[petsc-dev] Fwd: [ideas-xsdk] common configure/cmake arguments for XSDK packages ready for testing
Barry Smith
bsmith at mcs.anl.gov
Wed Dec 24 11:39:04 CST 2014
Now change the compiler to something else from Cray and run again.
> On Dec 24, 2014, at 12:56 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> wrt cray modules - I see the following env variables set [with a 'MODULE' in the env variable name]
> Satish
> balay at hopper01:~> env |grep MODULE
> MODULE_VERSION_STACK=3.2.6.7
> LIBRARYMODULES=acml:alps:apprentice2:atp:cray-fftw:cray-libsci:cray-mpich2:cray-petsc:cray-petsc-complex:cray-shmem:cray-tpsl:cray-trilinos:cudatoolkit:fftw:ga:hdf5:hdf5-parallel:iobuf:lgdb:libfast:libsci_acc:mpich1:mpich2:mrnet:netcdf:netcdf-hdf5parallel:netcdf-nofsync:netcdf-nofsync-hdf5parallel:ntk:onesided:papi:parallel-netcdf:petsc:petsc-complex:pmi:shmem:tpsl:trilinos:xt-atp:xt-lgdb:xt-libsci:xt-mpt:xt-papi:/etc/opt/cray/modules/site_librarymodules
> USERMODULES=acml:alps:apprentice2:atp:blcr:cce:chapel:cray-fftw:cray-libsci:cray-mpich2:craypat:craype:cray-petsc:cray-petsc-complex:cray-shmem:cray-tpsl:cray-trilinos:cudatoolkit:ddt:fftw:ga:gcc:hdf5:hdf5-parallel:intel:iobuf:java:lgdb:libfast:libsci_acc:mpich1:mrnet:netcdf:netcdf-hdf5parallel:netcdf-nofsync:netcdf-nofsync-hdf5parallel:ntk:onesided:papi:parallel-netcdf:pathscale:perftools:petsc:petsc-complex:pgi:pmi:PrgEnv-cray:PrgEnv-gnu:PrgEnv-intel:PrgEnv-pathscale:PrgEnv-pgi:stat:totalview:tpsl:trilinos:xt-asyncpe:xt-craypat:xt-lgdb:xt-libsci:xt-mpich2:xt-mpt:xt-papi:xt-shmem:xt-totalview:/etc/opt/cray/modules/site_usermodules:/usr/common/nsg/Modules/modulefiles
> MODULE_VERSION=3.2.6.7
> TARGETMODULES=craype-abudhabi:craype-abudhabi-cu:craype-accel-nvidia20:craype-accel-nvidia30:craype-accel-nvidia35:craype-barcelona:craype-hugepages128K:craype-hugepages128M:craype-hugepages16M:craype-hugepages256M:craype-hugepages2M:craype-hugepages512K:craype-hugepages512M:craype-hugepages64M:craype-hugepages8M:craype-interlagos:craype-interlagos-cu:craype-istanbul:craype-ivybridge:craype-knc:craype-mc12:craype-mc8:craype-network-aries:craype-network-gemini:craype-network-seastar:craype-sandybridge:craype-shanghai:craype-target-compute_node:craype-target-local_host:craype-target-native:craype-target-petest:craype-xeon:xtpe-barcelona:xtpe-interlagos:xtpe-interlagos-cu:xtpe-istanbul:xtpe-mc12:xtpe-mc8:xtpe-network-gemini:xtpe-network-seastar:xtpe-shanghai:xtpe-target-native:xtpe-xeon:/etc/opt/cray/modules/site_targetmodules
> MODULEPATH=/opt/cray/gem/modulefiles:/opt/cray/xt-asyncpe/default/modulefiles:/opt/cray/modulefiles:/opt/modulefiles:/usr/common/usg/Modules/modulefiles:/usr/syscom/nsg/modulefiles:/usr/syscom/nsg/opt/modulefiles:/usr/common/acts/Modules/modulefiles:/usr/common/ftg/Modules/modulefiles:/usr/common/graphics/Modules/modulefiles:/usr/common/jgi/Modules/modulefiles:/usr/common/tig/Modules/modulefiles
> LOADEDMODULES=modules/3.2.6.6:nsg/1.2.0:modules/3.2.6.7:xtpe-network-gemini:xt-asyncpe/5.23:pgi/13.6.0:cray-libsci/12.1.01:udreg/2.3.2-1.0402.7546.1.5.gem:ugni/5.0-1.0402.7551.1.10.gem:pmi/4.0.1-1.0000.9753.86.3.gem:dmapp/4.0.1-1.0402.7784.4.1.gem:gni-headers/2.1-1.0402.7541.1.5.gem:xpmem/0.1-2.0402.45248.1.5.gem:job/1.5.5-0.1_2.0402.45272.1.5.gem:csa/3.0.0-1_2.0402.45268.1.90.gem:rca/1.0.0-2.0402.47290.7.1.gem:audit/1.0.0-1.0402.45273.1.86.gem:ccm/2.2.0-1.0402.46086.4.120:configuration/1.0-1.0402.45284.1.2.gem:hosts/1.0-1.0402.45251.1.86.gem:lbcd/2.1-1.0402.45245.1.2.gem:nodehealth/5.1-1.0402.45895.3.76.gem:pdsh/2.26-1.0402.45278.1.1.gem:shared-root/1.0-1.0402.46893.3.17.gem:switch/1.0-1.0402.45840.2.63.gem:xe-sysroot/4.2.34:atp/1.7.0:PrgEnv-pgi/4.2.34:eswrap/1.0.20-1.010102.662.0:craype-mc12:cray-shmem/6.0.1:cray-mpich/6.0.1:torque/4.2.7.h1:moab/7.2.7-e7c070d1-b3-SUSE11:darshan/2.3.0:usg-default-modules/1.1
> PRGENVMODULES=PrgEnv-cray:PrgEnv-gnu:PrgEnv-intel:PrgEnv-pathscale:PrgEnv-pgi
> TOOLMODULES=apprentice:apprentice2:atp:chapel:craypat:ddt:gdb:iobuf:mrnet:papi:perftools:stat:totalview:xt-craypat:xt-lgdb:xt-papi:xt-totalview:/etc/opt/cray/modules/site_toolmodules
> MODULESHOME=/opt/modules/3.2.6.7
> But parsing this and figuring out - which module change is significant
> [wrt petsc build] and which one is not - is perhaps not easy. [Perhaps
> this is what Jed is refering to..]
> Satish
> On Tue, 23 Dec 2014, Barry Smith wrote:
>> I couldn't find any environmental variables for softenv and haven't logged into a cray in decades. We don't have to abort for all changes but perhaps could produce warning text or detect serious changes?
>> Barry
>>> On Dec 23, 2014, at 9:31 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>> Redirecting Jed's question specifically for PETSc configure.
>>>> Can we/should we save the modules setting at configure time and then
>>>> check them always at make time? Is some environmental variable set
>>>> that has a unique value based on the modules loaded?
>>> We can do it for modules (like Cray) and softenv, but aborting in all
>>> cases of environment change is not tractable and would be too much
>>> noise.
>>>> If this is a common problem for us then we should be doing this.
>>> It's a common problem in the sense that a lot of users get confused over
>>> this and it generates a significant amount of support email.
