Source/kwsys/CMakeFiles/cmsysTestDynload.dir/testDynload.c.o
Scanning dependencies of target cmsysTestsCxx
[ 54%] [ 54%] Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/cmsysTestsCxx.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testAutoPtr.cxx.o
Linking C shared module libcmsysTestDynload.so
[ 54%] [ 56%] [ 55%] [ 56%] [ 56%] [ 56%] [ 56%] [ 56%] Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testSystemTools.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testCommandLineArguments.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testHashSTL.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testIOS.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testRegistry.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testCommandLineArguments1.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testSystemInformation.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testDynamicLoader.cxx.o
[ 56%] Built target cmsysTestDynload
Linking C static library libcmcurl.a
[ 56%] Built target cmcurl
Scanning dependencies of target LIBCURL
[ 56%] Building C object Utilities/cmcurl/CMakeFiles/LIBCURL.dir/Testing/curltest.c.o
Linking C executable LIBCURL
[ 56%] Built target LIBCURL
Linking C static library libcmlibarchive.a
[ 56%] Built target cmlibarchive
Linking CXX executable cmsysTestsCxx
[ 56%] Built target cmsysTestsCxx
Scanning dependencies of target CMakeLib
[ 56%] [ 56%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmArchiveWrite.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmStandardIncludes.cxx.o
[ 56%] [ 57%] [ 57%] [ 57%] [ 57%] [ 57%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmBootstrapCommands.cxx.o
[ 57%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCommands.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCacheManager.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCommandArgumentLexer.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCommandArgumentParser.cxx.o
[ 58%] [ 58%] [ 59%] [ 60%] [ 58%] [ 60%] [ 60%] [ 60%] [ 60%] [ 60%] [ 60%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmComputeLinkDepends.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmComputeTargetDepends.cxx.o
[ 60%] [ 60%] [ 61%] [ 61%] [ 61%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCryptoHash.cxx.o
[ 62%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmComputeComponentGraph.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCustomCommandGenerator.cxx.o
[ 62%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCommandArgumentParserHelper.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCustomCommand.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDefinitions.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmComputeLinkInformation.cxx.o
[ 62%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsC.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsFortranParser.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsFortran.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsFortranLexer.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsJava.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDepends.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatter.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsJavaParser.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsJavaParserHelper.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsJavaLexer.cxx.o
[ 63%] [ 63%] [ 63%] [ 63%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterHTML.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentation.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterUsage.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterDocbook.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterMan.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterText.cxx.o
[ 63%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationSection.cxx.o
[ 63%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentVariables.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDynamicLoader.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmELF.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExprLexer.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExprParser.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExprParserHelper.cxx.o
[ 65%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportBuildFileGenerator.cxx.o
[ 65%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportFileGenerator.cxx.o
[ 65%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportInstallFileGenerator.cxx.o
[ 65%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportSet.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportSetMap.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExtraCodeBlocksGenerator.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExtraEclipseCDT4Generator.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmFileTimeComparison.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratedFileStream.cxx.o
[ 67%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpressionDAGChecker.cxx.o
[ 67%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpressionEvaluator.cxx.o
[ 67%] [ 67%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpressionLexer.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpressionParser.cxx.o
[ 68%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpression.cxx.o
[ 68%] [ 68%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorTarget.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGlobalGenerator.cxx.o
[ 68%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGlobalUnixMakefileGenerator3.cxx.o
[ 69%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGraphVizWriter.cxx.o
[ 69%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallGenerator.cxx.o
[ 69%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallExportGenerator.cxx.o
[ 69%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallFilesGenerator.cxx.o
[ 69%] [ 70%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallScriptGenerator.cxx.o
[ 70%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallDirectoryGenerator.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallTargetGenerator.cxx.o
[ 70%] [ 70%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmListFileCache.cxx.o
Building C object Source/CMakeFiles/CMakeLib.dir/cmListFileLexer.c.o
[ 70%] [ 71%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmLocalGenerator.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmLocalUnixMakefileGenerator3.cxx.o
[ 71%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakeDepend.cxx.o
[ 71%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefile.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefileTargetGenerator.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefileExecutableTargetGenerator.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefileLibraryTargetGenerator.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefileUtilityTargetGenerator.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmOSXBundleGenerator.cxx.o
[ 73%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmNewLineStyle.cxx.o
[ 73%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmOrderDirectories.cxx.o
[ 73%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmPolicies.cxx.o
[ 73%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmProcessTools.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmProperty.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmPropertyDefinition.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmPropertyDefinitionMap.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmPropertyMap.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmQtAutomoc.cxx.o
[ 75%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmScriptGenerator.cxx.o
[ 75%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmSourceFile.cxx.o
[ 75%] [ 75%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmSourceFileLocation.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmSourceGroup.cxx.o
[ 76%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmSystemTools.cxx.o
[ 76%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmTarget.cxx.o
[ 76%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmTest.cxx.o
[ 76%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmTestGenerator.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmVariableWatch.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmVersion.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmXMLParser.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmXMLSafe.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmake.cxx.o
[ 78%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmakewizard.cxx.o
[ 78%] Building C object Source/CMakeFiles/CMakeLib.dir/cm_sha2.c.o
[ 78%] Building C object Source/CMakeFiles/CMakeLib.dir/cm_utf8.c.o
[ 78%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGlobalKdevelopGenerator.cxx.o
[ 79%] [ 79%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGlobalNinjaGenerator.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmLocalNinjaGenerator.cxx.o
[ 79%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmNinjaTargetGenerator.cxx.o
[ 79%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmNinjaNormalTargetGenerator.cxx.o
[ 80%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmNinjaUtilityTargetGenerator.cxx.o
Linking CXX static library libCMakeLib.a
[ 80%] Built target CMakeLib
Scanning dependencies of target runcompilecommands
Scanning dependencies of target CMakeLibTests
Scanning dependencies of target cmake
[ 80%] [ 81%] [ 81%] [ 82%] [ 82%] [ 83%] [ 83%] Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/CMakeLibTests.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/runcompilecommands.dir/run_compile_commands.cxx.o
[ 83%] Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testSystemTools.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testGeneratedFileStream.cxx.o
Building CXX object Source/CMakeFiles/cmake.dir/cmakemain.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testXMLParser.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testXMLSafe.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testUTF8.cxx.o
Scanning dependencies of target ccmake
Scanning dependencies of target CPackLib
[ 83%] [ 83%] [ 83%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesFilePathWidget.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesBoolWidget.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesForm.cxx.o
[ 84%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesCacheEntryComposite.cxx.o
[ 84%] [ 84%] [ 84%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesLongMessageForm.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackLog.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/ccmake.cxx.o
[ 84%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesDummyWidget.cxx.o
[ 84%] Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackComponentGroup.cxx.o
[ 85%] [ 85%] [ 85%] Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackTarBZip2Generator.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesStringWidget.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesMainForm.cxx.o
[ 87%] [ 87%] [ 87%] [ 87%] [ 88%] [ 88%] [ 88%] [ 89%] [ 89%] [ 85%] [ 87%] [ 88%] [ 87%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesWidget.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackGeneratorFactory.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackNSISGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackTarCompressGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackDocumentMacros.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackArchiveGenerator.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesLabelWidget.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackTGZGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackZIPGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackSTGZGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackDocumentVariables.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesPathWidget.cxx.o
Scanning dependencies of target CTestLib
[ 90%] Building CXX object Source/CMakeFiles/CTestLib.dir/cmCTest.cxx.o
[ 90%] Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackDebGenerator.cxx.o
[ 90%] Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackRPMGenerator.cxx.o
[ 90%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmProcess.cxx.o
[ 90%] [ 90%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBatchTestHandler.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBuildAndTestHandler.cxx.o
[ 90%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBuildCommand.cxx.o
[ 91%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBuildHandler.cxx.o
[ 91%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestConfigureCommand.cxx.o
[ 91%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestConfigureHandler.cxx.o
[ 91%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestCoverageCommand.cxx.o
Linking CXX executable CMakeLibTests
[ 92%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestCoverageHandler.cxx.o
[ 92%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmParseMumpsCoverage.cxx.o
[ 92%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmParseCacheCoverage.cxx.o
[ 92%] [ 93%] [ 93%] [ 93%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmParseGTMCoverage.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestEmptyBinaryDirectoryCommand.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmParsePHPCoverage.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestHandlerCommand.cxx.o
[ 93%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestGenericHandler.cxx.o
[ 94%] [ 94%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestLaunch.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestMemCheckCommand.cxx.o
[ 94%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestMemCheckHandler.cxx.o
[ 94%] Built target CMakeLibTests
[ 94%] [ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestReadCustomFilesCommand.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestRunScriptCommand.cxx.o
Linking CXX executable runcompilecommands
[ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestRunTest.cxx.o
[ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestMultiProcessHandler.cxx.o
[ 95%] Built target runcompilecommands
[ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestScriptHandler.cxx.o
[ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestSleepCommand.cxx.o
[ 96%] [ 96%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestStartCommand.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestSubmitCommand.cxx.o
[ 96%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestSubmitHandler.cxx.o
[ 96%] [ 96%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestTestCommand.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestTestHandler.cxx.o
Linking CXX executable ../bin/cmake
Linking CXX executable ../bin/ccmake
[ 97%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestUpdateCommand.cxx.o
[ 97%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestUpdateHandler.cxx.o
[ 97%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestUploadCommand.cxx.o
[ 97%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestUploadHandler.cxx.o
[ 98%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestVC.cxx.o
[ 98%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestGlobalVC.cxx.o
[ 98%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestCVS.cxx.o
[ 98%] [ 98%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestSVN.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBZR.cxx.o
[ 99%] [ 99%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestHG.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestGIT.cxx.o
Linking CXX static library libCPackLib.a
[ 99%] Built target CPackLib
Scanning dependencies of target cpack
[ 99%] Building CXX object Source/CMakeFiles/cpack.dir/CPack/cpack.cxx.o
[ 99%] Built target cmake
[ 99%] Built target ccmake
Linking CXX static library libCTestLib.a
Linking CXX executable ../bin/cpack
[ 99%] Built target CTestLib
Scanning dependencies of target ctest
[ 99%] Building CXX object Source/CMakeFiles/ctest.dir/ctest.cxx.o
Linking CXX executable ../bin/ctest
[ 99%] Built target cpack
[ 99%] Built target ctest
Scanning dependencies of target documentation
[ 99%] [ 99%] [ 99%] [100%] Generating ../Docs/ccmake.txt
Generating ../Docs/ctest.txt
Generating ../Docs/cmake.txt
Generating ../Docs/cpack.txt
[100%] Built target documentation
[  1%] Built target cmIML_test
[  4%] Built target cmsys
[  4%] Built target cmsysTestDynload
[  5%] Built target cmsys_c
[  6%] Built target cmsysTestProcess
[  6%] Built target cmsysTestSharedForward
[  7%] Built target cmsysTestsC
[  9%] Built target cmsysTestsCxx
[ 12%] Built target cmzlib
[ 25%] Built target cmcurl
[ 25%] Built target LIBCURL
[ 26%] Built target cmcompress
[ 27%] Built target cmbzip2
[ 46%] Built target cmlibarchive
[ 46%] Built target cmexpat
[ 55%] Built target cmForm
[ 79%] Built target CMakeLib
[ 82%] Built target CPackLib
[ 92%] Built target CTestLib
[ 95%] Built target ccmake
[ 96%] Built target cmake
[ 96%] Built target cpack
[ 96%] Built target ctest
[ 97%] Built target documentation
[ 98%] Built target CMakeLibTests
[ 99%] Built target runcompilecommands
[ 99%] Built target foo
[100%] Built target memcheck_fail
[100%] Built target pseudo_BC
[100%] Built target pseudo_purify
[100%] Built target pseudo_valgrind
Install the project...
-- Install configuration: ""
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/Copyright.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/AddFileDependencies.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/BasicConfigVersion-ExactVersion.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/BasicConfigVersion-SameMajorVersion.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/BundleUtilities.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCCompilerFlag.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCXXSourceCompiles.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCXXSymbolExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckFunctionExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFile.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFile.cxx.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFiles.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckLanguage.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckLibraryExists.lists.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckPrototypeDefinition.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckSizeOf.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckTypeSize.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckTypeSize.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckTypeSizeMap.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddFortranSubdirectory
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddFortranSubdirectory/build_mingw.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddFortranSubdirectory/config_mingw.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddFortranSubdirectory.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddNewLanguage.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASMCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeBackwardCompatibilityCXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeBorlandFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeBuildSettings.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCCompilerABI.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCCompilerId.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCommonLanguageInclude.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeConfigurableFile.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCXXCompilerId.cpp.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCXXInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineASM-ATTCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineASM_MASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineASM_NASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCompilerABI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCompilerId.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineFortranCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineJavaCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineVSServicePack.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeExtraGeneratorDetermineCompilerMacrosAndIncludeDirs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindKDevelop3.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindWMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindXCode.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeForceCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFortranCompilerId.F.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFortranInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeNMakeFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakePlatformId.h.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakePrintSystemInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakePushCheckState.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeRCInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeSystem.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeSystemSpecificInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestASM_MASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestASM_NASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestFortranCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestWatcomVersion.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeUnixFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS6BackwardCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS6FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS7BackwardCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS8FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.Description.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.DS_Store.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.OSXScriptLauncher.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.OSXScriptLauncher.rsrc.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.RuntimeScript.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackBundle.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackComponent.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackDMG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackRPM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackZIP.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CTestScriptMode.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CTestTargets.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CTestUseLaunchers.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Dart.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/DeployQt4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/exportheader.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/ExternalProject.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindArmadillo.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindASPELL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBISON.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBLAS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBoost.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBZip2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCABLE.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCoin3D.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCUDA.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCups.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCURL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCxxTest.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindDart.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindFLEX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGit.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGLU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGLUT.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGTK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGTK2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindHDF5.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindHTMLHelp.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindImageMagick.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindITK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindJasper.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindJava.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindJNI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindJPEG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindKDE3.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLibArchive.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLibXml2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLibXslt.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMFC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMotif.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMPEG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMPEG2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenMP.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenSceneGraph.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgDB.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgIntrospection.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseVTKBuildSettings40.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseVTKConfig40.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/VTKCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/WriteBasicConfigVersionFile.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgQt.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgShadow.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgSim.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgTerrain.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseJavaSymlinks.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgViewer.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgVolume.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseJavaClassFilelist.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPackageMessage.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPerl.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPHP4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPhysFS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPike.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPkgConfig.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPNG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPostgreSQL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForSTDNamespace.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForSTDNamespace.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Use_wxWindows.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UsewxWidgets.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindQt.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForANSIStreamHeaders.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindQuickTime.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestCXXAcceptsFlag.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SystemInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForSSTREAM.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_sound.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_ttf.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSelfPackers.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSquish.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/RepositoryInfo.txt.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestEndianess.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindTCL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindTclsh.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindTclStub.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/readme.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindTIFF.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Qt4ConfigDependentSettings.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindVTK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindWget.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/MacroAddFileDependencies.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/NSIS.InstallOptions.ini.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindXMLRPC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindZLIB.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/IntelVSImplicitPath
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/IntelVSImplicitPath/CMakeLists.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/IntelVSImplicitPath/detect.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/IntelVSImplicitPath/hello.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/KDE3Macros.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-VisualAge-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-VisualAge-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-VisualAge-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BeOS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-base.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BSDOS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Catamount.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-windres.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-Absoft-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-Clang-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-Clang-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-Clang.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-icc.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-icpc.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-NAG-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-VisualAge-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-VisualAge-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/DragonFly.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/eCos.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/FreeBSD.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/gas.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-ADSP-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-ADSP-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-ADSP-Common.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-ADSP-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-SDCC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/GNUtoMS_lib.bat.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/GNUtoMS_lib.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Haiku.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/IRIX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/IRIX64.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/kFreeBSD.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Absoft-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Clang-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-como.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Clang-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Intel-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Intel-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Intel-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Intel.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-NAG-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PathScale-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PathScale-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PathScale-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PathScale.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PGI-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PGI-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PGI-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PGI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-SunPro-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-TinyCC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-VisualAge-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-VisualAge-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-VisualAge-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/MP-RAS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/NetBSD.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/OpenBSD.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/OpenVMS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/OSF1.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/QNX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/RISCos.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SCO_SV.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SINIX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/syllable.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Tru64.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/ULTRIX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/UNIX_SV.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/UnixPaths.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/UnixWare.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Borland-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Borland-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-df.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Embarcadero-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Embarcadero-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Embarcadero.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-G95-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-C-ABI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-CXX-ABI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-Fortran-ABI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-MSVC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-MSVC-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-MSVC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-NMcl.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-wcl386.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-windres.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsCE-MSVC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsCE-MSVC-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsCE-MSVC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsCE.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsPaths.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Xenix.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/InstallRequiredSystemLibraries.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/GetPrerequisites.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/AutomocInfo.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/BasicConfigVersion-AnyNewerVersion.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCSourceCompiles.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCSourceRuns.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCXXCompilerFlag.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCXXSourceRuns.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckForPthreads.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckFortranFunctionExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFile.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFileCXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckLibraryExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckPrototypeDefinition.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckStructHasMember.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckSymbolExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckVariableExists.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckVariableExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASM-ATTInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASM_MASMInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASM_NASMInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASMInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeBackwardCompatibilityC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeClDeps.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCompilerABI.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCXXCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCXXCompilerABI.cpp
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDependentOption.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestGNU.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCXXCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineRCCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineSystem.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeExpandImportedTargets.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeExportBuildSettings.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindBinUtils.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindCodeBlocks.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindEclipseCDT4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindFrameworks.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindPackageMode.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFortranCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFortranCompilerABI.F
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeGenericSystem.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeImportBuildSettings.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeJavaCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeJavaInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeJOMFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeMinGWFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeMSYSFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeNinjaFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakePackageConfigHelpers.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeParseArguments.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeParseImplicitLinkInfo.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeRCCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestASM-ATTCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestCompilerCommon.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestCXXCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestJavaCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestRCCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVerifyManifest.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS10FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS11FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS71FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS7FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Absoft-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Clang-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Clang-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Clang-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Clang.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Cray-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Cray-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Cray-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/G95-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/HP-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/HP-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/HP-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/HP-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Intel-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Intel-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Intel-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Intel-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/MIPSpro-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/MIPSpro-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/MIPSpro-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/NAG-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PathScale-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PathScale-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PathScale-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PathScale.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PGI-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PGI-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PGI-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PGI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SCO-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SCO-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SCO.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SunPro-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SunPro-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SunPro-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SunPro-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/TinyCC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/VisualAge-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/VisualAge-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/VisualAge-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS9FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/VS-10.vcxproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/VS-6.dsp.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/VS-7.vcproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/Xcode-1.pbxproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/Xcode-2.pbxproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/Xcode-3.pbxproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.background.png.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.distribution.dist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.Info.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.OSXX11.Info.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.OSXX11.main.scpt.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.STGZ_Header.sh.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.VolumeIcon.icns.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackCygwin.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackDeb.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackNSIS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackPackageMaker.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CTest.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/DartConfiguration.tcl.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Documentation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/DummyCXXFile.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/ecos_clean.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FeatureSummary.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindALSA.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindAVIFile.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBullet.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCUDA/make2cmake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCUDA/parse_cubin.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCUDA/run_nvcc.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCurses.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCVS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCygwin.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindDCMTK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindDevIL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindDoxygen.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindEXPAT.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindFLTK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindFLTK2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindFreetype.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGCCXML.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGDAL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGettext.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGIF.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGLEW.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGnuplot.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGnuTLS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGTest.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindHg.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindHSPELL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindKDE4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLAPACK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLATEX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLibLZMA.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLua50.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLua51.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMatlab.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMPI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenAL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenGL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForSSTREAM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenSSL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenThreads.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Findosg.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Findosg_functions.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgAnimation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgFX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgGA.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForANSIStreamHeaders.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgManipulator.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgParticle.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgPresentation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgProducer.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForANSIForScope.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForAnsiForScope.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/.NoDartCoverage
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgText.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgUtil.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SystemInformation.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgWidget.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SquishTestScript.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseVTK40.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPerlLibs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SelectLibraryConfigurations.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SquishRunTestCase.bat
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SquishRunTestCase.sh
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseSWIG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindProducer.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindProtobuf.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPythonInterp.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPythonLibs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseQt4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindQt3.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindQt4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UsePkgConfig.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindRTI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindRuby.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseJava.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_image.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_mixer.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_net.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/MacOSXFrameworkInfo.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/ProcessorCount.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseEcos.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSubversion.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSWIG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/MacOSXBundleInfo.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestBigEndian.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindThreads.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Qt4Macros.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindUnixCommands.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/kde3uic.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/NSIS.template.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindWish.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindwxWidgets.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindwxWindows.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindX11.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/kde3init_dummy.cpp.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FLTKCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/call_mod.f90
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/call_sub.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/CMakeLists.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Detect.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Input.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Macro.h.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/main.F
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/my_module.f90
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/my_module_.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/my_sub.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/mymodule.f90
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/mymodule_.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/mysub.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Output.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/symbol.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/CMakeLists.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/main.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/VerifyC.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/VerifyCXX.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/VerifyFortran.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/ITKCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/GenerateExportHeader.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/GNUInstallDirs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/AppleInfo.plist
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CMakeVisualStudio6Configurations.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CMakeVSMacros1.vsmacros
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CMakeVSMacros2.vsmacros
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CPack.GenericDescription.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CPack.GenericLicense.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CPack.GenericWelcome.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CPackConfig.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CTestScript.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/cygwin-package.sh.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/DLLFooter.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/DLLHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/EXEFooter.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/EXEHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/EXEWinHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/staticLibFooter.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/staticLibHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/TestDriver.cxx.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/UtilityFooter.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/UtilityHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmsys/Copyright.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmzlib/Copyright.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmcurl/COPYING
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmcompress/Copyright.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmlibarchive/COPYING
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmexpat/COPYING
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/include/cmCPluginAPI.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/ccmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cpack
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/ctest
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmake.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakecommands.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakecompat.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakeprops.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakepolicies.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakevars.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakemodules.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/ctest.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cpack.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/ccmake.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-policies.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-properties.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-variables.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-modules.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-commands.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-compatcommands.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ctest.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cpack.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ccmake.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-policies.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-properties.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-variables.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-modules.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-commands.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-compatcommands.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ctest.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cpack.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ccmake.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake.docbook
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ctest.docbook
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cpack.docbook
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ccmake.docbook
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/aclocal/cmake.m4
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/editors/vim/cmake-help.vim
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/editors/vim/cmake-indent.vim
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/editors/vim/cmake-syntax.vim
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/editors/emacs/cmake-mode.el
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/completions/cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/completions/cpack
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/completions/ctest
********Output of running make on cmake follows *******
Scanning dependencies of target foo
[  0%] Building CXX object Tests/FindPackageModeMakefileTest/CMakeFiles/foo.dir/foo.cpp.o
Scanning dependencies of target cmsys_c
Linking CXX static library libfoo.a
Scanning dependencies of target cmexpat
[  1%] [  1%] [  1%] Scanning dependencies of target memcheck_fail
Scanning dependencies of target cmcompress
Scanning dependencies of target pseudo_valgrind
[  1%] [  1%] [  1%] Scanning dependencies of target pseudo_purify
Scanning dependencies of target pseudo_BC
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/MD5.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/ProcessUNIX.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/Base64.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/System.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/String.c.o
Building C object Source/kwsys/CMakeFiles/cmsys_c.dir/Terminal.c.o
Scanning dependencies of target cmbzip2
[  3%] [  3%] [  3%] [  3%] [  3%] [  3%] [  3%] [  3%] Building C object Utilities/cmcompress/CMakeFiles/cmcompress.dir/cmcompress.c.o
Building C object Tests/CTestTestMemcheck/CMakeFiles/pseudo_valgrind.dir/ret0.c.o
Building C object Utilities/cmexpat/CMakeFiles/cmexpat.dir/xmlparse.c.o
Scanning dependencies of target cmIML_test
Building C object Tests/CTestTestMemcheck/CMakeFiles/memcheck_fail.dir/ret1.c.o
Building C object Utilities/cmexpat/CMakeFiles/cmexpat.dir/xmltok.c.o
Scanning dependencies of target cmzlib
Building C object Tests/CTestTestMemcheck/CMakeFiles/pseudo_BC.dir/ret0.c.o
Building C object Utilities/cmexpat/CMakeFiles/cmexpat.dir/xmlrole.c.o
[  3%] Building C object Tests/CTestTestMemcheck/CMakeFiles/pseudo_purify.dir/ret0.c.o
[  3%] [  3%] [  4%] [  4%] [  4%] Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/huffman.c.o
Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/crctable.c.o
Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/compress.c.o
[  4%] Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/blocksort.c.o
Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/randtable.c.o
Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/decompress.c.o
[  4%] [  4%] [  4%] [  5%] Building C object Utilities/cmbzip2/CMakeFiles/cmbzip2.dir/bzlib.c.o
[  5%] [  5%] [  5%] Building C object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_ABI_C.c.o
Building C object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test.c.o
Building CXX object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_ABI_CXX.cxx.o
Building C object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_include_C.c.o
[  5%] [  5%] Building CXX object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_INT_CXX.cxx.o
Building C object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_INT_C.c.o
Building CXX object Utilities/KWIML/test/CMakeFiles/cmIML_test.dir/test_include_CXX.cxx.o
Built target foo
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/adler32.c.o
[  6%] Scanning dependencies of target cmForm
[  6%] Linking C executable valgrind
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/compress.c.o
[  6%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/crc32.c.o
Linking C executable purify
Linking C executable memcheck_fail
Linking C executable BC
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/deflate.c.o
[  6%] [  6%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/ProcessUNIX.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_arg.c.o
[  6%] [  7%] [  7%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_attr.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_current.c.o
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/gzio.c.o
[  7%] [  7%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/Base64.c.o
[  7%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_def.c.o
[  7%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/MD5.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_dup.c.o
Linking C static library libcmcompress.a
[  8%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/inffast.c.o
[  9%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/Terminal.c.o
[  9%] [  9%] [  9%] [  9%] Built target pseudo_purify
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_ftchoice.c.o
[ 10%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/inflate.c.o
Built target pseudo_BC
[ 10%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_ftlink.c.o
Building C object Source/kwsys/CMakeFiles/cmsys.dir/System.c.o
[ 10%] [ 10%] [ 10%] [ 10%] Building C object Source/kwsys/CMakeFiles/cmsys.dir/String.c.o
[ 11%] Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/Directory.cxx.o
[ 11%] Built target pseudo_valgrind
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/DynamicLoader.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/Glob.cxx.o
[ 11%] Built target memcheck_fail
[ 11%] [ 11%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_info.c.o
[ 11%] [ 11%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/inftrees.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/RegularExpression.cxx.o
Built target cmcompress
[ 11%] [ 11%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_just.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_link.c.o
[ 12%] [ 12%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/trees.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/SystemTools.cxx.o
[ 12%] Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/uncompr.c.o
Building C object Utilities/cmzlib/CMakeFiles/cmzlib.dir/zutil.c.o
[ 12%] [ 14%] [ 14%] [ 14%] [ 14%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_max.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/CommandLineArguments.cxx.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_move.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/Registry.cxx.o
[ 14%] Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/IOStream.cxx.o
[ 14%] [ 14%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_newftyp.c.o
Building CXX object Source/kwsys/CMakeFiles/cmsys.dir/SystemInformation.cxx.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_opts.c.o
[ 14%] Linking CXX executable cmIML_test
[ 15%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_pad.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_page.c.o
[ 15%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_stat.c.o
[ 15%] [ 15%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_type.c.o
[ 16%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_cursor.c.o
[ 16%] [ 16%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_data.c.o
[ 16%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_def.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_driver.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_hook.c.o
[ 17%] [ 17%] [ 17%] [ 17%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_opts.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fld_user.c.o
[ 17%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_page.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_post.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_req_name.c.o
Linking C static library libcmsys_c.a
[ 17%] [ 18%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_sub.c.o
[ 18%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_scale.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_user.c.o
[ 18%] [ 18%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_alnum.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/frm_win.c.o
[ 19%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_alpha.c.o
[ 19%] [ 19%] [ 19%] [ 19%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_enum.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_int.c.o
[ 20%] [ 20%] Built target cmsys_c
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_ipv4.c.o
Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_num.c.o
[ 20%] Building C object Source/CursesDialog/form/CMakeFiles/cmForm.dir/fty_regex.c.o
Built target cmIML_test
Scanning dependencies of target cmsysTestProcess
Scanning dependencies of target cmsysTestSharedForward
Scanning dependencies of target cmsysTestsC
[ 20%] [ 21%] Building C object Source/kwsys/CMakeFiles/cmsysTestSharedForward.dir/testSharedForward.c.o
[ 21%] Building C object Source/kwsys/CMakeFiles/cmsysTestProcess.dir/testProcess.c.o
[ 21%] Building C object Source/kwsys/CMakeFiles/cmsysTestsC.dir/cmsysTestsC.c.o
Building C object Source/kwsys/CMakeFiles/cmsysTestsC.dir/testEncode.c.o
[ 22%] Building C object Source/kwsys/CMakeFiles/cmsysTestsC.dir/testTerminal.c.o
Linking C static library libcmzlib.a
Linking C static library libcmbzip2.a
Linking C executable cmsysTestsC
[ 22%] [ 22%] Built target cmbzip2
Built target cmzlib
Linking C executable cmsysTestSharedForward
Linking C executable cmsysTestProcess
Linking C static library libcmForm.a
[ 22%] Built target cmsysTestsC
[ 22%] Built target cmsysTestSharedForward
[ 22%] Built target cmsysTestProcess
[ 22%] Built target cmForm
Scanning dependencies of target cmlibarchive
Scanning dependencies of target cmcurl
[ 22%] [ 22%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/base64.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/connect.c.o
Linking C static library libcmexpat.a
[ 22%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/content_encoding.c.o
[ 23%] [ 23%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/dict.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/getinfo.c.o
[ 23%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/easy.c.o
[ 23%] [ 23%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_acl.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostares.c.o
[ 23%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/ftp.c.o
[ 23%] [ 23%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_crypto.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/cookie.c.o
[ 25%] [ 25%] [ 25%] [ 25%] [ 26%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/getenv.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_link_resolver.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hash.c.o
[ 26%] [ 26%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_sparse.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostip.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostip6.c.o
[ 27%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/escape.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_check_magic.c.o
[ 27%] [ 27%] [ 27%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] [ 29%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/gtls.c.o
[ 29%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/file.c.o
[ 29%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_copy_stat.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/formdata.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_stat.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_strmode.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_ppmd7.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostip4.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_entry_xattr.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_rb.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostasyn.c.o
[ 29%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_options.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostsyn.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/hostthre.c.o
[ 29%] [ 29%] [ 29%] [ 31%] [ 31%] [ 31%] [ 31%] Built target cmexpat
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http_chunks.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http_negotiate.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_disk_entry_from_file.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_data_into_fd.c.o
[ 31%] [ 32%] [ 32%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http_digest.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/http_ntlm.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/if2ip.c.o
[ 32%] [ 32%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/inet_ntop.c.o
[ 33%] [ 33%] [ 33%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_disk_posix.c.o
[ 34%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_extract.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_disk_set_standard_lookup.c.o
[ 34%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/inet_pton.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/krb4.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/ldap.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_open_fd.c.o
[ 34%] [ 34%] [ 35%] [ 35%] [ 35%] [ 35%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/llist.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_open_filename.c.o
[ 35%] [ 35%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/md5.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_set_options.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_all.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_bzip2.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_open_memory.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_open_file.c.o
[ 36%] [ 36%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/mprintf.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/multi.c.o
[ 36%] [ 36%] [ 36%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/parsedate.c.o
[ 37%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/netrc.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_compress.c.o
[ 37%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_gzip.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_none.c.o
[ 37%] [ 37%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_program.c.o
[ 37%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/progress.c.o
[ 38%] [ 38%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_rpm.c.o
[ 38%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_uu.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/security.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_filter_xz.c.o
[ 39%] [ 39%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/select.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/sendf.c.o
[ 39%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_7zip.c.o
[ 39%] [ 39%] [ 39%] [ 40%] [ 40%] [ 40%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/share.c.o
[ 40%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/socks.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/speedcheck.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_all.c.o
[ 40%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/splay.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_ar.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/sslgen.c.o
[ 41%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/ssh.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_by_code.c.o
[ 42%] [ 42%] [ 42%] [ 42%] [ 42%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_cab.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/ssluse.c.o
[ 43%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/strdup.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_cpio.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_empty.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_iso9660.c.o
[ 43%] [ 43%] [ 43%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_lha.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/strerror.c.o
[ 43%] [ 43%] [ 44%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/strequal.c.o
[ 44%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_mtree.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_rar.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/tftp.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/telnet.c.o
[ 44%] [ 45%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/timeval.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_raw.c.o
[ 45%] [ 45%] [ 46%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/url.c.o
Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/transfer.c.o
[ 46%] [ 46%] [ 46%] Building C object Utilities/cmcurl/CMakeFiles/cmcurl.dir/version.c.o
[ 46%] Linking CXX static library libcmsys.a
[ 47%] [ 47%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_tar.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_xar.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_read_support_format_zip.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_string.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_util.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_string_sprintf.c.o
[ 47%] [ 48%] [ 48%] [ 48%] [ 48%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_virtual.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_disk_set_standard_lookup.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_disk_posix.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_open_fd.c.o
[ 48%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_open_file.c.o
[ 49%] [ 49%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_open_filename.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_open_memory.c.o
[ 49%] [ 49%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_bzip2.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_compress.c.o
[ 49%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_gzip.c.o
[ 49%] [ 50%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_program.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_none.c.o
[ 50%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_add_filter_xz.c.o
[ 50%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format.c.o
[ 51%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_7zip.c.o
[ 51%] [ 51%] [ 51%] [ 51%] [ 52%] [ 52%] [ 52%] [ 52%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_by_name.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_ar.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_cpio.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_pax.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_mtree.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_gnutar.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_iso9660.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_cpio_newc.c.o
[ 53%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_shar.c.o
[ 53%] [ 53%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_ustar.c.o
[ 53%] Built target cmsys
[ 53%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_xar.c.o
[ 53%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_format_zip.c.o
Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/filter_fork.c.o
[ 54%] Building C object Utilities/cmlibarchive/libarchive/CMakeFiles/cmlibarchive.dir/archive_write_set_options.c.o
Scanning dependencies of target cmsysTestDynload
[ 54%] Building C object Source/kwsys/CMakeFiles/cmsysTestDynload.dir/testDynload.c.o
Scanning dependencies of target cmsysTestsCxx
[ 54%] [ 54%] Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/cmsysTestsCxx.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testAutoPtr.cxx.o
Linking C shared module libcmsysTestDynload.so
[ 54%] [ 56%] [ 55%] [ 56%] [ 56%] [ 56%] [ 56%] [ 56%] Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testSystemTools.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testCommandLineArguments.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testHashSTL.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testIOS.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testRegistry.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testCommandLineArguments1.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testSystemInformation.cxx.o
Building CXX object Source/kwsys/CMakeFiles/cmsysTestsCxx.dir/testDynamicLoader.cxx.o
[ 56%] Built target cmsysTestDynload
Linking C static library libcmcurl.a
[ 56%] Built target cmcurl
Scanning dependencies of target LIBCURL
[ 56%] Building C object Utilities/cmcurl/CMakeFiles/LIBCURL.dir/Testing/curltest.c.o
Linking C executable LIBCURL
[ 56%] Built target LIBCURL
Linking C static library libcmlibarchive.a
[ 56%] Built target cmlibarchive
Linking CXX executable cmsysTestsCxx
[ 56%] Built target cmsysTestsCxx
Scanning dependencies of target CMakeLib
[ 56%] [ 56%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmArchiveWrite.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmStandardIncludes.cxx.o
[ 56%] [ 57%] [ 57%] [ 57%] [ 57%] [ 57%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmBootstrapCommands.cxx.o
[ 57%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCommands.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCacheManager.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCommandArgumentLexer.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCommandArgumentParser.cxx.o
[ 58%] [ 58%] [ 59%] [ 60%] [ 58%] [ 60%] [ 60%] [ 60%] [ 60%] [ 60%] [ 60%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmComputeLinkDepends.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmComputeTargetDepends.cxx.o
[ 60%] [ 60%] [ 61%] [ 61%] [ 61%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCryptoHash.cxx.o
[ 62%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmComputeComponentGraph.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCustomCommandGenerator.cxx.o
[ 62%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCommandArgumentParserHelper.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmCustomCommand.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDefinitions.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmComputeLinkInformation.cxx.o
[ 62%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsC.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsFortranParser.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsFortran.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsFortranLexer.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsJava.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDepends.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatter.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsJavaParser.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsJavaParserHelper.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDependsJavaLexer.cxx.o
[ 63%] [ 63%] [ 63%] [ 63%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterHTML.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentation.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterUsage.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterDocbook.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterMan.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationFormatterText.cxx.o
[ 63%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentationSection.cxx.o
[ 63%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDocumentVariables.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmDynamicLoader.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmELF.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExprLexer.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExprParser.cxx.o
[ 64%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExprParserHelper.cxx.o
[ 65%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportBuildFileGenerator.cxx.o
[ 65%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportFileGenerator.cxx.o
[ 65%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportInstallFileGenerator.cxx.o
[ 65%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportSet.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExportSetMap.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExtraCodeBlocksGenerator.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmExtraEclipseCDT4Generator.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmFileTimeComparison.cxx.o
[ 66%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratedFileStream.cxx.o
[ 67%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpressionDAGChecker.cxx.o
[ 67%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpressionEvaluator.cxx.o
[ 67%] [ 67%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpressionLexer.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpressionParser.cxx.o
[ 68%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorExpression.cxx.o
[ 68%] [ 68%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGeneratorTarget.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGlobalGenerator.cxx.o
[ 68%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGlobalUnixMakefileGenerator3.cxx.o
[ 69%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGraphVizWriter.cxx.o
[ 69%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallGenerator.cxx.o
[ 69%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallExportGenerator.cxx.o
[ 69%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallFilesGenerator.cxx.o
[ 69%] [ 70%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallScriptGenerator.cxx.o
[ 70%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallDirectoryGenerator.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmInstallTargetGenerator.cxx.o
[ 70%] [ 70%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmListFileCache.cxx.o
Building C object Source/CMakeFiles/CMakeLib.dir/cmListFileLexer.c.o
[ 70%] [ 71%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmLocalGenerator.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmLocalUnixMakefileGenerator3.cxx.o
[ 71%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakeDepend.cxx.o
[ 71%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefile.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefileTargetGenerator.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefileExecutableTargetGenerator.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefileLibraryTargetGenerator.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmMakefileUtilityTargetGenerator.cxx.o
[ 72%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmOSXBundleGenerator.cxx.o
[ 73%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmNewLineStyle.cxx.o
[ 73%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmOrderDirectories.cxx.o
[ 73%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmPolicies.cxx.o
[ 73%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmProcessTools.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmProperty.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmPropertyDefinition.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmPropertyDefinitionMap.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmPropertyMap.cxx.o
[ 74%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmQtAutomoc.cxx.o
[ 75%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmScriptGenerator.cxx.o
[ 75%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmSourceFile.cxx.o
[ 75%] [ 75%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmSourceFileLocation.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmSourceGroup.cxx.o
[ 76%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmSystemTools.cxx.o
[ 76%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmTarget.cxx.o
[ 76%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmTest.cxx.o
[ 76%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmTestGenerator.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmVariableWatch.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmVersion.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmXMLParser.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmXMLSafe.cxx.o
[ 77%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmake.cxx.o
[ 78%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmakewizard.cxx.o
[ 78%] Building C object Source/CMakeFiles/CMakeLib.dir/cm_sha2.c.o
[ 78%] Building C object Source/CMakeFiles/CMakeLib.dir/cm_utf8.c.o
[ 78%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGlobalKdevelopGenerator.cxx.o
[ 79%] [ 79%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmGlobalNinjaGenerator.cxx.o
Building CXX object Source/CMakeFiles/CMakeLib.dir/cmLocalNinjaGenerator.cxx.o
[ 79%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmNinjaTargetGenerator.cxx.o
[ 79%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmNinjaNormalTargetGenerator.cxx.o
[ 80%] Building CXX object Source/CMakeFiles/CMakeLib.dir/cmNinjaUtilityTargetGenerator.cxx.o
Linking CXX static library libCMakeLib.a
[ 80%] Built target CMakeLib
Scanning dependencies of target runcompilecommands
Scanning dependencies of target CMakeLibTests
Scanning dependencies of target cmake
[ 80%] [ 81%] [ 81%] [ 82%] [ 82%] [ 83%] [ 83%] Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/CMakeLibTests.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/runcompilecommands.dir/run_compile_commands.cxx.o
[ 83%] Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testSystemTools.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testGeneratedFileStream.cxx.o
Building CXX object Source/CMakeFiles/cmake.dir/cmakemain.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testXMLParser.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testXMLSafe.cxx.o
Building CXX object Tests/CMakeLib/CMakeFiles/CMakeLibTests.dir/testUTF8.cxx.o
Scanning dependencies of target ccmake
Scanning dependencies of target CPackLib
[ 83%] [ 83%] [ 83%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesFilePathWidget.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesBoolWidget.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesForm.cxx.o
[ 84%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesCacheEntryComposite.cxx.o
[ 84%] [ 84%] [ 84%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesLongMessageForm.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackLog.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/ccmake.cxx.o
[ 84%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesDummyWidget.cxx.o
[ 84%] Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackComponentGroup.cxx.o
[ 85%] [ 85%] [ 85%] Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackTarBZip2Generator.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesStringWidget.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesMainForm.cxx.o
[ 87%] [ 87%] [ 87%] [ 87%] [ 88%] [ 88%] [ 88%] [ 89%] [ 89%] [ 85%] [ 87%] [ 88%] [ 87%] Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesWidget.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackGeneratorFactory.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackNSISGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackTarCompressGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackDocumentMacros.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackArchiveGenerator.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesLabelWidget.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackTGZGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackZIPGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackSTGZGenerator.cxx.o
Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackDocumentVariables.cxx.o
Building CXX object Source/CMakeFiles/ccmake.dir/CursesDialog/cmCursesPathWidget.cxx.o
Scanning dependencies of target CTestLib
[ 90%] Building CXX object Source/CMakeFiles/CTestLib.dir/cmCTest.cxx.o
[ 90%] Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackDebGenerator.cxx.o
[ 90%] Building CXX object Source/CMakeFiles/CPackLib.dir/CPack/cmCPackRPMGenerator.cxx.o
[ 90%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmProcess.cxx.o
[ 90%] [ 90%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBatchTestHandler.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBuildAndTestHandler.cxx.o
[ 90%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBuildCommand.cxx.o
[ 91%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBuildHandler.cxx.o
[ 91%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestConfigureCommand.cxx.o
[ 91%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestConfigureHandler.cxx.o
[ 91%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestCoverageCommand.cxx.o
Linking CXX executable CMakeLibTests
[ 92%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestCoverageHandler.cxx.o
[ 92%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmParseMumpsCoverage.cxx.o
[ 92%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmParseCacheCoverage.cxx.o
[ 92%] [ 93%] [ 93%] [ 93%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmParseGTMCoverage.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestEmptyBinaryDirectoryCommand.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmParsePHPCoverage.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestHandlerCommand.cxx.o
[ 93%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestGenericHandler.cxx.o
[ 94%] [ 94%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestLaunch.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestMemCheckCommand.cxx.o
[ 94%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestMemCheckHandler.cxx.o
[ 94%] Built target CMakeLibTests
[ 94%] [ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestReadCustomFilesCommand.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestRunScriptCommand.cxx.o
Linking CXX executable runcompilecommands
[ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestRunTest.cxx.o
[ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestMultiProcessHandler.cxx.o
[ 95%] Built target runcompilecommands
[ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestScriptHandler.cxx.o
[ 95%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestSleepCommand.cxx.o
[ 96%] [ 96%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestStartCommand.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestSubmitCommand.cxx.o
[ 96%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestSubmitHandler.cxx.o
[ 96%] [ 96%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestTestCommand.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestTestHandler.cxx.o
Linking CXX executable ../bin/cmake
Linking CXX executable ../bin/ccmake
[ 97%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestUpdateCommand.cxx.o
[ 97%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestUpdateHandler.cxx.o
[ 97%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestUploadCommand.cxx.o
[ 97%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestUploadHandler.cxx.o
[ 98%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestVC.cxx.o
[ 98%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestGlobalVC.cxx.o
[ 98%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestCVS.cxx.o
[ 98%] [ 98%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestSVN.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestBZR.cxx.o
[ 99%] [ 99%] Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestHG.cxx.o
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestGIT.cxx.o
Linking CXX static library libCPackLib.a
[ 99%] Built target CPackLib
Scanning dependencies of target cpack
[ 99%] Building CXX object Source/CMakeFiles/cpack.dir/CPack/cpack.cxx.o
[ 99%] Built target cmake
[ 99%] Built target ccmake
Linking CXX static library libCTestLib.a
Linking CXX executable ../bin/cpack
[ 99%] Built target CTestLib
Scanning dependencies of target ctest
[ 99%] Building CXX object Source/CMakeFiles/ctest.dir/ctest.cxx.o
Linking CXX executable ../bin/ctest
[ 99%] Built target cpack
[ 99%] Built target ctest
Scanning dependencies of target documentation
[ 99%] [ 99%] [ 99%] [100%] Generating ../Docs/ccmake.txt
Generating ../Docs/ctest.txt
Generating ../Docs/cmake.txt
Generating ../Docs/cpack.txt
[100%] Built target documentation
[  1%] Built target cmIML_test
[  4%] Built target cmsys
[  4%] Built target cmsysTestDynload
[  5%] Built target cmsys_c
[  6%] Built target cmsysTestProcess
[  6%] Built target cmsysTestSharedForward
[  7%] Built target cmsysTestsC
[  9%] Built target cmsysTestsCxx
[ 12%] Built target cmzlib
[ 25%] Built target cmcurl
[ 25%] Built target LIBCURL
[ 26%] Built target cmcompress
[ 27%] Built target cmbzip2
[ 46%] Built target cmlibarchive
[ 46%] Built target cmexpat
[ 55%] Built target cmForm
[ 79%] Built target CMakeLib
[ 82%] Built target CPackLib
[ 92%] Built target CTestLib
[ 95%] Built target ccmake
[ 96%] Built target cmake
[ 96%] Built target cpack
[ 96%] Built target ctest
[ 97%] Built target documentation
[ 98%] Built target CMakeLibTests
[ 99%] Built target runcompilecommands
[ 99%] Built target foo
[100%] Built target memcheck_fail
[100%] Built target pseudo_BC
[100%] Built target pseudo_purify
[100%] Built target pseudo_valgrind
Install the project...
-- Install configuration: ""
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/Copyright.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/AddFileDependencies.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/BasicConfigVersion-ExactVersion.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/BasicConfigVersion-SameMajorVersion.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/BundleUtilities.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCCompilerFlag.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCXXSourceCompiles.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCXXSymbolExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckFunctionExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFile.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFile.cxx.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFiles.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckLanguage.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckLibraryExists.lists.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckPrototypeDefinition.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckSizeOf.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckTypeSize.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckTypeSize.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckTypeSizeMap.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddFortranSubdirectory
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddFortranSubdirectory/build_mingw.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddFortranSubdirectory/config_mingw.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddFortranSubdirectory.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeAddNewLanguage.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASMCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeBackwardCompatibilityCXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeBorlandFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeBuildSettings.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCCompilerABI.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCCompilerId.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCommonLanguageInclude.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeConfigurableFile.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCXXCompilerId.cpp.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCXXInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineASM-ATTCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineASM_MASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineASM_NASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCompilerABI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCompilerId.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineFortranCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineJavaCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineVSServicePack.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeExtraGeneratorDetermineCompilerMacrosAndIncludeDirs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindKDevelop3.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindWMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindXCode.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeForceCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFortranCompilerId.F.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFortranInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeNMakeFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakePlatformId.h.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakePrintSystemInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakePushCheckState.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeRCInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeSystem.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeSystemSpecificInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestASM_MASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestASM_NASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestFortranCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestWatcomVersion.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeUnixFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS6BackwardCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS6FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS7BackwardCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS8FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.Description.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.DS_Store.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.OSXScriptLauncher.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.OSXScriptLauncher.rsrc.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.RuntimeScript.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackBundle.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackComponent.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackDMG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackRPM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackZIP.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CTestScriptMode.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CTestTargets.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CTestUseLaunchers.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Dart.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/DeployQt4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/exportheader.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/ExternalProject.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindArmadillo.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindASPELL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBISON.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBLAS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBoost.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBZip2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCABLE.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCoin3D.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCUDA.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCups.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCURL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCxxTest.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindDart.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindFLEX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGit.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGLU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGLUT.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGTK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGTK2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindHDF5.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindHTMLHelp.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindImageMagick.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindITK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindJasper.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindJava.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindJNI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindJPEG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindKDE3.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLibArchive.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLibXml2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLibXslt.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMFC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMotif.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMPEG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMPEG2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenMP.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenSceneGraph.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgDB.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgIntrospection.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseVTKBuildSettings40.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseVTKConfig40.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/VTKCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/WriteBasicConfigVersionFile.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgQt.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgShadow.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgSim.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgTerrain.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseJavaSymlinks.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgViewer.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgVolume.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseJavaClassFilelist.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPackageMessage.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPerl.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPHP4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPhysFS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPike.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPkgConfig.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPNG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPostgreSQL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForSTDNamespace.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForSTDNamespace.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Use_wxWindows.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UsewxWidgets.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindQt.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForANSIStreamHeaders.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindQuickTime.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestCXXAcceptsFlag.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SystemInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForSSTREAM.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_sound.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_ttf.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSelfPackers.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSquish.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/RepositoryInfo.txt.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestEndianess.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindTCL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindTclsh.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindTclStub.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/readme.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindTIFF.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Qt4ConfigDependentSettings.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindVTK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindWget.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/MacroAddFileDependencies.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/NSIS.InstallOptions.ini.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindXMLRPC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindZLIB.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/IntelVSImplicitPath
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/IntelVSImplicitPath/CMakeLists.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/IntelVSImplicitPath/detect.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/IntelVSImplicitPath/hello.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/KDE3Macros.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-VisualAge-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-VisualAge-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-VisualAge-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX-XL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/AIX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BeOS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-base.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic-XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-dynamic.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static-XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BlueGeneP-static.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/BSDOS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Catamount.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN-windres.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/CYGWIN.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-Absoft-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-Clang-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-Clang-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-Clang.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-icc.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-icpc.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-NAG-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-VisualAge-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-VisualAge-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Darwin.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/DragonFly.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/eCos.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/FreeBSD.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/gas.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-ADSP-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-ADSP-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-ADSP-Common.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-ADSP-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic-SDCC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Generic.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/GNUtoMS_lib.bat.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/GNUtoMS_lib.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Haiku.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX-HP.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/HP-UX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/IRIX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/IRIX64.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/kFreeBSD.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Absoft-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Clang-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-como.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Clang-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Intel-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Intel-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Intel-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-Intel.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-NAG-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PathScale-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PathScale-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PathScale-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PathScale.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PGI-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PGI-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PGI-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-PGI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-SunPro-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-TinyCC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-VisualAge-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-VisualAge-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-VisualAge-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux-XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Linux.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/MP-RAS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/NetBSD.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/OpenBSD.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/OpenVMS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/OSF1.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/QNX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/RISCos.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SCO_SV.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SINIX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/SunOS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/syllable.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Tru64.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/ULTRIX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/UNIX_SV.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/UnixPaths.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/UnixWare.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Borland-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Borland-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-df.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Embarcadero-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Embarcadero-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Embarcadero.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-G95-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-C-ABI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-CXX-ABI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-Fortran-ABI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-Intel.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-MSVC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-MSVC-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-MSVC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-NMcl.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-wcl386.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows-windres.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Windows.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsCE-MSVC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsCE-MSVC-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsCE-MSVC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsCE.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/WindowsPaths.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Platform/Xenix.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/InstallRequiredSystemLibraries.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/GetPrerequisites.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/AutomocInfo.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/BasicConfigVersion-AnyNewerVersion.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCSourceCompiles.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCSourceRuns.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCXXCompilerFlag.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckCXXSourceRuns.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckForPthreads.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckFortranFunctionExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFile.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckIncludeFileCXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckLibraryExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckPrototypeDefinition.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckStructHasMember.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckSymbolExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckVariableExists.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CheckVariableExists.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASM-ATTInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASM_MASMInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASM_NASMInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeASMInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeBackwardCompatibilityC.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeClDeps.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCompilerABI.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCXXCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeCXXCompilerABI.cpp
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDependentOption.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestGNU.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineCXXCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineRCCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeDetermineSystem.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeExpandImportedTargets.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeExportBuildSettings.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindBinUtils.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindCodeBlocks.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindEclipseCDT4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindFrameworks.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFindPackageMode.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFortranCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeFortranCompilerABI.F
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeGenericSystem.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeImportBuildSettings.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeJavaCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeJavaInformation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeJOMFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeMinGWFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeMSYSFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeNinjaFindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakePackageConfigHelpers.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeParseArguments.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeParseImplicitLinkInfo.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeRCCompiler.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestASM-ATTCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestASMCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestCompilerCommon.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestCXXCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestJavaCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeTestRCCompiler.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVerifyManifest.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS10FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS11FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS71FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS7FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Absoft-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Clang-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Clang-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Clang-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Clang.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Cray-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Cray-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Cray-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/G95-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/GNU.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/HP-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/HP-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/HP-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/HP-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Intel-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Intel-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Intel-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/Intel-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/MIPSpro-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/MIPSpro-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/MIPSpro-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/NAG-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PathScale-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PathScale-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PathScale-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PathScale.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PGI-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PGI-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PGI-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/PGI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SCO-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SCO-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SCO.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SunPro-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SunPro-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SunPro-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/SunPro-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/TinyCC-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/VisualAge-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/VisualAge-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/VisualAge-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL-ASM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL-C.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL-CXX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL-Fortran.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Compiler/XL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CMakeVS9FindMake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/VS-10.vcxproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/VS-6.dsp.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/VS-7.vcproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/Xcode-1.pbxproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/Xcode-2.pbxproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CompilerId/Xcode-3.pbxproj.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.background.png.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.distribution.dist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.Info.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.OSXX11.Info.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.OSXX11.main.scpt.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.STGZ_Header.sh.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPack.VolumeIcon.icns.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackCygwin.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackDeb.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackNSIS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CPackPackageMaker.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/CTest.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/DartConfiguration.tcl.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Documentation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/DummyCXXFile.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/ecos_clean.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FeatureSummary.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindALSA.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindAVIFile.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindBullet.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCUDA/make2cmake.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCUDA/parse_cubin.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCUDA/run_nvcc.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCurses.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCVS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindCygwin.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindDCMTK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindDevIL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindDoxygen.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindEXPAT.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindFLTK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindFLTK2.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindFreetype.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGCCXML.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGDAL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGettext.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGIF.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGLEW.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGnuplot.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGnuTLS.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindGTest.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindHg.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindHSPELL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindKDE4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLAPACK.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLATEX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLibLZMA.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLua50.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindLua51.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMatlab.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindMPI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenAL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenGL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForSSTREAM.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenSSL.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindOpenThreads.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Findosg.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Findosg_functions.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgAnimation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgFX.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgGA.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForANSIStreamHeaders.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgManipulator.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgParticle.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgPresentation.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgProducer.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForANSIForScope.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestForAnsiForScope.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/.NoDartCoverage
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgText.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgUtil.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SystemInformation.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindosgWidget.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SquishTestScript.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseVTK40.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPerlLibs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SelectLibraryConfigurations.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SquishRunTestCase.bat
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/SquishRunTestCase.sh
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseSWIG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindProducer.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindProtobuf.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPythonInterp.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindPythonLibs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseQt4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindQt3.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindQt4.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UsePkgConfig.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindRTI.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindRuby.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseJava.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_image.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_mixer.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSDL_net.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/MacOSXFrameworkInfo.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/ProcessorCount.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/UseEcos.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSubversion.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindSWIG.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/MacOSXBundleInfo.plist.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/TestBigEndian.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindThreads.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/Qt4Macros.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindUnixCommands.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/kde3uic.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/NSIS.template.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindWish.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindwxWidgets.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindwxWindows.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FindX11.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/kde3init_dummy.cpp.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FLTKCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/call_mod.f90
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/call_sub.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/CMakeLists.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Detect.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Input.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Macro.h.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/main.F
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/my_module.f90
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/my_module_.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/my_sub.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/mymodule.f90
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/mymodule_.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/mysub.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Output.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/symbol.c.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/CMakeLists.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/main.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/VerifyC.c
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/VerifyCXX.cxx
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/FortranCInterface/Verify/VerifyFortran.f
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/ITKCompatibility.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/GenerateExportHeader.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Modules/GNUInstallDirs.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/AppleInfo.plist
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CMakeVisualStudio6Configurations.cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CMakeVSMacros1.vsmacros
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CMakeVSMacros2.vsmacros
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CPack.GenericDescription.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CPack.GenericLicense.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CPack.GenericWelcome.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CPackConfig.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/CTestScript.cmake.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/cygwin-package.sh.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/DLLFooter.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/DLLHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/EXEFooter.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/EXEHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/EXEWinHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/staticLibFooter.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/staticLibHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/TestDriver.cxx.in
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/UtilityFooter.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/Templates/UtilityHeader.dsptemplate
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmsys/Copyright.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmzlib/Copyright.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmcurl/COPYING
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmcompress/Copyright.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmlibarchive/COPYING
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmexpat/COPYING
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/include/cmCPluginAPI.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/ccmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cpack
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/ctest
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmake.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakecommands.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakecompat.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakeprops.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakepolicies.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakevars.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cmakemodules.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/ctest.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/cpack.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/man/man1/ccmake.1
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-policies.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-properties.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-variables.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-modules.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-commands.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-compatcommands.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ctest.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cpack.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ccmake.txt
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-policies.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-properties.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-variables.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-modules.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-commands.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake-compatcommands.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ctest.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cpack.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ccmake.html
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cmake.docbook
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ctest.docbook
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/cpack.docbook
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/doc/cmake-2.8/ccmake.docbook
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/aclocal/cmake.m4
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/editors/vim/cmake-help.vim
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/editors/vim/cmake-indent.vim
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/editors/vim/cmake-syntax.vim
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/editors/emacs/cmake-mode.el
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/completions/cmake
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/completions/cpack
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/share/cmake-2.8/completions/ctest********End of Output of running make on cmake *******
Executing: cp -f /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/cmake-2.8.10.2/cmake.args /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/cmake
                  Defined make macro "CMAKE" to "/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake"
        Not checking for library in Download CMAKE: [] because no functions given to check for
TEST check from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:145)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:145)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
            No functions to check for in library [] []
        Checking for headers Download CMAKE: ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
TEST checkSharedLibrary from PETSc.packages.cmake(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:533)
TESTING: checkSharedLibrary from PETSc.packages.cmake(config/BuildSystem/config/package.py:533)
  By default we don't care about checking if the library is shared
      Popping language C
    Pushing language C
TEST configureLibrary from PETSc.packages.metis(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:479)
TESTING: configureLibrary from PETSc.packages.metis(config/BuildSystem/config/package.py:479)
  Find an installation and check if it can work with PETSc
      Checking for a functional metis
              Looking for METIS in directory starting with metis
              Could not locate an existing copy of metis:
                ['cmake-2.8.10.2', 'c2html-0.9.4', 'sowing-1.1.16e']
                Downloading metis
                  Downloading http://ftp.mcs.anl.gov/pub/petsc/externalpackages/metis-5.1.0-p1.tar.gz to /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_metis-5.1.0-p1.tar.gz
                  Extracting /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_metis-5.1.0-p1.tar.gz
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages; chmod -R a+r metis-5.1.0-p1;find  metis-5.1.0-p1 -type d -name "*" -exec chmod a+rx {} \;
                  Found a copy of METIS in metis-5.1.0-p1
                Pushing language C
                Popping language C
Have to rebuild metis, /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/metis != /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/metis
                      Configuring METIS; this may take several minutes
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64 -DCMAKE_VERBOSE_MAKEFILE=1 -DGKLIB_PATH=../GKlib -DCMAKE_C_COMPILER="mpixlc_r" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction " -DMETIS_USE_LONGINDEX=1 -DMETIS_USE_DOUBLEPRECISION=1
stdout:
-- The C compiler identification is XL 12.1.0
-- The CXX compiler identification is GNU 4.4.6
-- Check for working C compiler: /soft/compilers/wrappers/xl/mpixlc_r
-- Check for working C compiler: /soft/compilers/wrappers/xl/mpixlc_r -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Looking for execinfo.h
-- Looking for execinfo.h - found
-- Looking for getline
-- Looking for getline - found
-- Performing Test HAVE__thread
-- Performing Test HAVE__thread - Success
-- checking for __thread thread-local storage - found
-- Configuring done
-- Generating done
-- Build files have been written to: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64
                      Compiling METIS; this may take several minutes
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 && make && make install
stdout:
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -H/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1 -B/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 --check-build-system CMakeFiles/Makefile.cmake 0
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_start /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
make -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/depend
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_depends "Unix Makefiles" /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis/CMakeFiles/metis.dir/DependInfo.cmake --color=
Scanning dependencies of target metis
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
make -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/build
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 1
[  1%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/b64.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/b64.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/b64.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 2
[  3%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/blas.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/blas.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/blas.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 3
[  4%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/csr.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/csr.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/csr.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 4
[  6%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/error.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/error.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/error.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 5
[  8%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/evaluate.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/evaluate.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 6
[  9%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/fkvkselect.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 7
[ 11%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fs.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/fs.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/fs.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 8
[ 13%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/getopt.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/getopt.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/getopt.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 9
[ 14%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/gkregex.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/gkregex.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 10
[ 16%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/graph.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/graph.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/graph.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 11
[ 18%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/htable.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/htable.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/htable.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 12
[ 19%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/io.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/io.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/io.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 13
[ 21%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/itemsets.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/itemsets.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 14
[ 22%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/mcore.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/mcore.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/mcore.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 15
[ 24%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/memory.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/memory.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/memory.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 16
[ 26%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/omp.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/omp.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/omp.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 17
[ 27%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pdb.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/pdb.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/pdb.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 18
[ 29%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pqueue.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/pqueue.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 19
[ 31%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/random.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/random.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/random.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 20
[ 32%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/rw.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/rw.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/rw.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 21
[ 34%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/seq.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/seq.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/seq.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 22
[ 36%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/sort.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/sort.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/sort.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 23
[ 37%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/string.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/string.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/string.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 24
[ 39%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/timers.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/timers.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/timers.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 25
[ 40%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/tokenizer.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 26
[ 42%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/util.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/util.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/util.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 27
[ 44%] Building C object libmetis/CMakeFiles/metis.dir/auxapi.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/auxapi.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/auxapi.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 28
[ 45%] Building C object libmetis/CMakeFiles/metis.dir/balance.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/balance.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/balance.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 29
[ 47%] Building C object libmetis/CMakeFiles/metis.dir/bucketsort.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/bucketsort.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/bucketsort.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 30
[ 49%] Building C object libmetis/CMakeFiles/metis.dir/checkgraph.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/checkgraph.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/checkgraph.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 31
[ 50%] Building C object libmetis/CMakeFiles/metis.dir/coarsen.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/coarsen.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/coarsen.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 32
[ 52%] Building C object libmetis/CMakeFiles/metis.dir/compress.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/compress.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/compress.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 33
[ 54%] Building C object libmetis/CMakeFiles/metis.dir/contig.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/contig.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/contig.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 34
[ 55%] Building C object libmetis/CMakeFiles/metis.dir/debug.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/debug.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/debug.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 35
[ 57%] Building C object libmetis/CMakeFiles/metis.dir/fm.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/fm.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/fm.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 36
[ 59%] Building C object libmetis/CMakeFiles/metis.dir/fortran.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/fortran.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/fortran.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 37
[ 60%] Building C object libmetis/CMakeFiles/metis.dir/frename.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/frename.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/frename.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 38
[ 62%] Building C object libmetis/CMakeFiles/metis.dir/gklib.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/gklib.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/gklib.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 39
[ 63%] Building C object libmetis/CMakeFiles/metis.dir/graph.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/graph.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/graph.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 40
[ 65%] Building C object libmetis/CMakeFiles/metis.dir/initpart.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/initpart.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/initpart.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 41
[ 67%] Building C object libmetis/CMakeFiles/metis.dir/kmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/kmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/kmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 42
[ 68%] Building C object libmetis/CMakeFiles/metis.dir/kwayfm.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/kwayfm.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/kwayfm.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 43
[ 70%] Building C object libmetis/CMakeFiles/metis.dir/kwayrefine.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/kwayrefine.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/kwayrefine.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 44
[ 72%] Building C object libmetis/CMakeFiles/metis.dir/mcutil.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/mcutil.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/mcutil.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 45
[ 73%] Building C object libmetis/CMakeFiles/metis.dir/mesh.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/mesh.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/mesh.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 46
[ 75%] Building C object libmetis/CMakeFiles/metis.dir/meshpart.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/meshpart.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/meshpart.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 47
[ 77%] Building C object libmetis/CMakeFiles/metis.dir/minconn.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/minconn.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/minconn.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 48
[ 78%] Building C object libmetis/CMakeFiles/metis.dir/mincover.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/mincover.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/mincover.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 49
[ 80%] Building C object libmetis/CMakeFiles/metis.dir/mmd.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/mmd.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/mmd.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 50
[ 81%] Building C object libmetis/CMakeFiles/metis.dir/ometis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/ometis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/ometis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 51
[ 83%] Building C object libmetis/CMakeFiles/metis.dir/options.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/options.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/options.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 52
[ 85%] Building C object libmetis/CMakeFiles/metis.dir/parmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/parmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/parmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 53
[ 86%] Building C object libmetis/CMakeFiles/metis.dir/pmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/pmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/pmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 54
[ 88%] Building C object libmetis/CMakeFiles/metis.dir/refine.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/refine.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/refine.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 55
[ 90%] Building C object libmetis/CMakeFiles/metis.dir/separator.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/separator.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/separator.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 56
[ 91%] Building C object libmetis/CMakeFiles/metis.dir/sfm.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/sfm.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/sfm.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 57
[ 93%] Building C object libmetis/CMakeFiles/metis.dir/srefine.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/srefine.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/srefine.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 58
[ 95%] Building C object libmetis/CMakeFiles/metis.dir/stat.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/stat.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/stat.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 59
[ 96%] Building C object libmetis/CMakeFiles/metis.dir/timing.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/timing.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/timing.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 60
[ 98%] Building C object libmetis/CMakeFiles/metis.dir/util.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/util.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/util.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 61
[100%] Building C object libmetis/CMakeFiles/metis.dir/wspace.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/wspace.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/wspace.c
Linking C static library libmetis.a
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -P CMakeFiles/metis.dir/cmake_clean_target.cmake
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_link_script CMakeFiles/metis.dir/link.txt --verbose=1
/usr/bin/ar cr libmetis.a  CMakeFiles/metis.dir/__/GKlib/b64.c.o CMakeFiles/metis.dir/__/GKlib/blas.c.o CMakeFiles/metis.dir/__/GKlib/csr.c.o CMakeFiles/metis.dir/__/GKlib/error.c.o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o CMakeFiles/metis.dir/__/GKlib/fs.c.o CMakeFiles/metis.dir/__/GKlib/getopt.c.o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o CMakeFiles/metis.dir/__/GKlib/graph.c.o CMakeFiles/metis.dir/__/GKlib/htable.c.o CMakeFiles/metis.dir/__/GKlib/io.c.o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o CMakeFiles/metis.dir/__/GKlib/mcore.c.o CMakeFiles/metis.dir/__/GKlib/memory.c.o CMakeFiles/metis.dir/__/GKlib/omp.c.o CMakeFiles/metis.dir/__/GKlib/pdb.c.o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o CMakeFiles/metis.dir/__/GKlib/random.c.o CMakeFiles/metis.dir/__/GKlib/rw.c.o CMakeFiles/metis.dir/__/GKlib/seq.c.o CMakeFiles/metis.dir/__/GKlib/sort.c.o CMakeFiles/metis.dir/__/GKlib/string.c.o CMakeFiles/metis.dir/__/GKlib/timers.c.o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o CMakeFiles/metis.dir/__/GKlib/util.c.o CMakeFiles/metis.dir/auxapi.c.o CMakeFiles/metis.dir/balance.c.o CMakeFiles/metis.dir/bucketsort.c.o CMakeFiles/metis.dir/checkgraph.c.o CMakeFiles/metis.dir/coarsen.c.o CMakeFiles/metis.dir/compress.c.o CMakeFiles/metis.dir/contig.c.o CMakeFiles/metis.dir/debug.c.o CMakeFiles/metis.dir/fm.c.o CMakeFiles/metis.dir/fortran.c.o CMakeFiles/metis.dir/frename.c.o CMakeFiles/metis.dir/gklib.c.o CMakeFiles/metis.dir/graph.c.o CMakeFiles/metis.dir/initpart.c.o CMakeFiles/metis.dir/kmetis.c.o CMakeFiles/metis.dir/kwayfm.c.o CMakeFiles/metis.dir/kwayrefine.c.o CMakeFiles/metis.dir/mcutil.c.o CMakeFiles/metis.dir/mesh.c.o CMakeFiles/metis.dir/meshpart.c.o CMakeFiles/metis.dir/minconn.c.o CMakeFiles/metis.dir/mincover.c.o CMakeFiles/metis.dir/mmd.c.o CMakeFiles/metis.dir/ometis.c.o CMakeFiles/metis.dir/options.c.o CMakeFiles/metis.dir/parmetis.c.o CMakeFiles/metis.dir/pmetis.c.o CMakeFiles/metis.dir/refine.c.o CMakeFiles/metis.dir/separator.c.o CMakeFiles/metis.dir/sfm.c.o CMakeFiles/metis.dir/srefine.c.o CMakeFiles/metis.dir/stat.c.o CMakeFiles/metis.dir/timing.c.o CMakeFiles/metis.dir/util.c.o CMakeFiles/metis.dir/wspace.c.o
/usr/bin/ranlib libmetis.a
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles  1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
[100%] Built target metis
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_start /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 0
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -H/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1 -B/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 --check-build-system CMakeFiles/Makefile.cmake 0
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_start /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
make -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/depend
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_depends "Unix Makefiles" /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis/CMakeFiles/metis.dir/DependInfo.cmake --color=
make -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/build
make[2]: Nothing to be done for `libmetis/CMakeFiles/metis.dir/build'.
make -f CMakeFiles/Makefile2 preinstall
make[1]: Nothing to be done for `preinstall'.
Install the project...
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -P cmake_install.cmake
-- Install configuration: ""
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/metis.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/gklib_tls.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib/libmetis.a
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/gklib_defs.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/gklib_rename.h
********Output of running make on metis follows *******
-- The C compiler identification is XL 12.1.0
-- The CXX compiler identification is GNU 4.4.6
-- Check for working C compiler: /soft/compilers/wrappers/xl/mpixlc_r
-- Check for working C compiler: /soft/compilers/wrappers/xl/mpixlc_r -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Looking for execinfo.h
-- Looking for execinfo.h - found
-- Looking for getline
-- Looking for getline - found
-- Performing Test HAVE__thread
-- Performing Test HAVE__thread - Success
-- checking for __thread thread-local storage - found
-- Configuring done
-- Generating done
-- Build files have been written to: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -H/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1 -B/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 --check-build-system CMakeFiles/Makefile.cmake 0
Scanning dependencies of target metis
[  1%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/b64.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/b64.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/b64.c
[  3%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/blas.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/blas.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/blas.c
[  4%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/csr.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/csr.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/csr.c
[  6%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/error.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/error.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/error.c
[  8%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/evaluate.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/evaluate.c
[  9%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/fkvkselect.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 7
[ 11%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fs.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/fs.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/fs.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 8
[ 13%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/getopt.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/getopt.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/getopt.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 9
[ 14%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/gkregex.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/gkregex.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 10
[ 16%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/graph.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/graph.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/graph.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 11
[ 18%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/htable.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/htable.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/htable.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 12
[ 19%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/io.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/io.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/io.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 13
[ 21%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/itemsets.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/itemsets.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 14
[ 22%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/mcore.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/mcore.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/mcore.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 15
[ 24%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/memory.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/memory.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/memory.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 16
[ 26%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/omp.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/omp.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/omp.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 17
[ 27%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pdb.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/pdb.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/pdb.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 18
[ 29%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pqueue.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/pqueue.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 19
[ 31%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/random.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/random.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/random.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 20
[ 32%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/rw.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/rw.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/rw.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 21
[ 34%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/seq.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/seq.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/seq.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 22
[ 36%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/sort.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/sort.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/sort.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 23
[ 37%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/string.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/string.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/string.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 24
[ 39%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/timers.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/timers.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/timers.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 25
[ 40%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/tokenizer.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 26
[ 42%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/util.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/__/GKlib/util.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib/util.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 27
[ 44%] Building C object libmetis/CMakeFiles/metis.dir/auxapi.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/auxapi.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/auxapi.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 28
[ 45%] Building C object libmetis/CMakeFiles/metis.dir/balance.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/balance.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/balance.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 29
[ 47%] Building C object libmetis/CMakeFiles/metis.dir/bucketsort.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/bucketsort.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/bucketsort.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 30
[ 49%] Building C object libmetis/CMakeFiles/metis.dir/checkgraph.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/checkgraph.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/checkgraph.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 31
[ 50%] Building C object libmetis/CMakeFiles/metis.dir/coarsen.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/coarsen.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/coarsen.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 32
[ 52%] Building C object libmetis/CMakeFiles/metis.dir/compress.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/compress.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/compress.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 33
[ 54%] Building C object libmetis/CMakeFiles/metis.dir/contig.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/contig.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/contig.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 34
[ 55%] Building C object libmetis/CMakeFiles/metis.dir/debug.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/debug.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/debug.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 35
[ 57%] Building C object libmetis/CMakeFiles/metis.dir/fm.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/fm.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/fm.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 36
[ 59%] Building C object libmetis/CMakeFiles/metis.dir/fortran.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/fortran.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/fortran.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 37
[ 60%] Building C object libmetis/CMakeFiles/metis.dir/frename.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/frename.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/frename.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 38
[ 62%] Building C object libmetis/CMakeFiles/metis.dir/gklib.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/gklib.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/gklib.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 39
[ 63%] Building C object libmetis/CMakeFiles/metis.dir/graph.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/graph.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/graph.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 40
[ 65%] Building C object libmetis/CMakeFiles/metis.dir/initpart.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/initpart.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/initpart.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 41
[ 67%] Building C object libmetis/CMakeFiles/metis.dir/kmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/kmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/kmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 42
[ 68%] Building C object libmetis/CMakeFiles/metis.dir/kwayfm.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/kwayfm.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/kwayfm.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 43
[ 70%] Building C object libmetis/CMakeFiles/metis.dir/kwayrefine.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/kwayrefine.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/kwayrefine.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 44
[ 72%] Building C object libmetis/CMakeFiles/metis.dir/mcutil.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/mcutil.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/mcutil.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 45
[ 73%] Building C object libmetis/CMakeFiles/metis.dir/mesh.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/mesh.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/mesh.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 46
[ 75%] Building C object libmetis/CMakeFiles/metis.dir/meshpart.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/meshpart.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/meshpart.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 47
[ 77%] Building C object libmetis/CMakeFiles/metis.dir/minconn.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/minconn.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/minconn.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 48
[ 78%] Building C object libmetis/CMakeFiles/metis.dir/mincover.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/mincover.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/mincover.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 49
[ 80%] Building C object libmetis/CMakeFiles/metis.dir/mmd.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/mmd.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/mmd.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 50
[ 81%] Building C object libmetis/CMakeFiles/metis.dir/ometis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/ometis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/ometis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 51
[ 83%] Building C object libmetis/CMakeFiles/metis.dir/options.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/options.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/options.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 52
[ 85%] Building C object libmetis/CMakeFiles/metis.dir/parmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/parmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/parmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 53
[ 86%] Building C object libmetis/CMakeFiles/metis.dir/pmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/pmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/pmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 54
[ 88%] Building C object libmetis/CMakeFiles/metis.dir/refine.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/refine.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/refine.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 55
[ 90%] Building C object libmetis/CMakeFiles/metis.dir/separator.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/separator.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/separator.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 56
[ 91%] Building C object libmetis/CMakeFiles/metis.dir/sfm.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/sfm.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/sfm.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 57
[ 93%] Building C object libmetis/CMakeFiles/metis.dir/srefine.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/srefine.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/srefine.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 58
[ 95%] Building C object libmetis/CMakeFiles/metis.dir/stat.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/stat.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/stat.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 59
[ 96%] Building C object libmetis/CMakeFiles/metis.dir/timing.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/timing.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/timing.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 60
[ 98%] Building C object libmetis/CMakeFiles/metis.dir/util.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/util.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/util.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 61
[100%] Building C object libmetis/CMakeFiles/metis.dir/wspace.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -DLINUX -D_FILE_OFFSET_BITS=64 -DNDEBUG -DNDEBUG2 -DHAVE_EXECINFO_H -DHAVE_GETLINE -O3 -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/GKlib -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/. -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/include    -o CMakeFiles/metis.dir/wspace.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis/wspace.c
Linking C static library libmetis.a
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -P CMakeFiles/metis.dir/cmake_clean_target.cmake
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_link_script CMakeFiles/metis.dir/link.txt --verbose=1
/usr/bin/ar cr libmetis.a  CMakeFiles/metis.dir/__/GKlib/b64.c.o CMakeFiles/metis.dir/__/GKlib/blas.c.o CMakeFiles/metis.dir/__/GKlib/csr.c.o CMakeFiles/metis.dir/__/GKlib/error.c.o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o CMakeFiles/metis.dir/__/GKlib/fs.c.o CMakeFiles/metis.dir/__/GKlib/getopt.c.o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o CMakeFiles/metis.dir/__/GKlib/graph.c.o CMakeFiles/metis.dir/__/GKlib/htable.c.o CMakeFiles/metis.dir/__/GKlib/io.c.o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o CMakeFiles/metis.dir/__/GKlib/mcore.c.o CMakeFiles/metis.dir/__/GKlib/memory.c.o CMakeFiles/metis.dir/__/GKlib/omp.c.o CMakeFiles/metis.dir/__/GKlib/pdb.c.o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o CMakeFiles/metis.dir/__/GKlib/random.c.o CMakeFiles/metis.dir/__/GKlib/rw.c.o CMakeFiles/metis.dir/__/GKlib/seq.c.o CMakeFiles/metis.dir/__/GKlib/sort.c.o CMakeFiles/metis.dir/__/GKlib/string.c.o CMakeFiles/metis.dir/__/GKlib/timers.c.o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o CMakeFiles/metis.dir/__/GKlib/util.c.o CMakeFiles/metis.dir/auxapi.c.o CMakeFiles/metis.dir/balance.c.o CMakeFiles/metis.dir/bucketsort.c.o CMakeFiles/metis.dir/checkgraph.c.o CMakeFiles/metis.dir/coarsen.c.o CMakeFiles/metis.dir/compress.c.o CMakeFiles/metis.dir/contig.c.o CMakeFiles/metis.dir/debug.c.o CMakeFiles/metis.dir/fm.c.o CMakeFiles/metis.dir/fortran.c.o CMakeFiles/metis.dir/frename.c.o CMakeFiles/metis.dir/gklib.c.o CMakeFiles/metis.dir/graph.c.o CMakeFiles/metis.dir/initpart.c.o CMakeFiles/metis.dir/kmetis.c.o CMakeFiles/metis.dir/kwayfm.c.o CMakeFiles/metis.dir/kwayrefine.c.o CMakeFiles/metis.dir/mcutil.c.o CMakeFiles/metis.dir/mesh.c.o CMakeFiles/metis.dir/meshpart.c.o CMakeFiles/metis.dir/minconn.c.o CMakeFiles/metis.dir/mincover.c.o CMakeFiles/metis.dir/mmd.c.o CMakeFiles/metis.dir/ometis.c.o CMakeFiles/metis.dir/options.c.o CMakeFiles/metis.dir/parmetis.c.o CMakeFiles/metis.dir/pmetis.c.o CMakeFiles/metis.dir/refine.c.o CMakeFiles/metis.dir/separator.c.o CMakeFiles/metis.dir/sfm.c.o CMakeFiles/metis.dir/srefine.c.o CMakeFiles/metis.dir/stat.c.o CMakeFiles/metis.dir/timing.c.o CMakeFiles/metis.dir/util.c.o CMakeFiles/metis.dir/wspace.c.o
/usr/bin/ranlib libmetis.a
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles  1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
[100%] Built target metis
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_start /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles 0
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -H/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1 -B/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 --check-build-system CMakeFiles/Makefile.cmake 0
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_start /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
make -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/depend
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64'
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_depends "Unix Makefiles" /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/libmetis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/arch-bgq-ibm-opt64/libmetis/CMakeFiles/metis.dir/DependInfo.cmake --color=
make -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/build
make[2]: Nothing to be done for `libmetis/CMakeFiles/metis.dir/build'.
make -f CMakeFiles/Makefile2 preinstall
make[1]: Nothing to be done for `preinstall'.
Install the project...
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -P cmake_install.cmake
-- Install configuration: ""
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/metis.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/gklib_tls.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib/libmetis.a
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/gklib_defs.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/gklib_rename.h********End of Output of running make on metis *******
Executing: cp -f /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/metis-5.1.0-p1/metis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/metis
      Checking for library in Download METIS: ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib/libmetis.a']
      Contents: ['include', 'lib', 'bin', 'conf', 'externalpackages', 'share', 'man', 'doc']
TEST check from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:145)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:145)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
          Checking for functions [METIS_PartGraphKway] in library ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib/libmetis.a'] []
            Pushing language C
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.packages.MPI -I/tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/PETSc.packages.pthread  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.libraries/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char METIS_PartGraphKway();
static void _check_METIS_PartGraphKway() { METIS_PartGraphKway(); }
int main() {
_check_METIS_PartGraphKway();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  -Wl,-rpath,/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib -L/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib -lmetis -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
            Defined "HAVE_LIBMETIS" to "1"
            Popping language C
      Checking for headers Download METIS: ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
          Pushing language C
TEST checkInclude from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['metis.h'] in ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
            Checking include with compiler flags var CPPFLAGS ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.packages.pthread -I/tmp/petsc-ITHdGX/config.headers  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include /tmp/petsc-ITHdGX/config.headers/conftest.c
stdout:
#line 37 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdint.h"
typedef signed char		int8_t;
typedef short int		int16_t;
typedef int			int32_t;
typedef long int		int64_t;
#line 49
typedef unsigned char		uint8_t;
typedef unsigned short int	uint16_t;
typedef unsigned int		uint32_t;
#line 56
typedef unsigned long int	uint64_t;
#line 66
typedef signed char		int_least8_t;
typedef short int		int_least16_t;
typedef int			int_least32_t;
typedef long int		int_least64_t;
#line 77
typedef unsigned char		uint_least8_t;
typedef unsigned short int	uint_least16_t;
typedef unsigned int		uint_least32_t;
typedef unsigned long int	uint_least64_t;
#line 91
typedef signed char		int_fast8_t;
typedef long int		int_fast16_t;
typedef long int		int_fast32_t;
typedef long int		int_fast64_t;
#line 104
typedef unsigned char		uint_fast8_t;
typedef unsigned long int	uint_fast16_t;
typedef unsigned long int	uint_fast32_t;
typedef unsigned long int	uint_fast64_t;
#line 120
typedef long int		intptr_t;
#line 123
typedef unsigned long int	uintptr_t;
#line 135
typedef long int		intmax_t;
typedef unsigned long int	uintmax_t;
#line 35 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/inttypes.h"
typedef int __gwchar_t;
#line 279
typedef struct
    long int quot;
    long int rem;
  } imaxdiv_t;
#line 298
extern intmax_t imaxabs (intmax_t __n)  __attribute__ ((const));
#line 301
extern imaxdiv_t imaxdiv (intmax_t __numer, intmax_t __denom)
#line 305
extern intmax_t strtoimax (const char *__restrict __nptr,
			   char **__restrict __endptr, int __base) ;
#line 309
extern uintmax_t strtoumax (const char *__restrict __nptr,
			    char ** __restrict __endptr, int __base) ;
#line 313
extern intmax_t wcstoimax (const __gwchar_t *__restrict __nptr,
			   __gwchar_t **__restrict __endptr, int __base)
#line 318
extern uintmax_t wcstoumax (const __gwchar_t *__restrict __nptr,
			    __gwchar_t ** __restrict __endptr, int __base)
#line 114 "/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/metis.h"
  typedef int64_t idx_t;
#line 151
  typedef double real_t;
#line 199
int METIS_PartGraphRecursive(idx_t *nvtxs, idx_t *ncon, idx_t *xadj,
                  idx_t *adjncy, idx_t *vwgt, idx_t *vsize, idx_t *adjwgt,
                  idx_t *nparts, real_t *tpwgts, real_t *ubvec, idx_t *options,
                  idx_t *edgecut, idx_t *part);
int METIS_PartGraphKway(idx_t *nvtxs, idx_t *ncon, idx_t *xadj,
int METIS_MeshToDual(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
                  idx_t *ncommon, idx_t *numflag, idx_t **r_xadj, idx_t **r_adjncy);
int METIS_MeshToNodal(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
int METIS_PartMeshNodal(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
                  idx_t *vwgt, idx_t *vsize, idx_t *nparts, real_t *tpwgts,
                  idx_t *options, idx_t *objval, idx_t *epart, idx_t *npart);
int METIS_PartMeshDual(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
                  idx_t *vwgt, idx_t *vsize, idx_t *ncommon, idx_t *nparts,
                  real_t *tpwgts, idx_t *options, idx_t *objval, idx_t *epart,
                  idx_t *npart);
int METIS_NodeND(idx_t *nvtxs, idx_t *xadj, idx_t *adjncy, idx_t *vwgt,
                  idx_t *options, idx_t *perm, idx_t *iperm);
int METIS_Free(void *ptr);
int METIS_SetDefaultOptions(idx_t *options);
#line 234
int METIS_NodeNDP(idx_t nvtxs, idx_t *xadj, idx_t *adjncy, idx_t *vwgt,
                   idx_t npes, idx_t *options, idx_t *perm, idx_t *iperm,
                   idx_t *sizes);
int METIS_ComputeVertexSeparator(idx_t *nvtxs, idx_t *xadj, idx_t *adjncy,
                   idx_t *vwgt, idx_t *options, idx_t *sepsize, idx_t *part);
int METIS_NodeRefine(idx_t nvtxs, idx_t *xadj, idx_t *vwgt, idx_t *adjncy,
                   idx_t *where, idx_t *hmarker, real_t ubfactor);
#line 255
typedef enum {
  METIS_OK              = 1,
  METIS_ERROR_INPUT     = -2,
  METIS_ERROR_MEMORY    = -3,
  METIS_ERROR           = -4
} rstatus_et;
#line 264
typedef enum {
  METIS_OP_PMETIS,
  METIS_OP_KMETIS,
  METIS_OP_OMETIS
} moptype_et;
#line 272
typedef enum {
  METIS_OPTION_PTYPE,
  METIS_OPTION_OBJTYPE,
  METIS_OPTION_CTYPE,
  METIS_OPTION_IPTYPE,
  METIS_OPTION_RTYPE,
  METIS_OPTION_DBGLVL,
  METIS_OPTION_NITER,
  METIS_OPTION_NCUTS,
  METIS_OPTION_SEED,
  METIS_OPTION_NO2HOP,
  METIS_OPTION_MINCONN,
  METIS_OPTION_CONTIG,
  METIS_OPTION_COMPRESS,
  METIS_OPTION_CCORDER,
  METIS_OPTION_PFACTOR,
  METIS_OPTION_NSEPS,
  METIS_OPTION_UFACTOR,
  METIS_OPTION_NUMBERING,
#line 293
  METIS_OPTION_HELP,
  METIS_OPTION_TPWGTS,
  METIS_OPTION_NCOMMON,
  METIS_OPTION_NOOUTPUT,
  METIS_OPTION_BALANCE,
  METIS_OPTION_GTYPE,
  METIS_OPTION_UBVEC
} moptions_et;
#line 304
typedef enum {
  METIS_PTYPE_RB,
  METIS_PTYPE_KWAY
} mptype_et;
#line 310
typedef enum {
  METIS_GTYPE_DUAL,
  METIS_GTYPE_NODAL
} mgtype_et;
#line 316
typedef enum {
  METIS_CTYPE_RM,
  METIS_CTYPE_SHEM
} mctype_et;
#line 322
typedef enum {
  METIS_IPTYPE_GROW,
  METIS_IPTYPE_RANDOM,
  METIS_IPTYPE_EDGE,
  METIS_IPTYPE_NODE,
  METIS_IPTYPE_METISRB
} miptype_et;
#line 332
typedef enum {
  METIS_RTYPE_FM,
  METIS_RTYPE_GREEDY,
  METIS_RTYPE_SEP2SIDED,
  METIS_RTYPE_SEP1SIDED
} mrtype_et;
#line 341
typedef enum {
  METIS_DBG_INFO       = 1,
  METIS_DBG_TIME       = 2,
  METIS_DBG_COARSEN    = 4,
  METIS_DBG_REFINE     = 8,
  METIS_DBG_IPART      = 16,
  METIS_DBG_MOVEINFO   = 32,
  METIS_DBG_SEPINFO    = 64,
  METIS_DBG_CONNINFO   = 128,
  METIS_DBG_CONTIGINFO = 256,
  METIS_DBG_MEMORY     = 2048,
} mdbglvl_et;
#line 356
typedef enum {
  METIS_OBJTYPE_CUT,
  METIS_OBJTYPE_VOL,
  METIS_OBJTYPE_NODE
} mobjtype_et;
Found header files ['metis.h'] in ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
          Popping language C
TEST checkSharedLibrary from PETSc.packages.metis(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:533)
TESTING: checkSharedLibrary from PETSc.packages.metis(config/BuildSystem/config/package.py:533)
  By default we don't care about checking if the library is shared
    Popping language C
    Pushing language C
TEST configureLibrary from PETSc.packages.parmetis(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/package.py:479)
TESTING: configureLibrary from PETSc.packages.parmetis(config/BuildSystem/config/package.py:479)
  Find an installation and check if it can work with PETSc
      Checking for a functional parmetis
              Looking for PARMETIS in directory starting with parmetis
              Could not locate an existing copy of parmetis:
                ['cmake-2.8.10.2', 'c2html-0.9.4', 'sowing-1.1.16e', 'metis-5.1.0-p1']
                Downloading parmetis
                  Downloading http://ftp.mcs.anl.gov/pub/petsc/externalpackages/parmetis-4.0.3-p1.tar.gz to /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_parmetis-4.0.3-p1.tar.gz
                  Extracting /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/_d_parmetis-4.0.3-p1.tar.gz
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages; chmod -R a+r parmetis-4.0.3-p1;find  parmetis-4.0.3-p1 -type d -name "*" -exec chmod a+rx {} \;
                  Found a copy of PARMETIS in parmetis-4.0.3-p1
                Pushing language C
                Popping language C
Have to rebuild parmetis, /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/parmetis != /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/parmetis
                      Configuring ParMETIS; this may take several minutes
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64 && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64 -DCMAKE_VERBOSE_MAKEFILE=1 -DGKLIB_PATH=../headers -DCMAKE_C_COMPILER="mpixlc_r" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING=" -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction " -DMETIS_USE_LONGINDEX=1 -DMETIS_USE_DOUBLEPRECISION=1
stdout:
-- The C compiler identification is XL 12.1.0
-- The CXX compiler identification is GNU 4.4.6
-- Check for working C compiler: /soft/compilers/wrappers/xl/mpixlc_r
-- Check for working C compiler: /soft/compilers/wrappers/xl/mpixlc_r -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Configuring done
-- Generating done
-- Build files have been written to: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64
                      Compiling ParMETIS; this may take several minutes
Executing: cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64 && make && make install
stdout:
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -H/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1 -B/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64 --check-build-system CMakeFiles/Makefile.cmake 0
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_start /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles/progress.marks
make[1]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64'
make -f libparmetis/CMakeFiles/parmetis.dir/build.make libparmetis/CMakeFiles/parmetis.dir/depend
make[2]: Entering directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64'
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64 && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_depends "Unix Makefiles" /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64 /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis/CMakeFiles/parmetis.dir/DependInfo.cmake --color=
Scanning dependencies of target parmetis
make[2]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64'
make -f libparmetis/CMakeFiles/parmetis.dir/build.make libparmetis/CMakeFiles/parmetis.dir/build
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 1
[  2%] Building C object libparmetis/CMakeFiles/parmetis.dir/akwayfm.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/akwayfm.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/akwayfm.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 2
[  5%] Building C object libparmetis/CMakeFiles/parmetis.dir/ametis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/ametis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/ametis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 3
[  7%] Building C object libparmetis/CMakeFiles/parmetis.dir/balancemylink.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/balancemylink.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/balancemylink.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 4
[ 10%] Building C object libparmetis/CMakeFiles/parmetis.dir/comm.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/comm.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/comm.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 5
[ 12%] Building C object libparmetis/CMakeFiles/parmetis.dir/csrmatch.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/csrmatch.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/csrmatch.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 6
[ 15%] Building C object libparmetis/CMakeFiles/parmetis.dir/ctrl.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/ctrl.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/ctrl.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 7
[ 17%] Building C object libparmetis/CMakeFiles/parmetis.dir/debug.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/debug.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/debug.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 8
[ 20%] Building C object libparmetis/CMakeFiles/parmetis.dir/diffutil.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/diffutil.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/diffutil.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 9
[ 23%] Building C object libparmetis/CMakeFiles/parmetis.dir/frename.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/frename.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/frename.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 10
[ 25%] Building C object libparmetis/CMakeFiles/parmetis.dir/gkmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/gkmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/gkmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 11
[ 28%] Building C object libparmetis/CMakeFiles/parmetis.dir/gkmpi.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/gkmpi.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/gkmpi.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 12
[ 30%] Building C object libparmetis/CMakeFiles/parmetis.dir/graph.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/graph.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/graph.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 13
[ 33%] Building C object libparmetis/CMakeFiles/parmetis.dir/initbalance.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/initbalance.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/initbalance.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 14
[ 35%] Building C object libparmetis/CMakeFiles/parmetis.dir/initmsection.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/initmsection.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/initmsection.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 15
[ 38%] Building C object libparmetis/CMakeFiles/parmetis.dir/initpart.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/initpart.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/initpart.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 16
[ 41%] Building C object libparmetis/CMakeFiles/parmetis.dir/kmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/kmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/kmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 17
[ 43%] Building C object libparmetis/CMakeFiles/parmetis.dir/kwayrefine.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/kwayrefine.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/kwayrefine.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 18
[ 46%] Building C object libparmetis/CMakeFiles/parmetis.dir/match.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/match.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/match.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 19
[ 48%] Building C object libparmetis/CMakeFiles/parmetis.dir/mdiffusion.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/mdiffusion.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/mdiffusion.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 20
[ 51%] Building C object libparmetis/CMakeFiles/parmetis.dir/mesh.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/mesh.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/mesh.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 21
[ 53%] Building C object libparmetis/CMakeFiles/parmetis.dir/mmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/mmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/mmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 22
[ 56%] Building C object libparmetis/CMakeFiles/parmetis.dir/move.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/move.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/move.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 23
[ 58%] Building C object libparmetis/CMakeFiles/parmetis.dir/msetup.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/msetup.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/msetup.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 24
[ 61%] Building C object libparmetis/CMakeFiles/parmetis.dir/node_refine.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/node_refine.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/node_refine.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 25
[ 64%] Building C object libparmetis/CMakeFiles/parmetis.dir/ometis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/ometis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/ometis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 26
[ 66%] Building C object libparmetis/CMakeFiles/parmetis.dir/pspases.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/pspases.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/pspases.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 27
[ 69%] Building C object libparmetis/CMakeFiles/parmetis.dir/redomylink.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/redomylink.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/redomylink.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 28
[ 71%] Building C object libparmetis/CMakeFiles/parmetis.dir/remap.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/remap.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/remap.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 29
[ 74%] Building C object libparmetis/CMakeFiles/parmetis.dir/renumber.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/renumber.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/renumber.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 30
[ 76%] Building C object libparmetis/CMakeFiles/parmetis.dir/rmetis.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/rmetis.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/rmetis.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 31
[ 79%] Building C object libparmetis/CMakeFiles/parmetis.dir/selectq.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/selectq.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/selectq.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 32
[ 82%] Building C object libparmetis/CMakeFiles/parmetis.dir/serial.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/serial.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/serial.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 33
[ 84%] Building C object libparmetis/CMakeFiles/parmetis.dir/stat.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/stat.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/stat.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 34
[ 87%] Building C object libparmetis/CMakeFiles/parmetis.dir/timer.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/timer.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/timer.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 35
[ 89%] Building C object libparmetis/CMakeFiles/parmetis.dir/util.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/util.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/util.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 36
[ 92%] Building C object libparmetis/CMakeFiles/parmetis.dir/wave.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/wave.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/wave.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 37
[ 94%] Building C object libparmetis/CMakeFiles/parmetis.dir/weird.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/weird.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/weird.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 38
[ 97%] Building C object libparmetis/CMakeFiles/parmetis.dir/wspace.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/wspace.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/wspace.c
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 39
[100%] Building C object libparmetis/CMakeFiles/parmetis.dir/xyzpart.c.o
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /soft/compilers/wrappers/xl/mpixlc_r   -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/headers -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/metis/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/.    -o CMakeFiles/parmetis.dir/xyzpart.c.o   -c /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/libparmetis/xyzpart.c
Linking C static library libparmetis.a
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -P CMakeFiles/parmetis.dir/cmake_clean_target.cmake
cd /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/libparmetis && /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_link_script CMakeFiles/parmetis.dir/link.txt --verbose=1
/usr/bin/ar cr libparmetis.a  CMakeFiles/parmetis.dir/akwayfm.c.o CMakeFiles/parmetis.dir/ametis.c.o CMakeFiles/parmetis.dir/balancemylink.c.o CMakeFiles/parmetis.dir/comm.c.o CMakeFiles/parmetis.dir/csrmatch.c.o CMakeFiles/parmetis.dir/ctrl.c.o CMakeFiles/parmetis.dir/debug.c.o CMakeFiles/parmetis.dir/diffutil.c.o CMakeFiles/parmetis.dir/frename.c.o CMakeFiles/parmetis.dir/gkmetis.c.o CMakeFiles/parmetis.dir/gkmpi.c.o CMakeFiles/parmetis.dir/graph.c.o CMakeFiles/parmetis.dir/initbalance.c.o CMakeFiles/parmetis.dir/initmsection.c.o CMakeFiles/parmetis.dir/initpart.c.o CMakeFiles/parmetis.dir/kmetis.c.o CMakeFiles/parmetis.dir/kwayrefine.c.o CMakeFiles/parmetis.dir/match.c.o CMakeFiles/parmetis.dir/mdiffusion.c.o CMakeFiles/parmetis.dir/mesh.c.o CMakeFiles/parmetis.dir/mmetis.c.o CMakeFiles/parmetis.dir/move.c.o CMakeFiles/parmetis.dir/msetup.c.o CMakeFiles/parmetis.dir/node_refine.c.o CMakeFiles/parmetis.dir/ometis.c.o CMakeFiles/parmetis.dir/pspases.c.o CMakeFiles/parmetis.dir/redomylink.c.o CMakeFiles/parmetis.dir/remap.c.o CMakeFiles/parmetis.dir/renumber.c.o CMakeFiles/parmetis.dir/rmetis.c.o CMakeFiles/parmetis.dir/selectq.c.o CMakeFiles/parmetis.dir/serial.c.o CMakeFiles/parmetis.dir/stat.c.o CMakeFiles/parmetis.dir/timer.c.o CMakeFiles/parmetis.dir/util.c.o CMakeFiles/parmetis.dir/wave.c.o CMakeFiles/parmetis.dir/weird.c.o CMakeFiles/parmetis.dir/wspace.c.o CMakeFiles/parmetis.dir/xyzpart.c.o
/usr/bin/ranlib libparmetis.a
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_report /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles  1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
[100%] Built target parmetis
make[1]: Leaving directory `/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64'
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -E cmake_progress_start /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64/CMakeFiles 0
make -f CMakeFiles/Makefile2 all
make[2]: Nothing to be done for `libparmetis/CMakeFiles/parmetis.dir/build'.
make -f CMakeFiles/Makefile2 preinstall
make[1]: Nothing to be done for `preinstall'.
Install the project...
/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/bin/cmake -P cmake_install.cmake
-- Install configuration: ""
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include/parmetis.h
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib/libparmetis.a
********Output of running make on parmetis follows *******
-- Configuring done
-- Generating done
-- Build files have been written to: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/arch-bgq-ibm-opt64CMake Warning:
  Manually-specified variables were not used by the project:
    METIS_USE_LONGINDEX
-- Installing: /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib/libparmetis.a********End of Output of running make on parmetis *******
Executing: cp -f /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/externalpackages/parmetis-4.0.3-p1/parmetis /gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/conf/parmetis
      Checking for library in Download PARMETIS: ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib/libparmetis.a']
      Contents: ['include', 'lib', 'bin', 'conf', 'externalpackages', 'share', 'man', 'doc']
TEST check from config.libraries(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/libraries.py:145)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:145)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
          Checking for functions [ParMETIS_V3_PartKway] in library ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib/libparmetis.a'] ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib/libmetis.a']
            Pushing language C
Executing: mpixlc_r -c -o /tmp/petsc-ITHdGX/config.libraries/conftest.o -I/tmp/petsc-ITHdGX/config.compilers -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/PETSc.utilities.cacheDetails -I/tmp/petsc-ITHdGX/config.headers -I/tmp/petsc-ITHdGX/PETSc.utilities.featureTestMacros -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.utilities.missing -I/tmp/petsc-ITHdGX/config.functions -I/tmp/petsc-ITHdGX/config.packages.MPI -I/tmp/petsc-ITHdGX/PETSc.utilities.scalarTypes -I/tmp/petsc-ITHdGX/config.libraries -I/tmp/petsc-ITHdGX/PETSc.packages.pthread  -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction  /tmp/petsc-ITHdGX/config.libraries/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char ParMETIS_V3_PartKway();
static void _check_ParMETIS_V3_PartKway() { ParMETIS_V3_PartKway(); }
int main() {
_check_ParMETIS_V3_PartKway();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpixlc_r  -o /tmp/petsc-ITHdGX/config.libraries/conftest    -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction /tmp/petsc-ITHdGX/config.libraries/conftest.o  -Wl,-rpath,/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib -L/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib -lparmetis -Wl,-rpath,/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib -L/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/lib -lmetis -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib -L/bgsys/drivers/V1R2M0/ppc64/spi/lib -L/bgsys/drivers/V1R2M0/ppc64/comm/xl/lib -L/soft/compilers/ibmcmp-may2013/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2013/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2013/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2013/vacpp/bg/12.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2013/lib64/bg/bglib64 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/powerpc64-bgq-linux/lib -ldl -lmpich -lopa -lmpl -lpami -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
            Defined "HAVE_LIBPARMETIS" to "1"
            Popping language C
      Checking for headers Download PARMETIS: ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
          Pushing language C
TEST checkInclude from config.headers(/gpfs/mira-home/adams/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['parmetis.h'] in ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
            Checking include with compiler flags var CPPFLAGS ['/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include', '/bgsys/drivers/V1R2M0/ppc64', '/bgsys/drivers/V1R2M0/ppc64/comm/sys/include', '/bgsys/drivers/V1R2M0/ppc64/spi/include', '/bgsys/drivers/V1R2M0/ppc64/spi/include/kernel/cnk', '/bgsys/drivers/V1R2M0/ppc64/comm/xl/include', '/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include']
Executing: mpixlc_r -E  -I/tmp/petsc-ITHdGX/config.setCompilers -I/tmp/petsc-ITHdGX/config.types -I/tmp/petsc-ITHdGX/PETSc.packages.pthread -I/tmp/petsc-ITHdGX/config.headers  -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include -I/bgsys/drivers/V1R2M0/ppc64 -I/bgsys/drivers/V1R2M0/ppc64/comm/sys/include -I/bgsys/drivers/V1R2M0/ppc64/spi/include -I/bgsys/drivers/V1R2M0/ppc64/spi/include/kernel/cnk -I/bgsys/drivers/V1R2M0/ppc64/comm/xl/include -I/gpfs/mira-home/adams/petsc/arch-bgq-ibm-opt64/include /tmp/petsc-ITHdGX/config.headers/conftest.c
stdout:
#line 37 "/bgsys/drivers/toolchain/V1R2M0-efix23/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6/../../../../powerpc64-bgq-linux/sys-include/stdint.h"
typedef signed char		int8_t;
typedef short int		int16_t;
typedef int			int32_t;
typedef long int		int64_t;
#line 49
typedef unsigned char		uint8_t;
typedef unsigned short int	uint16_t;
typedef unsigned int		uint32_t;
#line 56
typedef unsigned long int	uint64_t;
#line 66
typedef signed char		int_least8_t;
typedef short int		int_least16_t;
typedef int			int_least32_t;
typedef long int		int_least64_t;
#line 77
typedef unsigned char		uint_least8_t;
typedef unsigned short int	uint_least16_t;
typedef unsigned int		uint_least32_t;
typedef unsigned long int	uint_least64_t;
#line 91
typedef signed char		int_fast8_t;
typedef long int		int_fast16_t;
typedef long int		int_fast32_t;
typedef long int		int_fast64_t;
#line 104
typedef unsigned char		uint_fast8_t;
typedef unsigned long int	uint_fast16_t;
typedef unsigned long int	uint_fast32_t;
typedef unsigned long int	uint_fast64_t;
#line 120
typedef long int		intptr_t;
#line 123
typedef unsigned long int	uintptr_t;
#line 135
typedef long int		intmax_t;
typedef unsigned long int	uintmax_t;
#line 83 "/bgsys/drivers/V1R2M0/ppc64/comm/xl/include/mpi.h"
typedef int MPI_Datatype;
#line 102
static const MPI_Datatype mpich_mpi_char                              = ((MPI_Datatype)0x4c000101);
static const MPI_Datatype mpich_mpi_signed_char                = ((MPI_Datatype)0x4c000118);
static const MPI_Datatype mpich_mpi_unsigned_char            = ((MPI_Datatype)0x4c000102);
static const MPI_Datatype mpich_mpi_wchar                          = ((MPI_Datatype)0x4c00040e);
static const MPI_Datatype mpich_mpi_short                            = ((MPI_Datatype)0x4c000203);
