[petsc-dev] [petsc-users] PETSc/VC12 compilation
    Aron Ahmadia
    aron at ahmadia.net
    Tue Jan 14 13:46:43 CST 2014
You produce warnings all the time.  When you ignore environment variables,
or another variable is set that suggests a mistake in configuration.
Or am I missing something here.
On Tue, Jan 14, 2014 at 2:43 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jan 14, 2014, at 1:21 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
> > I'd make it a warning, not a default.
>   Why?
>   We generally don’t produce “warnings” during configuration currently
>    Barry
> > On Tue, Jan 14, 2014 at 2:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >     Hmm, if the user provides --with-cc='win32fe cl’  shouldn’t we
> automatically add --with-cxx='win32fe cl’ as well?
> > It does not harm (right?) and will prevent this from hitting other
> people in the future.
> >    Barry
> > Request-assigned: balay automatically add --with-cxx='win32fe cl’  if
> --with-cc='win32fe cl’ is provided?
> > On Jan 14, 2014, at 10:37 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > Try adding configure option: --with-cxx='win32fe cl'
> > > Satish
> > > On Tue, 14 Jan 2014, Abilash Nair wrote:
> > >> Hello all,
> > >> I am trying to build petsc to use as a library on a visual C++
> project.
> > >> I configured the petsc (v3.4.3) with VC++ 2012 under the shell
> provided by
> > >> VC2012 with the following command (in cygwin):
> > >> ./config/configure.py --with-mpi=0 --download-f2cblaslapack=1
> --with-fc=0
> > >> --with-cc='win32fe cl' --with-debugging=1
> > >> then I did a make all; make test while still in cygwin. I have sent
> the log
> > >> file outputs from these commands. As the files show, I am able to
> make with
> > >> no errors at all, however I am unable to execute any of the tests
> (error
> > >> being that a libstcc++.lib not found).
> > >> I hope you would be able to suggest a path forward.
> > >> Thanks!
> > >> Abilash.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140114/96e9fadf/attachment.html>
