[petsc-dev] bitbucket giving wrong information
Jed Brown
jed at jedbrown.org
Thu Dec 4 15:33:37 CST 2014
Patrick Sanan <patrick.sanan at gmail.com> writes:
>> Sure thanks, but there is no way I can remember this; hence bitbucket should walk me through it.
> Yeah - their helpful hint doesnt work when pulling across repos, which is a useful, probably typical, case, so it'd be better for then to have said nothing!
GitHub does better here:
| You can merge this Pull Request by running:
| git pull https://github.com/someuser/petsc someuser/branch-name
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141204/ca258b64/attachment.sig>
