[petsc-dev] CFLAGS and COPTFLAGS
Jed Brown
jed at jedbrown.org
Wed Jan 22 11:31:34 CST 2014
Sean Farley <sean.michael.farley at gmail.com> writes:
> jed at jedbrown.org writes:
>>>> $prefix/bin/petsc-${version}-${arch}-config
>>>> and symlink $prefix/bin/petsc-config to it by default?
>>>> Then always namespace libraries and includes?
>>> This is what I had in mind as well. Though, distributions would remove
>>> the symlink since that would conflict.
>> Debian would probably manage it through /etc/alternatives.
> Just a note that MacPorts would manage it through etc/select :-)
Thanks, Sean. (I really was asking you as much as Barry/Matt/Satish/etc.
Packaging is a different environment.)
What do the rest of you think?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140122/8a6bfef2/attachment.sig>
