[petsc-dev] DMplex reader / viewers
    Tim Tautges (ANL)
    tautges at mcs.anl.gov
    Wed Jan 22 12:59:52 CST 2014
That's funny, I was thinking the same about DMPlex. :)
- tim
On 01/22/2014 12:45 PM, Matthew Knepley wrote:
> Tim,
>    I do not consider MOAB a real alternative here.
>       Matt
> On Wed, Jan 22, 2014 at 12:18 PM, Tim Tautges (ANL) <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>> wrote:
>     On 01/21/2014 05:58 PM, Gorman, Gerard J wrote:
>                 I am not sure if Exodus has a good solution here. As far as I understand, exodus is inherently
>                 sequential, even
>                 when implemented with HDF5 instead of netcdf. I would also worry about third party support for exodus
>                 files using
>                 HDF5 as their storage format. Exodus has an parallel extension called nemesis, but I can?t figure out
>                 how how
>                 their concept of ghost point and cells works. The documentation on this point is really unclear.
>         I have to admit I was kind of hoping that ExodusII folks would have come on a bit more on the parallel IO front (I’m
>         assuming those guys also run large simulations…). That said, I see this as a two stage process: first integrate with
>         DMPlex as that should give the high level abstraction for read/write to file; secondly extend the family of
>         readers/writers. At least this way there will be some agility and interoperability between different formats, and it
>         will not be too disruptive to the application codes when a different formats adopted.
>     My impression is that the ExodusII people are working within the context of code frameworks more than disk file
>     formats to do this, e.g. in Trilinos and Sierra.  I don't think the ExoII file format by itself is very conducive to
>     representing parallel, which is why Nemesis writes an annotation (though, I haven't followed ExoII developments
>     closely since they went open source several years back).
>                 b. Do ?poor man? parallel I/O where each CPU does its own I/O, and possibly create interface matching
>                 files ? la
>                 nemesis or SILO. Maybe, we can save enough information on the parallel layout in order to easily write an
>                 un-partitionner as a post-processor.
>         I am pretty sure that if we are writing everything in slabs to a HDF5 container we do not have to worry too much
>         about the parallel layout although some clear optimisations are possible. In the  worst case it is a three stage
>         process of where we perform a parallel read of the connectivity, scatter/gather for continuous numbering, parallel
>         repartitioning and subsequent parallel read of remaining data. Importantly, it is at least scalable.
>     We've seen fragmentation with unstructured meshes being a problem too, and you won't escape that even with
>     renumbering (though reading then migrating would address that, at the cost of some additional communication and
>     possibly reading to figure out where things need to go).
>             Depending on the degree of direct interaction/automation in those interactions between the mesh and Petsc, there
>             are other options as well.  One that we're developing, based on the MOAB library, can read/write (in serial)
>             ExodusII, and also supports parallel read/write using its own HDF5-based format.  Parallel I/O robustness
>             has been
>             iffy above ~16k procs and 32M-64M hex/tet elements, but for smaller problems it should work.  We're in the
>             process
>             of developing direct support for going between a mesh defined with fields (called tags in MOAB) and petsc
>             vectors.
>             MOAB has pretty solid support for things like computing sharing and ghosting between procs and
>             exchanging/reducing
>             field values on those entities.  Viz is supported either by compiling a VTK/Paraview plugin that pulls the
>             mesh/fields through MOAB or by translating to VTK (also supported directly from MOAB); Visit also has a
>             plugin you
>             can enable.  See http://trac.mcs.anl.gov/__projects/ITAPS/wiki/MOAB
>             <http://trac.mcs.anl.gov/projects/ITAPS/wiki/MOAB> for details of MOAB; the petsc integration stuff
>             is on a bitbucket branch of petsc owned by Vijay Mahadevan.
>         Another reason this could be of great interest is that MOAB supports (according to the docs) geometric topology
>         which
>         could be used when adapting the mesh on a curved surface for example - another item on my which list.
>     Yes, MOAB's file format can handle definitions of groupings (and relations between the groups) necessary to
>     represent geometric topology.  What you use for the shape evaluation of those geometric surfaces is another question
>     though.  If you're wanting to do that using a reconstructed continuous patch, MOAB has some code to do that too,
>     though it's not as good as the latest stuff in that area (from Jiao at Stony Brook).
>     Is it
>         integrated to PETSc via the plex or does this essentially replace the functionality of the plex?
>     It's not via plex, but I'm pretty sure all the mesh-related functionality available through plex is available
>     through different API functions in MOAB.
>     Why does it break
>         down for more than 16k procs?
>     It's a combination of things:
>     - maximizing generality means we're using more than just 2 or 3 tables, because in addition to nodes and elements,
>     we need groupings, whose membership determines whether a group is resident on a given processor, etc, and that
>     strongly affects scaling
>     - that same generality causes us to hit an MPI/IO bug on IBM (though we haven't checked on Q yet to see if that's
>     been addressed, it might have been); we've worked with ANL I/O guys off and on on this, and hope to get back to that
>     on Q soon
>     - we do single file parallel I/O, without any 2-phase (communicate down to I/O nodes then do I/O), and that hits
>     HDF5 pretty hard; we're working with hdfgroup to explore that
>     We haven't done any benchmarking on a Lustre system yet, but I expect that to do worse than IBM, because of the many
>     tables thing (my impression is that Lustre doesn't handle frequent metadata reads well)
>     is it just a case that Lustre gets hammered? What magic sauce is used by high order FEM
>         codes such as nek500 that can run on ~1m cores?
>     Those codes go for a much more restricted I/O data case, which allows them to specialize and do their own
>     implementation of parallel I/O.  So, Nek5000 has its own implementation of poor man's parallel, they repeat vertices
>     in the file that are logically the same (shared between hexes), and they don't really do subsets.  I think that's
>     great to do if you have to, but I'm still hoping for more support in that direction from general libraries.
>             libmesh also maintains its own DMlibmesh, but I'm not sure how solid their support for large mesh / parallel
>             I/O is
>             (but they've been working on it recently I know).
>         Are there any other formats that we should be considering? It’s a few years since I tried playing about with CGNS -
>         at the time its parallel IO was non-existent and I have not seen it being pushed since. XDMF looks interesting as it
>         is essentially some xml metadata and a HDF5 bucket. Is anyone championing this?
>     Don't know about XDMF.  I know there's been a bunch of work on SILO and its parallel performance fairly recently (3
>     or 4 yrs ago) and it's used heavily inside LLNL.
>     - tim
>         Cheers Gerard
>     ==============================__==============================__====
>     "You will keep in perfect peace him whose mind is
>        steadfast, because he trusts in you."               Isaiah 26:3
>                   Tim Tautges            Argonne National Laboratory
>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)      (telecommuting from UW-Madison)
>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>      1500 Engineering Dr.
>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>      Madison, WI 53706
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any
> results to which their experiments lead.
> -- Norbert Wiener
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
