[petsc-dev] PetscMalloc for size zero
Jed Brown
jed at jedbrown.org
Thu Jan 30 18:02:05 CST 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
> On Jan 30, 2014, at 3:00 PM, Jed Brown <jed at jedbrown.org> wrote:
> Yes, but in the debugger (or with a printf %p there is no portable
> way for a user to know that the pointer is invalid) whereas with
> NULL they would immediately know. A null pointer that leads to a
> segv conveys something different to someone debugging than some
> address where the user doesn’t know if that address came from a
> malloc(0) or some completely different way (like crazy pointer
> arithmetic).
True, but an array length is needed anyway and any references to that
pointer can still be detected by the memory checker. Also, if someone
really wants to get NULL (or a special value), we can use a malloc
implementation that does so. (We can add a runtime option for this if
someone wants it for debugging.)
> If you are trying to debug some code that you didn’t personally
> write (that may have been written by an idiot) it is rarely
> possible for you to know where this out-of-bound information is.
Fair, but you'll have as much trouble doing anything with that code.
> We would obviously turn off all of this completely when running
> under valgrind to let valgrind do its thing.
> Side note; PetscMallocn() needs much more error checking: for
> example PetscMalloc2(-8,&x1,10,&x2) would not be detected as a
> problem but is problematic.
Is this a problem actually encountered in practice?
> Since we have to add all this error checking (likely by making
> these beasts functions) adding a return NULL on 0 won’t muck up
> the code much.
We can't make them functions because we use the type sizes and pass
__FILE__, __LINE__. I'm not motivated to change this unless someone
demonstrates that this is a non-theoretical problem.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140130/68d53fd4/attachment.sig>
