[petsc-dev] resurrecting the finite element energy functions thread
Matthew Knepley
knepley at gmail.com
Thu Jan 23 08:43:56 CST 2014
On Wed, Jan 22, 2014 at 4:16 PM, Geoffrey Irving <irving at naml.us> wrote:
> On Tue, Jan 21, 2014 at 9:52 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Lisandro Dalcin <dalcinl at gmail.com> writes:
> >> I thought to do that in PetIGA, but then realized that a reducer+eval
> >> at quadrature points+MPI_MAX sounds weird (though I can imagine some
> >> use cases). A reduce with MPI_MAX is a lucky consequence of computing
> >> integrals through quadrature.
> > Suppose we want to know the max stress in a structure to determine
> > whether it will be damaged by a given loading scenario? The quadrature
> > points are not sufficient to determine a max stress for the discrete
> > solution, but it is a convergent method for determining the max stress
> > of the continuum structure.
> So I wrote PetscFEIntegrateScalars, but then realized that I have no
> idea how to organize the DM level. Residuals and jacobians can be
> only be "turned on" via DMSNESSetFunctionLocal, and then accessed via
> the SNES. This would work in the specific case of an objective, but
> not for the general case where we're integrating some arbitrary number
> of PetscScalars.
> Where should the outer "integrate a bunch of scalars over a DM with a
> bunch of PetscFE" objects go, and what should it be called? The
> naming conventions at this level are rather obscure.
> Relatedly, is it going to be a problem if I want to use PetscFE
> routines outside an SNES, such as inside a TAO optimization problem?
> Should I make a dummy SNES and then point TAO to SNESComputeObjective
> and such, or is there a cleaner way?
1) I have been putting functions like this (DMPlexComputeL2Diff) in DM
because there
seemed to be no other place.
2) Nope you can use them anywhere
Matt
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140123/42ae12d4/attachment.html>
