[petsc-dev] make test after make install is not right
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Jul 27 21:58:46 CDT 2014
  Our
     make install
     unset PETSC_ARCH
     export PETSC_DIR=/installed_location
     make test
  appears to be not working correctly
~/Src/petsc  maint $ export PETSC_DIR=/Users/barrysmith/petsc-prefix
~/Src/petsc  maint $ make test_build
Running test examples to verify correct installation
Using PETSC_DIR=/Users/barrysmith/Src/petsc and PETSC_ARCH=arch-prefix
<<<<<<<<<<   ^^^^ Note here it lists the configured PETSC_DIR and PETSC_ARCH
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI processes
Fortran example src/snes/examples/tutorials/ex5f run successfully with 1 MPI process
Completed test examples
~/Src/petsc  maint $ echo $PETSC_DIR
~/Src/petsc  maint $ echo $PETSC_ARCH
~/Src/petsc  maint $ ls conf/
adic.init          adicmf.init        gmakegen.py        rules              test.log           variables
adicmastercontrol  adicmfb.init       petscvariables     test               testmaingen.pyc
~/Src/petsc  maint $ more conf/petscvariables
include /Users/barrysmith/Src/petsc/arch-prefix/conf/petscvariables
<<<<<<<<<<<<<   At the top of makefile is
# next line defines PETSC_DIR and PETSC_ARCH if they are not set
include ././${PETSC_ARCH}/conf/petscvariables
include ${PETSC_DIR}/conf/variables
include ${PETSC_DIR}/conf/rules
include ${PETSC_DIR}/conf/test
<<<<<<<<<<<<<<<< This means the PETSC_DIR is ALWAYS set to the configure one, not the installed one
~/Src/petsc  maint $ rm conf/petscvariables
makefile:15: conf/petscvariables: No such file or directory
make: *** No rule to make target `conf/petscvariables'.  Stop.
<<<<<<<<<<<<<<<<<  How to fix this? should make install remove the stuff in conf/petscvariables?
~/Src/petsc  maint $ touch conf/petscvariables
Using PETSC_DIR=/Users/barrysmith/petsc-prefix and PETSC_ARCH=
<<<<<<<<<<<<<<<< That at least uses the right libraries/includes to run the tests
