[petsc-dev] Updating MOAB version during download
Jed Brown jed at jedbrown.org
Mon Jun 16 21:20:26 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>> Are you going to add the appropriate upstream workflow to all the
>> --download packages?  This sounds intractable.
>   I am not putting upstream workflow into any download packages. I am
>   wanting to do something very simple, let —download-xxx replace me
>   manually git clone xxxx; git checkout yyyy on some package. That is
>   all. (Where yyy may be a branch or a commit-hash depending on the
>   circumstances).
It clones and checks out the commit.  You can checkout the BRANCH
(branches are all about how the upstream package CHANGES) when you want
to contribute upstream (and you're entirely on your own to match up with
their workflow).  Why is that not sufficient?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140616/a1367e4a/attachment.sig>
