[petsc-dev] Sean is going to love this
    Sean Farley
    sean.michael.farley at gmail.com
    Sun Dec 28 21:54:24 CST 2014
Barry Smith writes:
>   Sean,
>     brew install /homebrew/science/petsc
>     brew install /homebrew/science/petsc --HEAD --with-x11
>   Is there any reason not to use home-brew for everything now? Should we be working with the homebrew/science guys to work out the rough edges? (Like their hypre build is sequential and they don't pass the MPI compiler wrappers properly to build packages and ... and ...)
That's up to you. Regardless of which package manager is used, the
discussion of how PETSc can work better in such a system still applies.
