[petsc-dev] mkl_pardiso test
José David Bermeo López
jdbermeol at gmail.com
Thu Jun 26 14:20:22 CDT 2014
Hi, I would like to add a test to the repository for mkl_pardiso, looking
for mumps test, I sow test ex125.c that uses MUMPS or other solvers
depending on the option, so i have some questions:
1. Would be a good idea to add mkl_pardiso in that test(ex125.c)
2. For that test you load matrix A, is it a distributed matrix or a
sequential matrix.
3. You had html pages, for documentation of each solver, is this
automatically generated base on comments, or do I had to added my self.
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140626/ea9300c4/attachment.html>
