[petsc-dev] Updating MOAB version during download
Satish Balay
balay at mcs.anl.gov
Mon Jun 16 16:24:30 CDT 2014
On Mon, 16 Jun 2014, Barry Smith wrote:
> When Vijay, or some one else doing something else says; hey Barry please take a look at my branch xyz and build it and test and add features a, b, c, ALL THEY SHOULD NEED TO TELL ME IS branch xyz, I check it out and start building. If they need to tell me also get branch wyx of moab and branch abc of XYZ then we are NOT using tools efficiently (let’s just email the files back and forth). Each branch should have all the information needed to build for that branch, this simply means each branch has IN the appropriate xxxx.py package file the correct information about what other packages versions to use. This is actually easy except for
Note: If I read this correctly you are not editing/fixing commiting to
moab repo.
To me it looks like you are 'mercurial subrepo' workflow. Perhaps an
equivalent thing exists for git. Jed might chime in.
And yes you can get equivalent thing with 'xxxx.py:gitcommit=xyz' - if
this is set correctly [not the gitcommit=branch/head thingy]. I think
this is what Jed was also advocating..
> merging to next and master where you may not want to drag along exactly the repository branch info that was used with the branch. (this relates to Vijay’s question).
Dragging gitcommit=xyz to master is not a problem [draging gitcommit=head is a problem]
> The tools manage the coordination, people don’t mange coordination with notes on scraps of paper and rumors in the hallway about what commit of moab they should use with what branch of petsc.
I agree one should use tools to simplify as much as possible. But configure should
not be the only tool that bears this burden. [to me workflow is partly a social
contract between team members to co-ordinate in a predetermined way].
> Jed has pointed out that a “branch” is not enough information, so what should we use in the xxx.py so that the correct thing is built when I build PETSc with a particular branch???
commit-id, tag.
Branch is also a 'tag' but its a moving tag - [with non-reproduceable
state]. I think this is Jed's objection. [and mine as well [wrt
gitcommit=master-head]
Satish
