[petsc-dev] getting ready for PETSc release
Sun Jun 8 12:45:28 CDT 2014
On Sun, Jun 8, 2014 at 12:20 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Sun, Jun 8, 2014 at 3:41 AM, Jed Brown <jed at jedbrown.org> wrote:
> >> Where is your Riemann solver interface?  I see
> >> DMPlexTSSetRHSFunctionLocal which has nothing in its name indicating
> >> that it is a Riemann solver, has no support for non-conservative systems
> >> (for which the Riemann solver returns a wave decomposition because
> >> "flux" is not defined), and cannot support a transverse solve (to double
> >> or triple the stable time step).  Note that this interface has a
> >> context, unlike your FE quadrature functions.  (Interface inconsistency
> >> is evil.)  Also, ex11 does not offer characteristic reconstruction.
> >> I meant for ex11 to be a demonstration of one way to solve these
> >> problems, but certainly not THE CANONICAL WAY.  I do not agree with
> >> moving it into PETSc, especially not using a name like PetscProblem.
> >> I'd rather it be in a separate project (that was the idea with the
> >> parmod repository, but I don't think you ever used that).
> > Fine, but what in the FV interface is inappropriate for this. Also, I
> > distrust the argument here because some of what you describe is
> > incredibly special-purpose, namely it will only work on Cartesian
> > grids, and thus should not determine large parts of the top level
> > interface.
> What only works on Cartesian grids?  Wave decomposition and such works
My understanding was that the Clawpack algorithms worked only on Cartesian
grids. Are these "mode decomposed"?
> on unstructured grids.  PetscProblem is the special-purpose thing that
> excludes large classes of good methods.  I think it is inappropriate to
> use the PetscProblem namespace for a specific class of methods.
I think you have an idiosyncratic and expansive understanding of the word
"Problem".
It can also mean a "difficulty", "unwelcome or harmful situation", or
"complication". If
its really down to the word, I could see changing it to reduce the number
of ultimately
unhelpful emails.
> >> >> >> > Maybe MOOSE does. However, neither of those has good integration
> >> with
> >> >> >> > the solver (I have discussed this personally with Roy and Derek
> and
> >> >> >> > they agree).
> >> >> >> You have to be able to formulate a similar scope of problems
> before
> >> you
> >> >> >> get to argue fine points of supporting geometric multigrid and the
> >> like.
> >> >> >> FWIW, it does not support the solve structure we use in pTatin so
> >> gives
> >> >> >> up significant performance relative to existing packages that use
> >> solver
> >> >> >> algorithms you want.
> >> >> > I asked you to help with this.
> >> >> I pointed out that your interface can't do that algorithm and I
> showed
> >> >> you code that can.  I'm not sure what you want me to do.  Change your
> >> >> interface to be able to do that method fast, implying other data
> >> >> structure changes and possible loss of functionality that you want?
> >> > Of course, there is nothing else to do but point out shortcomings.
> That
> >> > makes things easy.
> >> Some problems are not appropriate for a given level of abstraction.  I
> >> believe you are creating a specialized high-level PDE interface, which I
> >> consider to be out of scope for PETSc.  Imagine if KSP was only capable
> >> of solving scalar SPD problems.  "It's so easy to point out
> >> shortcomings" and yet those shortcomings define a scope that is
> >> incompatible with the name and not in the spirit of the software
> >> package.
> > KSP is of course only for Krylov solvers, and we dump everything else in
> PC.
> > There is nothing wrong with limiting the scope of an abstraction to a
> useful
> > subset. This is the essence of design, and a small-minded committment to
> > absorbing everything will dilute the interface to nothing.
> PetscProblem is a name that claims to be far more than it is.  You can't
Again, there are no claims in a name. Decades of linguistic research attest
to
the malleability of names.
> compose these things because the scope is so limited and can't even
> commit to using them because you'll end up spending lots of time
> extending the interface (which is not currently user-extensible and
> perhaps not useful to become user-extensible).
> Why can't you develop this in a separate package?
Too much overhead for too little benefit.
> >> >> How else would you describe it?  I suggested
> >> >> DMMattsCoolDiscretizationTSSetIFunctionVolumetricQuadrature().
> >> > Its not a DM.
> >> You access it via DMGetProblem() and your interfaces are analogous to
> >> the DM-specific interfaces we have used in the past.
> >> You might recall that we had a discussion a couple years ago about
> >> whether DM should be a "function space" or should hold the problem
> >> definition (via callbacks).  I argued for separation and still think
> >> that unadorned function spaces are useful, but others (especially Barry)
> >> wanted to limit the number of objects.  And in fact, the physics
> >> influences things like coarse-space homogenization and grid transfer
> >> within solver algorithms, so now I mixed opinions about it.  But in any
> >> case, we made a decision and built code around the DM owning that stuff.
> >> If you want to fundamentally change that model, it needs to be a
> >> project-wide decision, implemented consistently across projects.
> >> From the two examples that use PetscProblem, I think the issue is that
> >> you want it to work with DMDA and DMPlex because the formulation does
> >> not depend on grid topology, but the naming convention for
> >> implementation-specific functions uses different namespaces.  But we can
> >> have DM functions that are implemented by multiple implementations.  So
> >> maybe this maps to
> >> DMTSSetIFunctionMattsCoolDiscretizationVolumetricQuadrature().
> > 1) Volumetric here is inappropriate because it supports boundary
> integrals
> Through a different function, PetscProblemSetBdResidual().  (I will also
> complain that this does not support different boundary types.)
Criticize away. I did not want to give you the idea that criticism is
unwelcome.
> > 2) It is supposed to support both FEM and FVM
> But you need new functions for FV because PetscProblemSetResidual
> definitely does not support it.
Yep.
> > 3) It is a sub-object, just like PetscLayout, meant to operate is service
> > of a DM.
> >      Its never used apart from it, just like PetscLayout and Vec/Mat.
> > Layout is
> >      also a generic name, but Layout only supports the simples kind of
> > partition,
> >      and thus cannot do more complex things, but we did not have a huge
> >      discussion about it. I still fail to see how this is a big deal.
> PetscLayout contains nontrivial data size and can be shared between
> multiple objects (and we should do a better job of that sharing because
> PetscLayout storage is not trivial with a million MPI ranks if each
> object has its own).
PetscProblem can be shared between multiple objects, and has non-trivial
sizes.
There is no point to the above paragraph and it dodges the main issue of the
question.
   Matt
> We added the DMTS, DMSNES, etc., to hold functions of this sort.  Those
> are shared between nested solvers via a DM.  Now you're adding a new
> interface that does not explicitly name a problem level (TS, SNES, etc.)
> or a class of discretizations.  (I'm using "discretization" here in a
> general sense, independent of mesh topology.)  This interface
> fragmentation is inconsistent and forces the user to deal with yet
> another object.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140608/5db56685/attachment.html>
