[petsc-dev] gmake does not make
Blaise A Bourdin bourdin at lsu.edu
Tue Jun 17 17:05:07 CDT 2014
On Jun 17, 2014, at 4:54 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> I just tried a simple build on a centos 5.2 [rhel 5.2 clone] - and the
> build went through fine..
> Does it work for you with --download-make?
It seems to be working, yes. I don’t know (and don’t want to know) what is wrong with the system’s make.
Blaise
> Satish
> [balay at login01 ~]$ cat /etc/issue
> CentOS release 5.2 (Final)
> Kernel \r on an \m
> [balay at login01 ~]$ gmake --version
> GNU Make 3.81
> Copyright (C) 2006  Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.
> There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
> PARTICULAR PURPOSE.
> This program built for x86_64-redhat-linux-gnu
> [balay at login01 petsc-dev]$ ./configure --with-mpi=0 --download-fblaslapack=1
> <snip>
> [balay at login01 petsc-dev]$    make PETSC_DIR=/home/balay/petsc-dev PETSC_ARCH=arch-linux2-c-debug all
> gmake[1]: Entering directory `/home/balay/petsc-dev'
> <snip>
>          FC arch-linux2-c-debug/obj/src/ksp/f90-mod/petsckspmod.o
>          FC arch-linux2-c-debug/obj/src/snes/f90-mod/petscsnesmod.o
>          FC arch-linux2-c-debug/obj/src/ts/f90-mod/petsctsmod.o
>     CLINKER /home/balay/petsc-dev/arch-linux2-c-debug/lib/libpetsc.so.3.04.4
> gmake[2]: Leaving directory `/home/balay/petsc-dev'
> gmake[1]: Leaving directory `/home/balay/petsc-dev'
> Now to check if the libraries are working do:
> make PETSC_DIR=/home/balay/petsc-dev PETSC_ARCH=arch-linux2-c-debug test
> On Tue, 17 Jun 2014, Satish Balay wrote:
>> 3.81 should work. Its on all our test boxes [ubuntu 12.04]
>> Satish
>> On Tue, 17 Jun 2014, Blaise A Bourdin wrote:
>>> I have 3.81. Which version is known to work? It is on a RHEL 5.10 machine (not mine...)
>>> Blaise
>>> On Jun 17, 2014, at 4:39 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> I thought this issue was fixed - but perhaps you have an ancient make.
>>>> What do you have for 'gmake --version'
>>>> does '--download-make' solve this issue?
>>>> Perhaps we need version check somewhere..
>>>> Satish
>>>>> Hi,
>>>>> I am running into another problem with petsc-dev (master) where make exits without error but also without building petsc. I tried make all-legacy but it seems broken (perhaps because of the prefix install) an dtries to build the target tree that does not exist
>>>>> Any idea?
>>>>> Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
