[petsc-dev] configure failed after update of OSX
Mark Adams
mfadams at lbl.gov
Thu Jan 30 19:22:45 CST 2014
> $ sudo port install mpich-default
> $ sudo port select --set mpi mpich-mp-fortran
> Then try to build PETSc (minus the --download-mpich and CC, CXX, FC
> options).
That worked
> You could also try to install most of the external packages:
> $ sudo port install hypre ml parmetis metis hdf5-18 netcdf triangle \
> superlu superlu_dist mumps
This instal seemed to work but how would I configure PETSc to use them?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140130/fcdc15c6/attachment.html>
