[petsc-dev] Fwd: GPU preconditioners
Andrea Lani andrea.lani at gmail.com
Fri Jan 17 15:00:25 CST 2014
When I speak about totally inconsistent results between single and
multi-GPU in my previous e-mail, I mean with PCASM.  I don't see the same
with  PCJACOBI (even though, in this case, this is useless since it crashes
after a few iterations), so I'm doubting about what could be the source of
the problem.
When constructing the matrix for the multi-GPU case, I use this sequence of
calls:
MatSetType(m_mat, MATMPIAIJCUSP);
MatSetBlockSize(m_mat, blockSize);
MatMPIAIJSetPreallocation(m_mat, dnz, dnnz, onz, onnz);
and my sparsity pattern is computed accordingly, considering that I have an
AIJ matrix instead of the BAIJ I use on the "CPU version".
---------- Forwarded message ----------
Date: Fri, Jan 17, 2014 at 9:47 PM
Subject: Re: [petsc-dev] GPU preconditioners
To: Matthew Knepley <knepley at gmail.com>
Cc: For users of the development version of PETSc <petsc-dev at mcs.anl.gov>
Ok, thanks.
In fact, I have another major problem: when running on multi-GPU with PETSc
my results are totally inconsistent compared to a single GPU  .
In my code, for now, I'm assuming a 1-1 correspondence between CPU and GPU:
I run on 8 cores and 8 GPUs (4 K10).  How can I enforce this in the PETSc
solver? Is it automatically done or do I have to specify some options?
Thanks again
Andrea
On Jan 17, 2014, at 8:48 PM, Matthew Knepley <knepley at gmail.com> wrote:
On Fri, Jan 17, 2014 at 1:29 PM, Andrea Lani < <andrea.lani at gmail.com>
andrea.lani at gmail.com> wrote:
> Dear Devs,
> is the PCBJACOBI solver fully ported to GPU in the latest petsc-dev
> version? if not, is there any intention to do so in the near future?
> I have a convection-dominated (with strong discontinuities in the flow
> field) MHD problem where PCASM and PCBJACOBI both work fine with KSPGMRES.
These can be done on the GPU, but the key is the inner PC. Right now, we
have no ILU0 or equivalent, which I think is what
you want. You can try the AMG variants, but I am guessing they would not be
great for convection dominated flow.
Maybe Karl has a better suggestion?
     Matt
> Looking for a speedup in my code (which is using a petsc-dev version about
> two-months old), the only GPU alternative I found was PCJACOBI. This is
> indeed considerably faster on GPU, but does not converge (neither does,
> consistently, its CPU counterpart) if not for a few iterations before
> blowing up. Any other alternative for GPU-based preconditioners or solvers
> worth trying at the moment?
> Thanks in advance for your advice
> Andrea
> Dr. Andrea
> Lani
> Senior Research Engineer, PhD
> Aeronautics & Aerospace dept., CFD group
> Von Karman Institute for Fluid Dynamics
> Chausse de Waterloo 72,
> B-1640, Rhode-Saint-Genese,  Belgium
> fax  : +32-2-3599600
>  work : +32-2-3599769
> * <lani at vki.ac.be>lani at vki.ac.be <lani at vki.ac.be>*
experiments lead.
-- Norbert Wiener
Dr. Andrea
Lani
fax  : +32-2-3599600
*lani at vki.ac.be <lani at vki.ac.be>*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140117/69ce3a08/attachment.html>
