[petsc-dev] PCASM+KSPGMRES
Andrea Lani
andrea.lani at gmail.com
Wed Jan 22 06:25:11 CST 2014
Great! I'm happy not to be the only one having the problem
On Jan 22, 2014, at 1:19 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi again,
> > Well, I don't usually use PETSc runtime options. I have only a subset of parameters (PC types, KSP types, etc.) which are interfaced by my solver and exposed to the end-user. Other few settings (matrix types for instance) are hardcoded in some objects (which my linear system solver interface makes use of).
> Thanks for sending the hardcoded options, I could reproduce the problem with snes/examples/tutorials/ex2.c using the runtime options
> -pc_type asm -vec_type cusp -mat_type aijcusp
> Actually, the problem can be reduced down to only providing
> -vec_type cusp
> It seems to be the same problem as the one described here:
> http://lists.mcs.anl.gov/pipermail/petsc-dev/2014-January/014460.html
> which I couldn't track down yet. I'll let you know as soon as this is fixed.
> Best regards,
> Karli
