[petsc-dev] Fortran libraries cannot be used with C++ compiler
Pierpaolo Minelli
pierpaolo.minelli at ba.imip.cnr.it
Tue Apr 1 09:20:12 CDT 2014
Thanks for your reply. I tried with --with-cxxlib-autodetect=0 but i obtain the same error.
In attachment you can find configure.log for both cases:
configure.log is my original log (without using --with-cxxlib-autodetect=0)
configure.log.new is new log produced when i try to use option --with-cxxlib-autodetect=0
Pierpaolo
Il giorno 01/apr/2014, alle ore 15:02, Matthew Knepley <knepley at gmail.com> ha scritto:
> On Tue, Apr 1, 2014 at 5:15 AM, Pierpaolo Minelli <pierpaolo.minelli at ba.imip.cnr.it> wrote:
> Hi,
> i have some problems when i try to configure latest version of petsc-dev.
> I use this command that was working with a previous version:
> ./configure --PETSC_DIR=/raid0/users/cscppm59/Installers/petsc --PETSC_ARCH=petsc_dev --with-debugger=idbc --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --CFLAGS="-openmp -parallel" --FFLAGS="-ftz -O3 -prec-div -xSSE2 -mcmodel medium -shared-intel -openmp -parallel -fpp" --with-large-file-io=1 --with-debugging=0 --with-mpiexec="mpirun -f ~/mpd.hosts -r ssh" --with-blas-lapack-dir=/opt/intel/mkl/lib/intel64/ --with-threadcomm --with-openmp --with-x=0 --download-superlu_dist --download-parmetis -download-hypre -download-ml --download-metis
> and i receive this error:
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> Fortran libraries cannot be used with C++ compiler.
> Run with --with-fc=0 or --with-cxx=0
> File "./config/configure.py", line 272, in petsc_configure
> framework.configure(out = sys.stdout)
> File "/home/users/cscppm59/Installers/petsc/config/BuildSystem/config/framework.py", line 935, in configure
> child.configure()
> File "/home/users/cscppm59/Installers/petsc/config/BuildSystem/config/compilers.py", line 1396, in configure
> self.executeTest(self.checkFortranLibraries)
> File "/home/users/cscppm59/Installers/petsc/config/BuildSystem/config/base.py", line 126, in executeTest
> ret = test(*args,**kargs)
> File "/home/users/cscppm59/Installers/petsc/config/BuildSystem/config/compilers.py", line 1050, in checkFortranLibraries
> raise RuntimeError('Fortran libraries cannot be used with C++ compiler.\n Run with --with-fc=0 or --with-cxx=0')
> Finishing Configure Run at Tue Apr 1 11:33:05 2014
> Send configure.log for this case. You can also try --with-cxxlib-autodetect=0. This means you might have to put the C++
> compiler libraries in --LIBS=<>.
> Thanks,
> Matt
> So i tried to configure using --with-cxx=0 since i use fortran and i receive a new error:
> Error: Hypre requires C++ compiler. None specified
> child.configure()
> File "/home/users/cscppm59/Installers/petsc/config/BuildSystem/config/package.py", line 605, in configure
> self.executeTest(self.configureLibrary)
> File "/home/users/cscppm59/Installers/petsc/config/BuildSystem/config/package.py", line 533, in configureLibrary
> for location, directory, lib, incl in self.generateGuesses():
> File "/home/users/cscppm59/Installers/petsc/config/BuildSystem/config/package.py", line 266, in generateGuesses
> d = self.checkDownload(1)
> File "/home/users/cscppm59/Installers/petsc/config/BuildSystem/config/package.py", line 382, in checkDownload
> return self.getInstallDir()
> File "/home/users/cscppm59/Installers/petsc/config/BuildSystem/config/package.py", line 221, in getInstallDir
> return os.path.abspath(self.Install())
> File "/home/users/cscppm59/Installers/petsc/config/PETSc/packages/hypre.py", line 48, in Install
> raise RuntimeError('Error: Hypre requires C++ compiler. None specified')
> Finishing Configure Run at Tue Apr 1 11:45:23 2014
> Is there someone that could give me a workaround to solve this problem?
> Thanks in advance
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140401/ba57b6c6/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140401/ba57b6c6/attachment.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140401/ba57b6c6/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140401/ba57b6c6/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140401/ba57b6c6/attachment-0002.html>
