[petsc-dev] The question about the PETSc example
Peter Brune prbrune at gmail.com
Mon Sep 30 08:38:12 CDT 2013
This is not the full FD Jacobian, but the one constructed by coloring. It's
a hunch, but I'd bet DMComposite doesn't have a proper coloring in place.
This should error out. I'll check out why not.
You don't have to alter the source to do this. You can use
-snes_fd_coloring or -snes_fd.
- Peter
- Peter
On Sep 29, 2013 3:07 PM, "Lulu Liu" <lulu.liu at kaust.edu.sa> wrote:
> Run the example /petsc/src/snes/examples/tutorials/ex28.c using the
> following options(found in the makefile)
>  ./ex28 -da_grid_x 20 -snes_converged_reason -snes_monitor_short
> -problem_type 2
> It works using default analytic Jacobian to solve coupled system, however,
> I comment
>  Line 434 : ierr =
> SNESSetJacobian(snes,B,B,FormJacobian_All,user);CHKERRQ(ierr);
> and run the code again using the same options (i.e., FD Jacobian instead
> of analytic Jacobian), we will get the results:
> Nonlinear solve did not converge due to DIVERGED_MAX_IT iterations 50
> Could you explain why it does not work using FD Jacobian in this example?
> Thanks
> This message and its contents, including attachments are intended solely
> for the original recipient. If you are not the intended recipient or have
> received this message in error, please notify me immediately and delete
> this message from your computer system. Any unauthorized use or
> distribution is prohibited. Please consider the environment before printing
> this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130930/2da1fa9f/attachment.html>
