[petsc-dev] petsc-dev fails test with debugging=0
Andrea Lani andrea.lani at gmail.com
Sun Jan 19 15:46:41 CST 2014
Sure, this is the log file for the case with KSPGMRES and PCBJACOBI on 2
GPUs.
Andrea
On Sun, Jan 19, 2014 at 10:28 PM, Jed Brown <jed at jedbrown.org> wrote:
> Andrea Lani <andrea.lani at gmail.com> writes:
> > Dear Devs,
> > first of all, even after the latest Karl's fix, my GPU-enabled solver
> > (using PETSc's KSPGMRES and PCASM) still gives a substantially different
> > residual after one time step in 1 or more GPUs:
> > +0.72 (1 GPU) against -1.00 (2-8 GPU).
> > The situtation is even more dramatic for PCBJACOBI: in this case it works
> > the same on 1 GPU and crashes on more GPUs ( "Null argument, when
> expecting
> > valid pointer! [0]PETSC ERROR: Trying to zero at a null pointer!").
> *always* send the entire error message
Dr. Andrea
Lani
Senior Research Engineer, PhD
Aeronautics & Aerospace dept., CFD group
Von Karman Institute for Fluid Dynamics
Chausse de Waterloo 72,
B-1640, Rhode-Saint-Genese,  Belgium
fax  : +32-2-3599600
work : +32-2-3599769
*lani at vki.ac.be <lani at vki.ac.be>*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140119/9aa59a96/attachment.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140119/9aa59a96/attachment.bin>
