[petsc-dev] Disabling a header in configure based on a bad link?
Aron Ahmadia
aron at ahmadia.net
Wed Sep 25 11:41:43 CDT 2013
Thanks Satish!
A
On Wed, Sep 25, 2013 at 12:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Attached is the patch for this..
> Satish
> On Wed, 25 Sep 2013, Satish Balay wrote:
> > perhaps the appropriate thing is to move the 'fenv.h' from the current
> > location to this new test into config/BuildSystem/config/headers.py
> > [i.e this code would add fenv.h header if the test is successful]
> > Satish
> > On Wed, 25 Sep 2013, Aron Ahmadia wrote:
> > > Hi folks,
> > > I'm working on a Cygwin64 port of PETSc and I have a question about
> doing a
> > > specific disable in BuildSystem based on a failing link.
> > > The Cygwin folks provide an fenv.h implementation that (as far as I can
> > > tell), is currently broken due to an undefined FE_DFL_ENV variable. My
> > > inclination is to disable this functionality in PETSc by declaring that
> > > fenv.h is unavailable if a simple link test fails. I tried to write a
> test
> > > like this (in Configure.py)
> > > def configureCygwin(self):
> > > '''Cygwin specific stuff'''
> > > # detect problem with missing FE_DFL_ENV symbol in Cygwin64
> > > if not self.checkLink('#include <fenv.h>', 'fesetenv(FE_DFL_ENV)'):
> > > self.headers.headers.remove('fenv.h')
> > > I don't think it worked. Has anybody had experience with *disabling*
> > > functionality in BuildSystem? Should we be less optimistic about
> having
> > > the header and only enable it if the test passes? Where would it go?
> > > Cheers,
> > > Aron
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130925/382078fc/attachment.html>
