[petsc-dev] field split error
Fri Sep 27 20:56:41 CDT 2013
"Mark F. Adams" <mfadams at lbl.gov> writes:
>> I can't think of any reason for this to be an ISGeneral.  I would like
>> to have better IS matching, but this would obviously be better an
>> ISStride, and if that fixes it, it's enough until someone thinks of a
>> versatile and performant way to do IS matching.
> I am testing with ISStride now.
>>> creates a general IS (obviously) but matnest.c use ISStrideGetInfo,
>>> which returns 1 for start.
>> Why would it return 1?
> No idea.  Do you want me to find out?  What should a general IS return
> as 'start'?
ISStrideGetInfo does not dispatch through dynamically registered functionals.
PetscErrorCode  ISStrideGetInfo(IS is,PetscInt *first,PetscInt *step)
  IS_Stride *sub;
  PetscFunctionBegin;
  PetscValidHeaderSpecific(is,IS_CLASSID,1);
  if (first) PetscValidIntPointer(first,2);
  if (step) PetscValidIntPointer(step,3);
  sub = (IS_Stride*)is->data;
  if (first) *first = sub->first;
  if (step)  *step  = sub->step;
  PetscFunctionReturn(0);
> 'start' seems ill defined for ISGeneral … can it have any meaningful
> semantics?  and the other arg to ISGetInfo, 'stride', is obviously
> nonsensical for ISGeneral.  Perhaps ISGetInfo(is,&astart,&step) should
> throw an error for ISGeneral? This would have saved me a few days of
> Fieldsplit/MatComposite, printf debugging, on a bleeding edge machine,
> fun :)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130928/d1b6c257/attachment.sig>
