[petsc-dev] Zero sized VecSetValues
Barry Smith
bsmith at mcs.anl.gov
Fri Dec 12 22:50:59 CST 2014
Pierre,
Please find attached a patch to fix this; after applying the patch do
make gnumake
in the root PETSc directory and relink your code.
Thanks for reporting the problem
Barry
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141212/73bf1e5c/attachment.obj>
> On Dec 12, 2014, at 7:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Pierre,
> There is no rational, we will fix it.
> Barry
>> On Dec 12, 2014, at 11:47 AM, Pierre Jolivet <jolivet at ann.jussieu.fr> wrote:
>> Hello,
>> Taking http://www.mcs.anl.gov/petsc/petsc-current/src/vec/vec/examples/tutorials/ex2.c.html and changing its 56th line from
>> VecSetValues(x,1,&i,&one,ADD_VALUES);
>> to
>> VecSetValues(x,0,NULL,NULL,ADD_VALUES);
>> yield the following error (at least --with-debug=1):
>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> [0]PETSC ERROR: Invalid pointer
>> [0]PETSC ERROR: Null Pointer: Parameter # 3
>> What is the rationale behind first checking the pointers, then doing the work or lack thereof, instead of, first checking if there is some work to do, and only then check the pointers (? la MPI) ?
>> Thank you for your help,
>> Pierre
