[petsc-dev] P3DFFT is an open-source numerical library	providing highly scalable implementation of 3D spectral transforms
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Aug 20 16:05:29 CDT 2014
On Aug 20, 2014, at 4:00 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 20, 2014 at 3:52 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 20, 2014, at 3:34 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > The blurb should also answer the question, Why do we need another FFT library?
>   Because it actually does multidimensional FFTs in parallel?
> For something this old and established, it might be important to say that it does blah
> blah blah that Spiral, FFTW, etc.
>   In theory, with this one could write very efficient parallel 3d Poisson solvers in PETSc for boxes, which is an important special case that PETSc does not currently support.
> Wouldn't you just use MG?
   FFT when done properly is much faster!  Yes it is a specialized case but an important one.
> I have other uses for FFT, including DFT codes where it makes a lot of sense.
>    Matt
>   Barry
> >    Matt
> > On Wed, Aug 20, 2014 at 1:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > From: Dmitry Pekurovsky dmitry at sdsc.edu
> > Date: August 12, 2014
> > Subject: Library for spectral transforms in 3D for parallel machines
> > scalable implementation of 3D spectral transforms namely Fast
> > Fourier Transform (FFT), with an option to combine it with
> > cosine/sine/Chebyshev/empty transform in the third dimension. (The
> > empty transform allows the user to substitute their own custom
> > transform in the third dimension. This can be useful in
> > applications such as inhomogeneous wall bounded turbulence.) P3DFFT
> > implements 2D domain decomposition which allows it to overcome a
> > scalability restriction inherent in 1D decomposition. This approach
> > has shown good scalability up to 131,072 cores.
> > A new version of P3DFFT 2.7.1 is now available. The project Home
> > Page is http://code/google.com/p/p3dfft where instructions for
> > obtaining the source code are provided. Installation instructions
> > and a User Guide are also available.
> > P3DFFT features include real-to-complex and complex-to-real
> > transforms, in-place transforms, pruned transforms (with less than
> > full input or output), and multi-variable transforms. The package
> > includes example programs in Fortran and C. This is a project in
> > active development, with a user mailing list, a wiki page and a
> > version control system. P3DFFT is considered community software and
> > is being installed in public space at many supercomputer centers.
> > Contributions and feedback from users are welcome.
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> -- Norbert Wiener
