[petsc-dev] MUMPS and 64 bit indices
Garth N. Wells gnw20 at cam.ac.uk
Mon Dec 15 15:49:29 CST 2014
> On 15 Dec 2014, at 21:42, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Dec 15, 2014, at 3:16 PM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
>> It's possible to configure PETSc with the options
>>  --with-64-bit-indices --download-mumps
>> and compile and run, but it doesn't look like the MUMPS interface supports 64 bit indices. Should the above combination throw an error at configure time?
>  Yes, there is commented code in the consistency check, I cannot remember why it was commented.
> #      if self.double and not self.scalartypes.precision.lower() == 'double':
> #        raise RuntimeError('Cannot use '+self.name+' withOUT double precision numbers, it is not coded for this capability')
> #      if not self.complex and self.scalartypes.scalartype.lower() == 'complex':
> #        raise RuntimeError('Cannot use '+self.name+' with complex numbers it is not coded for this capability')
> #      if self.libraryOptions.integerSize == 64 and self.requires32bitint:
> #        raise RuntimeError('Cannot use '+self.name+' with 64 bit integers, it is not coded for this capability')
>> (On a side note, SuperLU_dist and Umfpack are flaky with 64 bit indices, which seems largely related to calling ParMETIS/METIS).
>  Hmm, never heard such reports. Are you using the --download-parmetis and metis? You should be. Is it reproducible problem?  We'd like to fix it.
Yes, I’m using --download-parmetis and --download-metis.
Yes, it’s reproducible for a given matrix but hard to know which matrices will be a problem, and for which solver (SuperLU_dist/Umfpack). I’ll try to package up a couple of examples that fail or give wrong results.
Garth
>  Barry
>> Garth
