[petsc-dev] Possible bugs when using TS with ViennaCL (continued)
Karl Rupp
rupp at mcs.anl.gov
Tue Jan 28 15:22:13 CST 2014
Hi Mani,
> Sorry, you're right. Indeed even when I use the Intel OpenCL to run on
> the CPU, the memory usage keeps increasing as the run progresses but the
> CPU RAM is so much that the run doesn't crash till the time I ran it. So
> basically there is a memory leak.
Thanks, that certainly helps with the diagnostics. :-)
Best regards,
Karli
> On Tue, Jan 28, 2014 at 2:58 PM, Karl Rupp <rupp at mcs.anl.gov
> <mailto:rupp at mcs.anl.gov>> wrote:
> Hi Mani,
> > Note that the error occurs in the middle of the run, after a certain
> number of time steps. The time step at which it fails is
> different for
> the two machines for which I tested. And it only happens when I
> use the
> GPU. The OpenCL backend using a CPU with Intel opencl works fine.
> what exactly do you mean by 'works fine' for the Intel OpenCL SDK?
> Do you see an increase in memory, or is the memory consumption
> constant throught the run? You won't necessarily see an allocation
> failure because your machine will most likely have enough main RAM
> to compensate.
> Best regards,
> Karli
