[petsc-dev] DMDA_BOUNDARY_GHOSTED
Barry Smith
bsmith at mcs.anl.gov
Thu Sep 26 13:16:30 CDT 2013
On Sep 26, 2013, at 1:10 PM, Mark F. Adams <mfadams at lbl.gov> wrote:
> Also, I know this is a dumb question, and I don't really need to know this, but I can't understand this, and am very curious how code like this can work:
> PetscScalar **array;
> ierr = DMDAVecGetArray(da, b, &array);CHKERRQ(ierr);
> for (j=ys; j<ys+ym; j++) {
> for (i=xs; i<xs+xm; i++) {
> array[j][i] = ….
> This is fantastic. You seem to be doing arbitrary(ish) indexing into a multidimensional, dynamically sized, array. Just like fortran. I never knew you could do this and can not see how the compiler even implements this as you are not even telling it any dimension as far as I can see. I obviously missing something very simple here.
Yup and if xm is not too small this is fine for efficiency :-) Never underestimate C
Here is the magic
PetscErrorCode VecGetArray2d(Vec x,PetscInt m,PetscInt n,PetscInt mstart,PetscInt nstart,PetscScalar **a[])
ierr = VecGetLocalSize(x,&N);CHKERRQ(ierr);
if (m*n != N) SETERRQ3(PETSC_COMM_SELF,PETSC_ERR_ARG_INCOMP,"Local array size %D does not match 2d array dimensions %D by %D",N,m,n);
ierr = VecGetArray(x,&aa);CHKERRQ(ierr);
ierr = PetscMalloc(m*sizeof(PetscScalar*),a);CHKERRQ(ierr);
for (i=0; i<m; i++) (*a)[i] = aa + i*n - nstart;
*a -= mstart;
PetscFunctionReturn(0);
Note one could even reuse the memory from a previous time and not have the malloc in here
Barry
> Mark
> On Sep 26, 2013, at 12:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> For vertex centered finite differences it is easy, one simply does not include the boundary nodes in the DMDA and then puts the actual Dirichlet values into the ghost slots.
>> For cell centered since the boundary value is the average of the ghost cell and the first cell I don't know how to do this because I don't know what one should put into the ghost location. Maybe include the "ghost" cell as a real point (don't use boundary_ghosted) and make the equation for that last cell force the average of that slot and its neighbor to equal the Dirichlet value.
>> Barry
>> On Sep 26, 2013, at 11:28 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Sep 26, 2013 at 9:25 AM, Mark F. Adams <mfadams at lbl.gov> wrote:
>>> I am interested in making a cell centered test problem with Dirichlet BCs. I want to go high(ish) order and doing explicit stencils (preferred) looks rather messy and I am interest in using ghost cells. I assume this would entail using DMDA_BOUNDARY_GHOSTED. I do not see any examples or documentation on using this other than just creating it. Any suggestions? I would think that there would have to be callback function for the user to set ghost values but I am not seeing anything like this around. Perhaps I am not understand the intent of DMDA_BOUNDARY_GHOSTED.
>>> My understanding is that it adds a single layer of ghost cells around the domain boundary. Then these show up in the gxm, etc. so that
>>> you can put values there if you want.
>>> Matt
>>> Mark
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
