[petsc-dev] PETSc release last chance for code changes
Satish Balay
balay at mcs.anl.gov
Sun Jun 15 10:28:37 CDT 2014
On Thu, 12 Jun 2014, Barry Smith wrote:
> Please get all changes into master before 9pm central time USA on Sunday June 15th that you would like in the release. At that time Satish will make a release branch and the only changes allowed in that release branch will be bug fixes that do not change the API.
Perhaps some of these branches [which are already merged to next] should be merged to master?
[and if they are false positives - perhaps those branches should be deleted?]
thanks,
Satish
$ candidate-branches next master
Candidate for master: refs/remotes/origin/irving/doc-cleanup Fri Jan 31 23:42:04 2014 -0700
Candidate for master: refs/remotes/origin/irving/snes-ex12-cleanup Fri Dec 13 15:24:09 2013 -0800
Candidate for master: refs/remotes/origin/jed/log-event-lookup Thu Apr 17 18:39:48 2014 -0600
Candidate for master: refs/remotes/origin/jed/mat-ptap-maij-bs Thu Apr 17 12:06:29 2014 -0600
Candidate for master: refs/remotes/origin/jed/vecghostgetvalues Sat Jun 14 22:28:04 2014 -0500
Candidate for master: refs/remotes/origin/jed/vecop Thu Apr 17 08:43:03 2014 -0600
Candidate for master: refs/remotes/origin/karpeev/fix-ksp-pcgasm Wed Jun 4 06:14:36 2014 -0500
Candidate for master: refs/remotes/origin/knepley/feature-optcontrol-mg Wed Jun 11 14:34:25 2014 -0500
Candidate for master: refs/remotes/origin/madams/sr-driver4 Fri Oct 25 14:43:12 2013 -0400
Candidate for master: refs/remotes/origin/mlange05/fix-gmsh-coordinates Tue Apr 1 10:45:39 2014 +0100
Candidate for master: refs/remotes/origin/paulmullowney/aijcusp-ellpack-fix Tue Aug 6 10:34:13 2013 -0500
Candidate for master: refs/remotes/origin/prbrune/sf-examplefix Fri Dec 13 11:38:36 2013 -0600
Candidate for master: refs/remotes/origin/prbrune/snes-ex19vtkoutput Wed Jul 24 10:40:02 2013 -0500
Candidate for master: refs/remotes/origin/sarich/fix-tao-valgrind-warning Fri Apr 4 10:58:28 2014 -0500
Candidate for master: refs/remotes/origin/sarich/tao-purge-dm Fri Jun 13 11:10:05 2014 -0500
Candidate for master: refs/remotes/origin/stefano_zampini/pcbddc-applytranspose Mon Nov 18 16:32:38 2013 +0100
Candidate for master: refs/remotes/origin/stefano_zampini/pcbddc-globalordering-api Tue Nov 12 17:04:42 2013 +0100
Candidate for master: refs/remotes/origin/stefano_zampini/pcbddcgraph-improved Tue Jun 3 16:44:29 2014 +0300
Candidate for master: refs/remotes/origin/stefano_zampini/pcredundant-transpose Tue Jan 7 14:52:15 2014 +0100
