[petsc-dev] getting data out of a PetscFE simulation
Jed Brown
jed at jedbrown.org
Tue Jan 28 22:24:57 CST 2014
Matthew Knepley <knepley at gmail.com> writes:
>> > In ex62:
>> > if (user.runType == RUN_FULL) {
>> > PetscViewer viewer;
>> > Vec uLocal;
>> > const char *name;
>> > ierr = PetscViewerCreate(PETSC_COMM_WORLD, &viewer);CHKERRQ(ierr);
>> > ierr = PetscViewerSetType(viewer, PETSCVIEWERVTK);CHKERRQ(ierr);
>> > ierr = PetscViewerSetFormat(viewer,
>> > PETSC_VIEWER_ASCII_VTK);CHKERRQ(ierr);
>> > ierr = PetscViewerFileSetName(viewer, "ex62_sol.vtk");CHKERRQ(ierr);
>> Please don't do this. Just set the type to PETSCVIEWERVTK, set the file
>> name to some *.vtu; the VTK viewer will infer output format from
>> extension and write the VTU XML format with binary-appended data in a
>> fairly fast and memory-scalable way. Then
>> VecView(u,viewer);
> I think Jed is wrong here. You need to be using local vectors since
> they have BC and constraints in them. Please explain how your VTU
> format will magically put them in.
We made this work when I threw a temper tantrum while we were writing TS
ex11.c (late 2012).
PetscErrorCode VecView_Plex(Vec v, PetscViewer viewer)
DM dm;
PetscBool isvtk;
PetscErrorCode ierr;
PetscFunctionBegin;
ierr = VecGetDM(v, &dm);CHKERRQ(ierr);
if (!dm) SETERRQ(PetscObjectComm((PetscObject)v), PETSC_ERR_ARG_WRONG, "Vector not generated from a DM");
ierr = PetscObjectTypeCompare((PetscObject) viewer, PETSCVIEWERVTK, &isvtk);CHKERRQ(ierr);
if (isvtk) {
Vec locv;
const char *name;
ierr = DMGetLocalVector(dm, &locv);CHKERRQ(ierr);
ierr = PetscObjectGetName((PetscObject) v, &name);CHKERRQ(ierr);
ierr = PetscObjectSetName((PetscObject) locv, name);CHKERRQ(ierr);
ierr = DMGlobalToLocalBegin(dm, v, INSERT_VALUES, locv);CHKERRQ(ierr);
ierr = DMGlobalToLocalEnd(dm, v, INSERT_VALUES, locv);CHKERRQ(ierr);
ierr = VecView_Plex_Local(locv, viewer);CHKERRQ(ierr);
ierr = DMRestoreLocalVector(dm, &locv);CHKERRQ(ierr);
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140128/bdfaa6f8/attachment.sig>
