[petsc-dev] Sean is going to love this
    Sean Farley
    sean.michael.farley at gmail.com
    Tue Dec 23 18:45:42 CST 2014
Barry Smith writes:
>> On Dec 23, 2014, at 6:11 PM, Sean Farley <sean.michael.farley at gmail.com> wrote:
>> Barry Smith writes:
>>>   Sean,
>>>    Say I am writing a PETSc package (for any generic packaging system) that will use the MPICH compilers package and the BLAS/LAPACK package (and say, the hdf5 package). How do I indicate to PETSc's configure the information for MPICH, BLAS/LAPACK, and hdf5 so they will be correct for users when they link and run their applications? That is, I don't want to randomly list some hdf5 on the system but is it enough to just list the exact location of the hdf5 I know the package manager will install hdf5 to?
>> That is a hard problem. Jed and others will chime in on this problem,
>> but this is why some packages have a binary / script that outputs its
>> compiler / linker flags. For example, netcdf has nc-config:
>> $ nc-config --has-hdf5
>> yes
>> $ nc-config --libs
>> -L/opt/local/lib -lnetcdf
>> There is also pkg-config:
>> $ pkg-config --libs libpng
>> -L/opt/local/lib -lpng16
>> Ideally, package managers should provide this information. Currently,
>> they do not. For PETSc, this would mean something akin to 'petscmpiexec'
>> and / or supplying this information to pkg-config (this actually should
>> be fairly easy).
>> An end-user would then use pkg-config or a PETSc-provided script for
>> compiling and linking,
>> $ pkg-config --libs petsc
>> -L/opt/local/lib -lnetcdf -lpetsc -L/opt/local/lib/mpich-mp -lmpi -lpmpi
>   Yeah in theory we do this.
>   But this actually doesn't answer my question; I'm also asking about the situation when the package system (like brew) is compiling the package on the users machine.  Say I need the -I info for hdf5 to pass to PETSc's configure. If the user has selected a nonstandard location for installs with brew(not /usr/local) how do I know what directory to pass with the -I ? Somehow the package system has to provide the information for me to use in calling configure.
Ah, sorry, then I misunderstood. This is definitely dependent on the
package manager system. In MacPorts, this is just listing the libraries
directory:
configure.args-append --with-hdf5-dir=${prefix}
The requirement (of most?) package managers to have a locked-down prefix
(e.g. /opt/local) is that installing something outside of the package
would break the above code.
In some package managers (MacPorts is an example), CPPFLAGS are set to
${prefix}/include and LDFLAGS are set to ${prefix}/lib. To prevent
over-linking and help deter incorrect linking, there is a trace mode
that sandboxes the whole process so that only dependencies are
explicitly allowed.
Is that what you were asking?
