[petsc-dev] [petsc-users] PETSc/VC12 compilation
    Aron Ahmadia
    aron at ahmadia.net
    Tue Jan 14 13:21:55 CST 2014
I'd make it a warning, not a default.
On Tue, Jan 14, 2014 at 2:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>     Hmm, if the user provides --with-cc='win32fe cl’  shouldn’t we
> automatically add --with-cxx='win32fe cl’ as well?
> It does not harm (right?) and will prevent this from hitting other people
> in the future.
>    Barry
> Request-assigned: balay automatically add --with-cxx='win32fe cl’  if
> --with-cc='win32fe cl’ is provided?
> On Jan 14, 2014, at 10:37 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Try adding configure option: --with-cxx='win32fe cl'
> > Satish
> > On Tue, 14 Jan 2014, Abilash Nair wrote:
> >> Hello all,
> >> I am trying to build petsc to use as a library on a visual C++ project.
> >> I configured the petsc (v3.4.3) with VC++ 2012 under the shell provided
> by
> >> VC2012 with the following command (in cygwin):
> >> ./config/configure.py --with-mpi=0 --download-f2cblaslapack=1
> --with-fc=0
> >> --with-cc='win32fe cl' --with-debugging=1
> >> then I did a make all; make test while still in cygwin. I have sent the
> log
> >> file outputs from these commands. As the files show, I am able to make
> with
> >> no errors at all, however I am unable to execute any of the tests (error
> >> being that a libstcc++.lib not found).
> >> I hope you would be able to suggest a path forward.
> >> Thanks!
> >> Abilash.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140114/e80916f8/attachment.html>
