[petsc-dev] getting ready for PETSc release
    Jed Brown
    jed at jedbrown.org
    Fri Jun  6 12:33:20 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> On Thu, Jun 5, 2014 at 8:37 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>    We’ll be making a PETSc release in a few days so please get anything
>> you need into next for testing and movement over to master.
> I want knepley/feature-problem-class and knepley/fix-fe-gpu in. They are
> pushed to 'next; for tonight, and can be in master tomorrow. I
> expect no problems.
How do we note that these interfaces are not stable and will likely
change soon after the release?  (At least I think the current
arrangement is brittle and either will not last or will not be used
much.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140606/2679ec56/attachment.sig>
