[petsc-dev] Petsc+ViennaCL usage
Mani Chandra
mc0710 at gmail.com
Wed Jan 22 11:26:25 CST 2014
Thanks Karl. Is there anyway I can get the build info?
Also, my system is such that I have the GPU on one platform (0) and the CPU
on another (1). When I try using -viennalcl_device_cpu, it still uses the
GPU cause I think that it defaults to the first platform it finds which
only has the GPU. Is there some way to toggle between the platforms or do
you suggest that I manually pass in the contexts into viennacl?
Cheers,
Mani
On Tue, Jan 21, 2014 at 3:28 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi Mani,
> > I like to pass in "-cl-nv-verbose" for compilation on nvidia cards.
> ok, in such case you also want access to the compiler output, don't you?
> Also, I pass in parameters, for ex "-D Nx=128 -D Ny=128". I'll look at
>> the ViennaCL api.
> Use
> viennacl::ocl::current_context().build_options("flags_here");
> and make sure you have VIENNACL_WITH_OPENCL defined for your compilation
> unit. I'll extend the PETSc API suitably when updating the ViennaCL
> bindings to the latest 1.5.1 release.
> Best regards,
> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140122/d9a5f44b/attachment.html>
