[petsc-dev] _intel_fast_{memcpy,memset} configure tests?
Jed Brown jed at jedbrown.org
Mon Jun 16 10:12:09 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
> On Fri, 13 Jun 2014, Jed Brown wrote:
>> We are testing for these now, but never call them since
>> https://bitbucket.org/petsc/petsc/commits/9b5000abb3a60be67df1194dc2bfaf8b24ce60ad
>> I think we should remove those tests.  I wonder how many more configure
>> tests can be removed because their result is unused.
> I can push this one..
Looks good to me.
> $ git diff config/PETSc/Configure.py config/PETSc/utilities/missing.py |cat
> diff --git a/config/PETSc/Configure.py b/config/PETSc/Configure.py
> index 6568904..d0f83a2 100644
> --- a/config/PETSc/Configure.py
> +++ b/config/PETSc/Configure.py
> @@ -103,7 +103,7 @@ class Configure(config.base.Configure):
>                   'readlink', 'realpath',  'sigaction', 'signal', 'sigset', 'usleep', 'sleep', '_sleep', 'socket',
>                   'times', 'gethostbyname', 'uname','snprintf','_snprintf','lseek','_lseek','time','fork','stricmp',
>                   'strcasecmp', 'bzero', 'dlopen', 'dlsym', 'dlclose', 'dlerror','get_nprocs','sysctlbyname',
> -                 '_intel_fast_memcpy','_intel_fast_memset']
>      libraries1 = [(['socket', 'nsl'], 'socket'), (['fpe'], 'handle_sigfpes')]
>      self.headers.headers.extend(headersC)
>      self.functions.functions.extend(functions)
> diff --git a/config/PETSc/utilities/missing.py b/config/PETSc/utilities/missing.py
> index b02b3a7..29a2c72 100644
> --- a/config/PETSc/utilities/missing.py
> +++ b/config/PETSc/utilities/missing.py
> @@ -138,21 +138,6 @@ if (drand48_ptr() > 0.5) return 1;
>        self.popLanguage()
>      return
> -  def configureMissingIntelFastPrototypes(self):
> -    if self.functions.haveFunction('_intel_fast_memcpy'):
> -      self.addPrototype('#include <stddef.h> \nvoid *_intel_fast_memcpy(void *,const void *,size_t);', 'C')
> -      if hasattr(self.compilers, 'CXX'):
> -        self.pushLanguage('C++')
> -        self.addPrototype('#include <stddef.h> \nvoid *_intel_fast_memcpy(void *,const void *,size_t);', 'extern C')
> -        self.popLanguage()
> -    if self.functions.haveFunction('_intel_fast_memset'):
> -      self.addPrototype('#include <stddef.h> \nvoid *_intel_fast_memset(void *, int, size_t);', 'C')
> -        self.addPrototype('#include <stddef.h> \nvoid *_intel_fast_memset(void *, int, size_t);', 'extern C')
> -    return
>    def configure(self):
>      self.executeTest(self.configureMissingDefines)
>      self.executeTest(self.configureMissingUtypeTypedefs)
> @@ -160,5 +145,4 @@ if (drand48_ptr() > 0.5) return 1;
>      self.executeTest(self.configureMissingSignals)
>      self.executeTest(self.configureMissingGetdomainnamePrototype)
>      self.executeTest(self.configureMissingSrandPrototype)
> -    self.executeTest(self.configureMissingIntelFastPrototypes)
>      return
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140616/555f8123/attachment.sig>
