[petsc-dev] [GPU] Crash on ex19 with mpirun -np 2 (optimized build)
    Karl Rupp
    rupp at mcs.anl.gov
    Tue Jan 14 10:19:59 CST 2014
Hi Pierre,
 >> I could reproduce the problem and also get some uninitialized variable
>> warnings in Valgrind. The debug version detects these errors, hence
>> you only see the errors in the debug build. For the optimized build,
>> chances are good that the computed values are either wrong or may
>> become wrong in other environments. I'll see what I can do when I'm
>> again at GPU machine tomorrow (parallel GPU debugging via SSH is not
>> great...)
> Sorry, I mean:
> Parallel calculation on CPU or GPU run well with PETSc non optimized library
> Parallel calculation on GPU crashes with PETSc optimized library (on CPU
> it is OK)
The fact that it happens to run in one mode out of {debug, optimized}
but not in the other is at most a lucky coincidence, but it still means
that this is a bug we need to solve :-)
> I could add that the "mpirun -np 1 ex19" runs well for all builds on CPU
> and GPU.
I see valgrind warnings in the vector scatter routines, which is likely
the reason why it doesn't work with multiple MPI ranks.
Best regards,
Karli
