[petsc-dev] [petsc-users] MatMPIBAIJSetPreallocationCSR i and j indices
Andrs, David
david.andrs at inl.gov
Mon Sep 30 09:34:44 CDT 2013
On Mon, Sep 30, 2013 at 8:32 AM, Andrs, David <david.andrs at inl.gov> wrote:
> On Sun, Sep 29, 2013 at 3:07 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> patch-review doesn't happen. Aside from you, none of the rest of us
>> give a shit about patch review hence we should automatically check for
>> whatever we can to make up for the lack of review.
>> Lots of lame excuses why standards shouldn't be enforced automatically.
>> Maybe we should work exclusively inside a IDE that can enforce all kinds of
>> rules without security concerns etc etc or we could do development of each
>> project in its own VM and thus "make normal commands behave differently
>> inside the VM" without security fears. I don't buy these arguments. Our IDE
>> is Emacs+shell+make+python and we can make that IDE help us out, it won't
>> be perfect but if blocks 80% of the goof ups that is a great thing.
>> There is also an enormous psychological/sociological advantage to "the
>> development system" enforcing standards: people hate it when after days or
>> weeks of working some wise-ass reviewer says your code doesn't adhere to
>> standards and they will likely push less code in the future but when an
>> automatic test rejects some code and tells the user how to fix it that
>> doesn't make them less likely to push code in the future. Linus has surely
>> lost many decent developers over the years by being an asshole, we don't
>> need to lose the few we have. I'm not saying there should be no code
>> review, just that the sooner in the process each problem is found the
>> better for productively and I see no reason why each git repository
>> couldn't have in it somewhere a list of rules for that project that git
>> verifies are being followed as the user commits code, pushes code, edits
>> code etc. Many of these could just be warnings, for example
>> commit -a directly into maint, next, or master: "Are you sure you want
>> to do this COMMIT DIRECTLY INTO maint, normally this is not desirable?"
> If you put this little "script" into .git/hooks/pre-commit, it will do it:
Sorry, too fast. Here is the script:
branch_name=$(git symbolic-ref -q HEAD)
if [ "$branch_name" == "refs/heads/maint" ] || [ "$branch_name" ==
"refs/heads/next" ]
then
echo "Trying to commit to into " $branch_name ". This is normally not
desireable."
exit 1
fi
exit 0
>> branch off of next: "Are you sure you want to branch off of NEXT?"
>> commit a file with // in it. "Yoo Mark, PETSc requires the silly old
>> fashion /* comments, you cannot commit this file since you used the modern
>> variables declared in the middle of source code. "Yoo, we use C89 here,
>> make sure all variables are declared at the top of scope!"
>> commit a file with hundreds of lines of commented out source. "Don't be
>> putting commented out code in the repository!"
>> etc.
Not quite sure how to prevent that branching off of next.
The rest of the checks can probably go into pre-commit hook as well.
The only problem is that it is a client side script, so it will not get
cloned from the central repo (AFAIK).
HTH,
David
>> Going back to my maint screw up today. Just one useful warning from
>> git/"our Emacs/shell/make/python IDE" along the way and we would have a
>> nice branch we could continue to improve on, instead we have this ugly
>> illegal commit directly into maint that will be harder to work with. Yes,
>> you can easily say, "that Barry is an idiot who always fucks up procedure"
>> but that doesn't help resolve the problem. One damn warning and it won't
>> have happened, but no, you refuse to consider having any enforcement
>> mechanisms at all and expect all developers to internalize 100% all these
>> rules.
>> Barry
>> On Sep 29, 2013, at 3:01 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> > Barry Smith <bsmith at mcs.anl.gov> writes:
>> >>> On the Reported-by tags, could you do them in a structured way as
>> >>> Reported-by: Matteo Parsani <parsani.matteo at gmail.com>
>> >>> Reported-by: Lisandro Dalcin <dalcinl at gmail.com>
>> >> This is fine, but there needs to be a mechanism to ensure this,
>> > We already have whitespace conventions, a convention that there are no
>> > memory leaks, a convention that type-specialized functions use dynamic
>> > composition, a convention that we do not create dependency loops, a
>> > function naming convention, a convention about avoiding globals, a
>> > branch usage convention, etc. None of these are enforced and only some
>> > have automated checking.
>> >> imposing requirements on developers that do not have enforcement
>> >> mechanisms (besides being yelled at later) don't work.
>> > Patch review is more flexible than any automated tool can be. It is
>> > only time to write an automated tool when the effort to do so, and the
>> > attainable accuracy, is a better use of human time than had the same
>> > time been devoted to patch review. Note that patch review can catch
>> > many things, but automated tools can only catch that which has been
>> > automated.
>> >> Note that this is the same kind of situation as me accidentally
>> >> editing directly into maint. I did
>> >> git branch barry/fix-matmpibaijsetpreallocationcsr
>> > This creates a branch without checking it out. If you want to create
>> > the branch _and_ check it out, use
>> > $ git checkout -b barry/fix-matmpibaijsetpreallocationcsr
>> >> happily edited away and tested
>> >> git commit -a
>> >> git push
>> >> Now what should have happened is as soon as I tried to happily edit
>> >> away, something should come back and said to me: "are you sure you
>> >> want to edit in maint?"
>> > This is policy on the branch rather than the fact that you created a new
>> > branch prior to starting this work. (I do that sometimes so that I'll
>> > be able to easily compare to the old state later.) We could perhaps
>> > prevent direct commits on 'maint'.
>> >> And don't go and mail me some elisp that I can stick in somewhere to
>> >> warn me about the maint editing business; that would only solve the
>> >> problem for me, not for the n-1 other people in the world who make the
>> >> same mistake. Git needs some way of "baking in" a set of standards
>> >> (optional obviously) that it does its best to enforce and not leaving
>> >> it up to each user to remember 324 things they need to constantly be
>> >> checking depending on what project they are working on.
>> > There is a security problem with making normal commands behave
>> > differently when run inside some repository that you just cloned. Any
>> > such policy would need to be opt-in.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130930/3a714644/attachment.html>
