[petsc-dev] MUMPS and 64 bit indices
Wed Dec 17 16:03:45 CST 2014
  Garth,
   I have found the bug and it is ours. In SuiteSparse.py we set ulong_max = 'ULONG_MAX' which is totally wrong because SuiteSparse is looking for the largest SIGNED long. So if you change the ULONG_MAX to LONG_MAX in SuiteSparse.py and rerun the ./configure (after deleting your $PETSC_DIR/$PETSC_ARCH directory) the 64 bit index version will run the same as the 32 bit version.
  I have fixed this in the branches maint and master
  Barry
> On Dec 16, 2014, at 2:52 PM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> Attached is test code and matrix/vector files to reproduce a problem I'm seeing with Umfpack and 64-bit indices. It works fine with Umfpack and 32-bit indices. The matrix comes from a mixed formulation of the Poisson equation. The matrix is indefinite. I've computed all eigenvalues and they're nonzero.
> Running the test program with:
>   ./test -pc_factor_mat_solver_package umfpack
> the output is
>   Solution L2 norm: -nan
>   Solution L2 norm should be: 2.96824
>   ./test -pc_factor_mat_solver_package superlu_dist
> the output is
>   Solution L2 norm: 2.968238
> My PETSc configure line is
>   --with-64-bit-indices --download-hypre=yes --download-suitesparse=1 --download-parmetis --download-metis --with-debugging=no COPTFLAGS="-O3 -march=native" FOPTFLAGS="-O3 -march=native" CXXOPTFLAGS="-O3 -march=native" --prefix=/home/garth/local/packages/petsc-64 --download-ptscotch --download-superlu_dist
> Git log is 7fbfed63fbc5325cf1eefdb967627c4417715c46
> (message copied to petsc-maint so the attachment doesn't get scrubbed)
> Garth
> On Mon, 15 Dec, 2014 at 9:49 PM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
>>> On 15 Dec 2014, at 21:42, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> On Dec 15, 2014, at 3:16 PM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
>>>> It's possible to configure PETSc with the options
>>>>  --with-64-bit-indices --download-mumps
>>>> and compile and run, but it doesn't look like the MUMPS interface supports 64 bit indices. Should the above combination throw an error at configure time?
>>>  Yes, there is commented code in the consistency check, I cannot remember why it was commented.
>>> #      if self.double and not self.scalartypes.precision.lower() == 'double':
>>> #        raise RuntimeError('Cannot use '+self.name+' withOUT double precision numbers, it is not coded for this capability')
>>> #      if not self.complex and self.scalartypes.scalartype.lower() == 'complex':
>>> #        raise RuntimeError('Cannot use '+self.name+' with complex numbers it is not coded for this capability')
>>> #      if self.libraryOptions.integerSize == 64 and self.requires32bitint:
>>> #        raise RuntimeError('Cannot use '+self.name+' with 64 bit integers, it is not coded for this capability')
>>>> (On a side note, SuperLU_dist and Umfpack are flaky with 64 bit indices, which seems largely related to calling ParMETIS/METIS).
>>>  Hmm, never heard such reports. Are you using the --download-parmetis and metis? You should be. Is it reproducible problem?  We'd like to fix it.
>> Yes, I’m using --download-parmetis and --download-metis.
>> Yes, it’s reproducible for a given matrix but hard to know which matrices will be a problem, and for which solver (SuperLU_dist/Umfpack). I’ll try to package up a couple of examples that fail or give wrong results.
>> Garth
>>>  Barry
>>>> Garth
> <petsc_lu_test.tgz>
