[petsc-dev] CFLAGS and COPTFLAGS
Jed Brown
jed at jedbrown.org
Fri Jan 17 21:46:59 CST 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
> Yes, What if they just set a single flag having nothing to do with
> optimization. This will turn off PETSc’s attempt to provide any
> kind of optimization flag (even with —with-debugging=0). I think
> this is bad. *
Is it really that bad? Other packages usually don't try to do anything
smart and I think there is a very real cost to second-guessing the user.
Worse, the user has to wait minutes for configure to complete before
reading the printout carefully to learn what PETSc decided to use.
I think we still want warning flags because users are unlikely to guess
decent ones. And -fPIC needs to be automatic based on shared libs.
>>> Could we do the following?
>>> Look through any provided CFLAGS (FFLAGS, CXXFLAGS) if we detect
>>> something that looks like optimization then act as if COPTFLAGS was
>>> set and do not set our own optimization default flag? We can also
>>> keep support for the COPTFLAGS stuff
>>> We can look for -O%d , are there other things to look for? This seems easy enough to add.
>> -ftree-vectorize, -fast, -qhot -qsimd=auto
> So if they pass -fast then we simply don’t set any optimization flags ourself? We could do that.
My point was that there are *lots* of optimization flags, with new ones
every release from every vendor. We could test for a few, but can never
be comprehensive. Do we want to be in this business?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140117/b52d7d61/attachment.sig>
