[petsc-dev] Fwd: [Bitbucket] Issue #84: pastix compilation error when custom compiler flags are set (petsc/petsc)
Barry Smith
bsmith at mcs.anl.gov
Thu Dec 18 11:52:35 CST 2014
Satish,
Can you update maint and master to use this new version (after testing in next of course :-)
Barry
> Begin forwarded message:
> Subject: Re: [Bitbucket] Issue #84: pastix compilation error when custom compiler flags are set (petsc/petsc)
> From: XL <issues-reply at bitbucket.org>
> To: <bsmith at mcs.anl.gov>
> Date: December 18, 2014 at 8:57:38 AM CST
> XL commented on issue #84:
> pastix compilation error when custom compiler flags are set <https://bitbucket.org/petsc/petsc/issue/84/pastix-compilation-error-when-custom>
> I just released a new version that should fix the issue: https://gforge.inria.fr/frs/download.php/file/34392/pastix_5.2.2.20.tar.bz2 <https://gforge.inria.fr/frs/download.php/file/34392/pastix_5.2.2.20.tar.bz2>.
> View this issue <https://bitbucket.org/petsc/petsc/issue/84/pastix-compilation-error-when-custom> or add a comment by replying to this email.
> Unsubscribe from issue emails <https://bitbucket.org/api/1.0/petsc/petsc/issue/84/unsubscribe/BarryFSmith/f343cf249e6eedb3a0515582b9c690454c49d619/> for this repository. <https://bitbucket.org/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141218/3030d5a2/attachment.html>
