[petsc-dev] What happened to -log_summary_python?
Thu Jan 30 23:05:41 CST 2014
On Thu, Jan 30, 2014 at 6:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Matt,
>     Ok, I took a look at that and see why I deleted it.
>    I had hoped my new viewer with PetscLogView_Detailed() which can be
> accessed with -log_view :filename:ascii_info_detail could be used instead
> of PetscLogViewPython()
I like your new organization. I was trying to output in a format that did
not require us to write another parser. I will
reintegrate the code into your new setup.
    Matt
>    It, in theory, provides more information since it provides the values
> for each process so you can do any kind of cross process statistics you
> want. Or you can just add up the values from each process.
>    Anyways, if you can't use it let me know and we can iterate on
> PetscLogView_Detailed() to make it useful.
>    Barry
> On Jan 30, 2014, at 4:31 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > I was using that.
> >    Matt
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140130/f854f93e/attachment.html>
