[petsc-dev] RegisterAllCalled visibility
Jed Brown jed at jedbrown.org
Fri Dec 12 19:55:48 CST 2014
Matthew Knepley <knepley at gmail.com> writes:
> That is just crappy engineering on our part. The RegisterAllCalled()
> should be idempotent just like PackageInitialize(). Does anyone
> disagree with this?
I'm not sure it deserves to be a public interface.  What is the use case
for XXRegisterAll() called from anywhere but XXInitializePackage?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141212/2d214308/attachment.sig>
