[petsc-dev] resurrecting the finite element energy functions thread
Jed Brown
jed at jedbrown.org
Tue Jan 21 23:52:34 CST 2014
Lisandro Dalcin <dalcinl at gmail.com> writes:
> I thought to do that in PetIGA, but then realized that a reducer+eval
> at quadrature points+MPI_MAX sounds weird (though I can imagine some
> use cases). A reduce with MPI_MAX is a lucky consequence of computing
> integrals through quadrature.
Suppose we want to know the max stress in a structure to determine
whether it will be damaged by a given loading scenario? The quadrature
points are not sufficient to determine a max stress for the discrete
solution, but it is a convergent method for determining the max stress
of the continuum structure.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140121/978d64c2/attachment.sig>
