[petsc-dev] broken stuff in next please fix
Sat Jan 4 21:19:23 CST 2014
On Jan 4, 2014, at 8:41 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
>> On Sat, Jan 4, 2014 at 6:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2014/01/04/filtered-make_next_arch-linux-pkgs-dbg-ftn-interfaces_crank.log
>>> /sandbox/petsc/petsc.clone/src/sys/objects/pinit.c:224:37: warning:
>>> argument type 'struct <anonymous struct at
>>> /sandbox/petsc/petsc.clone/src/sys/objects/pinit.c:217:3> *' doesn't match
>>> specified 'MPI' type tag that requires 'struct mpich_struct_mpi_2int *'
>>> [-Wtype-safety]
>>> 1 warning generated.
>>> /sandbox/petsc/petsc.clone/src/vec/is/sf/interface/sf.c:459:49: warning:
>>> argument type 'PetscSFNode *' doesn't match specified 'MPI' type tag that
>>> requires 'struct mpich_struct_mpi_2int *' [-Wtype-safety]
>> Can we shut off this warning?
> What version of MPICH and Clang are you using?  Current MPICH 'master'
> is broken, but earlier versions with clang-3.3 are not producing this
> warning.
    Ahh, what should we be using for nightly tests?  We can use a release or any development version. Currently we don’t seem to have a policy of what to track,.
At the moment I have it set to http://www.mpich.org/static/downloads/3.0/mpich-3.0.tar.gz
   Barry
