[petsc-dev] CFLAGS and COPTFLAGS
Jed Brown
jed at jedbrown.org
Sun Jan 19 18:44:02 CST 2014
Satish Balay <balay at mcs.anl.gov> writes:
> To clarify - petsc configure ignores CC etc from env - but the following is accepted.
> ./configure CC=gcc CXX=g++ FC=gfortran
Yeah, though in an effort to allow package scripts to be concise and
less error-prone, they put the system-desired CC, CXX, CFLAGS, LDFLAGS,
etc. into the environment of the packaging script. For PETSc, this
means writing
./configure CC="$CC" CFLAGS="$CFLAGS" CXX="$CXXFLAGS" ....
and if you forget one, the package may not be built correctly. It
definitely makes package maintainers' lives easier to not try to be
smart.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140119/d69aee9c/attachment.sig>
