[petsc-dev] cuda fails in next
    Barry Smith
    bsmith at mcs.anl.gov
    Sat Feb  8 09:28:34 CST 2014
---- ERRORS ----
       CUDAC arch-cuda-double/obj/src/mat/impls/aij/mpi/mpicusp/mpiaijAssemble.o
       CUDAC arch-cuda-double/obj/src/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.o
/home/balay/petsc.clone/src/mat/impls/aij/mpi/mpicusp/mpiaijcusp.cu:5:28: fatal error: mpicuspmatimpl.h: No such file or directory
compilation terminated.
make[2]: *** [arch-cuda-double/obj/src/mat/impls/aij/mpi/mpicusp/mpiaijcusp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
/home/balay/soft/cusp-v0.3.1/cusp/complex.h(730): warning: a __host__ function("cusp::conj") redeclared with __host__ __device__, hence treated as a __host__ __device__ function
/home/balay/soft/cusp-v0.3.1/cusp/complex.h(736): warning: a __host__ function("cusp::abs") redeclared with __host__ __device__, hence treated as a __host__ __device__ function
   CUDAC.dep arch-cuda-double/obj/src/mat/impls/aij/mpi/mpicusp/mpiaijAssemble.o
make[2]: Leaving directory `/home/balay/petsc.clone’
