[petsc-dev] Sean is going to love this
    Sean Farley
    sean.michael.farley at gmail.com
    Wed Dec 24 12:22:49 CST 2014
Jose E. Roman writes:
> El 23/12/2014, a las 20:38, Sean Farley escribió:
>> 4) Better coordination with dependent packages
>> This item is hard to implement because it's out of the PETSc team's
>> control. For example, packages like SLEPc depend on PETSc but don't have
>> as good of a build system. SLEPc can't be built with a version of SLEPc
>> already installed in the prefix. This is unnecessarily cumbersome for
>> end-users.
> SLEPc issues a warning in this case, but does not prevent building. I have removed the warning, since it is no longer necessary. Please report any problems.
Ah, great! Thanks!
