[petsc-dev] known-mpi-shared-libraries
    Jed Brown
    jed at jedbrown.org
    Fri Jun  6 08:16:53 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> The other packages just break. We put it in to interact with Python,
> which requires an MPI shared library.
Huh?  We're building PETSc, which does not depend on Python (except for
configure).  Why should PETSc configure be deciding how to make the
library work with some Python that may never exist?  I must not
understand what you're trying to say.
> If you do not check, the executable just breaks in weird ways, like it
> would for PyTrilinos. The check is an actual check, but it requires
> running.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140606/facc1ecd/attachment.sig>
